[GRASS-SVN] r71971 - grass/branches/releasebranch_7_4/gui/wxpython/startup
svn_grass at osgeo.org
Mon Dec 25 14:50:38 PST 2017
Author: martinl
Date: 2017-12-25 14:50:38 -0800 (Mon, 25 Dec 2017)
New Revision: 71971
grass/branches/releasebranch_7_4/gui/wxpython/startup/locdownload.py
wxGUI: download dialog
* report progress
* layout cosmetics
* download sample location progress info, be less verbose + formatting issues
(merge r71759 & r71846 from trunk)
Modified: grass/branches/releasebranch_7_4/gui/wxpython/startup/locdownload.py
--- grass/branches/releasebranch_7_4/gui/wxpython/startup/locdownload.py 2017-12-25 21:19:00 UTC (rev 71970)
+++ grass/branches/releasebranch_7_4/gui/wxpython/startup/locdownload.py 2017-12-25 22:50:38 UTC (rev 71971)
@@ -22,6 +22,7 @@
import sys
import tempfile
import shutil
+import time
try:
from urllib2 import HTTPError, URLError
@@ -83,6 +84,16 @@
"""Error happened during download or when processing the file"""
pass
+class RedirectText(object):
+ def __init__(self, window):
+ self.out = window
+ def write(self, string):
+ try:
+ wx.CallAfter(self.out.SetLabel, string)
+ except:
+ # window closed -> PyDeadObjectError
+ pass
# copy from g.extension, potentially move to library
def move_extracted_files(extract_dir, target_dir, files):
@@ -155,7 +166,23 @@
extract_tar.supported_formats = ['tar.gz', 'gz', 'bz2', 'tar', 'gzip', 'targz']
+# based on https://blog.shichao.io/2012/10/04/progress_speed_indicator_for_urlretrieve_in_python.html
+def reporthook(count, block_size, total_size):
+ global start_time
+ if count == 0:
+ start_time = time.time()
+ sys.stdout.write("Download in progress ...\n0%")
+ return
+ if count % 100 != 0: # be less verbose
+ return
+ duration = time.time() - start_time
+ progress_size = int(count * block_size)
+ speed = int(progress_size / (1024 * duration))
+ percent = int(count * block_size * 100 / total_size)
+ sys.stdout.write("Download in progress ...\n{0}%, {1} MB, {2} KB/s, {3:.0f} seconds passed".format(
+ percent, progress_size / (1024 * 1024), speed, duration
# based on g.extension, potentially move to library
def download_end_extract(source):
"""Download a file (archive) from URL and uncompress it"""
@@ -163,7 +190,7 @@
directory = os.path.join(tmpdir, 'location')
if source.endswith('.zip'):
archive_name = os.path.join(tmpdir, 'location.zip')
- filename, headers = urlretrieve(source, archive_name)
+ filename, headers = urlretrieve(source, archive_name, reporthook)
if headers.get('content-type', '') != 'application/zip':
raise DownloadError(
_("Download of <{url}> failed"
@@ -177,7 +204,7 @@
else:
ext = source.rsplit('.', 1)[1]
archive_name = os.path.join(tmpdir, 'extension.' + ext)
- urlretrieve(source, archive_name)
+ urlretrieve(source, archive_name, reporthook)
# TODO: error handling for urlretrieve
extract_tar(name=archive_name, directory=directory, tmpdir=tmpdir)
else:
@@ -258,7 +285,7 @@
self.label = wx.StaticText(
parent=self,
- label=_("Select from sample location at grass.osgeo.org"))
+ label=_("Select sample location to download:"))
choices = []
for item in self.locations:
@@ -276,7 +303,8 @@
# TODO: messages copied from gis_set.py, need this as API?
self.message = wx.StaticText(parent=self, size=(-1, 50))
+ sys.stdout = RedirectText(self.message)
# It is not clear if all wx versions supports color, so try-except.
# The color itself may not be correct for all platforms/system settings
# but in http://xoomer.virgilio.it/infinity77/wxPython/Widgets/wx.SystemSettings.html
@@ -300,16 +328,16 @@
self.sizer = vertical
vertical.Add(self.label, proportion=0,
- flag=wx.EXPAND | wx.ALL, border=10)
+ flag=wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT, border=10)
vertical.Add(self.choice, proportion=0,
button_sizer = wx.BoxSizer(wx.HORIZONTAL)
button_sizer.AddStretchSpacer()
button_sizer.Add(self.download_button, proportion=0)
vertical.Add(button_sizer, proportion=0,
+ flag=wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT | wx.ALIGN_RIGHT, border=10)
vertical.AddStretchSpacer()
vertical.Add(self.message, proportion=0,
flag=wx.ALIGN_CENTER_VERTICAL |
@@ -350,7 +378,7 @@
self._warning(_("Download completed"))
self._download_in_progress = True
- self._warning(_("Download in progress"))
+ self._warning(_("Download in progress..."))
self.thread.Run(callable=download_location,
url=url, name=dirname, database=self.database,
ondone=download_complete_callback)
@@ -427,16 +455,18 @@
wx.Dialog.__init__(self, parent=parent, title=title)
self.panel = LocationDownloadPanel(parent=self, database=database)
close_button = Button(self, id=wx.ID_CLOSE)
+ # TODO: terminate download process
close_button.Bind(wx.EVT_BUTTON, lambda event: self.Close())
sizer = wx.BoxSizer(wx.VERTICAL)
- sizer.Add(self.panel)
+ sizer.Add(self.panel, proportion=1, flag=wx.EXPAND)
button_sizer = wx.StdDialogButtonSizer()
- button_sizer.Add(close_button, flag=wx.EXPAND)
+ button_sizer.Add(close_button)
button_sizer.Realize()
- sizer.Add(button_sizer, flag=wx.EXPAND | wx.ALL, border=10)
+ sizer.Add(button_sizer, proportion=0,
+ flag=wx.ALIGN_RIGHT | wx.BOTTOM, border=10)
self.SetSizer(sizer)
sizer.Fit(self)
