[GRASS-SVN] r71359 - grass-addons/grass7/raster/r.terrain.texture
Wed Aug 9 10:40:37 PDT 2017
Author: spawley
Date: 2017-08-09 10:40:37 -0700 (Wed, 09 Aug 2017)
New Revision: 71359
   grass-addons/grass7/raster/r.terrain.texture/r.terrain.texture.py
enhancement to r.terrain.texture using resampling filter to calculate pit and peak density
Modified: grass-addons/grass7/raster/r.terrain.texture/r.terrain.texture.py
--- grass-addons/grass7/raster/r.terrain.texture/r.terrain.texture.py	2017-08-09 17:15:22 UTC (rev 71358)
+++ grass-addons/grass7/raster/r.terrain.texture/r.terrain.texture.py	2017-08-09 17:40:37 UTC (rev 71359)
@@ -6,12 +6,12 @@
 # AUTHOR(S):    Steven Pawley
 # PURPOSE:      Calculates the density of pits and peaks in a DEM
-#                           Based on the methodology of Iwahashi & Pike (2007)
-#                           Automated classifications of topography from DEMs by an unsupervised
-#                           nested-means algorithm and a three-part geometric signature.
-#                           Geomorphology. 86, 409-440
+#               Based on the methodology of Iwahashi & Pike (2007)
+#               Automated classifications of topography from DEMs by an unsupervised
+#               nested-means algorithm and a three-part geometric signature.
+#               Geomorphology. 86, 409-440
-# COPYRIGHT:    (C) 2015 Steven Pawley, and by the GRASS Development Team
+# COPYRIGHT:    (C) 2017 Steven Pawley and by the GRASS Development Team
@@ -21,7 +21,7 @@
 #%option G_OPT_R_INPUT
 #% description: Input elevation raster:
-#% key: elevation
+#% key: input
 #% required : yes
 #%end
@@ -34,7 +34,7 @@
 #%end
 #%option
-#% key: window
+#% key: size
 #% type: double
 #% description: Size of counting window:
 #% answer: 21
@@ -43,59 +43,80 @@
 #%option G_OPT_R_OUTPUT
 #% description: Output Texture Image:
-#% key: pitdensity
+#% key: output
 #% required : yes
 #%end
 import sys
 import random
 import string
-import grass.script as grass
+from subprocess import PIPE
+import atexit
+import grass.script as gs
+from grass.pygrass.modules.shortcuts import general as g
+from grass.pygrass.modules.shortcuts import raster as r
+from grass.script.utils import parse_key_val
+TMP_RAST = []
+def cleanup():
+    gs.message("Deleting intermediate files...")
+    for f in TMP_RAST:
+        gs.run_command(
+            "g.remove", type="raster", name=f, flags="f", quiet=True)
 def main():
-    elevation = options['elevation']
-    thres = options['thres']
-    window = options['window']
-    pitdensity = options['pitdensity']
+    elevation = options['input']
+    thres = float(options['thres'])
+    window = int(options['size'])
+    pitdensity = options['output']
-    # Internal grid calculations - to be removed at end of process
-    median = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in range(8)])
-    pitpeaks = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in range(8)])
-    pitcount = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in range(8)])
-    pitdensity_tmp = 'tmp_' + ''.join([random.choice(string.ascii_letters + string.digits) for n in range(8)])
+    # current region settings
+    current_reg = parse_key_val(
+        g.region(flags='pg', stdout_=PIPE).outputs.stdout)
+    del current_reg['projection']
+    del current_reg['zone']
+    del current_reg['cells']
     # Smooth the DEM
-    grass.message("Smooth DEM with a 3x3 median filter:")
-    grass.run_command("r.neighbors", input = elevation, method = "median", size = 3, output = median)
+    gs.message("Smoothing input DEM with a 3x3 median filter...")
+    filtered_dem = 'tmp_filtred_dem' + ''.join(
+        [random.choice(string.ascii_letters + string.digits) for n in range(4)])
+    TMP_RAST.append(filtered_dem)
+    gs.run_command("r.neighbors", input = elevation, method = "median",
+                   size = 3, output = filtered_dem, flags='c', quiet=True)
     # Extract the pits and peaks based on the threshold
-    grass.message("Extract pits and peaks:")
-    grass.mapcalc('{x} = if ( abs({dem}-{median})>{thres}, 1, null())'.format(x=pitpeaks, dem=elevation, thres=thres, median=median))
+    pitpeaks = 'tmp_pitpeaks' + ''.join(
+    TMP_RAST.append(pitpeaks)
-    # Count the number of pits and peaks
-    grass.message("Count the number of pits and peaks in a moving window:")
-    grass.run_command("r.neighbors", input = pitpeaks, method = "count", size = window, output = pitcount, flags = 'c')
+    gs.message("Extracting pits and peaks with difference > thres...")
+    gs.mapcalc(
+        '{x} = if ( abs({dem}-{median})>{thres}, 1, 0)'.format(
+                x=pitpeaks, dem=elevation, thres=thres, median=filtered_dem),
+                quiet=True)
+    # calculate density of pits and peaks
+    gs.message("Using resampling filter to create terrain texture...")
+    window_radius = (window-1)/2
+    y_radius = float(current_reg['ewres'])*window_radius
+    x_radius = float(current_reg['nsres'])*window_radius
+    r.resamp_filter(input=pitpeaks, output=pitdensity, filter=['bartlett','gauss'],
+                    radius=[x_radius,y_radius])
+    # return to original region
+    g.region(**current_reg)
-    # Convert the pit and peak counts into a percentage
-    grass.message("Convert the pit and peak counts into a percentage:")
-    size = int(window)*int(window)
-    grass.mapcalc('{x} = 100*{pitcount}/float({size})'.format(x=pitdensity_tmp, pitcount=pitcount, size = size))
+    # set colors
+    r.colors(map=pitdensity, color='haxby', quiet=True)
-    # Mask the raster to remove the background
-    grass.message("Mask the terrain surface texture with the input DEM:")
-    grass.run_command("r.mask", raster = elevation, maskcats = "*", layer = "1")
-    grass.mapcalc('{x} = {pitdensity_tmp}'.format(x=pitdensity, pitdensity_tmp=pitdensity_tmp))
-    grass.run_command("r.mask", raster = elevation, maskcats = "*", layer = "1", flags = 'r')
-    # Clean-up
-    grass.message("Deleting intermediate files:")
-    grass.run_command("g.remove", type="raster", name=median, flags="f", quiet=True)
-    grass.run_command("g.remove", type="raster", name=pitpeaks, flags="f", quiet=True)
-    grass.run_command("g.remove", type="raster", name=pitcount, flags="f", quiet=True)
-    grass.run_command("g.remove", type="raster", name=pitdensity_tmp, flags="f", quiet=True)
     return 0
 if __name__ == "__main__":
-    options, flags = grass.parser()
+    options, flags = gs.parser()
+    atexit.register(cleanup)
     sys.exit(main())
