[GRASS-SVN] r71382 - grass-addons/grass7/raster/r.seasons
svn_grass at osgeo.org
Thu Aug 10 13:59:19 PDT 2017
Author: veroandreo
Date: 2017-08-10 13:59:19 -0700 (Thu, 10 Aug 2017)
New Revision: 71382
grass-addons/grass7/raster/r.seasons/main.c
grass-addons/grass7/raster/r.seasons/r.seasons.html
r.seasons: manual cosmetics
Modified: grass-addons/grass7/raster/r.seasons/main.c
--- grass-addons/grass7/raster/r.seasons/main.c 2017-08-10 20:50:33 UTC (rev 71381)
+++ grass-addons/grass7/raster/r.seasons/main.c 2017-08-10 20:59:19 UTC (rev 71382)
@@ -290,7 +290,7 @@
flag.lo = G_define_flag();
flag.lo->key = 'l';
- flag.lo->description = _("Stop a season when a value is above threshold (default: below threshold");
+ flag.lo->description = _("Stop a season when a value is above threshold (default: below threshold)");
flag.lazy = G_define_flag();
flag.lazy->key = 'z';
Modified: grass-addons/grass7/raster/r.seasons/r.seasons.html
--- grass-addons/grass7/raster/r.seasons/r.seasons.html 2017-08-10 20:50:33 UTC (rev 71381)
+++ grass-addons/grass7/raster/r.seasons/r.seasons.html 2017-08-10 20:59:19 UTC (rev 71382)
@@ -2,31 +2,34 @@
<em>r.seasons</em> counts the number of seasons in a time series. A
season is defined as a time period of at least <em>min_length</em>
-length where no value is below threshold (with the <em>-l</em>
-flag, no value above threshold). As threshold, a fixed value can be
-specified with the <em>tval</em> option, or a raster map with per-cell
-threshold values can be supplied with the <em>tmap</em> option.
+length in which no value is below the threshold set. If the <em>-l</em>
+flag is used, the seasons are identified when no value is above the
+threshold set. As threshold, either a fixed value for the whole region
+can be specified with the <em>threshold_value</em> option, or a raster
+map with per-cell threshold values can be supplied with the
+<em>threshold_map</em> option.
<p>
-The <em>nout</em> output holds the number of detected seasons. Output
+The <em>nout</em> output map holds the number of detected seasons. Output
raster maps with the start and end dates of each season are produced
for at most <em>n</em> number of seasons.
<p>
-A season will not include gaps equal or longer than <em>max_gap</em>.
-For each season, two start dates and two end dates are determined. The
-start date start1 and the end date end1 indicate the start and end of
-the core season, while the start date start2 and the end date end2
-indicate the start and end of the full season including some periods
-shorter than <em>min_length</em> separated by gaps shorter than
-<em>max_gap</em> at the beginning and end of the season. A core season
-will not include blocks shorter than <em>min_length</em>, while a full
-season can have blocks shorter than <em>min_length</em> at the
-beginning or end.
+A season is a period of time that might include gaps up to <em>max_gap</em>.
+For each season identified, two start dates and two end dates are determined.
+The start date "start1" and the end date "end1" indicate the start and
+end of the core season (i.e.: season without gaps), while the start date
+"start2" and the end date "end2" indicate the start and end of the full
+season including some periods shorter than <em>min_length</em> separated
+by gaps shorter than <em>max_gap</em> at the beginning and end of the
+season. A core season is at least <em>min_length</em> long and does not
+have any gaps, while a full season can have blocks shorter than
+<em>min_length</em> at the beginning or end as long as these blocks are
+separated by gaps shorter than the <em>max_gap</em>.
<p>
-The length of the longest core and full season can be stored in output
-maps <em>max_length_core</em> and <em>max_length_full</em>.
+The length of the longest core and full seasons can be stored in the
+<em>max_length_core</em> and <em>max_length_full</em> output maps.
<h2>NOTES</h2>
@@ -62,10 +65,10 @@
<h2>EXAMPLES</h2>
-Determine occurrence/number of seasons with their respective start and end
-dates (in the form of map indexes) in global NDVI data. Let's use the example
-from <em>r.modis.import</em> to download and import NDVI global data and,
-create a time series with it:
+Determine occurrence/number of seasons with their respective start and
+end dates (in the form of map indexes) in global NDVI data. Let's use
+the example from <em>r.modis.import</em> to download and import NDVI
+global data and, create a time series with it:
<div class="code"><pre>
# download two years of data: MOD13C1, global NDVI, 16-days, 5600 m
@@ -73,19 +76,20 @@
startday=2015-01-01 endday=2016-12-31 folder=$USER/data/ndvi_MOD13C1.006
# import band 1 = NDVI
-r.modis.import files=$USER/data/ndvi_MOD13C1.006/listfileMOD13C1.006.txt \
- spectral="( 1 )" method=bilinear -w
+r.modis.import -w files=$USER/data/ndvi_MOD13C1.006/listfileMOD13C1.006.txt \
+ spectral="( 1 )" method=bilinear outfile=$HOME/list_for_tregister.csv
# create empty temporal DB
t.create type=strds temporaltype=absolute output=ndvi_16_5600m \
title="Global NDVI 16 days MOD13C1" \
description="MOD13C1 Global NDVI 16 days" semantictype=mean
-# register datasets (tempfile name is provided by r.modis.import -w
-t.register input=ndvi_16_5600m file=$USER/tmp/grass7-user-5370/tmp_rGPcg
+# register datasets (using outfile from r.modis.import -w)
+t.register input=ndvi_16_5600m file=$HOME/list_for_tregister.csv
</pre></div>
-First, visualize the NDVI time series in a location with <em>g.gui.tplot</em>:
+First, visualize the NDVI time series in a particular point with
+<em>g.gui.tplot</em>:
g.gui.tplot strds=ndvi_16_5600m coordinates=146.537059538,-29.744835966
@@ -100,13 +104,13 @@
<i>Global NDVI from MOD13C1 product (right) and an example of a time series in southeastern Australia (left).</i>
</div>
-Now, identify seasons based on a fixed threshold and a minimum duration. The
-threshold and duration were visually estimated from the time series plot for
-the example.
+Now, identify seasons based on a fixed threshold and a minimum duration.
+The threshold and duration were visually estimated from the time series
+plot for the example.
r.seasons input=`g.list rast pat=MOD13* sep=,` prefix=ndvi_season n=3 \
- nout=ndvi_season tval=3000 min_length=6
+ nout=ndvi_season threshold_value=3000 min_length=6
# the outputs are:
g.list type=raster pattern=ndvi_season*
@@ -141,7 +145,7 @@
<p>
<div align="center" style="margin: 10px">
-<a href=".ndvi_season2_start1png">
+<a href="ndvi_season2_start1.png">
<img src="ndvi_season2_start1.png" width="500" alt="Start of season 2" border=0>
<a href="ndvi_season2_end1.png">
<img src="ndvi_season2_end1.png" width="500" alt="End of season 2" border=0>
