[GRASS-SVN] r71417 - in grass/trunk/raster/r.sim: r.sim.sediment r.sim.water simlib
svn_grass at osgeo.org
Sat Aug 19 13:08:55 PDT 2017
Author: annakrat
Date: 2017-08-19 13:08:55 -0700 (Sat, 19 Aug 2017)
New Revision: 71417
grass/trunk/raster/r.sim/r.sim.sediment/Makefile
grass/trunk/raster/r.sim/r.sim.sediment/main.c
grass/trunk/raster/r.sim/r.sim.water/Makefile
grass/trunk/raster/r.sim/r.sim.water/main.c
grass/trunk/raster/r.sim/simlib/Makefile
grass/trunk/raster/r.sim/simlib/hydro.c
grass/trunk/raster/r.sim/simlib/random.c
grass/trunk/raster/r.sim/simlib/simlib.h
grass/trunk/raster/r.sim/simlib/waterglobs.h
r.sim: add parallelization support to r.sim.water and r.sim.sediment - ported r.sim.water.mp from addons by Jaroslav Hofierka et al
Modified: grass/trunk/raster/r.sim/r.sim.sediment/Makefile
--- grass/trunk/raster/r.sim/r.sim.sediment/Makefile 2017-08-19 19:30:03 UTC (rev 71416)
+++ grass/trunk/raster/r.sim/r.sim.sediment/Makefile 2017-08-19 20:08:55 UTC (rev 71417)
@@ -4,10 +4,10 @@
EXTRA_CLEAN_DIRS=doxygenhtml
-LIBES = $(SIMLIB) $(GMATHLIB) $(GISLIB)
+LIBES = $(SIMLIB) $(GMATHLIB) $(GISLIB) $(OMPLIB)
DEPENDENCIES = $(SIMDEP) $(GMATHDEP) $(GISDEP)
EXTRA_INC = $(VECT_INC)
-EXTRA_CFLAGS = -I ../simlib $(VECT_CFLAGS)
+EXTRA_CFLAGS = -I ../simlib $(VECT_CFLAGS) $(OMPCFLAGS)
include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/raster/r.sim/r.sim.sediment/main.c
--- grass/trunk/raster/r.sim/r.sim.sediment/main.c 2017-08-19 19:30:03 UTC (rev 71416)
+++ grass/trunk/raster/r.sim/r.sim.sediment/main.c 2017-08-19 20:08:55 UTC (rev 71417)
@@ -100,6 +100,7 @@
int main(int argc, char *argv[])
int ii;
+ int threads;
int ret_val;
struct Cell_head cellhd;
struct WaterParams wp;
@@ -278,6 +279,15 @@
_("Automatically generates random seed for random number"
" generator (use when you don't want to provide the seed option)");
+ parm.threads = G_define_option();
+ parm.threads->key = "nprocs";
+ parm.threads->type = TYPE_INTEGER;
+ parm.threads->answer = NUM_THREADS;
+ parm.threads->required = NO;
+ parm.threads->description =
+ _("Number of threads which will be used for parallel compute");
+ parm.threads->guisection = _("Parameters");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -358,6 +368,16 @@
wp.erdep = parm.erdep->answer;
wp.outwalk = parm.outwalk->answer;
+ sscanf(parm.threads->answer, "%d", &threads);
+ if (threads < 1)
+ G_warning(_("<%d> is not valid number of threads. Number of threads will be set on <%d>"),
+ threads, abs(threads));
+ threads = abs(threads);
+ omp_set_num_threads(threads);
+ G_message(_("Number of threads: %d"), threads);
/* sscanf(parm.nwalk->answer, "%d", &wp.maxwa); */
sscanf(parm.niter->answer, "%d", &wp.timesec);
sscanf(parm.outiter->answer, "%d", &wp.iterout);
Modified: grass/trunk/raster/r.sim/r.sim.water/Makefile
--- grass/trunk/raster/r.sim/r.sim.water/Makefile 2017-08-19 19:30:03 UTC (rev 71416)
+++ grass/trunk/raster/r.sim/r.sim.water/Makefile 2017-08-19 20:08:55 UTC (rev 71417)
@@ -4,10 +4,10 @@
Modified: grass/trunk/raster/r.sim/r.sim.water/main.c
--- grass/trunk/raster/r.sim/r.sim.water/main.c 2017-08-19 19:30:03 UTC (rev 71416)
+++ grass/trunk/raster/r.sim/r.sim.water/main.c 2017-08-19 20:08:55 UTC (rev 71417)
@@ -90,7 +90,6 @@
#include <grass/simlib.h>
/* MAIN */
@@ -98,6 +97,7 @@
int ii;
+ int threads;
int ret_val;
double x_orig, y_orig;
struct GModule *module;
@@ -314,6 +314,15 @@
exit(EXIT_FAILURE);
@@ -387,6 +396,16 @@
G_debug(3, "Parsing rain parameters");
+ if (threads < 1)
/* if no rain map input, then: */
if (parm.rain->answer == NULL) {
/*Check for Rain Unique Value Input */
Modified: grass/trunk/raster/r.sim/simlib/Makefile
--- grass/trunk/raster/r.sim/simlib/Makefile 2017-08-19 19:30:03 UTC (rev 71416)
+++ grass/trunk/raster/r.sim/simlib/Makefile 2017-08-19 20:08:55 UTC (rev 71417)
@@ -1,9 +1,9 @@
MODULE_TOPDIR = ../../..
-LIBES = $(GISLIB) $(DATETIMELIB) $(GMATHLIB) $(RASTERLIB) $(VECTORLIB)
+LIBES = $(GISLIB) $(DATETIMELIB) $(GMATHLIB) $(RASTERLIB) $(VECTORLIB) $(OMPLIB)
DEPENDENCIES = $(GISDEP) $(BITMAPDEP) $(DBMIDEP) $(GMATHDEP) $(LINKMDEP) $(XDRDEP) $(SITESDEP) $(VECTORDEP) $(RASTERDEP) $(VECTORDEP)
-EXTRA_CFLAGS = $(VECT_CFLAGS)
+EXTRA_CFLAGS = $(VECT_CFLAGS) $(OMPCFLAGS)
LIB = SIM
Modified: grass/trunk/raster/r.sim/simlib/hydro.c
--- grass/trunk/raster/r.sim/simlib/hydro.c 2017-08-19 19:30:03 UTC (rev 71416)
+++ grass/trunk/raster/r.sim/simlib/hydro.c 2017-08-19 20:08:55 UTC (rev 71417)
@@ -268,7 +268,14 @@
nwalka = 0;
nstack = 0;
- for (lw = 0; lw < nwalk; lw++) {
+#pragma omp parallel firstprivate(l,lw,k,decr,d1,hhc,velx,vely,eff,gaux,gauy)//nwalka
+ int steps = (int)((((double)nwalk) / ((double) omp_get_num_threads())) + 0.5);
+ int tid = omp_get_thread_num();
+ int min_loop = tid * steps;
+ int max_loop = ((tid + 1) * steps) > nwalk ? nwalk : (tid + 1) * steps;
+ for (lw = min_loop; lw < max_loop; lw++) {
if (w[lw][2] > EPS) { /* check the walker weight */
++nwalka;
l = (int)((w[lw][0] + stxm) / stepx) - mx - 1;
@@ -305,6 +312,7 @@
gama[k][l] += (addac * w[lw][2]); /* add walker weigh to water depth or conc. */
d1 = gama[k][l] * conn;
+ gasdev_for_paralel(&gaux, &gauy);
hhc = pow(d1, 3. / 5.);
if (hhc > hhmax && wdepth == NULL) { /* increased diffusion if w.depth > hhmax */
@@ -329,9 +337,6 @@
- gaux = gasdev();
- gauy = gasdev();
w[lw][0] += (velx + dif[k][l] * gaux); /* move the walker */
w[lw][1] += (vely + dif[k][l] * gauy);
@@ -358,7 +363,7 @@
} /* lw loop */
/* Changes made by Soeren 8. Mar 2011 to replace the site walker output implementation */
/* Save all walkers located within the computational region and with valid
z coordinates */
Modified: grass/trunk/raster/r.sim/simlib/random.c
--- grass/trunk/raster/r.sim/simlib/random.c 2017-08-19 19:30:03 UTC (rev 71416)
+++ grass/trunk/raster/r.sim/simlib/random.c 2017-08-19 20:08:55 UTC (rev 71417)
@@ -45,3 +45,17 @@
return ret_val;
} /* gasdev */
+void gasdev_for_paralel(double *x, double *y)
+ double r = 0., vv1, vv2, fac;
+ while (r >= 1. || r == 0.) {
+ vv1 = simwe_rand() * 2. - 1.;
+ vv2 = simwe_rand() * 2. - 1.;
+ r = vv1 * vv1 + vv2 * vv2;
+ fac = sqrt(log(r) * -2. / r);
+ (*y) = vv1 * fac;
+ (*x) = vv2 * fac;
Modified: grass/trunk/raster/r.sim/simlib/simlib.h
--- grass/trunk/raster/r.sim/simlib/simlib.h 2017-08-19 19:30:03 UTC (rev 71416)
+++ grass/trunk/raster/r.sim/simlib/simlib.h 2017-08-19 20:08:55 UTC (rev 71417)
@@ -5,6 +5,12 @@
* \brief This is the interface for the simlib (SIMWE) library.
+#define NUM_THREADS "1"
+#if defined(_OPENMP)
+#include <omp.h>
+#endif
struct WaterParams
double xmin, ymin, xmax, ymax;
@@ -85,7 +91,7 @@
*observation, *depth, *disch, *err, *outwalk, *nwalk, *niter, *outiter,
*density, *diffc, *hmax, *halpha, *hbeta, *wdepth, *detin, *tranin,
*tauin, *tc, *et, *conc, *flux, *erdep, *rainval, *maninval,
- *infilval, *logfile, *seed;
+ *infilval, *logfile, *seed, *threads;
struct flags
Modified: grass/trunk/raster/r.sim/simlib/waterglobs.h
--- grass/trunk/raster/r.sim/simlib/waterglobs.h 2017-08-19 19:30:03 UTC (rev 71416)
+++ grass/trunk/raster/r.sim/simlib/waterglobs.h 2017-08-19 20:08:55 UTC (rev 71417)
@@ -61,6 +61,7 @@
extern int output_et(void);
extern double simwe_rand(void);
extern double gasdev(void);
+extern void gasdev_for_paralel(double *, double *);
extern double amax1(double, double);
extern double amin1(double, double);
extern int min(int, int);
