[GRASS-SVN] r71883 - in grass/branches/releasebranch_7_4: raster/r.neighbors vector/v.kernel
Fri Dec 1 06:48:19 PST 2017
Author: veroandreo
Date: 2017-12-01 06:48:19 -0800 (Fri, 01 Dec 2017)
New Revision: 71883
   grass/branches/releasebranch_7_4/raster/r.neighbors/r.neighbors.html
   grass/branches/releasebranch_7_4/vector/v.kernel/main.c
r.neighbors manual: beautify table; v.kernel: edit output description (trunk, r71882)
Modified: grass/branches/releasebranch_7_4/raster/r.neighbors/r.neighbors.html
--- grass/branches/releasebranch_7_4/raster/r.neighbors/r.neighbors.html	2017-12-01 14:42:59 UTC (rev 71882)
+++ grass/branches/releasebranch_7_4/raster/r.neighbors/r.neighbors.html	2017-12-01 14:48:19 UTC (rev 71883)
@@ -338,9 +338,8 @@
 These combine to create four possibilities:
 <p>
 <table border="1">
- <tr><th>input type</th><th>integer</th><th>integer</th><th>float</th><th>float</th></tr>
- <tr><td>weighted</td><td>no</td><td>yes</td><td>no</td><td>yes</td></tr>
- <tr><td> </td><td> </td><td> </td><td> </td><td> </td></tr>
+ <tr><th rowspan="2">input type/weight</th><th colspan="2">integer</th><th colspan="2">float</th></tr>
+ <tr><th>no</th><th>yes</th><th>no</th><th>yes</th></tr>
  <tr><td>average</td><td>float</td><td>float</td><td>float</td><td>float</td></tr>
  <tr><td>median</td><td>[1]</td><td>[1]</td><td>float</td><td>float</td></tr>
  <tr><td>mode</td><td>integer</td><td>integer</td><td>[2]</td><td>[2]</td></tr>
Modified: grass/branches/releasebranch_7_4/vector/v.kernel/main.c
--- grass/branches/releasebranch_7_4/vector/v.kernel/main.c	2017-12-01 14:42:59 UTC (rev 71882)
+++ grass/branches/releasebranch_7_4/vector/v.kernel/main.c	2017-12-01 14:48:19 UTC (rev 71883)
@@ -131,6 +131,7 @@
     out_opt->key = "output";
     out_opt->required = NO;
     out_opt->label = _("Name for output raster map");
+    out_opt->description = NULL;
     out_opt->guisection = _("Basic");
     net_out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
