[GRASS-SVN] r71454 - grass/branches/releasebranch_7_2/vector/v.in.ogr
svn_grass at osgeo.org
Thu Aug 31 10:14:02 PDT 2017
Author: mmetz
Date: 2017-08-31 10:14:02 -0700 (Thu, 31 Aug 2017)
New Revision: 71454
grass/branches/releasebranch_7_2/vector/v.in.ogr/main.c
v.in.ogr: disable OSM import because it needs a special reading mode (backport from trunk r71453)
Modified: grass/branches/releasebranch_7_2/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_7_2/vector/v.in.ogr/main.c 2017-08-31 17:11:19 UTC (rev 71453)
+++ grass/branches/releasebranch_7_2/vector/v.in.ogr/main.c 2017-08-31 17:14:02 UTC (rev 71454)
@@ -91,6 +91,7 @@
/* OGR */
OGRDataSourceH Ogr_ds;
+ const char *ogr_driver_name;
OGRLayerH Ogr_layer;
OGRFieldDefnH Ogr_field;
char *Ogr_fieldname;
@@ -409,6 +410,14 @@
if (Ogr_ds == NULL)
G_fatal_error(_("Unable to open data source <%s>"), dsn);
+ ogr_driver_name = OGR_Dr_GetName(OGR_DS_GetDriver(Ogr_ds));
+ if (strcmp(ogr_driver_name, "OSM") == 0) {
+ OGR_DS_Destroy(Ogr_ds);
+ G_warning(_("OpenStreetMap import can result in missing features. "
+ "Please use ogr2ogr first to convert to a different format."));
+ G_fatal_error(_("OSM import cancelled."));
if (param.geom->answer) {
#if GDAL_VERSION_NUM >= 1110000
if (!OGR_DS_TestCapability(Ogr_ds, ODsCCreateGeomFieldAfterCreateLayer)) {
@@ -425,12 +434,9 @@
/* check encoding for given driver */
if (param.encoding->answer) {
- const char *ogr_driver;
- ogr_driver = OGR_Dr_GetName(OGR_DS_GetDriver(Ogr_ds));
- if (strcmp(ogr_driver, "ESRI Shapefile") != 0 &&
- strcmp(ogr_driver, "DXF") != 0)
- G_warning(_("Encoding value not supported by OGR driver <%s>"), ogr_driver);
+ if (strcmp(ogr_driver_name, "ESRI Shapefile") != 0 &&
+ strcmp(ogr_driver_name, "DXF") != 0)
+ G_warning(_("Encoding value not supported by OGR driver <%s>"), ogr_driver_name);
/* make a list of available layers */
@@ -1301,6 +1307,7 @@
if (!flag.notab->answer) {
db_commit_transaction(driver);
+ db_close_database_shutdown_driver(driver);
if (nogeom > 0)
@@ -1674,28 +1681,36 @@
delete_table = Vect_maptype(&Map) != GV_FORMAT_NATIVE;
- if (0 != Vect_close(&Map))
- G_fatal_error(_("Import failed"));
/* create index - may fail on non-unique categories */
- if (db_create_index2(driver, Fi->table, key_column) != DB_OK)
- G_warning(_("Unable to create index for table <%s>, key <%s>"),
- Fi->table, key_column);
- if (delete_table) {
- sprintf(buf, "drop table %s", Fi->table);
- db_set_string(&sql, buf);
- if (db_execute_immediate(driver, &sql) != DB_OK) {
- G_fatal_error(_("Unable to drop table: '%s'"),
- db_get_string(&sql));
+ for (layer = 0; layer < nlayers; layer++) {
+ Fi = Vect_get_field(&Map, layer + 1);
+ driver =
+ db_start_driver_open_database(Fi->driver,
+ Vect_subst_var(Fi->database,
+ &Map));
- db_close_database_shutdown_driver(driver);
+ if (!delete_table) {
+ if (db_create_index2(driver, Fi->table, key_column) != DB_OK)
+ G_warning(_("Unable to create index for table <%s>, key <%s>"),
+ Fi->table, key_column);
+ else {
+ sprintf(buf, "drop table %s", Fi->table);
+ db_set_string(&sql, buf);
+ if (db_execute_immediate(driver, &sql) != DB_OK) {
+ G_fatal_error(_("Unable to drop table: '%s'"),
+ db_get_string(&sql));
+ if (0 != Vect_close(&Map))
+ G_fatal_error(_("Import failed"));
/* Extend current window based on dataset. */
