[GRASS-SVN] r71369 - in grass/trunk/lib/python/temporal: . testsuite
svn_grass at osgeo.org
Thu Aug 10 04:36:46 PDT 2017
Author: huhabla
Date: 2017-08-10 04:36:46 -0700 (Thu, 10 Aug 2017)
New Revision: 71369
Added:
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_spatial_topology.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/register.py
grass/trunk/lib/python/temporal/space_time_datasets.py
grass/trunk/lib/python/temporal/temporal_algebra.py
grass/trunk/lib/python/temporal/temporal_granularity.py
grass/trunk/lib/python/temporal/temporal_operator.py
grass/trunk/lib/python/temporal/temporal_raster_algebra.py
grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
grass/trunk/lib/python/temporal/temporal_vector_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py
grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py
temporal framework: Added spatial topological operators to the temporal algebra
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/core.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -456,7 +456,7 @@
for mapset in mapsets:
driver = c_library_interface.get_driver_name(mapset)
database = c_library_interface.get_database_name(mapset)
message_interface.debug(1, "get_available_temporal_mapsets: "\
"\n mapset %s\n driver %s\n database %s"%(mapset,
driver, database))
@@ -1063,14 +1063,14 @@
if dbstring is None:
global tgis_database_string
self.dbstring = tgis_database_string
self.dbstring = dbstring
self.msgr = get_tgis_message_interface()
self.msgr.debug(1, "DBConnection constructor:"\
"\n backend: %s"\
"\n dbstring: %s"%(backend, self.dbstring))
- #"\n traceback:%s"%(backend, self.dbstring,
+ #"\n traceback:%s"%(backend, self.dbstring,
#str(" \n".join(traceback.format_stack()))))
def __del__(self):
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/register.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -483,7 +483,7 @@
# In case of a empty map continue, do not register empty maps
if delete_empty:
- if type in ["raster", "raster_3d"]:
+ if type in ["raster", "raster_3d", "rast", "rast3d"]:
if map_layer.metadata.get_min() is None and \
map_layer.metadata.get_max() is None:
empty_maps.append(map_layer)
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -42,6 +42,7 @@
.. code-block:: python
>>> import grass.script as grass
+ >>> import grass.temporal as tgis
>>> init()
>>> grass.use_temp_region()
>>> grass.run_command("g.region", n=80.0, s=0.0, e=120.0, w=0.0,
@@ -53,7 +54,7 @@
>>> grass.run_command("r.timestamp", map="strds_map_test_case",
... date="15 jan 1999", quiet=True)
0
- >>> mapset = get_current_mapset()
+ >>> mapset = tgis.get_current_mapset()
>>> name = "strds_map_test_case"
>>> identifier = "%s@%s" % (name, mapset)
>>> rmap = RasterDataset(identifier)
@@ -1022,24 +1023,23 @@
>>> tgis.init()
- >>> strds = tgis.SpaceTimeRasterDataset("old at PERMANENT")
+ >>> strds = tgis.SpaceTimeRasterDataset("old@%s"%mapset)
>>> strds.is_in_db()
False
>>> strds.is_stds()
True
>>> strds.get_type()
'strds'
- >>> newstrds = strds.get_new_instance("newstrds at PERMANENT")
+ >>> newstrds = strds.get_new_instance("newstrds@%s"%mapset)
>>> isinstance(newstrds, SpaceTimeRasterDataset)
True
- >>> newmap = strds.get_new_map_instance("newmap at PERMANENT")
+ >>> newmap = strds.get_new_map_instance("newmap@%s"%mapset)
>>> isinstance(newmap, RasterDataset)
True
- >>> strds.reset("new at PERMANENT")
+ >>> strds.reset("new@%s"%mapset)
>>> strds.is_in_db()
False
- >>> strds.get_id()
- 'new at PERMANENT'
>>> strds.reset(None)
>>> strds.is_in_db()
False
@@ -1131,24 +1131,23 @@
>>> tgis.init()
- >>> str3ds = tgis.SpaceTimeRaster3DDataset("old at PERMANENT")
+ >>> str3ds = tgis.SpaceTimeRaster3DDataset("old@%s"%mapset)
>>> str3ds.is_in_db()
False
>>> str3ds.is_stds()
True
>>> str3ds.get_type()
'str3ds'
- >>> newstrds = str3ds.get_new_instance("newstrds at PERMANENT")
+ >>> newstrds = str3ds.get_new_instance("newstrds@%s"%mapset)
>>> isinstance(newstrds, SpaceTimeRaster3DDataset)
True
- >>> newmap = str3ds.get_new_map_instance("newmap at PERMANENT")
+ >>> newmap = str3ds.get_new_map_instance("newmap@%s"%mapset)
>>> isinstance(newmap, Raster3DDataset)
True
- >>> str3ds.reset("new at PERMANENT")
+ >>> str3ds.reset("new@%s"%mapset)
>>> str3ds.is_in_db()
False
- >>> str3ds.get_id()
>>> str3ds.reset(None)
>>> str3ds.is_in_db()
False
@@ -1259,24 +1258,23 @@
>>> tgis.init()
- >>> stvds = tgis.SpaceTimeVectorDataset("old at PERMANENT")
+ >>> stvds = tgis.SpaceTimeVectorDataset("old@%s"%mapset)
>>> stvds.is_in_db()
False
>>> stvds.is_stds()
True
>>> stvds.get_type()
'stvds'
- >>> newstvds = stvds.get_new_instance("newstvds at PERMANENT")
+ >>> newstvds = stvds.get_new_instance("newstvds@%s"%mapset)
>>> isinstance(newstvds, SpaceTimeVectorDataset)
True
- >>> newmap = stvds.get_new_map_instance("newmap at PERMANENT")
+ >>> newmap = stvds.get_new_map_instance("newmap@%s"%mapset)
>>> isinstance(newmap, VectorDataset)
True
- >>> stvds.reset("new at PERMANENT")
+ >>> stvds.reset("new@%s"%mapset)
>>> stvds.is_in_db()
False
- >>> stvds.get_id()
>>> stvds.reset(None)
>>> stvds.is_in_db()
False
Modified: grass/trunk/lib/python/temporal/temporal_algebra.py
--- grass/trunk/lib/python/temporal/temporal_algebra.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/temporal_algebra.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -778,6 +778,11 @@
self.nprocs = nprocs
self.use_granularity = False
+ # Topology lists
+ self.temporal_topology_list = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS", "OVERLAPPED", \
+ "DURING", "STARTS", "FINISHES", "CONTAINS", "STARTED", "FINISHED"]
+ self.spatial_topology_list = ["EQUIVALENT", "COVER", "OVERLAP", "IN", "CONTAIN", "MEET"]
def __del__(self):
if self.dbif.connected:
self.dbif.close()
@@ -1039,6 +1044,7 @@
:return: Map list with specified temporal extent.
resultdict = {}
+ temporal_topo_list, spatial_topo_list = self._check_topology(topolist=topolist)
for map_i in maplist:
# Loop over temporal related maps and create overlay modules.
@@ -1050,30 +1056,32 @@
for topo in topolist:
if topo in tbrelations.keys():
for map_j in (tbrelations[topo]):
- if temporal == 'r':
- # Generate an intermediate map for the result map list.
- map_new = self.generate_new_map(base_map=map_i, bool_op='and',
- copy=True, rename=True)
- # Create overlaid map extent.
- returncode = self.overlay_map_extent(map_new, map_j, 'and',
- temp_op=temporal)
- # Stop the loop if no temporal or spatial relationship exist.
- if returncode == 0:
- break
- # Append map to result map list.
- elif returncode == 1:
- # print(map_new.get_id() + " " + str(map_new.get_temporal_extent_as_tuple()))
- # print(map_new.condition_value)
- # print(map_new.cmd_list)
- # resultlist.append(map_new)
- resultdict[map_new.get_id()] = map_new
+ if self._check_spatial_topology_relation(spatial_topo_list, map_i, map_j) is True:
+ if temporal == 'r':
+ # Generate an intermediate map for the result map list.
+ map_new = self.generate_new_map(base_map=map_i, bool_op='and',
+ copy=True, rename=True)
+ # Create overlaid map extent.
+ returncode = self.overlay_map_extent(map_new, map_j, 'and',
+ temp_op=temporal)
+ print(map_new.get_id(), map_j.get_id())
+ # Stop the loop if no temporal or spatial relationship exist.
+ if returncode == 0:
+ break
+ # Append map to result map list.
+ elif returncode == 1:
+ # print(map_new.get_id() + " " + str(map_new.get_temporal_extent_as_tuple()))
+ # print(map_new.condition_value)
+ # print(map_new.cmd_list)
+ # resultlist.append(map_new)
+ resultdict[map_new.get_id()] = map_new
- # Create r.mapcalc expression string for the operation.
- #cmdstring = self.build_command_string(s_expr_a = map_new,
- # s_expr_b = map_j,
- # operator = function)
- # Conditional append of module command.
- #map_new.cmd_list = cmdstring
+ # Create r.mapcalc expression string for the operation.
+ #cmdstring = self.build_command_string(s_expr_a = map_new,
+ # s_expr_b = map_j,
+ # operator = function)
+ # Conditional append of module command.
+ #map_new.cmd_list = cmdstring
if returncode == 0:
break
@@ -1221,33 +1229,110 @@
return(maplist)
- def get_temporal_topo_list(self,
- maplistA,
- maplistB=None,
- topolist=["EQUAL"],
- assign_val=False,
- count_map=False,
- compare_bool=False,
- compop=None,
- aggregate=None):
- """Build temporal topology for two space time data sets, copy map objects
+ def _check_spatial_topology_entries(self, spatial_topo_list, spatial_relations):
+ """Check the spatial topology entries in the spatial relation list
+ Return True if no spatial relation list is provided or if one spatial relation
+ was found
+ :param spatial_topo_list: The spatial relations that were defined in the expression
+ :param spatial_relations: The spatial relations of a single map object
+ :return: True if a spatial topological relation was found, False if not
+ # Check spatial topology
+ spatial_topo_check = False
+ if len(spatial_topo_list) == 0:
+ spatial_topo_check = True
+ else:
+ for spatial_topology in spatial_topo_list:
+ if spatial_topology in spatial_relations.keys():
+ if self.debug is True:
+ print("Spatial topology list", spatial_topo_list, spatial_topo_check)
+ return spatial_topo_check
+ def _check_spatial_topology_relation(self, spatial_topo_list, map_a, map_b):
+ """Check if map_b has one of the spatial topological relations to map_a that is defined
+ in spatial_topo_list
+ :param map_a:
+ :param map_b:
+ :return:
+ else:
+ map_a_sr = map_a.get_spatial_relations()
+ if spatial_topology in map_a_sr.keys():
+ if map_b in map_a_sr[spatial_topology]:
+ def _check_topology(self, topolist):
+ """Check the topology definitions of the expression
+ :param topolist: List of strings of temporal and spatial relations.
+ :return: A tuple of spatial and temporal topology lists (temporal_topo_list, spatial_topo_list)
+ :raises: This method will raise a syntax error in case the topology name is unknown
+ temporal_topo_list = []
+ spatial_topo_list= []
+ # Check if given temporal relation are valid.
+ for topo in topolist:
+ if topo.upper() not in self.temporal_topology_list and topo.upper() not in self.spatial_topology_list:
+ raise SyntaxError("Unpermitted topological relation name '" + topo + "'")
+ if topo.upper() in self.spatial_topology_list:
+ spatial_topo_list.append(topo.upper())
+ if topo.upper() in self.temporal_topology_list:
+ temporal_topo_list.append(topo.upper())
+ return temporal_topo_list, spatial_topo_list
+ def build_spatio_temporal_topology_list(self,
+ maplistA,
+ maplistB=None,
+ topolist=["EQUAL"],
+ assign_val=False,
+ count_map=False,
+ compare_bool=False,
+ compop=None,
+ aggregate=None):
+ """Build spatio-temporal topology for two space time data sets, copy map objects
for given relation into map list.
:param maplistA: List of maps.
:param maplistB: List of maps.
- :param topolist: List of strings of temporal relations.
+ :param topolist: List of strings of spatio-temporal relations.
:param assign_val: Boolean for assigning a boolean map value based on
- the map_values from the compared map list by
- topological relationships.
+ the map_values from the compared map list by
+ topological relationships.
:param count_map: Boolean if the number of topological related maps
- should be returned.
+ should be returned.
:param compare_bool: Boolean for comparing boolean map values based on
- related map list and compariosn operator.
+ related map list and comparison operator.
:param compop: Comparison operator, && or ||.
:param aggregate: Aggregation operator for relation map list, & or |.
:return: List of maps from maplistA that fulfil the topological relationships
- to maplistB specified in topolist.
+ to maplistB specified in topolist.
@@ -1269,7 +1354,7 @@
... check = mapB.set_relative_time(i, i + 1, "months")
... mapsA.append(mapA)
... mapsB.append(mapB)
- >>> resultlist = l.get_temporal_topo_list(mapsA, mapsB, ['EQUAL'])
+ >>> resultlist = l.build_spatio_temporal_topology_list(mapsA, mapsB, ['EQUAL'])
>>> for map in resultlist:
... if map.get_equal():
... relations = map.get_equal()
@@ -1285,7 +1370,7 @@
Map a7 has equal relation to map b7
Map a8 has equal relation to map b8
Map a9 has equal relation to map b9
- >>> resultlist = l.get_temporal_topo_list(mapsA, mapsB, ['DURING'])
+ >>> resultlist = l.build_spatio_temporal_topology_list(mapsA, mapsB, ['DURING'])
>>> print(resultlist)
>>> # Create two list of maps with equal time stamps
@@ -1302,7 +1387,7 @@
... check = mapB.set_relative_time(i, i + 2, "months")
- >>> resultlist = l.get_temporal_topo_list(mapsA, mapsB, ['starts','during'])
+ >>> resultlist = l.build_spatio_temporal_topology_list(mapsA, mapsB, ['starts','during'])
... if map.get_starts():
... relations = map.get_starts()
@@ -1366,7 +1451,7 @@
... datetime(2000,1,i + 7))
- >>> resultlist = l.get_temporal_topo_list(mapsA, mapsB)
+ >>> resultlist = l.build_spatio_temporal_topology_list(mapsA, mapsB)
... print(map.get_id())
a5 at B
@@ -1374,88 +1459,85 @@
a7 at B
a8 at B
a9 at B
- >>> resultlist = l.get_temporal_topo_list(mapsA, mapsB, ['during'])
+ >>> resultlist = l.build_spatio_temporal_topology_list(mapsA, mapsB, ['during'])
- topologylist = ["EQUAL", "FOLLOWS", "PRECEDES", "OVERLAPS", "OVERLAPPED", \
- "DURING", "STARTS", "FINISHES", "CONTAINS", "STARTED", \
- "FINISHED"]
- complementdict = {"EQUAL": "EQUAL", "FOLLOWS" : "PRECEDES",
- "PRECEDES" : "FOLLOWS", "OVERLAPS" : "OVERLAPPED",
- "OVERLAPPED" : "OVERLAPS", "DURING" : "CONTAINS",
- "CONTAINS" : "DURING", "STARTS" : "STARTED",
- "STARTED" : "STARTS", "FINISHES" : "FINISHED",
- "FINISHED" : "FINISHES"}
+ # Check the topology definitions and return the list of temporal and spatial
+ # topological relations that must be fulfilled
resultdict = {}
- # Check if given temporal relation are valid.
- for topo in topolist:
- if topo.upper() not in topologylist:
- raise SyntaxError("Unpermitted temporal relation name '" + topo + "'")
- # Create temporal topology for maplistA to maplistB.
+ # Create spatio-temporal topology for maplistA to maplistB.
tb = SpatioTemporalTopologyBuilder()
- # Dictionary with different spatial variables used for topology builder.
- spatialdict = {'strds' : '2D', 'stvds' : '2D', 'str3ds' : '3D'}
- # Build spatial temporal topology
- if self.spatial:
- tb.build(maplistA, maplistB, spatial = spatialdict[self.stdstype])
+ if len(spatial_topo_list) > 0:
+ # Dictionary with different spatial variables used for topology builder.
+ spatialdict = {'strds' : '2D', 'stvds' : '2D', 'str3ds' : '3D'}
+ tb.build(maplistA, maplistB, spatial=spatialdict[self.stdstype])
else:
tb.build(maplistA, maplistB)
# Iterate through maps in maplistA and search for relationships given
# in topolist.
for map_i in maplistA:
- tbrelations = map_i.get_temporal_relations()
if assign_val:
- self.assign_bool_value(map_i, tbrelations, topolist)
+ self.assign_bool_value(map_i, temporal_topo_list, spatial_topo_list)
elif compare_bool:
- self.compare_bool_value(map_i, tbrelations, compop, aggregate, topolist)
- if topo.upper() in tbrelations.keys():
- if count_map:
- relationmaplist = tbrelations[topo.upper()]
- gvar = GlobalTemporalVar()
- gvar.td = len(relationmaplist)
- if "map_value" in dir(map_i):
- map_i.map_value.append(gvar)
- else:
- map_i.map_value = gvar
- # Use unique identifier, since map names may be equal
- resultdict[map_i.uid] = map_i
+ self.compare_bool_value(map_i, compop, aggregate, temporal_topo_list, spatial_topo_list)
+ temporal_relations = map_i.get_temporal_relations()
+ spatial_relations = map_i.get_spatial_relations()
+ for temporal_topology in temporal_topo_list:
+ if temporal_topology.upper() in temporal_relations.keys():
+ if self._check_spatial_topology_entries(spatial_topo_list, spatial_relations) is True:
+ if count_map:
+ relationmaplist = temporal_relations[temporal_topology.upper()]
+ gvar = GlobalTemporalVar()
+ gvar.td = len(relationmaplist)
+ if "map_value" in dir(map_i):
+ map_i.map_value.append(gvar)
+ else:
+ map_i.map_value = gvar
+ # Use unique identifier, since map names may be equal
+ resultdict[map_i.uid] = map_i
resultlist = resultdict.values()
# Sort list of maps chronological.
- resultlist = sorted(resultlist, key = AbstractDatasetComparisonKeyStartTime)
+ resultlist = sorted(resultlist, key=AbstractDatasetComparisonKeyStartTime)
return(resultlist)
def assign_bool_value(self,
map_i,
- tbrelations,
- topolist=["EQUAL"]):
+ temporal_topo_list=["EQUAL"],
+ spatial_topo_list=[]):
""" Function to assign boolean map value based on the map_values from the
compared map list by topological relationships.
:param map_i: Map object with temporal extent.
- :param tbrelations: List of temporal relation to map_i.
- :param topolist: List of strings for given temporal relations.
+ :param temporal_topo_list: List of strings for given temporal relations.
+ :param spatial_topo_list: List of strings for given spatial relations.
:return: Map object with conditional value that has been assigned by
relation maps that fulfil the topological relationships to
- maplistB specified in topolist.
+ maplistB specified in temporal_topo_list.
condition_value_list = []
- #relationmaplist = tbrelations[complementdict[topo.upper()]]
+ for topo in temporal_topo_list:
+ if topo.upper() in temporal_relations.keys():
+ relationmaplist = temporal_relations[topo.upper()]
for relationmap in relationmaplist:
- for boolean in relationmap.condition_value:
- if isinstance(boolean, bool):
- condition_value_list.append(boolean)
- if self.debug:
- print(str(relationmap.get_temporal_extent_as_tuple()) + str(boolean))
+ if self._check_spatial_topology_relation(spatial_topo_list, map_i, relationmap) is True:
+ for boolean in relationmap.condition_value:
+ if isinstance(boolean, bool):
+ condition_value_list.append(boolean)
+ if self.debug:
+ print("assign_bool_value", str(relationmap.get_temporal_extent_as_tuple())
+ + str(boolean))
if all(condition_value_list):
resultbool = True
else:
@@ -1466,39 +1548,46 @@
def compare_bool_value(self,
map_i,
- tbrelations,
compop,
aggregate,
""" Function to evaluate two map lists with boolean values by boolean
:return: Map object with conditional value that has been evaluated by
comparison operators.
# Build conditional list with elements from related maps and given relation operator.
leftbool = map_i.condition_value[0]
condition_value_list = [leftbool]
count = 0
- if count == 0:
- condition_value_list.append(compop[0])
- condition_value_list.append('(')
- if count > 0:
- condition_value_list.append(aggregate)
- count = count + 1
+ if count == 0:
+ condition_value_list.append(compop[0])
+ condition_value_list.append('(')
+ if count > 0:
+ condition_value_list.append(aggregate)
+ count = count + 1
+ if self.debug:
+ print("compare_bool_value", map_i.get_id(), relationmap.get_id())
if count > 0:
condition_value_list.append(')')
# Convert conditional list to concatenated string and evaluate booleans.
@@ -1605,13 +1694,13 @@
if not inverse:
- topolist = self.get_temporal_topo_list(maplistA, maplistB, topolist,
- assign_val = assign_val)
+ topolist = self.build_spatio_temporal_topology_list(maplistA, maplistB, topolist,
+ assign_val = assign_val)
resultlist = topolist
else:
resultlist = []
if map_i not in topolist:
@@ -1927,7 +2016,7 @@
""" This function evaluates temporal variable expressions of a conditional
expression in two steps.
At first it combines stepwise the single conditions by their relations with LALR.
- In this prossess sub condition map lists will be created which will include
+ In this process sub condition map lists will be created which will include
information of the underlying single conditions. Important: The temporal
relations between conditions are evaluated by implicit aggregation.
In the second step the aggregated condition map list will be compared with the
@@ -1974,7 +2063,7 @@
operator = tvarexpr[iter +1]
relexpr = tvarexpr[iter +2]
if all([issubclass(type(ele), list) for ele in [expr, relexpr]]):
- resultlist = self.get_temporal_topo_list(expr, relexpr)
+ resultlist = self.build_spatio_temporal_topology_list(expr, relexpr)
# Loop through the list, search for map lists or global variables.
for expr in tvarexpr:
if isinstance(expr, list):
@@ -2381,9 +2470,9 @@
if self.run:
maplistA = self.check_stds(t[1])
maplistB = self.check_stds(t[3])
- resultlist = self.get_temporal_topo_list(maplistA,
- maplistB,
- count_map=True)
+ resultlist = self.build_spatio_temporal_topology_list(maplistA,
+ maplistB,
+ count_map=True)
t[0] = resultlist
def p_t_hash2(self,t):
@@ -2398,10 +2487,10 @@
topolist = self.eval_toperator(t[2], optype='hash')[0]
- maplistB,
- topolist,
- count_map=True)
+ maplistB,
+ topolist,
+ count_map=True)
t[0] = resultlist
def p_t_hash_paren(self, t):
@@ -2588,9 +2677,9 @@
function = t[2] + t[3]
aggregate = t[2]
# Build conditional values based on topological relationships.
- complist = self.get_temporal_topo_list(tvarexprA, tvarexprB, topolist=relations,
- compare_bool=True, compop=function[0],
- aggregate=aggregate)
+ complist = self.build_spatio_temporal_topology_list(tvarexprA, tvarexprB, topolist=relations,
+ compare_bool=True, compop=function[0],
+ aggregate=aggregate)
# Set temporal extent based on topological relationships.
resultlist = self.set_temporal_extent_list(complist, topolist = relations,
temporal=temporal)
@@ -2610,8 +2699,8 @@
# Evaluate temporal comparison operator.
relations, temporal, function, aggregate = self.eval_toperator(t[2], optype='boolean')
- compare_bool=True, compop=function[0], aggregate=aggregate)
+ compare_bool=True, compop=function[0], aggregate=aggregate)
resultlist = self.set_temporal_extent_list(complist, topolist=relations,
temporal=temporal)
Modified: grass/trunk/lib/python/temporal/temporal_granularity.py
--- grass/trunk/lib/python/temporal/temporal_granularity.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/temporal_granularity.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -1021,25 +1021,25 @@
def gran_singular_unit(gran):
"""Return the absolute granularity unit in its singular term
:param gran: input granularity
:return: granularity unit
>>> tgis.init()
>>> tgis.gran_singular_unit('1 month')
- month
+ 'month'
>>> tgis.gran_singular_unit('2 months')
- month
+ 'month'
>>> tgis.gran_singular_unit('6 seconds')
- second
+ 'second'
>>> tgis.gran_singular_unit('1 year')
- year
+ 'year'
if check_granularity_string(gran, 'absolute'):
output, unit = gran.split(" ")
@@ -1057,31 +1057,31 @@
else:
print(_("Invalid absolute granularity"))
return False
def gran_plural_unit(gran):
>>> tgis.init()
- months
+ 'month'
- months
+ 'month'
- seconds
+ 'second'
- years
+ 'year'
@@ -1106,7 +1106,7 @@
granularity based on the Gregorian calendar hierarchy that 1 year
equals 12 months or 365.2425 days or 24 * 365.2425 hours or 86400 *
365.2425 seconds.
:param from_gran: input granularity, this should be bigger than to_gran
:param to_gran: output granularity
:return: The output granularity
@@ -1117,25 +1117,25 @@
>>> tgis.init()
>>> tgis.gran_to_gran('1 month', '1 day')
'30.436875 days'
>>> tgis.gran_to_gran('1 month', '1 day', True)
30.436875
>>> tgis.gran_to_gran('10 year', '1 hour')
'87658.2 hours'
>>> tgis.gran_to_gran('10 year', '1 minute')
'5259492.0 minutes'
>>> tgis.gran_to_gran('6 months', '1 day')
'182.62125 days'
>>> tgis.gran_to_gran('1 months', '1 second')
'2629746.0 seconds'
>>> tgis.gran_to_gran('1 month', '1 second', True)
2629746.0
>>> tgis.gran_to_gran('30 month', '1 month', True)
30
@@ -1171,8 +1171,8 @@
else:
return False
# http://akiscode.com/articles/gcd_of_a_list.shtml
# Copyright (c) 2010 Stephen Akiki
Modified: grass/trunk/lib/python/temporal/temporal_operator.py
--- grass/trunk/lib/python/temporal/temporal_operator.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/temporal_operator.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -12,6 +12,12 @@
>>> p = TemporalOperatorParser()
+ >>> expression = "{equal|equivalent|cover|in|meet|contain|overlap}"
+ >>> p.parse(expression, optype = 'relation')
+ >>> print((p.relations, p.temporal, p.function))
+ (['equal', 'equivalent', 'cover', 'in', 'meet', 'contain', 'overlap'], None, None)
+ >>> p = TemporalOperatorParser()
>>> expression = "{equal| during}"
@@ -146,6 +152,7 @@
# Functions that defines topological relations.
relations = {
+ # temporal relations
'equal' : "EQUAL",
'follows' : "FOLLOWS",
'precedes' : "PRECEDES",
@@ -157,7 +164,14 @@
'contains' : "CONTAINS",
'started' : "STARTED",
'finished' : "FINISHED",
- 'over' : "OVER"
+ 'over' : "OVER",
+ # spatial relations
+ 'equivalent' : "EQUIVALENT",
+ 'cover' : "COVER",
+ 'overlap' : "OVERLAP",
+ 'in' : "IN",
+ 'contain' : "CONTAIN",
+ 'meet' : "MEET"
# This is the list of token names.
@@ -451,7 +465,7 @@
else:
if len(t) == 4:
# Set three operator components.
- self.relations = ['equal']
+ self.relations = ['equal', 'equivalent']
self.temporal = "l"
self.function = t[2]
elif len(t) == 6:
@@ -579,7 +593,7 @@
t[0] = t[2]
def p_relation(self, t):
- # The list of relations.
+ # The list of relations. Temporal and spatial relations are supported
relation : EQUAL
| FOLLOWS
@@ -592,6 +606,12 @@
| CONTAINS
| STARTED
| FINISHED
+ | EQUIVALENT
+ | COVER
+ | OVERLAP
+ | IN
+ | CONTAIN
+ | MEET
t[0] = t[1]
@@ -657,6 +677,7 @@
| NOT
t[0] = t[1]
if __name__ == "__main__":
Modified: grass/trunk/lib/python/temporal/temporal_raster_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_algebra.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/temporal_raster_algebra.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -78,7 +78,10 @@
spatial=spatial, register_null=register_null,
dry_run=dry_run, nprocs=nprocs)
- self.m_mapcalc = pymod.Module('r.mapcalc')
+ if spatial is True:
+ self.m_mapcalc = pymod.Module('r.mapcalc', region="union", run_=False)
+ else:
+ self.m_mapcalc = pymod.Module('r.mapcalc')
self.m_mremove = pymod.Module('g.remove')
def parse(self, expression, basename = None, overwrite=False):
Modified: grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py
--- grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/temporal_raster_base_algebra.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -175,10 +175,10 @@
return "null()"
######################### Temporal functions ##############################
- def get_temporal_topo_list(self, maplistA, maplistB=None, topolist=["EQUAL"],
- assign_val=False, count_map=False, compare_bool=False,
- compare_cmd=False, compop=None, aggregate=None,
- new=False, convert=False, operator_cmd=False):
+ def build_spatio_temporal_topology_list(self, maplistA, maplistB=None, topolist=["EQUAL"],
+ assign_val=False, count_map=False, compare_bool=False,
+ compare_cmd=False, compop=None, aggregate=None,
+ new=False, convert=False, operator_cmd=False):
@@ -204,65 +204,94 @@
+ >>> # Create two list of maps with equal time stamps
+ >>> from datetime import datetime
+ >>> tgis.init(True)
+ >>> l = tgis.TemporalAlgebraParser()
+ >>> mapsA = []
+ >>> mapsB = []
+ >>> for i in range(10):
+ ... idA = "a%i at B"%(i)
+ ... mapA = tgis.RasterDataset(idA)
+ ... mapA.uid = idA
+ ... mapA.map_value = True
+ ... idB = "b%i at B"%(i)
+ ... mapB = tgis.RasterDataset(idB)
+ ... mapB.uid = idB
+ ... mapB.map_value = False
+ ... check = mapA.set_absolute_time(datetime(2000,1,i+1),
+ ... datetime(2000,1,i + 2))
+ ... check = mapB.set_absolute_time(datetime(2000,1,i+6),
+ ... datetime(2000,1,i + 7))
+ ... mapsA.append(mapA)
+ ... mapsB.append(mapB)
+ >>> for map in resultlist:
+ ... print(map.get_id())
+ a5 at B
+ a6 at B
+ a7 at B
+ a8 at B
+ a9 at B
- "FINISHED"]
+ print(topolist, assign_val, count_map, compare_bool, compare_cmd,
+ compop, aggregate, new, convert, operator_cmd)
resultdict = {}
- if self.spatial:
+ # Build spatio-temporal topology
else:
# in topolist.
- # Check for boolean parameters for further calculations.
if assign_val:
elif compare_bool:
elif compare_cmd:
- self.compare_cmd_value(map_i, tbrelations, compop, aggregate, topolist, convert)
+ self.compare_cmd_value(map_i, compop, aggregate, temporal_topo_list, spatial_topo_list, convert)
elif operator_cmd:
- self.operator_cmd_value(map_i, tbrelations, compop, topolist)
+ self.operator_cmd_value(map_i, compop, temporal_topo_list, spatial_topo_list)
- if count_map:
- else:
+ if count_map:
+ else:
+ # map_i.print_info()
return(resultlist)
- def build_command_string(self, map_i, relmap, operator = None, cmd_type = None):
+ def build_command_string(self, map_i, relmap, operator = None, cmd_type = None):
"""This function build the r.mapcalc command string for conditionals,
spatial variable combinations and boolean comparisons.
@@ -312,26 +341,33 @@
cmdstring = "(%s %s %s)" %(leftsub, operator, rightsub)
return(cmdstring)
- def compare_cmd_value(self, map_i, tbrelations, compop, aggregate,
- topolist = ["EQUAL"], convert = False):
+ def compare_cmd_value(self, map_i, compop, aggregate,
+ temporal_topo_list = ["EQUAL"],
+ spatial_topo_list = [], convert = False):
+ R = A && B
+ R = if(A < 1 && B > 1, A, B)
+ R = if(A < 1 {&&,equal|equivalent} B > 1, A, B)
Extended temporal algebra version with command
list builder for temporal raster algebra.
+ :param temporal_relations: List of temporal relation to map_i.
:param convert: Boolean if conditional values should be converted to
- r.mapcalc command strings.
+ r.mapcalc command strings.
- # Build comandlist list with elements from related maps and given relation operator.
+ # Build command list list with elements from related maps and given relation operator.
if convert and "condition_value" in dir(map_i):
if map_i.condition_value != []:
cmdstring = str(int(map_i.condition_value[0]))
@@ -341,57 +377,76 @@
cmd_value_list = [leftcmd]
count = 0
if count == 0 and "cmd_list" in dir(map_i):
cmd_value_list.append(compop)
cmd_value_list.append('(')
- if convert and "condition_value" in dir(relationmap):
- if relationmap.condition_value != []:
- cmdstring = str(int(relationmap.condition_value[0]))
- relationmap.cmd_list = cmdstring
- if "cmd_list" in dir(relationmap):
- if count > 0:
- cmd_value_list.append(aggregate + aggregate)
- cmd_value_list.append(relationmap.cmd_list)
- count = count + 1
+ if convert and "condition_value" in dir(relationmap):
+ if relationmap.condition_value != []:
+ cmdstring = str(int(relationmap.condition_value[0]))
+ relationmap.cmd_list = cmdstring
+ if "cmd_list" in dir(relationmap):
+ if count > 0:
+ cmd_value_list.append(aggregate + aggregate)
+ cmd_value_list.append(relationmap.cmd_list)
+ count = count + 1
+ if self.debug:
+ print("compare_cmd_value", map_i.get_id(),
+ relationmap.get_id(), relationmap.cmd_list)
if count > 0:
cmd_value_list.append(')')
cmd_value_str = ''.join(map(str, cmd_value_list))
# Add command list to result map.
map_i.cmd_list = cmd_value_str
+ print(cmd_value_str)
return(cmd_value_str)
- def operator_cmd_value(self, map_i, tbrelations, operator, topolist = ["EQUAL"]):
+ def operator_cmd_value(self, map_i, operator,
+ spatial_topo_list = []):
""" Function to evaluate two map lists by given arithmetic operator.
:param operator: Arithmetic operator, +-*/%.
- :return: Map object with command list with operators that has been
- evaluated by implicit aggregration.
+ :return: Map object with command list with operators that has been
+ evaluated by implicit aggregation.
leftcmd = map_i
cmdstring = ""
- cmdstring = self.build_command_string(leftcmd,
- relationmap,
- operator=operator,
- cmd_type="operator")
- leftcmd = cmdstring
+ cmdstring = self.build_command_string(leftcmd,
+ relationmap,
+ operator=operator,
+ cmd_type="operator")
+ leftcmd = cmdstring
+ if self.debug:
+ print("operator_cmd_value", map_i.get_id(), operator, relationmap.get_id())
map_i.cmd_list = cmdstring
+ print("map command string", cmdstring)
return(cmdstring)
def set_temporal_extent_list(self, maplist, topolist=["EQUAL"], temporal='l' ,
@@ -400,11 +455,11 @@
other map list and given temporal operator.
:param maplist: List of map objects for which relations has been build
- correctely.
+ correctly.
:param temporal: The temporal operator specifying the temporal
- extent operation (intersection, union, disjoint
- union, right reference, left reference).
+ extent operation (intersection, union, disjoint
+ union, right reference, left reference).
:param cmd_bool: Boolean if command string should be merged for related maps.
:param cmd_type: map object with defined temporal relation to map_i:
condition, conclusion or operator.
@@ -413,6 +468,7 @@
:return: Map list with specified temporal extent and optional command string.
resultdict = {}
@@ -427,34 +483,35 @@
- bool_op='and',
- copy=True,
- rename=True)
- 'and',
- temp_op = temporal)
+ bool_op='and',
+ copy=True,
+ rename=True)
+ 'and',
+ temp_op=temporal)
- break
- if cmd_bool:
- cmdstring = self.build_command_string(map_i,
- map_j,
- cmd_type=cmd_type)
- map_new.cmd_list = cmdstring
- # Write map object to result dictionary.
- resultdict[map_new.uid] = map_new
+ break
+ if cmd_bool:
+ cmdstring = self.build_command_string(map_i,
+ map_j,
+ cmd_type=cmd_type)
+ map_new.cmd_list = cmdstring
+ # Write map object to result dictionary.
+ resultdict[map_new.uid] = map_new
if returncode == 0:
break
@@ -477,12 +534,12 @@
:param thenlist: Map list with temporal extents and command list or numeric string.
:param elselist: Map list with temporal extents and command list or numeric string.
:param condition_topolist: List of strings for given temporal relations between
- conditions and conclusions.
+ conditions and conclusions.
:param conclusion_topolist: List of strings for given temporal relations between
- conditions (then and else).
+ conditions (then and else).
:param null: Boolean if null map support should be activated.
:return: map list with resulting command string for given condition type.
@@ -492,8 +549,8 @@
# Check if alternative conclusion map list is given.
if all([isinstance(thenlist, list), isinstance(elselist, list)]):
# Build conclusion command map list.
- conclusiontopolist = self.get_temporal_topo_list(thenlist, elselist,
- conclusion_topolist)
+ conclusiontopolist = self.build_spatio_temporal_topology_list(thenlist, elselist,
+ conclusion_topolist)
conclusionlist = self.set_temporal_extent_list(conclusiontopolist,
topolist=conclusion_topolist,
temporal=temporal ,
@@ -549,9 +606,10 @@
return(resultlist)
elif isinstance(conclusionlist, list):
# Build result command map list between conditions and conclusions.
- conditiontopolist = self.get_temporal_topo_list(iflist,
- conclusionlist,
- topolist=condition_topolist)
+ print("build_condition_cmd_list", condition_topolist)
+ conditiontopolist = self.build_spatio_temporal_topology_list(iflist,
+ conclusionlist,
+ topolist=condition_topolist)
resultlist = self.set_temporal_extent_list(conditiontopolist,
topolist=condition_topolist,
temporal='r',
@@ -603,7 +661,8 @@
m_expression = newident + "=" + map_i.cmd_list
m.inputs["expression"].value = str(m_expression)
m.flags["overwrite"].value = self.overwrite
- #print(m.get_bash())
+ if self.debug:
+ print(m.get_bash())
self.process_chain_dict["processes"].append(m.get_dict())
if self.dry_run is False:
@@ -620,7 +679,8 @@
m_expression = newident + "=" + map_i.get_map_id()
+ if self.debug:
@@ -761,7 +821,7 @@
- topolist = self.get_temporal_topo_list(maplistA, maplistB)
+ topolist = self.build_spatio_temporal_topology_list(maplistA, maplistB)
if self.run:
resultlist = []
@@ -930,7 +990,7 @@
# Check input stds.
if self.run:
resultlist = []
@@ -1081,11 +1141,11 @@
relations, temporal, function, aggregate = self.eval_toperator(t[2], optype='raster')
- complist = self.get_temporal_topo_list(maplistA,
- maplistB,
- topolist=relations,
- operator_cmd=True,
- compop=function)
+ complist = self.build_spatio_temporal_topology_list(maplistA,
+ maplistB,
+ topolist=relations,
+ operator_cmd=True,
+ compop=function)
topolist=relations,
@@ -1116,11 +1176,11 @@
- maplistB,
- compop=function)
+ maplistB,
+ compop=function)
topolist=relations,
@@ -1347,12 +1407,12 @@
aggregate = t[2]
- complist = self.get_temporal_topo_list(s_var_exprA,
- s_var_exprB,
- compare_cmd=True,
- compop=function,
+ complist = self.build_spatio_temporal_topology_list(s_var_exprA,
+ s_var_exprB,
+ compare_cmd=True,
+ compop=function,
topolist=relations,
@@ -1377,12 +1437,12 @@
- s_var_exprB,
- compare_cmd=True,
- compop=function,
+ s_var_exprB,
+ compare_cmd=True,
+ compop=function,
topolist=relations,
@@ -1720,13 +1780,13 @@
aggregate = t[2]
- s_var_exprB,
- compare_cmd=True,
- compop=function,
- aggregate=aggregate,
- convert=True)
+ s_var_exprB,
+ compare_cmd=True,
+ compop=function,
+ aggregate=aggregate,
+ convert=True)
topolist=relations,
Modified: grass/trunk/lib/python/temporal/temporal_vector_algebra.py
--- grass/trunk/lib/python/temporal/temporal_vector_algebra.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/temporal_vector_algebra.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -162,10 +162,10 @@
- def get_temporal_topo_list(self, maplistA, maplistB = None, topolist = ["EQUAL"],
- assign_val = False, count_map = False, compare_bool = False,
- compare_cmd = False, compop = None, aggregate = None,
- new = False, convert = False, overlay_cmd = False):
+ def build_spatio_temporal_topology_list(self, maplistA, maplistB = None, topolist = ["EQUAL"],
+ assign_val = False, count_map = False, compare_bool = False,
+ compare_cmd = False, compop = None, aggregate = None,
+ new = False, convert = False, overlay_cmd = False):
@@ -540,8 +540,8 @@
temporal = 'l'
function = t[2]
# Build command list for related maps.
- complist = self.get_temporal_topo_list(maplistA, maplistB, topolist = relations,
- compop = function, overlay_cmd = True)
+ complist = self.build_spatio_temporal_topology_list(maplistA, maplistB, topolist = relations,
+ compop = function, overlay_cmd = True)
temporal = temporal)
@@ -563,8 +563,8 @@
relations, temporal, function, aggregate = self.eval_toperator(t[2], optype = 'overlay')
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_conditionals.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -38,7 +38,7 @@
cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="e1 = 11")
cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="e2 = 12")
cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="e3 = 13")
cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="singletmap = 99")
tgis.open_new_stds(name="A", type="strds", temporaltype="absolute",
@@ -51,7 +51,7 @@
title="D", descr="D", semantic="field", overwrite=True)
tgis.open_new_stds(name="E", type="strds", temporaltype="absolute",
title="E", descr="E", semantic="field", overwrite=True)
tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a1,a2,a3,a4",
start="2001-01-01", increment="1 day", interval=True)
tgis.register_maps_in_space_time_dataset(type="raster", name="B", maps="b1,b2",
@@ -62,7 +62,7 @@
start="2001-01-03", increment="1 day", interval=True)
tgis.register_maps_in_space_time_dataset(type="raster", name="E", maps="e1,e2,e3",
start="2000-12-31", increment="2 day", interval=True)
- tgis.register_maps_in_space_time_dataset(type="raster", name=None, maps="singletmap",
+ tgis.register_maps_in_space_time_dataset(type="raster", name=None, maps="singletmap",
start="2001-01-03", end="2001-01-04")
def tearDown(self):
@@ -83,8 +83,8 @@
D = tgis.open_old_stds("R", type="strds")
D.select()
self.assertEqual(D.metadata.get_number_of_maps(), 2)
- self.assertEqual(D.metadata.get_min_min(), 3)
- self.assertEqual(D.metadata.get_max_max(), 4)
+ self.assertEqual(D.metadata.get_min_min(), 3)
+ self.assertEqual(D.metadata.get_max_max(), 4)
start, end = D.get_absolute_time()
self.assertEqual(start, datetime.datetime(2001, 1, 3))
self.assertEqual(end, datetime.datetime(2001, 1, 5))
@@ -99,14 +99,14 @@
D.select()
self.assertEqual(D.metadata.get_number_of_maps(), 4)
- self.assertEqual(D.metadata.get_min_min(), 1)
+ self.assertEqual(D.metadata.get_min_min(), 1)
self.assertEqual(start, datetime.datetime(2001, 1, 1))
self.assertEqual( D.check_temporal_topology(), True)
self.assertEqual(D.get_granularity(), u'1 day')
def test_temporal_condition_3(self):
"""Testing the temporal select operator with equal relations. """
ta = tgis.TemporalAlgebraParser(run=True, debug=True)
@@ -115,14 +115,14 @@
D.select()
def test_temporal_condition_4(self):
@@ -131,8 +131,8 @@
D.select()
@@ -147,14 +147,14 @@
D.select()
- self.assertEqual(D.metadata.get_max_max(), 2)
+ self.assertEqual(D.metadata.get_max_max(), 2)
self.assertEqual(end, datetime.datetime(2001, 1, 3))
def test_temporal_condition_6(self):
@@ -164,8 +164,8 @@
D.select()
- self.assertEqual(D.metadata.get_min_min(), 2)
- self.assertEqual(D.metadata.get_max_max(), 3)
+ self.assertEqual(D.metadata.get_min_min(), 2)
+ self.assertEqual(D.metadata.get_max_max(), 3)
self.assertEqual(start, datetime.datetime(2001, 1, 2))
self.assertEqual(end, datetime.datetime(2001, 1, 4))
@@ -181,8 +181,8 @@
D.select()
- self.assertEqual(D.metadata.get_min_min(), 5)
- self.assertEqual(D.metadata.get_max_max(), 6)
+ self.assertEqual(D.metadata.get_min_min(), 5)
+ self.assertEqual(D.metadata.get_max_max(), 6)
@@ -198,8 +198,8 @@
D.select()
@@ -215,8 +215,8 @@
D.select()
self.assertEqual(D.metadata.get_number_of_maps(), 1)
- self.assertEqual(D.metadata.get_max_max(), 5)
+ self.assertEqual(D.metadata.get_max_max(), 5)
@@ -232,14 +232,14 @@
D.select()
self.assertEqual(D.metadata.get_number_of_maps(), 3)
- self.assertEqual(D.metadata.get_min_min(), 11)
- self.assertEqual(D.metadata.get_max_max(), 13)
+ self.assertEqual(D.metadata.get_min_min(), 11)
+ self.assertEqual(D.metadata.get_max_max(), 13)
self.assertEqual(start, datetime.datetime(2000, 12, 31))
self.assertEqual(end, datetime.datetime(2001, 1, 6))
self.assertEqual(D.get_granularity(), u'2 days')
def test_temporal_condition_11(self):
@@ -249,8 +249,8 @@
D.select()
- self.assertEqual(D.metadata.get_max_max(), 11)
+ self.assertEqual(D.metadata.get_max_max(), 11)
self.assertEqual(end, datetime.datetime(2001, 1, 2))
@@ -266,14 +266,14 @@
D.select()
def test_temporal_conditional_13(self):
"""Testing the hash operator function in conditional statement. """
@@ -284,14 +284,14 @@
D.select()
maplist = D.get_registered_maps_as_objects()
def test_temporal_condition_else_1(self):
@@ -301,14 +301,14 @@
D.select()
- self.assertEqual(D.metadata.get_max_max(), 9)
+ self.assertEqual(D.metadata.get_max_max(), 9)
def test_temporal_condition_else_2(self):
@@ -318,8 +318,8 @@
D.select()
- self.assertEqual(D.metadata.get_min_min(), 4)
- self.assertEqual(D.metadata.get_max_max(), 8)
+ self.assertEqual(D.metadata.get_min_min(), 4)
+ self.assertEqual(D.metadata.get_max_max(), 8)
@@ -336,7 +336,7 @@
D.select()
self.assertEqual(D.metadata.get_min_min(), 8)
@@ -354,8 +354,8 @@
for map in D.get_registered_maps_as_objects():
print(map.get_map_id())
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster3d_algebra.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -32,7 +32,7 @@
cls.runModule("r3.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
tgis.open_new_stds(name="A", type="str3ds", temporaltype="absolute",
- title="A", descr="A", semantic="field", overwrite=True)
+ title="A", descr="A", semantic="field", overwrite=True)
tgis.register_maps_in_space_time_dataset(type="raster_3d", name="A", maps="a1,a2,a3,a4",
@@ -44,11 +44,14 @@
def tearDownClass(cls):
"""Remove the temporary region
- cls.runModule("t.remove", type="str3ds", flags="rf", inputs="A", quiet=True)
+ #cls.runModule("t.remove", type="str3ds", flags="rf", inputs="A", quiet=True)
cls.del_temp_region()
def test_temporal_neighbors_1(self):
"""Simple temporal neighborhood computation test"""
+ A = tgis.open_old_stds("A", type="str3ds")
+ A.print_info()
tra = tgis.TemporalRaster3DAlgebraParser(run = True, debug = True)
tra.parse(expression='D = A[-1] + A[1]',
basename="d", overwrite=True)
@@ -65,6 +68,9 @@
def test_temporal_neighbors_2(self):
+ A.print_info()
tra.parse(expression='D = A[0,0,0,-1] + A[0,0,0,1]',
Added: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_spatial_topology.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_spatial_topology.py (rev 0)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_spatial_topology.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -0,0 +1,133 @@
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert and Thomas Leppelt
+import datetime
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+class TestTemporalRasterAlgebraImplicitAggregation(TestCase):
+ @classmethod
+ def setUpClass(cls):
+ """Initiate the temporal GIS and set the region
+ tgis.init(True) # Raise on error instead of exit(1)
+ cls.use_temp_region()
+ cls.runModule("g.region", n=30.0, s=0.0, e=30.0, w=0.0, t=1.0, b=0.0, res=10.0)
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a1 = 1")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b1 = 1")
+ cls.runModule("g.region", n=50.0, s=20.0, e=50.0, w=20.0, t=1.0, b=0.0, res=10.0)
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a2 = 2")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b2 = 2")
+ cls.runModule("g.region", n=40.0, s=25.0, e=40.0, w=25.0, t=1.0, b=0.0, res=10.0)
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a3 = 3")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b3 = 3")
+ cls.runModule("g.region", n=60.0, s=40.0, e=60.0, w=40.0, t=1.0, b=0.0, res=10.0)
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b4 = 4")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="singletmap = 100")
+ cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="singlemap = 1000")
+ tgis.open_new_stds(name="A", type="strds", temporaltype="absolute",
+ tgis.open_new_stds(name="B", type="strds", temporaltype="absolute",
+ title="B", descr="B", semantic="field", overwrite=True)
+ tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a1,a2,a3,a4",
+ start="2001-01-01", interval=False)
+ tgis.register_maps_in_space_time_dataset(type="raster", name="B", maps="b1,b2,b3,b4",
+ start="2001-01-01")
+ def tearDown(self):
+ self.runModule("t.remove", flags="rf", inputs="R", quiet=True)
+ @classmethod
+ def tearDownClass(cls):
+ """Remove the temporary region
+ cls.runModule("t.remove", flags="rf", inputs="A,B", quiet=True)
+ cls.runModule("t.unregister", maps="singletmap", quiet=True)
+ cls.del_temp_region()
+ def test_equal_equivalent_sum(self):
+ """Spatial topology distinction with equal timestamps
+ STRDS A and B have identical time stamps, hence the differentiation
+ is based on the spatial topological relations
+ R = A {+,equal|equivalent,l} B
+ spatial equal extents pairs: a1,b1 a2,b2 a3,b3 a4,b4
+ r1 = a1 + b1 # 2
+ r1 = a2 + b2 # 4
+ r1 = a3 + b3 # 6
+ r1 = a4 + b4 # 8
+ ta = tgis.TemporalRasterAlgebraParser(run=True, debug=True, spatial=True)
+ ta.parse(expression="R = A {+,equal|equivalent,l} B", basename="r", overwrite=True)
+ D = tgis.open_old_stds("R", type="strds")
+ D.select()
+ self.assertEqual(D.metadata.get_number_of_maps(), 4)
+ start, end = D.get_absolute_time()
+ self.assertEqual(start, datetime.datetime(2001, 1, 1))
+ self.assertEqual( D.check_temporal_topology(), False)
+ self.assertEqual(D.get_granularity(), None)
+ def test_equal_equivalent_compare(self):
+ """Test implicit aggregation
+ R = if({equal|equivalent}, A > 0 {&&,equal|equivalent} B < 10, A {+,equal|equivalent,l} B
+ r1 = a1 + b1 # 2
+ r1 = a2 + b2 # 4
+ r1 = a3 + b3 # 6
+ r1 = a4 + b4 # 8
+ ta.parse(expression="R = if({equal|equivalent}, A > 0 {&&,equal|equivalent} B < 10, A {+,equal|equivalent,l} B)",
+ basename="r", overwrite=True)
+ D.select()
+if __name__ == '__main__':
+ test()
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py 2017-08-10 09:33:59 UTC (rev 71368)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals.py 2017-08-10 11:36:46 UTC (rev 71369)
@@ -44,7 +44,7 @@
title="C", descr="C", semantic="field", overwrite=True)
tgis.open_new_stds(name="D", type="strds", temporaltype="absolute",
@@ -53,7 +53,7 @@
start="2001-01-02", increment="2 day", interval=True)
tgis.register_maps_in_space_time_dataset(type="raster", name="D", maps="d1,d2,d3,d4",
def tearDown(self):
@@ -65,8 +65,8 @@
def test_temporal_conditional_time_dimension_bug(self):
- """Testing the conditional time dimension bug, that uses the time
- dimension of the conditional statement instead the time dimension
+ """Testing the conditional time dimension bug, that uses the time
+ dimension of the conditional statement instead the time dimension
of the then/else statement."""
tra = tgis.TemporalRasterAlgebraParser(run = True, debug = True)
tra.parse(expression='R = if({contains}, B == 5, A - 1, A + 1)', basename="r", overwrite=True)
@@ -83,8 +83,8 @@
self.assertEqual(R.get_granularity(), u'1 day')
def test_temporal_conditional_1(self):
tra.parse(expression='R = if(td(A) == 1, D * 2, D)', basename="r", overwrite=True)
@@ -101,8 +101,8 @@
def test_temporal_conditional_relation_1(self):
tra.parse(expression='R = if({during},exist(A), B - 1, B + 1)', basename="r", overwrite=True)
@@ -119,7 +119,7 @@
self.assertEqual(R.get_granularity(), u'2 days')
def test_spatial_conditional_1(self):
- """Testing the spatial conditionals combined by AND/OR operators.
+ """Testing the spatial conditionals combined by AND/OR operators.
Evaluation """
tra.parse(expression='R = if(A > 1 && A < 4 && isntnull(A), A)', basename="r", overwrite=True)
@@ -136,7 +136,7 @@
def test_spatial_conditional_2(self):
Evaluation """
tra.parse(expression='R = if(A > 1 && A < 4 && isntnull(A), A, null())', basename="r", overwrite=True)
@@ -153,7 +153,7 @@
def test_spatial_conditional_3(self):
Evaluation """
tra.parse(expression='R = if(A > 1, A, D)', basename="r", overwrite=True)
@@ -170,7 +170,7 @@
def test_spatial_conditional_4(self):
Evaluation """
tra.parse(expression='R = if(A > 0, A)', basename="r", overwrite=True)
@@ -187,7 +187,7 @@
def test_spatial_conditional_5(self):
Evaluation """
tra.parse(expression='R = if(B > 5 {&&,contains,l} A < 5, B)', basename="r", overwrite=True)
@@ -202,9 +202,9 @@
self.assertEqual( R.check_temporal_topology(), True)
def test_spatial_conditional_relation_1(self):
Evaluation """
tra.parse(expression='R = if({contains},B > 5, D)', basename="r", overwrite=True)
@@ -251,9 +251,9 @@
def test_spatial_conditional_numeric_relation_2(self):
Evaluation """
tra.parse(expression='R = if({contains},B > 5, A + 2 / 4.0)', basename="r", overwrite=True)
@@ -268,7 +268,7 @@
def test_spatial_conditional_numeric_1(self):
"""Testing the spatial conditionals with numeric conclusions"""
@@ -412,9 +412,9 @@
def test_spatiotemporal_conditional_numeric_relation_2(self):
Evaluation """
tra.parse(expression='R = if({contains},td(B) == 2 && start_date(B) == "2001-01-03" && B > 5 , A + 2 / 4.0)', basename="r", overwrite=True)
@@ -429,7 +429,7 @@
def test_spatiotemporal_conditional_numeric_1(self):
