[GRASS-SVN] r71985 - grass-addons/grass7/raster/r.learn.ml
Wed Dec 27 22:19:41 PST 2017
Author: spawley
Date: 2017-12-27 22:19:41 -0800 (Wed, 27 Dec 2017)
New Revision: 71985
Removed:
   grass-addons/grass7/raster/r.learn.ml/rlearn_rasters.py
r.learn.ml deleted file rlearn_rasters.py
Deleted: grass-addons/grass7/raster/r.learn.ml/rlearn_rasters.py
--- grass-addons/grass7/raster/r.learn.ml/rlearn_rasters.py	2017-12-28 06:16:47 UTC (rev 71984)
+++ grass-addons/grass7/raster/r.learn.ml/rlearn_rasters.py	2017-12-28 06:19:41 UTC (rev 71985)
@@ -1,486 +0,0 @@
-#!/usr/bin/env python
-# -- coding: utf-8 --
-The module rlearn_rasters contains functions to
-extract training data from GRASS rasters.
-from __future__ import absolute_import
-import numpy as np
-import tempfile
-import grass.script as gscript
-from grass.pygrass.raster import RasterRow
-from grass.pygrass.gis.region import Region
-from grass.pygrass.raster.buffer import Buffer
-from grass.pygrass.vector import VectorTopo
-from grass.pygrass.utils import get_raster_for_points, pixel2coor
-def extract(response, predictors, lowmem=False):
-    Samples a list of GRASS rasters using a labelled raster
-    Per raster sampling
-    Args
-    response: String; GRASS raster with labelled pixels
-    predictors: List of GRASS rasters containing explanatory variables
-    lowmem: Boolean, use numpy memmap to query predictors
-    Returns
-    training_data: Numpy array of extracted raster values
-    training_labels: Numpy array of labels
-    is_train: Row and Columns of label positions
-    current = Region()
-    # open response raster as rasterrow and read as np array
-    if RasterRow(response).exist() is True:
-        roi_gr = RasterRow(response)
-        roi_gr.open('r')
-        if lowmem is False:
-            response_np = np.array(roi_gr)
-        else:
-            response_np = np.memmap(
-                tempfile.NamedTemporaryFile(),
-                dtype='float32', mode='w+',
-                shape=(current.rows, current.cols))
-            response_np[:] = np.array(roi_gr)[:]
-    else:
-        gscript.fatal("GRASS response raster does not exist.... exiting")
-    # determine number of predictor rasters
-    n_features = len(predictors)
-    # check to see if all predictors exist
-    for i in range(n_features):
-        if RasterRow(predictors[i]).exist() is not True:
-            gscript.fatal("GRASS raster " + predictors[i] +
-                          " does not exist.... exiting")
-    # check if any of those pixels are labelled (not equal to nodata)
-    # can use even if roi is FCELL because nodata will be nan
-    is_train = np.nonzero(response_np > -2147483648)
-    training_labels = response_np[is_train]
-    n_labels = np.array(is_train).shape[1]
-    # Create a zero numpy array of len training labels
-        training_data = np.zeros((n_labels, n_features))
-    else:
-        training_data = np.memmap(tempfile.NamedTemporaryFile(),
-                                  shape=(n_labels, n_features))
-    # Loop through each raster and sample pixel values at training indexes
-    if lowmem is True:
-        feature_np = np.memmap(tempfile.NamedTemporaryFile(),
-    for f in range(n_features):
-        predictor_gr = RasterRow(predictors[f])
-        predictor_gr.open('r')
-            feature_np = np.array(predictor_gr)
-        else:
-            feature_np[:] = np.array(predictor_gr)[:]
-        training_data[0:n_labels, f] = feature_np[is_train]
-        # close each predictor map
-        predictor_gr.close()
-    # convert any CELL maps no datavals to NaN in the training data
-        training_data[training_data[:, i] == -2147483648] = np.nan
-    # convert indexes of training pixels from tuple to n*2 np array
-    is_train = np.array(is_train).T
-    for i in range(is_train.shape[0]):
-        is_train[i, :] = np.array(pixel2coor(tuple(is_train[i]), current))
-    # close the response map
-    roi_gr.close()
-    return(training_data, training_labels, is_train)
-def extract_points(gvector, grasters, field):
-    Extract values from grass rasters using vector points input
-    Args
-    gvector: character, name of grass points vector
-    grasters: list of names of grass raster to query
-    field: character, name of field in table to use as response variable
-    Returns
-    X: 2D numpy array of training data
-    y: 1D numpy array with the response variable
-    coordinates: 2D numpy array of sample coordinates
-    # open grass vector
-    points = VectorTopo(gvector.split('@')[0])
-    points.open('r')
-    # create link to attribute table
-    points.dblinks.by_name(name=gvector)
-    # extract table field to numpy array
-    table = points.table
-    cur = table.execute("SELECT {field} FROM {name}".format(field=field, name=table.name))
-    y = np.array([np.isnan if c is None else c[0] for c in cur])
-    # extract raster data
-    X = np.zeros((points.num_primitives()['point'], len(grasters)), dtype=float)
-    for i, raster in enumerate(grasters):
-        rio = RasterRow(raster)
-        values = np.asarray(get_raster_for_points(points, rio))
-        coordinates = values[:, 1:3]
-        X[:, i] = values[:, 3]
-        rio.close()
-    # set any grass integer nodata values to NaN
-    X[X == -2147483648] = np.nan
-    # remove missing response data
-    X = X[~np.isnan(y)]
-    coordinates = coordinates[~np.isnan(y)]
-    y = y[~np.isnan(y)]
-    # close
-    points.close()
-    return(X, y, coordinates)
-def predict(estimator, predictors, output, predict_type='raw',
-            index=None, rowincr=25, n_jobs=-2):
-    Prediction on list of GRASS rasters using a fitted scikit learn model
-    Args
-    estimator: scikit-learn estimator object
-    predictors: list of GRASS rasters
-    output: Name of GRASS raster to output classification results
-    predict_type: character, 'raw' for classification/regression;
-                  'prob' for class probabilities
-    index: Optional, list of class indices to export
-    rowincr: Integer of raster rows to process at one time
-    n_jobs: Number of processing cores
-    from sklearn.externals.joblib import Parallel, delayed
-    # convert potential single index to list
-    if isinstance(index, int): index = [index]
-    # open predictors as list of rasterrow objects
-    # turn off multiprocessing for multi-threaded classifiers
-    # first unwrap the estimator from any potential pipelines or gridsearchCV
-    if type(estimator).__name__ == 'Pipeline':
-        clf_type = estimator.named_steps['classifier']
-    else:
-    if type(clf_type).__name__ == 'GridSearchCV' or \
-        type(clf_type).__name__ == 'RandomizedSearchCV':
-        clf_type = clf_type.best_estimator_
-    # check name against already multithreaded classifiers
-    if n_jobs == 1 or type(clf_type).__name__ in ['RandomForestClassifier',
-                                                  'RandomForestRegressor',
-                                                  'ExtraTreesClassifier',
-                                                  'ExtraTreesRegressor',
-                                                  'KNeighborsClassifier',
-                                                  'XGBClassifier',
-                                                  'XGBRegressor']:
-        # sequential prediction
-        rasstack = [0] * n_features
-            rasstack[i] = RasterRow(predictors[i])
-            if rasstack[i].exist() is True:
-                rasstack[i].open('r')
-            else:
-        # Prediction using blocks of rows per iteration
-        for rowblock in range(0, current.rows, rowincr):
-            gscript.percent(rowblock, current.rows, rowincr)
-            # check that the row increment does not exceed the number of rows
-            if rowblock+rowincr > current.rows:
-                rowincr = current.rows - rowblock
-            img_np_row = np.zeros((rowincr, current.cols, n_features))
-            # loop through each row, and each band and add to 2D img_np_row
-            for row in range(rowblock, rowblock+rowincr, 1):
-                for band in range(n_features):
-                    img_np_row[row-rowblock, :, band] = \
-                        np.array(rasstack[band][row])
-            # create mask
-            img_np_row[img_np_row == -2147483648] = np.nan
-            mask = np.zeros((img_np_row.shape[0], img_np_row.shape[1]))
-            for feature in range(n_features):
-                invalid_indexes = np.nonzero(np.isnan(img_np_row[:, :, feature]))
-                mask[invalid_indexes] = np.nan
-            # reshape each row-band matrix into a n*m array
-            nsamples = rowincr * current.cols
-            flat_pixels = img_np_row.reshape((nsamples, n_features))
-            # remove NaNs prior to passing to scikit-learn predict
-            flat_pixels = np.nan_to_num(flat_pixels)
-            # perform prediction for classification/regression
-            if predict_type == 'raw':
-                result = estimator.predict(flat_pixels)
-                result = result.reshape((rowincr, current.cols))
-                # determine nodata value and grass raster type
-                if result.dtype == 'float':
-                    nodata = np.nan
-                    ftype = 'FCELL'
-                else:
-                    nodata = -2147483648
-                    ftype = 'CELL'
-                # replace NaN values so that the prediction does not have a border
-                result[np.nonzero(np.isnan(mask))] = nodata
-                # on first iteration create the RasterRow object
-                if rowblock == 0:
-                        classification = RasterRow(output)
-                        classification.open('w', ftype, overwrite=True)
-                # write the classification result
-                for row in range(rowincr):
-                    newrow = Buffer((result.shape[1],), mtype=ftype)
-                    newrow[:] = result[row, :]
-                    classification.put_row(newrow)
-            # perform prediction for class probabilities
-            if predict_type == 'prob':
-                result_proba = estimator.predict_proba(flat_pixels)
-                # on first loop determine number of probability classes
-                # and open rasterrow objects for writing
-                if rowblock == 0:
-                    if index is None:
-                        index = range(result_proba.shape[1])
-                        n_classes = len(index)
-                    else:
-                        n_classes = len(np.unique(index))
-                    # create and open RasterRow objects for probabilities
-                    prob_out_raster = [0] * n_classes
-                    prob = [0] * n_classes
-                    for iclass, label in enumerate(index):
-                        prob_out_raster[iclass] = output + '_classPr' + str(label)
-                        prob[iclass] = RasterRow(prob_out_raster[iclass])
-                        prob[iclass].open('w', 'FCELL', overwrite=True)
-                    result_proba_class = result_proba[:, label]
-                    result_proba_class = result_proba_class.reshape((rowincr, current.cols))
-                    result_proba_class[np.nonzero(np.isnan(mask))] = np.nan
-                        newrow = Buffer((result_proba_class.shape[1],), mtype='FCELL')
-                        newrow[:] = result_proba_class[row, :]
-                        prob[iclass].put_row(newrow)
-        # close maps
-            rasstack[i].close()
-    else:
-        # parallel prediction
-        # create lists of row increments
-        row_mins, row_maxs = [], []
-        for row in range(0, current.rows, rowincr):
-            if row+rowincr > current.rows:
-            row_mins.append(row)
-            row_maxs.append(row+rowincr)
-        # perform predictions on lists of row increments in parallel
-        predictions = Parallel(n_jobs=n_jobs, max_nbytes=None)(
-            delayed(__predict_parallel)
-            (estimator, predictors, predict_type, current, row_min, row_max)
-            for row_min, row_max in zip(row_mins, row_maxs))
-        # unpack the results
-        results = []
-        ftypes = []
-        for block in predictions:
-            results.append(block[0])
-            ftypes.append(block[1])
-        #  writing of predicted results for classification
-            classification.open('w', ftypes[0], overwrite=True)
-            for result_block in results:
-                for row in range(result_block.shape[0]):
-                    newrow = Buffer((result_block.shape[1],), mtype=ftypes[0])
-                    newrow[:] = result_block[row, :]
-        # writing of predicted results for probabilities
-            # determine number of classes
-            if index is None:
-                index = range(results[0].shape[2])
-            else:
-            # write the class probability results
-            for results_proba_block in results:
-                    result_proba_class = results_proba_block[:, :, label]
-                    for row in range(result_proba_class.shape[0]):
-    # close all maps
-    if predict_type == 'raw': classification.close()
-        try:
-            for iclass in range(n_classes):
-                prob[iclass].close()
-        except:
-            pass
-def __predict_parallel(estimator, predictors, predict_type, current, row_min, row_max):
-    Performs prediction on range of rows in grass rasters
-    Args
-    current: current region settings
-    row_min, row_max: Range of rows of grass rasters to perform predictions
-    Returns
-    result: 2D (classification) or 3D numpy array (class probabilities) of predictions
-    ftypes: data storage type
-    # initialize output
-    result, ftype, mask = None, None, None
-    # open grass rasters
-        else:
-    img_np_row = np.zeros((row_max-row_min, current.cols, n_features))
-    for row in range(row_min, row_max):
-            img_np_row[row-row_min, :, band] = np.array(rasstack[band][row])
-    # create mask
-    nsamples = (row_max-row_min) * current.cols
-        result = result.reshape((row_max-row_min, current.cols))
-            nodata = np.nan
-            ftype = 'FCELL'
-        else:
-            ftype = 'CELL'
-        result = estimator.predict_proba(flat_pixels)
-        result = result.reshape((row_max-row_min, current.cols, result.shape[1]))
-        result[np.nonzero(np.isnan(mask))] = np.nan
-    # close maps
-    return (result, ftype)
