[GRASS-SVN] r71994 - grass/trunk/scripts/r.drain
svn_grass at osgeo.org
Fri Dec 29 00:31:22 PST 2017
Author: mmetz
Date: 2017-12-29 00:31:21 -0800 (Fri, 29 Dec 2017)
New Revision: 71994
Added:
grass/trunk/scripts/r.drain/r.drain.py
r.drain: add script
Added: grass/trunk/scripts/r.drain/r.drain.py
--- grass/trunk/scripts/r.drain/r.drain.py (rev 0)
+++ grass/trunk/scripts/r.drain/r.drain.py 2017-12-29 08:31:21 UTC (rev 71994)
@@ -0,0 +1,171 @@
+#!/usr/bin/env python
+# MODULE: r.drain
+# AUTHOR(S): Markus Metz
+# PURPOSE: Wrapper for r.path. If no input directions are provided,
+# directions are determined with r.fill.dir
+# COPYRIGHT: (C) 2017 by metz, and the GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+#%module
+#% description: Traces a flow through an elevation model or cost surface on a raster map.
+#% keyword: raster, hydrology, cost surface
+#%end
+#%option
+#% key: input
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input elevation or cost surface raster map
+#% gisprompt: old,cell,raster
+#%end
+#%option
+#% key: direction
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% label: Name of input movement direction map associated with the cost surface
+#% description: Direction in degrees CCW from east
+#% guisection: Cost surface
+#%end
+#%option
+#% key: output
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name for output raster map
+#% gisprompt: new,cell,raster
+#%end
+#%option
+#% key: drain
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% label: Name for output drain vector map
+#% description: Recommended for cost surface made using knight's move
+#% gisprompt: new,vector,vector
+#%end
+#%option
+#% key: start_coordinates
+#% type: double
+#% required: no
+#% multiple: no
+#% key_desc: east,north
+#% description: Coordinates of starting point(s) (E,N)
+#% gisprompt: old,coords,coords
+#% guisection: Start
+#%end
+#%option
+#% key: start_points
+#% type: string
+#% required: no
+#% multiple: yes
+#% key_desc: name
+#% label: Name of starting vector points map(s)
+#% gisprompt: old,vector,vector
+#%end
+#%flag
+#% key: c
+#% description: Copy input cell values on output
+#% guisection: Path settings
+#%end
+#%flag
+#% key: a
+#% description: Accumulate input values along the path
+#%end
+#%flag
+#% key: n
+#% description: Count cell numbers along the path
+#%end
+#%flag
+#% key: d
+#% description: The input raster map is a cost surface (direction surface must also be specified)
+#%end
+import os
+import sys
+import atexit
+import grass.script as grass
+def cleanup():
+ """Delete temporary direction map."""
+ if tmp_maps:
+ try:
+ grass.run_command("g.remove", flags='f', quiet=True, type='raster', name=tmp_maps)
+ except:
+ pass
+def main():
+ valmap = options['input']
+ dirmap = options['direction']
+ rpathmap = options['output']
+ vpathmap = options['drain']
+ start_coords = options['start_coordinates']
+ start_pnts = options['start_points']
+ global tmp_maps
+ tmp_maps = False
+ atexit.register(cleanup)
+ if not dirmap:
+ # get directions with r.fill.dir, without sink filling
+ dirmap = "%s_tmp_%d" % (valmap, os.getpid())
+ fill_map = "%s_fill_%d" % (valmap, os.getpid())
+ area_map = "%s_area_%d" % (valmap, os.getpid())
+ tmp_maps = dirmap + ',' + fill_map + ',' + area_map
+ print tmp_maps
+ grass.run_command("r.fill.dir", input=valmap, output=fill_map, direction=dirmap, areas=area_map, flags='f', format='grass');
+ # create args for r.path
+ kwargs = {}
+ kwargs['input'] = dirmap
+ kwargs['values'] = valmap
+ kwargs['format'] = 'degree'
+ if start_coords:
+ kwargs['start_coordinates'] = start_coords
+ if start_pnts:
+ kwargs['start_points'] = start_pnts
+ if rpathmap:
+ kwargs['raster_path'] = rpathmap
+ if vpathmap:
+ kwargs['vector_path'] = vpathmap
+ pathflags = ''
+ if flags['c']:
+ pathflags += 'c'
+ if flags['a']:
+ pathflags += 'a'
+ if flags['n']:
+ pathflags += 'n'
+ grass.run_command("r.path", flags=pathflags, **kwargs)
+ return 0
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ sys.exit(main())
