[GRASS-SVN] r71443 - grass-addons/grass7/vector/v.neighborhoodmatrix
svn_grass at osgeo.org
Mon Aug 28 09:26:09 PDT 2017
Author: mlennert
Date: 2017-08-28 09:26:09 -0700 (Mon, 28 Aug 2017)
New Revision: 71443
grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.html
grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py
v.neighborhoodmatrix: add option to identify polygons through an arbitrary attribute column, instead of only category value
Modified: grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.html
--- grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.html 2017-08-28 04:50:26 UTC (rev 71442)
+++ grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.html 2017-08-28 16:26:09 UTC (rev 71443)
@@ -5,26 +5,33 @@
number of neighborhood relations with each relation only listed in one
direction (i.e. if a is neighbor of b, the list will contain a,b, but
not b,a) unless the <em>b</em> flag is specified.
-It uses <em>v.to.db</em> to determine neighborhood relations.
-If a path to an output file is specified, the matrix will be written to that file, otherwise it will be sent to standard output.
+By default, neighbors are identified by the category numbers. Using the
+<em>idcolumn</em> parameter the user can define a column to use as identifier
+of the polygons.
+If a path to an output file is specified, the matrix will be written to that
+file, otherwise it will be sent to standard output.
<h2>NOTES</h2>
Currently the module assumes that the layer above the layer containing the
polygons is empty and available for adding categories to boundaries.
+The module uses <em>v.to.db</em> to determine neighborhood relations.
<h2>EXAMPLE</h2>
-Send the neighborhood matrix of the counties in the boundary_county map of the North Carolina dataset to standard output:
+Send the neighborhood matrix of the census tracts of the North Carolina dataset
+to standard output identifying each tract by its category value:
<div class="code"><pre>
-v.neighborhoodmatrix in=boundary_county sep=,
+v.neighborhoodmatrix in=census_wake2000
</pre></div>
-Idem, but sending the output to a file
+Idem, but identifying each tract by its STFID code and sending the output to a
+file:
-v.neighborhoodmatrix in=boundary_county sep=, output=county_neighbors.csv
+v.neighborhoodmatrix in=census_wake2000 idcolumn=STFID output=census_neighbors.csv
</pre></div>
<h2>SEE ALSO</h2>
Modified: grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py
--- grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py 2017-08-28 04:50:26 UTC (rev 71442)
+++ grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py 2017-08-28 16:26:09 UTC (rev 71443)
@@ -26,6 +26,11 @@
#% answer: 1
#% required: no
#%end
+#%option G_OPT_DB_COLUMN
+#% key: idcolumn
+#% description: Name of column containing polygon ids
+#% required: no
+#%end
#%option G_OPT_F_OUTPUT
#% description: Name for output file (if omitted or "-" output to stdout)
#% required: no
@@ -52,6 +57,7 @@
input = options['input']
player = int(options['player'])
output = options['output']
+ idcolumn = options['idcolumn'] if options['idcolumn'] else False
sep = separator(options['separator'])
bidirectional = flags['b']
global tempmapname
@@ -69,7 +75,7 @@
temp_neighbors=[]
for line in vtodb_results.splitlines():
if line.split('|')[1]<>'-1' and line.split('|')[2]<>'-1':
- temp_neighbors.append([int(line.split('|')[1]), int(line.split('|')[2])])
+ temp_neighbors.append([int(line.split('|')[1]), int(line.split('|')[2])])
#temp_neighbors.sort()
@@ -77,21 +83,47 @@
if bidirectional:
neighbors_reversed=[]
for pair in temp_neighbors:
- neighbors_reversed.append([pair[1], pair[0]])
+ neighbors_reversed.append([pair[1], pair[0]])
temp_neighbors += neighbors_reversed
#uniqify the list of integer pairs
neighbors = [list(x) for x in set(tuple(x) for x in temp_neighbors)]
neighbors.sort()
+ currentcat=''
if output and output != '-':
out=open(output, 'w')
- for pair in neighbors:
- out.write(str(pair[0]) + sep + str(pair[1])+'\n')
+ for pair in neighbors:
+ if idcolumn:
+ # While pair[0] stays the same we don't have to call v.db.select
+ # again and again to get the id
+ if currentcat != pair[0]:
+ currentcat = pair[0]
+ fromid=gscript.read_command('v.db.select',
+ map=input,
+ column=idcolumn,
+ where="cat=%d" % pair[0],
+ layer=player,
+ flags="c",
+ quiet=True).rstrip()
+ toid=gscript.read_command('v.db.select',
+ map=input,
+ column=idcolumn,
+ where="cat=%d" % pair[1],
+ layer=player,
+ flags="c",
+ if output and output != '-':
+ out.write(fromid + sep + toid + '\n')
+ else:
+ print(fromid + sep + toid)
+ else:
+ out.write(str(pair[0]) + sep + str(pair[1])+'\n')
+ else:
+ print(str(pair[0]) + sep + str(pair[1]))
out.close()
- else:
- print(str(pair[0]) + sep + str(pair[1]))
