[GRASS-SVN] r71907 - grass/branches/releasebranch_7_2/raster/r.support
svn_grass at osgeo.org
Fri Dec 8 01:49:05 PST 2017
Author: lucadelu
Date: 2017-12-08 01:49:05 -0800 (Fri, 08 Dec 2017)
New Revision: 71907
grass/branches/releasebranch_7_2/raster/r.support/r.support.html
r.support: added examples, thanks to Jerry Huang and Google Code-in
Modified: grass/branches/releasebranch_7_2/raster/r.support/r.support.html
--- grass/branches/releasebranch_7_2/raster/r.support/r.support.html 2017-12-08 09:46:36 UTC (rev 71906)
+++ grass/branches/releasebranch_7_2/raster/r.support/r.support.html 2017-12-08 09:49:05 UTC (rev 71907)
@@ -5,6 +5,29 @@
history, and title is supported. Category labels can also be copied from
another raster map.
+<h2>EXAMPLES</h2>
+These examples are based on the North Carolina dataset, more specfically the <em>landuse</em> raster map.
+Copy the landuse map to the current mapset
+<div class="code"><pre>g.copy raster=landuse,my_landuse
+</pre></div>
+<h3>Update statistics</h3>
+<div class="code"><pre>r.support -s map=my_landuse
+</pre></div>
+<h3>Update Title</h3>
+<div class="code"><pre>r.support map=my_landuse title="Landuse copied"
+</pre></div>
+<h3>Append to History Metadata</h3>
+<div class="code"><pre>r.support map=my_landuse history="Copied from PERMANENT mapset"
+</pre></div>
+<h3>Update Units Display</h3>
+<div class="code"><pre>r.support map=my_landuse units=meter
+</pre></div>
<h2>NOTES</h2>
If metadata options such as <b>title</b> or <b>history</b> are given the
