[GRASS-SVN] r71905 - grass/branches/releasebranch_7_4/imagery/i.albedo
Fri Dec 8 01:09:20 PST 2017
Author: lucadelu
Date: 2017-12-08 01:09:20 -0800 (Fri, 08 Dec 2017)
New Revision: 71905
Added:
   grass/branches/releasebranch_7_4/imagery/i.albedo/albedo_landsat5.png
   grass/branches/releasebranch_7_4/imagery/i.albedo/albedo_landsat7.png
   grass/branches/releasebranch_7_4/imagery/i.albedo/i.albedo.html
i.albedo: added examples and screenshots, thanks to Jerry Huang and Google Code-in
Added: grass/branches/releasebranch_7_4/imagery/i.albedo/albedo_landsat5.png
(Binary files differ)
Property changes on: grass/branches/releasebranch_7_4/imagery/i.albedo/albedo_landsat5.png
___________________________________________________________________
Added: svn:mime-type
   + image/png
Added: grass/branches/releasebranch_7_4/imagery/i.albedo/albedo_landsat7.png
Property changes on: grass/branches/releasebranch_7_4/imagery/i.albedo/albedo_landsat7.png
   + image/png
Modified: grass/branches/releasebranch_7_4/imagery/i.albedo/i.albedo.html
--- grass/branches/releasebranch_7_4/imagery/i.albedo/i.albedo.html	2017-12-08 09:02:12 UTC (rev 71904)
+++ grass/branches/releasebranch_7_4/imagery/i.albedo/i.albedo.html	2017-12-08 09:09:20 UTC (rev 71905)
@@ -12,6 +12,29 @@
 <p>
 It assumes MODIS product surface reflectance in [0;10000].
+<h2>EXAMPLE</h2>
+Code creates the raster map "albedo_lsat7_1987" from the
+LANDSAT-TM5 bands in the North Carolina dataset.
+<div class="code"><pre>
+i.albedo -l input=lsat5_1987_10,lsat5_1987_20,lsat5_1987_30,lsat5_1987_40,lsat5_1987_50,lsat5_1987_70 output=albedo_lsat7_1987
+</pre></div>
+<p>
+<center>
+<img src="albedo_landsat5.png" alt="i.albedo LANDSAT-TM5 1987 example"><br>
+<i>Figure: Resulting albedo map from LANDSAT 5</i>
+</center>
+<p>
+Code creates the raster map "albedo_lsat7_2000" from the
+LANDSAT-TM7 bands in the North Carolina dataset.
+i.albedo -l input=lsat7_2000_10,lsat7_2000_20,lsat7_2000_30,lsat7_2000_40,lsat7_2000_50,lsat7_2000_70 output=albedo_lsat7_2000
+</pre></div>
+<p>
+<center>
+<img src="albedo_landsat7.png" alt="i.albedo LANDSAT-TM7 2000 example"><br>
+<i>Figure: Resulting albedo map from LANDSAT 7</i>
+</center>
 <h2>TODO</h2>
 Maybe change input requirement of MODIS to [0.0-1.0]?
