[GRASS-SVN] r71379 - in grass/trunk/lib/python/temporal: . testsuite
Thu Aug 10 13:46:33 PDT 2017
Author: huhabla
Date: 2017-08-10 13:46:33 -0700 (Thu, 10 Aug 2017)
New Revision: 71379
Added:
   grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals_complement_else.py
   grass/trunk/lib/python/temporal/open_stds.py
   grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_spatial_topology.py
temporal framework: Implementing temporal algebra complement tests that show the current condition bugs
Modified: grass/trunk/lib/python/temporal/open_stds.py
--- grass/trunk/lib/python/temporal/open_stds.py	2017-08-10 20:40:25 UTC (rev 71378)
+++ grass/trunk/lib/python/temporal/open_stds.py	2017-08-10 20:46:33 UTC (rev 71379)
@@ -49,7 +49,7 @@
     # Check if the dataset name contains the mapset as well
     if name.find("@") < 0:
-        id = name + "@" + mapset
+        id = name.decode("utf-8") + "@" + mapset.decode("utf-8")
     else:
         id = name
Modified: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_spatial_topology.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_spatial_topology.py	2017-08-10 20:40:25 UTC (rev 71378)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_algebra_spatial_topology.py	2017-08-10 20:46:33 UTC (rev 71379)
@@ -13,7 +13,7 @@
 from grass.gunittest.main import test
-class TestTemporalRasterAlgebraImplicitAggregation(TestCase):
+class TestTemporalRasterAlgebraSpatialTopology(TestCase):
     @classmethod
     def setUpClass(cls):
@@ -57,6 +57,7 @@
     def tearDown(self):
         self.runModule("t.remove", flags="rf", inputs="R", quiet=True)
+        pass
     @classmethod
     def tearDownClass(cls):
@@ -76,10 +77,10 @@
         spatial equal extents pairs: a1,b1  a2,b2  a3,b3  a4,b4
-        r1 = a1 + b1  # 2
+        r0 = a1 + b1  # 2
         r1 = a2 + b2  # 4
-        r1 = a3 + b3  # 6
-        r1 = a4 + b4  # 8
+        r2 = a3 + b3  # 6
+        r3 = a4 + b4  # 8
         ta = tgis.TemporalRasterAlgebraParser(run=True, debug=True, spatial=True)
@@ -96,7 +97,124 @@
         self.assertEqual( D.check_temporal_topology(),  False)
         self.assertEqual(D.get_granularity(),  None)
+    def test_equal_overlap_sum(self):
+        """Spatial topology distinction with equal timestamps
+        STRDS A and B have identical time stamps, hence the differentiation
+        is based on the spatial topological relations
+        R = A {+,equal|overlap,l} B
+        spatial overlap extents pairs: a3,b1 a1,b2,b3 a2,b1,b4 a4,b2
+        r0 = a3 + b1       # 4
+        r1 = a1 + b2 + b3  # NULL
+        r2 = a2 + b1 + b4  # NULL
+        r3 = a4 + b2       # 6
+        ta = tgis.TemporalRasterAlgebraParser(run=True, debug=True, spatial=True)
+        ta.parse(expression="R = A {+,equal|overlap,l} B",   basename="r", overwrite=True)
+        D = tgis.open_old_stds("R", type="strds")
+        D.select()
+        self.assertEqual(D.metadata.get_number_of_maps(), 2)
+        self.assertEqual(D.metadata.get_min_min(), 4)
+        self.assertEqual(D.metadata.get_max_max(), 6)
+        start, end = D.get_absolute_time()
+        self.assertEqual(start, datetime.datetime(2001, 1, 1))
+        self.assertEqual( D.check_temporal_topology(),  False)
+        self.assertEqual(D.get_granularity(),  None)
+    def test_equal_overlap_sum_with_null(self):
+        R = A {+,equal|cover,l} B
+        r0 = a3 + b1       # 4
+        r3 = a4 + b2       # 6
+        ta = tgis.TemporalRasterAlgebraParser(run=True, debug=True, spatial=True, register_null=True)
+        D.select()
+        self.assertEqual(D.metadata.get_number_of_maps(), 4)
+    def test_equal_contain_sum(self):
+        spatial overlap extents pairs: a2,b3
+        r0 = a2 + b3       # 4
+        ta.parse(expression="R = A {+,equal|contain,l} B",   basename="r", overwrite=True)
+        D.select()
+        self.assertEqual(D.metadata.get_number_of_maps(), 1)
+        self.assertEqual(D.metadata.get_min_min(), 5)
+        self.assertEqual(D.metadata.get_max_max(), 5)
+        self.assertEqual( D.check_temporal_topology(),  True)
+    def test_equal_equivalent_contain_sum(self):
+        R = A {+,equal|equivalent|contain,l} B
+        spatial equal extents pairs: a1,b1  a2,b2  a3,b3  a4,b4
+        r0 = a1 + b1       # 2
+        r1 = a2 + b2 + b3  # 7
+        r2 = a3 + b3       # 6
+        r3 = a4 + b4       # 8
+        ta.parse(expression="R = A {+,equal|equivalent|contain,l} B",   basename="r", overwrite=True)
+        D.select()
+        self.assertEqual(D.metadata.get_min_min(), 2)
+        self.assertEqual(D.metadata.get_max_max(), 8)
     def test_equal_equivalent_compare(self):
         """Test implicit aggregation
@@ -107,10 +225,10 @@
-        r1 = a1 + b1  # 2
+        r0 = a1 + b1  # 2
         r1 = a2 + b2  # 4
-        r1 = a3 + b3  # 6
-        r1 = a4 + b4  # 8
+        r2 = a3 + b3  # 6
+        r3 = a4 + b4  # 8
Added: grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals_complement_else.py
--- grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals_complement_else.py	                        (rev 0)
+++ grass/trunk/lib/python/temporal/testsuite/unittests_temporal_raster_conditionals_complement_else.py	2017-08-10 20:46:33 UTC (rev 71379)
@@ -0,0 +1,127 @@
+(C) 2014 by the GRASS Development Team
+This program is free software under the GNU General Public
+License (>=v2). Read the file COPYING that comes with GRASS
+for details.
+:authors: Soeren Gebbert and Thomas Leppelt
+import datetime
+import grass.temporal as tgis
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+class TestTemporalRasterAlgebraConditionalComplements(TestCase):
+    @classmethod
+    def setUpClass(cls):
+        """Initiate the temporal GIS and set the region
+        tgis.init(True) # Raise on error instead of exit(1)
+        cls.use_temp_region()
+        cls.runModule("g.region", n=80.0, s=0.0, e=120.0,
+                      w=0.0, t=1.0, b=0.0, res=10.0)
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a1 = 1")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a2 = 2")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a3 = 3")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a4 = 4")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a5 = 5")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="a6 = 6")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b1 = 7")
+        cls.runModule("r.mapcalc", overwrite=True, quiet=True, expression="b2 = 8")
+        tgis.open_new_stds(name="A", type="strds", temporaltype="absolute",
+                                         title="A", descr="A", semantic="field", overwrite=True)
+        tgis.open_new_stds(name="B", type="strds", temporaltype="absolute",
+                                         title="B", descr="B", semantic="field", overwrite=True)
+        tgis.register_maps_in_space_time_dataset(type="raster", name="A", maps="a1,a2,a3,a4,a5,a6",
+                                                 start="2001-01-01", increment="1 day", interval=True)
+        tgis.register_maps_in_space_time_dataset(type="raster", name="B", maps="b1,b2",
+                                                 start="2001-01-02", increment="2 day", interval=True)
+    def tearDown(self):
+        self.runModule("t.remove", flags="rf", inputs="R", quiet=True)
+    @classmethod
+    def tearDownClass(cls):
+        """Remove the temporary region
+        cls.runModule("t.remove", flags="rf", inputs="A,B", quiet=True)
+        cls.del_temp_region()
+    def test_temporal_conditional_complement(self):
+        """Test the conditional expression that evaluate if then else statements
+        so that the else statement is a complement operation
+        R = if({equal|contains}, B {#,contains,r} A == 2, B {+,contains,l} A, A)
+        IF B contains two maps from A
+        THEN add maps from A and B that fulfill the B contains A condition using implicit aggregation
+        ELSE copy the maps from A
+        The connection between the if then else statements are the topological relations equal and contains
+        r0 = a1            # 1
+        r1 = b1 + a2 + a3  # 12
+        r2 = b2 + a4 + a5  # 16
+        r4 = a6            # 6
+        tra = tgis.TemporalRasterAlgebraParser(run = True, debug = True)
+        tra.parse(expression='R = if({equal|contains}, B {#,contains,r} A == 2, B {+,contains,l} A, A)',
+                  basename="r", overwrite=True)
+        R = tgis.open_old_stds("R", type="strds")
+        R.select()
+        self.assertEqual(R.metadata.get_number_of_maps(), 4)
+        self.assertEqual(R.metadata.get_min_min(), 1)
+        self.assertEqual(R.metadata.get_max_max(), 16)
+        start, end = R.get_absolute_time()
+        self.assertEqual(end, datetime.datetime(2001, 1, 7))
+        self.assertEqual( R.check_temporal_topology(),  True)
+        self.assertEqual(R.get_granularity(),  u'1 day')
+    def test_temporal_conditional_complement_right_side_timestamps(self):
+        R = if({equal|contains|during}, B {#,contains,r} A == 2, B {+,contains,r} A, A)
+        THEN add maps from A and B that fulfill the B contains A condition using the right side timestamps
+        topological relations equal, contains and during
+        r0 = a1            # 1
+        r2 = b1 + a2 + a3  # 12
+        r3 = b2 + a4 + a5  # 16
+        r4 = b2 + a4 + a5  # 16
+        r5 = a6            # 6
+        tra.parse(expression='R = if({equal|contains|during}, B {#,contains,r} A == 2, B {+,contains,r} A, A)',
+        R.select()
+        self.assertEqual(R.metadata.get_number_of_maps(), 6)
+if __name__ == '__main__':
+    test()
