[GRASS-SVN] r71407 - grass/trunk/scripts/m.proj
svn_grass at osgeo.org
Tue Aug 15 23:58:03 PDT 2017
Author: hellik
Date: 2017-08-15 23:58:03 -0700 (Tue, 15 Aug 2017)
New Revision: 71407
grass/trunk/scripts/m.proj/m.proj.html
correct example for Long/Lat WGS84 output in decimal degree
Modified: grass/trunk/scripts/m.proj/m.proj.html
--- grass/trunk/scripts/m.proj/m.proj.html 2017-08-15 22:00:08 UTC (rev 71406)
+++ grass/trunk/scripts/m.proj/m.proj.html 2017-08-16 06:58:03 UTC (rev 71407)
@@ -89,7 +89,7 @@
v.out.ascii bridges | m.proj -o input=-
# Long/Lat WGS84 output in decimal degree
-v.out.ascii bridges | m.proj -o input=-
+v.out.ascii bridges | m.proj -o -d input=-
</pre></div>
<h3>Reproject Long/Lat WGS84 coordinate pair to current map projection</h3>
