[GRASS-SVN] r71337 - grass/trunk/lib/python/temporal/testsuite
svn_grass at osgeo.org
Mon Aug 7 08:26:27 PDT 2017
Author: huhabla
Date: 2017-08-07 08:26:27 -0700 (Mon, 07 Aug 2017)
New Revision: 71337
Added:
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_equal_ts.py
temporal framework: Tests regarding implicit temporal aggregation
Added: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_equal_ts.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_equal_ts.py (rev 0)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_equal_ts.py 2017-08-07 15:26:27 UTC (rev 71337)
@@ -0,0 +1,191 @@
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert and Thomas Leppelt
+import datetime
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+class TestTemporalRasterAlgebraImplicitAggregation(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ tgis.init(True) # Raise on error instead of exit(1)
+ cls.use_temp_region()
+ cls.runModule("g.region", n=80.0, s=0.0, e=120.0,
+ w=0.0, t=1.0, b=0.0, res=10.0)
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a1 = 1")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a2 = 2")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a3 = 3")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="singletmap = 100")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="singlemap = 1000")
+ tgis.open_new_stds(name="A", type="strds", temporaltype="absolute",
+ title="A", descr="A", semantic="field", overwrite=True)
+ tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a1,a2,a3,a4",
+ start="2001-01-01", interval=False)
+ tgis.register_maps_in_space_time_dataset(type="raster", name=None, maps="singletmap",
+ start="2001-01-01")
+ def tearDown(self):
+ self.runModule("t.remove", flags="rf", inputs="R", quiet=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.runModule("t.remove", flags="rf", inputs="A", quiet=True)
+ cls.runModule("t.unregister", maps="singletmap", quiet=True)
+ cls.del_temp_region()
+ def test_simple_operator(self):
+ """Test implicit aggregation
+ R = A + A
+ result with implicit aggregation to:
+ r1 = a1 + a1 + a2 + a3 + a4 # 11
+ r2 = a2 + a1 + a2 + a3 + a4 # 12
+ r3 = a3 + a1 + a2 + a3 + a4 # 13
+ r4 = a4 + a1 + a2 + a3 + a4 # 14
+ ta = tgis.TemporalRasterAlgebraParser(run=True, debug=True)
+ ta.parse(expression="R = A + A", basename="r", overwrite=True)
+ D = tgis.open_old_stds("R", type="strds")
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 4)
+ self.assertEqual(D.metadata.get_min_min(), 11)
+ self.assertEqual(D.metadata.get_max_max(), 14)
+ start, end = D.get_absolute_time()
+ self.assertEqual(start, datetime.datetime(2001, 1, 1))
+ self.assertEqual( D.check_temporal_topology(), False)
+ self.assertEqual(D.get_granularity(), None)
+ def test_complex_operator(self):
+ R = A {+,equal,l} A
+ ta.parse(expression="R = A {+, equal,l} A", basename="r", overwrite=True)
+ D.select()
+ def test_single_map_complex_operator(self):
+ R = singletmap {+,equal,l} A
+ r1 = singletmap + a1 + a2 + a3 + a4 # 110
+ r2 = singletmap + a1 + a2 + a3 + a4 # 110
+ r3 = singletmap + a1 + a2 + a3 + a4 # 110
+ r4 = singletmap + a1 + a2 + a3 + a4 # 110
+ ta.parse(expression="R = tmap(singletmap) {+, equal,l} A", basename="r", overwrite=True)
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 1)
+ self.assertEqual(D.metadata.get_min_min(), 110)
+ self.assertEqual(D.metadata.get_max_max(), 110)
+ self.assertEqual( D.check_temporal_topology(), True)
+ def test_single_map_simple_operator(self):
+ R = singletmap + A
+ ta.parse(expression="R = tmap(singletmap) + A", basename="r", overwrite=True)
+ D.select()
+ def test_single_map_complex_operator_right_ts(self):
+ TODO: Ist this the correct result? Implicit aggregation and full permutation?
+ R = singletmap {+,equal,r} A
+ ta.parse(expression="R = tmap(singletmap) {+, equal,r} A", basename="r", overwrite=True)
+ D.select()
+if __name__ == '__main__':
+ test()
