[GRASS-SVN] r71974 - grass/branches/releasebranch_7_4/gui/wxpython/startup
svn_grass at osgeo.org
Tue Dec 26 04:17:25 PST 2017
Author: martinl
Date: 2017-12-26 04:17:25 -0800 (Tue, 26 Dec 2017)
New Revision: 71974
grass/branches/releasebranch_7_4/gui/wxpython/startup/locdownload.py
wxGUI:downloc: note user that must wait until download process is finished
(merge r71973 from trunk)
Modified: grass/branches/releasebranch_7_4/gui/wxpython/startup/locdownload.py
--- grass/branches/releasebranch_7_4/gui/wxpython/startup/locdownload.py 2017-12-26 12:10:00 UTC (rev 71973)
+++ grass/branches/releasebranch_7_4/gui/wxpython/startup/locdownload.py 2017-12-26 12:17:25 UTC (rev 71974)
@@ -175,7 +175,7 @@
global start_time
if count == 0:
start_time = time.time()
- sys.stdout.write("Download in progress ...\n0%")
+ sys.stdout.write("Download in progress, wait until it is finished\n0%")
return
if count % 100 != 0: # be less verbose
return
@@ -183,7 +183,7 @@
progress_size = int(count * block_size)
speed = int(progress_size / (1024 * duration))
percent = int(count * block_size * 100 / total_size)
- sys.stdout.write("Download in progress ...\n{0}%, {1} MB, {2} KB/s, {3:.0f} seconds passed".format(
+ sys.stdout.write("Download in progress, wait until it is finished\n{0}%, {1} MB, {2} KB/s, {3:.0f} seconds passed".format(
percent, progress_size / (1024 * 1024), speed, duration
@@ -191,6 +191,7 @@
def download_end_extract(source):
"""Download a file (archive) from URL and uncompress it"""
tmpdir = tempfile.mkdtemp()
+ Debug.msg(1, 'Tmpdir: {}'.format(tmpdir))
directory = os.path.join(tmpdir, 'location')
if source.endswith('.zip'):
archive_name = os.path.join(tmpdir, 'location.zip')
@@ -308,7 +309,7 @@
# TODO: messages copied from gis_set.py, need this as API?
self.message = wx.StaticText(parent=self, size=(-1, 50))
sys.stdout = RedirectText(self.message)
# It is not clear if all wx versions supports color, so try-except.
# The color itself may not be correct for all platforms/system settings
# but in http://xoomer.virgilio.it/infinity77/wxPython/Widgets/wx.SystemSettings.html
@@ -382,7 +383,7 @@
self._warning(_("Download completed"))
self._download_in_progress = True
- self._warning(_("Download in progress..."))
+ self._warning(_("Download in progress, wait until it is finished"))
self.thread.Run(callable=download_location,
url=url, name=dirname, database=self.database,
ondone=download_complete_callback)
