[GRASS-SVN] r71934 - in grass/branches/releasebranch_7_4/display: d.grid d.mon d.rgb
svn_grass at osgeo.org
Wed Dec 13 00:38:31 PST 2017
Author: neteler
Date: 2017-12-13 00:38:31 -0800 (Wed, 13 Dec 2017)
New Revision: 71934
grass/branches/releasebranch_7_4/display/d.grid/d.grid.html
grass/branches/releasebranch_7_4/display/d.mon/d.mon.html
grass/branches/releasebranch_7_4/display/d.rgb/d.rgb.html
d.grid, d.mon, d.rgb manuals: various grammar fixes
Modified: grass/branches/releasebranch_7_4/display/d.grid/d.grid.html
--- grass/branches/releasebranch_7_4/display/d.grid/d.grid.html 2017-12-13 08:37:43 UTC (rev 71933)
+++ grass/branches/releasebranch_7_4/display/d.grid/d.grid.html 2017-12-13 08:38:31 UTC (rev 71934)
@@ -34,7 +34,7 @@
<h2>EXAMPLES</h2>
To draw a red geographic grid with 30 minute grid spacing, run
-either of the following:
+one of the following commands:
<div class="code"><pre>
d.grid -g size=00:30:00 color=red
@@ -49,7 +49,7 @@
<div style="margin: 10px" align="center">
<img src="d_grid_red_grid.png" alt="d.grid red grid example" border="0">
<br>
-<i>Figure: The red geographic grid.</i>
+<i>Figure: Showing a geographic grid in red line color</i>
</div>
To draw a blue standard rectangular grid at a 500 (meter) spacing run the following:
@@ -61,7 +61,7 @@
<img src="d_grid_blue_grid.png" alt="d.grid blue grid example" border="0">
<br>
-<i>Figure: The blue rectangular grid.</i>
+<i>Figure: Showing a rectangular grid in blue line color</i>
</div>
<h2>SEE ALSO</h2>
Modified: grass/branches/releasebranch_7_4/display/d.mon/d.mon.html
--- grass/branches/releasebranch_7_4/display/d.mon/d.mon.html 2017-12-13 08:37:43 UTC (rev 71933)
+++ grass/branches/releasebranch_7_4/display/d.mon/d.mon.html 2017-12-13 08:38:31 UTC (rev 71934)
@@ -60,7 +60,7 @@
<h3>wx0 monitor</h3>
-To start interactive <em><a href="wxGUI.html#map-display-window">wxGUI map
+To start the interactive <em><a href="wxGUI.html#map-display-window">wxGUI map
display</a></em>, run
@@ -70,36 +70,36 @@
<img src="d_mon_wx0.png" alt="Blank wx0 display" border="0">
<br>
-<i>Figure: The initialization of display wx0</i>
+<i>Figure: The initialization of display monitor wx0</i>
</div>
-All data will be rendered on <tt>wx0</tt> display.
+All subsequently displayed data will be rendered on monitor <tt>wx0</tt>.
-g.region raster=elevation
+g.region raster=elevation -p
d.rast map=elevation
</pre></div>
<img src="d_mon_wx0_raster.png" alt="Display wx0 with raster map" border="0">
<br>
-<i>Figure: The display wx0 show the elevation raster map</i>
+<i>Figure: The display wx0 showing an elevation raster map</i>
</div>
<h3>CAIRO file renderer monitor</h3>
-A new CAIRO monitor can be started (and selected) by
+A CAIRO monitor can be started (and selected) by
d.mon start=cairo output=out.pdf
</pre></div>
-From this moment all data will be rendered into
+From this moment on all displayed data will be rendered into
file <tt>output.pdf</tt>.
<h3>List running monitors</h3>
-To list running monitors, use
+To list the currently running monitors, use
d.mon -l
@@ -111,7 +111,7 @@
<h3>Show currently selected monitor</h3>
-To determine currently selected monitor
+To identify the currently selected monitor, use
d.mon -p
@@ -121,8 +121,8 @@
<h3>Switching between monitors</h3>
-To switch back to interactive, earlier started and still running wxGUI
-monitor
+To switch back to interactive display mode, here to an earlier started and
+still running wxGUI monitor, use
d.mon select=wx0
@@ -130,7 +130,7 @@
<h3>Stopping a monitor</h3>
-To close the wxGUI monitor
+To close the wxGUI monitor, run
d.mon stop=wx0
Modified: grass/branches/releasebranch_7_4/display/d.rgb/d.rgb.html
--- grass/branches/releasebranch_7_4/display/d.rgb/d.rgb.html 2017-12-13 08:37:43 UTC (rev 71933)
+++ grass/branches/releasebranch_7_4/display/d.rgb/d.rgb.html 2017-12-13 08:38:31 UTC (rev 71934)
@@ -53,7 +53,7 @@
<img src="d_rgb.png" alt="d.rgb example" border="0">
<br>
-<i>Figure: map displayed from previous example.</i>
+<i>Figure: Visual color composite of a LANDSAT scene (North Carolina sample dataset)</i>
</div>
<h2>SEE ALSO</h2>
