[GRASS-SVN] r71410 - grass/trunk
svn_grass at osgeo.org
Sat Aug 19 06:48:47 PDT 2017
Author: neteler
Date: 2017-08-19 06:48:47 -0700 (Sat, 19 Aug 2017)
New Revision: 71410
Removed:
grass/trunk/README.debian
removed outdated debian notes (pls refer to ./INSTALL)
Deleted: grass/trunk/README.debian
--- grass/trunk/README.debian 2017-08-18 09:27:29 UTC (rev 71409)
+++ grass/trunk/README.debian 2017-08-19 13:48:47 UTC (rev 71410)
@@ -1,77 +0,0 @@
-# For preparing GRASS Debian package you should download the packaging
-# rules from DebianGIS's git repository, then use the Debian build scripts
-# to construct the .deb files.
-# Make sure git and the debian build scripts are installed:
- sudo apt-get install git subversion devscripts
-# and download the latest svn copy of GRASS:
- cd src/grass/
- svn checkout https://svn.osgeo.org/grass/grass/trunk g7_trunk
-# From the grass source dir download the packaging rules (the contents
-# of debiangis/grass/ can be ignored, only the debian/ dir is needed):
- git clone git://git.debian.org/git/pkg-grass/grass.git debiangis
- ln -s debiangis/grass/debian debian
-# If you haven't built GRASS from source on this machine before, you'll
-# have to install a bunch of -dev packages. Look at the debian/control
-# file and install the packages on the "Build-depends" lines.
- sudo apt-get install flex bison libreadline-dev libncurses5-dev # ... etc.
-# You can take care of this pretty much automatically by running
- dpkg-checkbuilddeps
-# in the main grass source directory, or with:
- sudo apt-get build-dep grass
-# (for that to work, make sure the 'deb-src' lines are active in
-# your /etc/apt/sources.list file)
-# Once all of the build dependencies are installed, in your favorite text
-# editor open debian/changelog and adjust the version number on the top
-# line to reflect the GRASS SVN checkout number.
-# e.g. for r50539: grass (7.0+svn50539-0) unstable; urgency=low
- nano debian/changelog
-# After that, you can build the current version of GRASS with
- cd g7_trunk
- ln -s ../debian .
- svn up
- debuild -i -uc -us -b
-#TODO: does 'debuild -i -uc -us -b -j4' work for parallel build??
-# it works for debuild'ing qgis; need to test with grass
-# run from the main GRASS source directory. After the packages are
-# generated, you can install them with:
- sudo dpkg -i ../grass*.deb
-# (make sure to move away older grass*.deb files first)
-# to try again, first clean out the old build by running:
-# (from the main source dir)
- debuild clean
-# then repeat the build process
-FIXME: how to download just the grass/debian/ directory from git
- and not the whole thing?
-H.Bowman
-Last changed: $Date$
