[GRASS-SVN] r71390 - grass/branches/releasebranch_7_2/db/db.select
svn_grass at osgeo.org
Fri Aug 11 03:16:57 PDT 2017
Author: mlennert
Date: 2017-08-11 03:16:56 -0700 (Fri, 11 Aug 2017)
New Revision: 71390
grass/branches/releasebranch_7_2/db/db.select/db.select.html
db.select: update man page to indicate that SQL statements have to be one complete query per line (backport from trunk r71389)
Modified: grass/branches/releasebranch_7_2/db/db.select/db.select.html
--- grass/branches/releasebranch_7_2/db/db.select/db.select.html 2017-08-11 10:14:08 UTC (rev 71389)
+++ grass/branches/releasebranch_7_2/db/db.select/db.select.html 2017-08-11 10:16:56 UTC (rev 71390)
@@ -2,7 +2,8 @@
<em>db.select</em> prints result of selection from database based on
SQL statement read from input file or from standard input to standard
-output.
+output. Each individual query has to be written on one single line and
+different queries have to be written on separate lines.
<h2>NOTE</h2>
