[GRASS-SVN] r71989 - grass-addons/grass7/raster/r.learn.ml
    svn_grass at osgeo.org
    Wed Dec 27 22:38:22 PST 2017
Author: spawley
Date: 2017-12-27 22:38:22 -0800 (Wed, 27 Dec 2017)
New Revision: 71989
Removed:
   grass-addons/grass7/raster/r.learn.ml/rlearn_prediction.py
   grass-addons/grass7/raster/r.learn.ml/rlearn_sampling.py
   grass-addons/grass7/raster/r.learn.ml/rlearn_utils.py
r.learn.ml grouped functions into single file
Deleted: grass-addons/grass7/raster/r.learn.ml/rlearn_prediction.py
--- grass-addons/grass7/raster/r.learn.ml/rlearn_prediction.py	2017-12-28 06:36:50 UTC (rev 71988)
+++ grass-addons/grass7/raster/r.learn.ml/rlearn_prediction.py	2017-12-28 06:38:22 UTC (rev 71989)
@@ -1,195 +0,0 @@
-#!/usr/bin/env python
-# -- coding: utf-8 --
-The module rlearn_prediction contains functions to
-perform predictions on GRASS rasters
-from __future__ import absolute_import
-import numpy as np
-import grass.script as gs
-from grass.pygrass.gis.region import Region
-def predict(estimator, predictors, output, predict_type='raw', index=None,
-            class_labels=None, overwrite=False, rowincr=25, n_jobs=-2):
-    Prediction on list of GRASS rasters using a fitted scikit learn model
-    Args
-    estimator (object): scikit-learn estimator object
-    predictors (list): Names of GRASS rasters
-    output (string): Name of GRASS raster to output classification results
-    predict_type (string): 'raw' for classification/regression;
-        'prob' for class probabilities
-    index (list): Optional, list of class indices to export
-    class_labels (1d numpy array): Optional, class labels
-    overwrite (boolean): enable overwriting of existing raster
-    n_jobs (integer): Number of processing cores;
-        -1 for all cores; -2 for all cores-1
-    from sklearn.externals.joblib import Parallel, delayed
-    from grass.pygrass.raster import numpy2raster
-    # TODO
-    # better memory efficiency and use of memmap for parallel
-    # processing
-    #from sklearn.externals.joblib.pool import has_shareable_memory
-    # first unwrap the estimator from any potential pipelines or gridsearchCV
-    if type(estimator).__name__ == 'Pipeline':
-       clf_type = estimator.named_steps['classifier']
-    else:
-    if type(clf_type).__name__ == 'GridSearchCV' or \
-    type(clf_type).__name__ == 'RandomizedSearchCV':
-        clf_type = clf_type.best_estimator_
-    # check name against already multithreaded classifiers
-    if type(clf_type).__name__ in [
-       'RandomForestClassifier',
-        'RandomForestRegressor',
-        'ExtraTreesClassifier',
-        'ExtraTreesRegressor',
-        'KNeighborsClassifier']:
-       n_jobs = 1
-    # convert potential single index to list
-    if isinstance(index, int): index = [index]
-    # open predictors as list of rasterrow objects
-    current = Region()
-    # create lists of row increments
-    row_mins, row_maxs = [], []
-    for row in range(0, current.rows, rowincr):
-        if row+rowincr > current.rows:
-            rowincr = current.rows - row
-        row_mins.append(row)
-        row_maxs.append(row+rowincr)
-    # perform predictions on lists of row increments in parallel
-    prediction = Parallel(n_jobs=n_jobs, max_nbytes=None)(
-        delayed(__predict_parallel2)
-        (estimator, predictors, predict_type, current, row_min, row_max)
-        for row_min, row_max in zip(row_mins, row_maxs))
-    prediction = np.vstack(prediction)
-    # determine raster dtype
-    if prediction.dtype == 'float':
-        ftype = 'FCELL'
-    else:
-        ftype = 'CELL'
-    #  writing of predicted results for classification
-    if predict_type == 'raw':
-        numpy2raster(array=prediction, mtype=ftype, rastname=output,
-                     overwrite=True)
-    # writing of predicted results for probabilities
-    if predict_type == 'prob':
-        # use class labels if supplied
-        # else output predictions as 0,1,2...n
-        if class_labels is None:
-            class_labels = range(prediction.shape[2])
-        # output all class probabilities if subset is not specified
-        if index is None:
-            index = class_labels
-        # select indexes of predictions 3d numpy array to be exported to rasters
-        selected_prediction_indexes = [i for i, x in enumerate(class_labels) if x in index]
-        # write each 3d of numpy array as a probability raster
-        for pred_index, label in zip(selected_prediction_indexes, index):
-            rastername = output + '_' + str(label)
-            numpy2raster(array=prediction[:, :, pred_index], mtype='FCELL',
-                         rastname=rastername, overwrite=overwrite)
-def __predict_parallel2(estimator, predictors, predict_type, current, row_min, row_max):
-    Performs prediction on range of rows in grass rasters
-    Args
-    estimator: scikit-learn estimator object
-    predictors: list of GRASS rasters
-    predict_type: character, 'raw' for classification/regression;
-    current: current region settings
-    row_min, row_max: Range of rows of grass rasters to perform predictions
-    Returns
-    result: 2D (classification) or 3D numpy array (class probabilities) of predictions
-    ftypes: data storage type
-    from grass.pygrass.raster import RasterRow
-    # initialize output
-    result, mask = None, None
-    # open grass rasters
-    n_features = len(predictors)
-    rasstack = [0] * n_features
-    for i in range(n_features):
-        rasstack[i] = RasterRow(predictors[i])
-        if rasstack[i].exist() is True:
-            rasstack[i].open('r')
-        else:
-            gs.fatal("GRASS raster " + predictors[i] +
-                     " does not exist.... exiting")
-    # loop through each row, and each band and add to 2D img_np_row
-    img_np_row = np.zeros((row_max-row_min, current.cols, n_features))
-    for row in range(row_min, row_max):
-        for band in range(n_features):
-            img_np_row[row-row_min, :, band] = np.array(rasstack[band][row])
-    # create mask
-    img_np_row[img_np_row == -2147483648] = np.nan
-    mask = np.zeros((img_np_row.shape[0], img_np_row.shape[1]))
-    for feature in range(n_features):
-        invalid_indexes = np.nonzero(np.isnan(img_np_row[:, :, feature]))
-        mask[invalid_indexes] = np.nan
-    # reshape each row-band matrix into a n*m array
-    nsamples = (row_max-row_min) * current.cols
-    flat_pixels = img_np_row.reshape((nsamples, n_features))
-    # remove NaNs prior to passing to scikit-learn predict
-    flat_pixels = np.nan_to_num(flat_pixels)
-    # perform prediction for classification/regression
-        result = estimator.predict(flat_pixels)
-        result = result.reshape((row_max-row_min, current.cols))
-        # determine nodata value and grass raster type
-        if result.dtype == 'float':
-            nodata = np.nan
-        else:
-            nodata = -2147483648
-        # replace NaN values so that the prediction does not have a border
-        result[np.nonzero(np.isnan(mask))] = nodata
-    # perform prediction for class probabilities
-        result = estimator.predict_proba(flat_pixels)
-        result = result.reshape((row_max-row_min, current.cols, result.shape[1]))
-        result[np.nonzero(np.isnan(mask))] = np.nan
-    # close maps
-        rasstack[i].close()
-    return result
Deleted: grass-addons/grass7/raster/r.learn.ml/rlearn_sampling.py
--- grass-addons/grass7/raster/r.learn.ml/rlearn_sampling.py	2017-12-28 06:36:50 UTC (rev 71988)
+++ grass-addons/grass7/raster/r.learn.ml/rlearn_sampling.py	2017-12-28 06:38:22 UTC (rev 71989)
@@ -1,192 +0,0 @@
-The module rlearn_sampling contains functions to
-extract training data from GRASS rasters.
-import numpy as np
-import tempfile
-def extract_pixels(response, predictors, lowmem=False, na_rm=False):
-    Samples a list of GRASS rasters using a labelled raster
-    Per raster sampling
-    Args
-    response (string): Name of GRASS raster with labelled pixels
-    predictors (list): List of GRASS raster names containing explanatory variables
-    lowmem (boolean): Use numpy memmap to query predictors
-    na_rm (boolean): Remove samples containing NaNs
-    Returns
-    training_data (2d numpy array): Extracted raster values
-    training_labels (1d numpy array): Numpy array of labels
-    is_train (2d numpy array): Row and Columns of label positions
-    from grass.pygrass.utils import pixel2coor
-    # open response raster as rasterrow and read as np array
-    if RasterRow(response).exist() is True:
-        roi_gr = RasterRow(response)
-        roi_gr.open('r')
-        if lowmem is False:
-            response_np = np.array(roi_gr)
-        else:
-            response_np = np.memmap(
-                tempfile.NamedTemporaryFile(),
-                dtype='float32', mode='w+',
-                shape=(current.rows, current.cols))
-            response_np[:] = np.array(roi_gr)[:]
-    else:
-        gs.fatal("GRASS response raster does not exist.... exiting")
-    # determine number of predictor rasters
-    # check to see if all predictors exist
-        if RasterRow(predictors[i]).exist() is not True:
-    # check if any of those pixels are labelled (not equal to nodata)
-    # can use even if roi is FCELL because nodata will be nan
-    is_train = np.nonzero(response_np > -2147483648)
-    training_labels = response_np[is_train]
-    n_labels = np.array(is_train).shape[1]
-    # Create a zero numpy array of len training labels
-        training_data = np.zeros((n_labels, n_features))
-    else:
-        training_data = np.memmap(tempfile.NamedTemporaryFile(),
-                                  shape=(n_labels, n_features))
-    # Loop through each raster and sample pixel values at training indexes
-    if lowmem is True:
-        feature_np = np.memmap(tempfile.NamedTemporaryFile(),
-    for f in range(n_features):
-        predictor_gr = RasterRow(predictors[f])
-        predictor_gr.open('r')
-            feature_np = np.array(predictor_gr)
-        else:
-            feature_np[:] = np.array(predictor_gr)[:]
-        training_data[0:n_labels, f] = feature_np[is_train]
-        # close each predictor map
-        predictor_gr.close()
-    # convert any CELL maps no datavals to NaN in the training data
-        training_data[training_data[:, i] == -2147483648] = np.nan
-    # convert indexes of training pixels from tuple to n*2 np array
-    is_train = np.array(is_train).T
-    for i in range(is_train.shape[0]):
-        is_train[i, :] = np.array(pixel2coor(tuple(is_train[i]), current))
-    # close the response map
-    roi_gr.close()
-    # remove samples containing NaNs
-    if na_rm is True:
-        if np.isnan(training_data).any() == True:
-            gs.message('Removing samples with NaN values in the raster feature variables...')
-        training_labels = training_labels[~np.isnan(training_data).any(axis=1)]
-        is_train = is_train[~np.isnan(training_data).any(axis=1)]
-        training_data = training_data[~np.isnan(training_data).any(axis=1)]
-    return(training_data, training_labels, is_train)
-def extract_points(gvector, grasters, field, na_rm=False):
-    Extract values from grass rasters using vector points input
-    Args
-    gvector (string): Name of grass points vector
-    grasters (list): Names of grass raster to query
-    field (string): Name of field in table to use as response variable
-    Returns
-    X (2d numpy array): Training data
-    y (1d numpy array): Array with the response variable
-    coordinates (2d numpy array): Sample coordinates
-    from grass.pygrass.vector import VectorTopo
-    from grass.pygrass.utils import get_raster_for_points
-    # open grass vector
-    points = VectorTopo(gvector.split('@')[0])
-    points.open('r')
-    # create link to attribute table
-    points.dblinks.by_name(name=gvector)
-    # extract table field to numpy array
-    table = points.table
-    cur = table.execute("SELECT {field} FROM {name}".format(field=field, name=table.name))
-    y = np.array([np.isnan if c is None else c[0] for c in cur])
-    y = np.array(y, dtype='float')
-    # extract raster data
-    X = np.zeros((points.num_primitives()['point'], len(grasters)), dtype=float)
-    for i, raster in enumerate(grasters):
-        rio = RasterRow(raster)
-        if rio.exist() is False:
-            gs.fatal('Raster {x} does not exist....'.format(x=raster))
-        values = np.asarray(get_raster_for_points(points, rio))
-        coordinates = values[:, 1:3]
-        X[:, i] = values[:, 3]
-        rio.close()
-    # set any grass integer nodata values to NaN
-    X[X == -2147483648] = np.nan
-    # remove missing response data
-    X = X[~np.isnan(y)]
-    coordinates = coordinates[~np.isnan(y)]
-    y = y[~np.isnan(y)]
-    # int type if classes represented integers
-    if all(y % 1 == 0) is True:
-        y = np.asarray(y, dtype='int')
-    # close
-    points.close()
-    if na_rm is True:
-        if np.isnan(X).any() == True:
-        y = y[~np.isnan(X).any(axis=1)]
-        coordinates = coordinates[~np.isnan(X).any(axis=1)]
-        X = X[~np.isnan(X).any(axis=1)]
-    return(X, y, coordinates)
Deleted: grass-addons/grass7/raster/r.learn.ml/rlearn_utils.py
--- grass-addons/grass7/raster/r.learn.ml/rlearn_utils.py	2017-12-28 06:36:50 UTC (rev 71988)
+++ grass-addons/grass7/raster/r.learn.ml/rlearn_utils.py	2017-12-28 06:38:22 UTC (rev 71989)
@@ -1,273 +0,0 @@
-The module rlearn_utils contains functinons to assist
-with passing pre-defined scikit learn classifiers
-and other utilities for loading/saving training data.
-from subprocess import PIPE
-import numpy as np
-import os
-from grass.pygrass.modules.shortcuts import imagery as im
-def model_classifiers(estimator, random_state, n_jobs, p, weights=None):
-    Provides the classifiers and parameters using by the module
-    Args
-    estimator (string): Name of scikit learn estimator
-    random_state (float): Seed to use in randomized components
-    n_jobs (integer): Number of processing cores to use;
-    p (dict): Classifier setttings (keys) and values
-    weights (string): None, or 'balanced' to add class_weights
-    Returns
-    clf (object): Scikit-learn classifier object
-    mode (string): Flag to indicate whether classifier performs classification
-        or regression
-    from sklearn.linear_model import LogisticRegression
-    from sklearn.discriminant_analysis import LinearDiscriminantAnalysis
-    from sklearn.discriminant_analysis import QuadraticDiscriminantAnalysis
-    from sklearn.naive_bayes import GaussianNB
-    from sklearn.tree import DecisionTreeClassifier, DecisionTreeRegressor
-    from sklearn.ensemble import (
-        RandomForestClassifier, RandomForestRegressor, ExtraTreesClassifier,
-        ExtraTreesRegressor)
-    from sklearn.ensemble import GradientBoostingClassifier, GradientBoostingRegressor
-    from sklearn.svm import SVC
-    from sklearn.neighbors import KNeighborsClassifier
-    # convert balanced boolean to scikit learn method
-    if weights is True:
-        weights = 'balanced'
-    else: weights = None
-    # optional packages that add additional classifiers here
-    if estimator == 'EarthClassifier' or estimator == 'EarthRegressor':
-        try:
-            from sklearn.pipeline import Pipeline
-            from pyearth import Earth
-            earth_classifier = Pipeline(
-                [('classifier', Earth(max_degree=p['max_degree'])),
-                 ('Logistic', LogisticRegression(n_jobs=n_jobs))])
-            classifiers = {
-                'EarthClassifier': earth_classifier,
-                'EarthRegressor': Earth(max_degree=p['max_degree'])
-        except:
-            gs.fatal('Py-earth package not installed')
-    else:
-        # core sklearn classifiers go here
-        classifiers = {
-            'SVC': SVC(C=p['C'],
-                       class_weight=weights,
-                       probability=True,
-                       random_state=random_state),
-            'LogisticRegression':
-                LogisticRegression(C=p['C'],
-                                   solver='liblinear',
-                                   random_state=random_state,
-                                   n_jobs=n_jobs,
-                                   fit_intercept=True),
-            'DecisionTreeClassifier':
-                DecisionTreeClassifier(max_depth=p['max_depth'],
-                                       max_features=p['max_features'],
-                                       min_samples_split=p['min_samples_split'],
-                                       min_samples_leaf=p['min_samples_leaf'],
-            'DecisionTreeRegressor':
-                DecisionTreeRegressor(max_features=p['max_features'],
-            'RandomForestClassifier':
-                RandomForestClassifier(n_estimators=p['n_estimators'],
-                                       n_jobs=n_jobs,
-                                       oob_score=False),
-            'RandomForestRegressor':
-                RandomForestRegressor(n_estimators=p['n_estimators'],
-                                      n_jobs=n_jobs,
-                                      oob_score=False),
-            'ExtraTreesClassifier':
-                ExtraTreesClassifier(n_estimators=p['n_estimators'],
-                                     n_jobs=n_jobs,
-                                     oob_score=False),
-            'ExtraTreesRegressor':
-                ExtraTreesRegressor(n_estimators=p['n_estimators'],
-                                    n_jobs=n_jobs,
-                                    oob_score=False),
-            'GradientBoostingClassifier':
-                GradientBoostingClassifier(learning_rate=p['learning_rate'],
-                                           n_estimators=p['n_estimators'],
-                                           max_depth=p['max_depth'],
-                                           subsample=p['subsample'],
-            'GradientBoostingRegressor':
-                GradientBoostingRegressor(learning_rate=p['learning_rate'],
-            'GaussianNB': GaussianNB(),
-            'LinearDiscriminantAnalysis': LinearDiscriminantAnalysis(),
-            'QuadraticDiscriminantAnalysis': QuadraticDiscriminantAnalysis(),
-            'KNeighborsClassifier': KNeighborsClassifier(n_neighbors=p['n_neighbors'],
-                                                         weights=p['weights'],
-                                                         n_jobs=n_jobs)
-    # define classifier
-    clf = classifiers[estimator]
-    # classification or regression
-    if estimator == 'LogisticRegression' \
-        or estimator == 'DecisionTreeClassifier' \
-        or estimator == 'RandomForestClassifier' \
-        or estimator == 'ExtraTreesClassifier' \
-        or estimator == 'GradientBoostingClassifier' \
-        or estimator == 'GaussianNB' \
-        or estimator == 'LinearDiscriminantAnalysis' \
-        or estimator == 'QuadraticDiscriminantAnalysis' \
-        or estimator == 'EarthClassifier' \
-        or estimator == 'SVC' \
-        or estimator == 'KNeighborsClassifier':
-        mode = 'classification'
-    else:
-        mode = 'regression'
-    return (clf, mode)
-def save_training_data(X, y, groups, coords, file):
-    Saves any extracted training data to a csv file
-    Args
-    X (2d numpy array): Numpy array containing predictor values
-    y (1d numpy array): Numpy array containing labels
-    groups (1d numpy array): Numpy array of group labels
-    coords (2d numpy array): Numpy array containing xy coordinates of samples
-    file (string): Path to a csv file to save data to
-    # if there are no group labels, create a nan filled array
-    if groups is None:
-        groups = np.empty((y.shape[0]))
-        groups[:] = np.nan
-    training_data = np.column_stack([coords, X, y, groups])
-    np.savetxt(file, training_data, delimiter=',')
-def load_training_data(file):
-    Loads training data and labels from a csv file
-    Args
-    Returns
-    groups (1d numpy array): Numpy array of group labels, or None
-    coords (2d numpy array): Numpy array containing x,y coordinates of samples
-    training_data = np.loadtxt(file, delimiter=',')
-    n_cols = training_data.shape[1]
-    last_Xcol = n_cols-2
-    # check to see if last column contains group labels or nans
-    groups = training_data[:, -1]
-    # if all nans then set groups to None
-    if bool(np.isnan(groups).all()) is True:
-        groups = None
-    # fetch X and y
-    coords = training_data[:, 0:2]
-    X = training_data[:, 2:last_Xcol]
-    y = training_data[:, -2]
-    return(X, y, groups, coords)
-def maps_from_group(group):
-    Parse individual rasters into a list from an imagery group
-    Args
-    group (string): Name of GRASS imagery group
-    Returns
-    maplist (list): List containing individual GRASS raster maps
-    map_names (list): List with print friendly map names
-    groupmaps = im.group(group=group, flags="g",
-                         quiet=True, stdout_=PIPE).outputs.stdout
-    maplist = groupmaps.split(os.linesep)
-    maplist = maplist[0:len(maplist)-1]
-    map_names = []
-    for rastername in maplist:
-        map_names.append(rastername.split('@')[0])
-    return(maplist, map_names)
-def save_model(estimator, X, y, sample_coords, groups, filename):
-    from sklearn.externals import joblib
-    joblib.dump((estimator, X, y, sample_coords, group_id), filename)
-def load_model(filename):
-    estimator, X, y, sample_coords, groups = joblib.load(filename)
-    return (estimator, X, y, sample_coords, groups)
\ No newline at end of file
