[GRASS-SVN] r71999 - grass/trunk/lib/gis
svn_grass at osgeo.org
Fri Dec 29 03:30:53 PST 2017
Author: mmetz
Date: 2017-12-29 03:30:53 -0800 (Fri, 29 Dec 2017)
New Revision: 71999
grass/trunk/lib/gis/lz4.c
grass/trunk/lib/gis/lz4.h
libgis: update lz4 to 1.8.0
Modified: grass/trunk/lib/gis/lz4.c
--- grass/trunk/lib/gis/lz4.c 2017-12-29 11:30:23 UTC (rev 71998)
+++ grass/trunk/lib/gis/lz4.c 2017-12-29 11:30:53 UTC (rev 71999)
@@ -1,6 +1,6 @@
LZ4 - Fast LZ compression algorithm
- Copyright (C) 2011-2015, Yann Collet.
+ Copyright (C) 2011-2017, Yann Collet.
BSD 2-Clause License (http://www.opensource.org/licenses/bsd-license.php)
@@ -28,20 +28,22 @@
OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
You can contact the author at :
- - LZ4 source repository : https://github.com/Cyan4973/lz4
- - LZ4 public forum : https://groups.google.com/forum/#!forum/lz4c
+ - LZ4 homepage : http://www.lz4.org
+ - LZ4 source repository : https://github.com/lz4/lz4
* Tuning parameters
- * HEAPMODE :
+ * LZ4_HEAPMODE :
* Select how default compression functions will allocate memory for their hash table,
* in memory stack (0:default, fastest), or in memory heap (1:requires malloc()).
-#define HEAPMODE 0
+#ifndef LZ4_HEAPMODE
+# define LZ4_HEAPMODE 0
+#endif
* ACCELERATION_DEFAULT :
@@ -50,9 +52,30 @@
#define ACCELERATION_DEFAULT 1
* CPU Feature Detection
+/* LZ4_FORCE_MEMORY_ACCESS
+ * By default, access to unaligned memory is controlled by `memcpy()`, which is safe and portable.
+ * Unfortunately, on some target/compiler combinations, the generated assembly is sub-optimal.
+ * The below switch allow to select different access method for improved performance.
+ * Method 0 (default) : use `memcpy()`. Safe and portable.
+ * Method 1 : `__packed` statement. It depends on compiler extension (ie, not portable).
+ * This method is safe if your compiler supports it, and *generally* as fast or faster than `memcpy`.
+ * Method 2 : direct access. This method is portable but violate C standard.
+ * It can generate buggy code on targets which assembly generation depends on alignment.
+ * But in some circumstances, it's the only known way to get the most performance (ie GCC + ARMv6)
+ * See https://fastcompression.blogspot.fr/2015/08/accessing-unaligned-memory.html for details.
+ * Prefer these methods in priority order (0 > 1 > 2)
+#ifndef LZ4_FORCE_MEMORY_ACCESS /* can be defined externally */
+# if defined(__GNUC__) && ( defined(__ARM_ARCH_6__) || defined(__ARM_ARCH_6J__) || defined(__ARM_ARCH_6K__) || defined(__ARM_ARCH_6Z__) || defined(__ARM_ARCH_6ZK__) || defined(__ARM_ARCH_6T2__) )
+# define LZ4_FORCE_MEMORY_ACCESS 2
+# elif defined(__INTEL_COMPILER) || defined(__GNUC__)
+# define LZ4_FORCE_MEMORY_ACCESS 1
+# endif
+#endif
* LZ4_FORCE_SW_BITCOUNT
* Define this parameter if your target system or compiler does not support hardware bit count
@@ -62,34 +85,39 @@
#endif
-* Includes
+* Dependency
#include "lz4.h"
+/* see also "memory routines" below */
* Compiler Options
#ifdef _MSC_VER /* Visual Studio */
-# define FORCE_INLINE static __forceinline
# include <intrin.h>
# pragma warning(disable : 4127) /* disable: C4127: conditional expression is constant */
# pragma warning(disable : 4293) /* disable: C4293: too large shift (32-bits) */
-#else
-# if defined(__STDC_VERSION__) && (__STDC_VERSION__ >= 199901L) /* C99 */
-# if defined(__GNUC__) || defined(__clang__)
-# define FORCE_INLINE static inline __attribute__((always_inline))
-# else
-# endif
-# else
-# endif /* __STDC_VERSION__ */
#endif /* _MSC_VER */
-/* LZ4_GCC_VERSION is defined into lz4.h */
-#if (LZ4_GCC_VERSION >= 302) || (__INTEL_COMPILER >= 800) || defined(__clang__)
+#ifndef FORCE_INLINE
+# ifdef _MSC_VER /* Visual Studio */
+# define FORCE_INLINE static __forceinline
+# else
+# if defined (__cplusplus) || defined (__STDC_VERSION__) && __STDC_VERSION__ >= 199901L /* C99 */
+# ifdef __GNUC__
+# define FORCE_INLINE static inline __attribute__((always_inline))
+# else
+# endif
+# else
+# endif /* __STDC_VERSION__ */
+# endif /* _MSC_VER */
+#endif /* FORCE_INLINE */
+#if (defined(__GNUC__) && (__GNUC__ >= 3)) || (defined(__INTEL_COMPILER) && (__INTEL_COMPILER >= 800)) || defined(__clang__)
# define expect(expr,value) (__builtin_expect ((expr),(value)) )
#else
# define expect(expr,value) (expr)
@@ -99,7 +127,7 @@
#define unlikely(expr) expect((expr) != 0, 0)
* Memory routines
#include <stdlib.h> /* malloc, calloc, free */
@@ -109,54 +137,100 @@
#define MEM_INIT memset
* Basic Types
-#if defined (__STDC_VERSION__) && (__STDC_VERSION__ >= 199901L) /* C99 */
+#if defined(__cplusplus) || (defined (__STDC_VERSION__) && (__STDC_VERSION__ >= 199901L) /* C99 */)
# include <stdint.h>
typedef uint8_t BYTE;
typedef uint16_t U16;
typedef uint32_t U32;
typedef int32_t S32;
typedef uint64_t U64;
+ typedef uintptr_t uptrval;
#else
typedef unsigned char BYTE;
typedef unsigned short U16;
typedef unsigned int U32;
typedef signed int S32;
typedef unsigned long long U64;
+ typedef size_t uptrval; /* generally true, except OpenVMS-64 */
#endif
+#if defined(__x86_64__)
+ typedef U64 reg_t; /* 64-bits in x32 mode */
+#else
+ typedef size_t reg_t; /* 32-bits in x32 mode */
+#endif
* Reading and writing into memory
-#define STEPSIZE sizeof(size_t)
-static unsigned LZ4_64bits(void) { return sizeof(void*)==8; }
static unsigned LZ4_isLittleEndian(void)
- const union { U32 i; BYTE c[4]; } one = { 1 }; /* don't use static : performance detrimental */
+ const union { U32 u; BYTE c[4]; } one = { 1 }; /* don't use static : performance detrimental */
return one.c[0];
+#if defined(LZ4_FORCE_MEMORY_ACCESS) && (LZ4_FORCE_MEMORY_ACCESS==2)
+/* lie to the compiler about data alignment; use with caution */
+static U16 LZ4_read16(const void* memPtr) { return *(const U16*) memPtr; }
+static U32 LZ4_read32(const void* memPtr) { return *(const U32*) memPtr; }
+static reg_t LZ4_read_ARCH(const void* memPtr) { return *(const reg_t*) memPtr; }
+static void LZ4_write16(void* memPtr, U16 value) { *(U16*)memPtr = value; }
+static void LZ4_write32(void* memPtr, U32 value) { *(U32*)memPtr = value; }
+#elif defined(LZ4_FORCE_MEMORY_ACCESS) && (LZ4_FORCE_MEMORY_ACCESS==1)
+/* __pack instructions are safer, but compiler specific, hence potentially problematic for some compilers */
+/* currently only defined for gcc and icc */
+typedef union { U16 u16; U32 u32; reg_t uArch; } __attribute__((packed)) unalign;
+static U16 LZ4_read16(const void* ptr) { return ((const unalign*)ptr)->u16; }
+static U32 LZ4_read32(const void* ptr) { return ((const unalign*)ptr)->u32; }
+static reg_t LZ4_read_ARCH(const void* ptr) { return ((const unalign*)ptr)->uArch; }
+static void LZ4_write16(void* memPtr, U16 value) { ((unalign*)memPtr)->u16 = value; }
+static void LZ4_write32(void* memPtr, U32 value) { ((unalign*)memPtr)->u32 = value; }
+#else /* safe and portable access through memcpy() */
- U16 val16;
- memcpy(&val16, memPtr, 2);
- return val16;
+ U16 val; memcpy(&val, memPtr, sizeof(val)); return val;
+ U32 val; memcpy(&val, memPtr, sizeof(val)); return val;
+ reg_t val; memcpy(&val, memPtr, sizeof(val)); return val;
+ memcpy(memPtr, &value, sizeof(value));
+#endif /* LZ4_FORCE_MEMORY_ACCESS */
static U16 LZ4_readLE16(const void* memPtr)
- if (LZ4_isLittleEndian())
+ if (LZ4_isLittleEndian()) {
return LZ4_read16(memPtr);
- else
+ } else {
const BYTE* p = (const BYTE*)memPtr;
return (U16)((U16)p[0] + (p[1]<<8));
@@ -164,63 +238,39 @@
static void LZ4_writeLE16(void* memPtr, U16 value)
- memcpy(memPtr, &value, 2);
- else
+ LZ4_write16(memPtr, value);
+ } else {
BYTE* p = (BYTE*)memPtr;
p[0] = (BYTE) value;
p[1] = (BYTE)(value>>8);
-static U32 LZ4_read32(const void* memPtr)
+static void LZ4_copy8(void* dst, const void* src)
- U32 val32;
- memcpy(&val32, memPtr, 4);
- return val32;
+ memcpy(dst,src,8);
-static U64 LZ4_read64(const void* memPtr)
- U64 val64;
- memcpy(&val64, memPtr, 8);
- return val64;
-static size_t LZ4_read_ARCH(const void* p)
- if (LZ4_64bits())
- return (size_t)LZ4_read64(p);
- else
- return (size_t)LZ4_read32(p);
-static void LZ4_copy4(void* dstPtr, const void* srcPtr) { memcpy(dstPtr, srcPtr, 4); }
-static void LZ4_copy8(void* dstPtr, const void* srcPtr) { memcpy(dstPtr, srcPtr, 8); }
-/* customized version of memcpy, which may overwrite up to 7 bytes beyond dstEnd */
+/* customized variant of memcpy, which can overwrite up to 8 bytes beyond dstEnd */
static void LZ4_wildCopy(void* dstPtr, const void* srcPtr, void* dstEnd)
BYTE* d = (BYTE*)dstPtr;
const BYTE* s = (const BYTE*)srcPtr;
- BYTE* e = (BYTE*)dstEnd;
+ BYTE* const e = (BYTE*)dstEnd;
do { LZ4_copy8(d,s); d+=8; s+=8; } while (d<e);
* Common Constants
#define MINMATCH 4
-#define COPYLENGTH 8
+#define WILDCOPYLENGTH 8
#define LASTLITERALS 5
-#define MFLIMIT (COPYLENGTH+MINMATCH)
+#define MFLIMIT (WILDCOPYLENGTH+MINMATCH)
static const int LZ4_minLength = (MFLIMIT+1);
#define KB *(1 <<10)
@@ -236,55 +286,60 @@
#define RUN_MASK ((1U<<RUN_BITS)-1)
-* Common Utils
+* Error detection
#define LZ4_STATIC_ASSERT(c) { enum { LZ4_static_assert = 1/(int)(!!(c)) }; } /* use only *after* variable declarations */
+#if defined(LZ4_DEBUG) && (LZ4_DEBUG>=2)
+# include <stdio.h>
+# define DEBUGLOG(l, ...) { \
+ if (l<=LZ4_DEBUG) { \
+ fprintf(stderr, __FILE__ ": "); \
+ fprintf(stderr, __VA_ARGS__); \
+ fprintf(stderr, " \n"); \
+#else
+# define DEBUGLOG(l, ...) {} /* disabled */
+#endif
* Common functions
-static unsigned LZ4_NbCommonBytes (register size_t val)
+static unsigned LZ4_NbCommonBytes (register reg_t val)
- if (LZ4_64bits())
+ if (sizeof(val)==8) {
# if defined(_MSC_VER) && defined(_WIN64) && !defined(LZ4_FORCE_SW_BITCOUNT)
unsigned long r = 0;
_BitScanForward64( &r, (U64)val );
return (int)(r>>3);
-# elif (defined(__clang__) || (LZ4_GCC_VERSION >= 304)) && !defined(LZ4_FORCE_SW_BITCOUNT)
+# elif (defined(__clang__) || (defined(__GNUC__) && (__GNUC__>=3))) && !defined(LZ4_FORCE_SW_BITCOUNT)
return (__builtin_ctzll((U64)val) >> 3);
# else
static const int DeBruijnBytePos[64] = { 0, 0, 0, 0, 0, 1, 1, 2, 0, 3, 1, 3, 1, 4, 2, 7, 0, 2, 3, 6, 1, 5, 3, 5, 1, 3, 4, 4, 2, 5, 6, 7, 7, 0, 1, 2, 3, 3, 4, 6, 2, 6, 5, 5, 3, 4, 5, 6, 7, 1, 2, 4, 6, 4, 4, 5, 7, 2, 6, 5, 7, 6, 7, 7 };
return DeBruijnBytePos[((U64)((val & -(long long)val) * 0x0218A392CDABBD3FULL)) >> 58];
# endif
- else /* 32 bits */
+ } else /* 32 bits */ {
# if defined(_MSC_VER) && !defined(LZ4_FORCE_SW_BITCOUNT)
unsigned long r;
_BitScanForward( &r, (U32)val );
return (int)(r>>3);
return (__builtin_ctz((U32)val) >> 3);
# else
static const int DeBruijnBytePos[32] = { 0, 0, 3, 0, 3, 1, 3, 0, 3, 2, 2, 1, 3, 2, 0, 1, 3, 3, 1, 2, 2, 2, 2, 0, 3, 1, 2, 0, 1, 0, 1, 1 };
return DeBruijnBytePos[((U32)((val & -(S32)val) * 0x077CB531U)) >> 27];
# endif
- else /* Big Endian CPU */
- if (LZ4_64bits())
+ } else /* Big Endian CPU */ {
_BitScanReverse64( &r, val );
return (unsigned)(r>>3);
return (__builtin_clzll((U64)val) >> 3);
# else
unsigned r;
@@ -293,14 +348,12 @@
r += (!val);
return r;
# endif
_BitScanReverse( &r, (unsigned long)val );
return (__builtin_clz((U32)val) >> 3);
# else
unsigned r;
@@ -312,19 +365,19 @@
+#define STEPSIZE sizeof(reg_t)
static unsigned LZ4_count(const BYTE* pIn, const BYTE* pMatch, const BYTE* pInLimit)
const BYTE* const pStart = pIn;
- while (likely(pIn<pInLimit-(STEPSIZE-1)))
- size_t diff = LZ4_read_ARCH(pMatch) ^ LZ4_read_ARCH(pIn);
+ while (likely(pIn<pInLimit-(STEPSIZE-1))) {
+ reg_t const diff = LZ4_read_ARCH(pMatch) ^ LZ4_read_ARCH(pIn);
if (!diff) { pIn+=STEPSIZE; pMatch+=STEPSIZE; continue; }
pIn += LZ4_NbCommonBytes(diff);
return (unsigned)(pIn - pStart);
- if (LZ4_64bits()) if ((pIn<(pInLimit-3)) && (LZ4_read32(pMatch) == LZ4_read32(pIn))) { pIn+=4; pMatch+=4; }
+ if ((STEPSIZE==8) && (pIn<(pInLimit-3)) && (LZ4_read32(pMatch) == LZ4_read32(pIn))) { pIn+=4; pMatch+=4; }
if ((pIn<(pInLimit-1)) && (LZ4_read16(pMatch) == LZ4_read16(pIn))) { pIn+=2; pMatch+=2; }
if ((pIn<pInLimit) && (*pMatch == *pIn)) pIn++;
@@ -332,29 +385,16 @@
#ifndef LZ4_COMMONDEFS_ONLY
* Local Constants
-#define LZ4_HASHLOG (LZ4_MEMORY_USAGE-2)
-#define HASHTABLESIZE (1 << LZ4_MEMORY_USAGE)
-#define HASH_SIZE_U32 (1 << LZ4_HASHLOG) /* required as macro for static allocation */
static const int LZ4_64Klimit = ((64 KB) + (MFLIMIT-1));
static const U32 LZ4_skipTrigger = 6; /* Increase this value ==> compression run slower on incompressible data */
* Local Structures and types
-typedef struct {
- U32 hashTable[HASH_SIZE_U32];
- U32 currentOffset;
- U32 initCheck;
- const BYTE* dictionary;
- BYTE* bufferStart; /* obsolete, used for slideInputBuffer */
- U32 dictSize;
-} LZ4_stream_t_internal;
typedef enum { notLimited = 0, limitedOutput = 1 } limitedOutput_directive;
typedef enum { byPtr, byU32, byU16 } tableType_t;
@@ -365,44 +405,43 @@
typedef enum { full = 0, partial = 1 } earlyEnd_directive;
* Local Utils
int LZ4_versionNumber (void) { return LZ4_VERSION_NUMBER; }
+const char* LZ4_versionString(void) { return LZ4_VERSION_STRING; }
int LZ4_compressBound(int isize) { return LZ4_COMPRESSBOUND(isize); }
int LZ4_sizeofState() { return LZ4_STREAMSIZE; }
* Compression functions
-static U32 LZ4_hashSequence(U32 sequence, tableType_t const tableType)
+static U32 LZ4_hash4(U32 sequence, tableType_t const tableType)
if (tableType == byU16)
- return (((sequence) * 2654435761U) >> ((MINMATCH*8)-(LZ4_HASHLOG+1)));
+ return ((sequence * 2654435761U) >> ((MINMATCH*8)-(LZ4_HASHLOG+1)));
else
- return (((sequence) * 2654435761U) >> ((MINMATCH*8)-LZ4_HASHLOG));
+ return ((sequence * 2654435761U) >> ((MINMATCH*8)-LZ4_HASHLOG));
-static const U64 prime5bytes = 889523592379ULL;
-static U32 LZ4_hashSequence64(size_t sequence, tableType_t const tableType)
+static U32 LZ4_hash5(U64 sequence, tableType_t const tableType)
+ static const U64 prime5bytes = 889523592379ULL;
+ static const U64 prime8bytes = 11400714785074694791ULL;
const U32 hashLog = (tableType == byU16) ? LZ4_HASHLOG+1 : LZ4_HASHLOG;
- const U32 hashMask = (1<<hashLog) - 1;
- return ((sequence * prime5bytes) >> (40 - hashLog)) & hashMask;
+ return (U32)(((sequence << 24) * prime5bytes) >> (64 - hashLog));
+ else
+ return (U32)(((sequence >> 24) * prime8bytes) >> (64 - hashLog));
-static U32 LZ4_hashSequenceT(size_t sequence, tableType_t const tableType)
+FORCE_INLINE U32 LZ4_hashPosition(const void* const p, tableType_t const tableType)
- if (LZ4_64bits())
- return LZ4_hashSequence64(sequence, tableType);
- return LZ4_hashSequence((U32)sequence, tableType);
+ if ((sizeof(reg_t)==8) && (tableType != byU16)) return LZ4_hash5(LZ4_read_ARCH(p), tableType);
+ return LZ4_hash4(LZ4_read32(p), tableType);
-static U32 LZ4_hashPosition(const void* p, tableType_t tableType) { return LZ4_hashSequenceT(LZ4_read_ARCH(p), tableType); }
static void LZ4_putPositionOnHash(const BYTE* p, U32 h, void* tableBase, tableType_t const tableType, const BYTE* srcBase)
switch (tableType)
@@ -413,27 +452,30 @@
-static void LZ4_putPosition(const BYTE* p, void* tableBase, tableType_t tableType, const BYTE* srcBase)
+FORCE_INLINE void LZ4_putPosition(const BYTE* p, void* tableBase, tableType_t tableType, const BYTE* srcBase)
- U32 h = LZ4_hashPosition(p, tableType);
+ U32 const h = LZ4_hashPosition(p, tableType);
LZ4_putPositionOnHash(p, h, tableBase, tableType, srcBase);
static const BYTE* LZ4_getPositionOnHash(U32 h, void* tableBase, tableType_t tableType, const BYTE* srcBase)
if (tableType == byPtr) { const BYTE** hashTable = (const BYTE**) tableBase; return hashTable[h]; }
- if (tableType == byU32) { U32* hashTable = (U32*) tableBase; return hashTable[h] + srcBase; }
- { U16* hashTable = (U16*) tableBase; return hashTable[h] + srcBase; } /* default, to ensure a return */
+ if (tableType == byU32) { const U32* const hashTable = (U32*) tableBase; return hashTable[h] + srcBase; }
+ { const U16* const hashTable = (U16*) tableBase; return hashTable[h] + srcBase; } /* default, to ensure a return */
-static const BYTE* LZ4_getPosition(const BYTE* p, void* tableBase, tableType_t tableType, const BYTE* srcBase)
+FORCE_INLINE const BYTE* LZ4_getPosition(const BYTE* p, void* tableBase, tableType_t tableType, const BYTE* srcBase)
return LZ4_getPositionOnHash(h, tableBase, tableType, srcBase);
+/** LZ4_compress_generic() :
+ inlined, to ensure branches are decided at compilation time */
FORCE_INLINE int LZ4_compress_generic(
- void* const ctx,
+ LZ4_stream_t_internal* const cctx,
const char* const source,
char* const dest,
const int inputSize,
@@ -444,15 +486,13 @@
const dictIssue_directive dictIssue,
const U32 acceleration)
- LZ4_stream_t_internal* const dictPtr = (LZ4_stream_t_internal*)ctx;
const BYTE* ip = (const BYTE*) source;
const BYTE* base;
const BYTE* lowLimit;
- const BYTE* const lowRefLimit = ip - dictPtr->dictSize;
- const BYTE* const dictionary = dictPtr->dictionary;
- const BYTE* const dictEnd = dictionary + dictPtr->dictSize;
- const size_t dictDelta = dictEnd - (const BYTE*)source;
+ const BYTE* const lowRefLimit = ip - cctx->dictSize;
+ const BYTE* const dictionary = cctx->dictionary;
+ const BYTE* const dictEnd = dictionary + cctx->dictSize;
+ const ptrdiff_t dictDelta = dictEnd - (const BYTE*)source;
const BYTE* anchor = (const BYTE*) source;
const BYTE* const iend = ip + inputSize;
const BYTE* const mflimit = iend - MFLIMIT;
@@ -462,10 +502,9 @@
BYTE* const olimit = op + maxOutputSize;
U32 forwardH;
- size_t refDelta=0;
/* Init conditions */
- if ((U32)inputSize > (U32)LZ4_MAX_INPUT_SIZE) return 0; /* Unsupported input size, too large (or negative) */
+ if ((U32)inputSize > (U32)LZ4_MAX_INPUT_SIZE) return 0; /* Unsupported inputSize, too large (or negative) */
switch(dict)
case noDict:
@@ -474,11 +513,11 @@
lowLimit = (const BYTE*)source;
break;
case withPrefix64k:
- base = (const BYTE*)source - dictPtr->currentOffset;
- lowLimit = (const BYTE*)source - dictPtr->dictSize;
+ base = (const BYTE*)source - cctx->currentOffset;
+ lowLimit = (const BYTE*)source - cctx->dictSize;
break;
case usingExtDict:
break;
@@ -486,44 +525,38 @@
if (inputSize<LZ4_minLength) goto _last_literals; /* Input too small, no compression (all literals) */
/* First Byte */
- LZ4_putPosition(ip, ctx, tableType, base);
+ LZ4_putPosition(ip, cctx->hashTable, tableType, base);
ip++; forwardH = LZ4_hashPosition(ip, tableType);
/* Main Loop */
- for ( ; ; )
+ for ( ; ; ) {
+ ptrdiff_t refDelta = 0;
const BYTE* match;
BYTE* token;
- const BYTE* forwardIp = ip;
+ /* Find a match */
+ { const BYTE* forwardIp = ip;
unsigned step = 1;
unsigned searchMatchNb = acceleration << LZ4_skipTrigger;
- /* Find a match */
do {
- U32 h = forwardH;
+ U32 const h = forwardH;
ip = forwardIp;
forwardIp += step;
step = (searchMatchNb++ >> LZ4_skipTrigger);
if (unlikely(forwardIp > mflimit)) goto _last_literals;
- match = LZ4_getPositionOnHash(h, ctx, tableType, base);
- if (dict==usingExtDict)
- if (match<(const BYTE*)source)
+ match = LZ4_getPositionOnHash(h, cctx->hashTable, tableType, base);
+ if (dict==usingExtDict) {
+ if (match < (const BYTE*)source) {
refDelta = dictDelta;
lowLimit = dictionary;
- else
+ } else {
refDelta = 0;
forwardH = LZ4_hashPosition(forwardIp, tableType);
- LZ4_putPositionOnHash(ip, h, ctx, tableType, base);
+ LZ4_putPositionOnHash(ip, h, cctx->hashTable, tableType, base);
} while ( ((dictIssue==dictSmall) ? (match < lowRefLimit) : 0)
|| ((tableType==byU16) ? 0 : (match + MAX_DISTANCE < ip))
@@ -531,18 +564,17 @@
/* Catch up */
- while ((ip>anchor) && (match+refDelta > lowLimit) && (unlikely(ip[-1]==match[refDelta-1]))) { ip--; match--; }
+ while (((ip>anchor) & (match+refDelta > lowLimit)) && (unlikely(ip[-1]==match[refDelta-1]))) { ip--; match--; }
- /* Encode Literal length */
- unsigned litLength = (unsigned)(ip - anchor);
+ /* Encode Literals */
+ { unsigned const litLength = (unsigned)(ip - anchor);
token = op++;
- if ((outputLimited) && (unlikely(op + litLength + (2 + 1 + LASTLITERALS) + (litLength/255) > olimit)))
- return 0; /* Check output limit */
- if (litLength>=RUN_MASK)
+ if ((outputLimited) && /* Check output buffer overflow */
+ (unlikely(op + litLength + (2 + 1 + LASTLITERALS) + (litLength/255) > olimit)))
+ return 0;
+ if (litLength >= RUN_MASK) {
int len = (int)litLength-RUN_MASK;
- *token=(RUN_MASK<<ML_BITS);
+ *token = (RUN_MASK<<ML_BITS);
for(; len >= 255 ; len-=255) *op++ = 255;
*op++ = (BYTE)len;
@@ -558,41 +590,37 @@
LZ4_writeLE16(op, (U16)(ip-match)); op+=2;
/* Encode MatchLength */
- unsigned matchLength;
+ { unsigned matchCode;
- if ((dict==usingExtDict) && (lowLimit==dictionary))
+ if ((dict==usingExtDict) && (lowLimit==dictionary)) {
const BYTE* limit;
match += refDelta;
limit = ip + (dictEnd-match);
if (limit > matchlimit) limit = matchlimit;
- matchLength = LZ4_count(ip+MINMATCH, match+MINMATCH, limit);
- ip += MINMATCH + matchLength;
- if (ip==limit)
- unsigned more = LZ4_count(ip, (const BYTE*)source, matchlimit);
- matchLength += more;
+ matchCode = LZ4_count(ip+MINMATCH, match+MINMATCH, limit);
+ ip += MINMATCH + matchCode;
+ if (ip==limit) {
+ unsigned const more = LZ4_count(ip, (const BYTE*)source, matchlimit);
+ matchCode += more;
ip += more;
+ } else {
+ matchCode = LZ4_count(ip+MINMATCH, match+MINMATCH, matchlimit);
- else
- matchLength = LZ4_count(ip+MINMATCH, match+MINMATCH, matchlimit);
- if ((outputLimited) && (unlikely(op + (1 + LASTLITERALS) + (matchLength>>8) > olimit)))
- if (matchLength>=ML_MASK)
+ if ( outputLimited && /* Check output buffer overflow */
+ (unlikely(op + (1 + LASTLITERALS) + (matchCode>>8) > olimit)) )
+ return 0;
+ if (matchCode >= ML_MASK) {
*token += ML_MASK;
- matchLength -= ML_MASK;
- for (; matchLength >= 510 ; matchLength-=510) { *op++ = 255; *op++ = 255; }
- if (matchLength >= 255) { matchLength-=255; *op++ = 255; }
- *op++ = (BYTE)matchLength;
- else *token += (BYTE)(matchLength);
+ matchCode -= ML_MASK;
+ LZ4_write32(op, 0xFFFFFFFF);
+ while (matchCode >= 4*255) op+=4, LZ4_write32(op, 0xFFFFFFFF), matchCode -= 4*255;
+ op += matchCode / 255;
+ *op++ = (BYTE)(matchCode % 255);
+ } else
+ *token += (BYTE)(matchCode);
anchor = ip;
@@ -601,24 +629,19 @@
if (ip > mflimit) break;
/* Fill table */
- LZ4_putPosition(ip-2, ctx, tableType, base);
+ LZ4_putPosition(ip-2, cctx->hashTable, tableType, base);
/* Test next position */
- match = LZ4_getPosition(ip, ctx, tableType, base);
+ match = LZ4_getPosition(ip, cctx->hashTable, tableType, base);
- else
+ } else {
refDelta = 0;
if ( ((dictIssue==dictSmall) ? (match>=lowRefLimit) : 1)
&& (match+MAX_DISTANCE>=ip)
&& (LZ4_read32(match+refDelta)==LZ4_read32(ip)) )
@@ -630,19 +653,16 @@
_last_literals:
/* Encode Last Literals */
- const size_t lastRun = (size_t)(iend - anchor);
- if ((outputLimited) && ((op - (BYTE*)dest) + lastRun + 1 + ((lastRun+255-RUN_MASK)/255) > (U32)maxOutputSize))
- if (lastRun >= RUN_MASK)
+ { size_t const lastRun = (size_t)(iend - anchor);
+ if ( (outputLimited) && /* Check output buffer overflow */
+ ((op - (BYTE*)dest) + lastRun + 1 + ((lastRun+255-RUN_MASK)/255) > (U32)maxOutputSize) )
+ return 0;
+ if (lastRun >= RUN_MASK) {
size_t accumulator = lastRun - RUN_MASK;
*op++ = RUN_MASK << ML_BITS;
for(; accumulator >= 255 ; accumulator-=255) *op++ = 255;
*op++ = (BYTE) accumulator;
- else
+ } else {
*op++ = (BYTE)(lastRun<<ML_BITS);
memcpy(op, anchor, lastRun);
@@ -656,38 +676,36 @@
int LZ4_compress_fast_extState(void* state, const char* source, char* dest, int inputSize, int maxOutputSize, int acceleration)
+ LZ4_stream_t_internal* ctx = &((LZ4_stream_t*)state)->internal_donotuse;
LZ4_resetStream((LZ4_stream_t*)state);
if (acceleration < 1) acceleration = ACCELERATION_DEFAULT;
- if (maxOutputSize >= LZ4_compressBound(inputSize))
+ if (maxOutputSize >= LZ4_compressBound(inputSize)) {
if (inputSize < LZ4_64Klimit)
- return LZ4_compress_generic(state, source, dest, inputSize, 0, notLimited, byU16, noDict, noDictIssue, acceleration);
+ return LZ4_compress_generic(ctx, source, dest, inputSize, 0, notLimited, byU16, noDict, noDictIssue, acceleration);
else
- return LZ4_compress_generic(state, source, dest, inputSize, 0, notLimited, LZ4_64bits() ? byU32 : byPtr, noDict, noDictIssue, acceleration);
- else
+ return LZ4_compress_generic(ctx, source, dest, inputSize, 0, notLimited, (sizeof(void*)==8) ? byU32 : byPtr, noDict, noDictIssue, acceleration);
+ } else {
- return LZ4_compress_generic(state, source, dest, inputSize, maxOutputSize, limitedOutput, byU16, noDict, noDictIssue, acceleration);
+ return LZ4_compress_generic(ctx, source, dest, inputSize, maxOutputSize, limitedOutput, byU16, noDict, noDictIssue, acceleration);
else
- return LZ4_compress_generic(state, source, dest, inputSize, maxOutputSize, limitedOutput, LZ4_64bits() ? byU32 : byPtr, noDict, noDictIssue, acceleration);
+ return LZ4_compress_generic(ctx, source, dest, inputSize, maxOutputSize, limitedOutput, (sizeof(void*)==8) ? byU32 : byPtr, noDict, noDictIssue, acceleration);
int LZ4_compress_fast(const char* source, char* dest, int inputSize, int maxOutputSize, int acceleration)
-#if (HEAPMODE)
+#if (LZ4_HEAPMODE)
void* ctxPtr = ALLOCATOR(1, sizeof(LZ4_stream_t)); /* malloc-calloc always properly aligned */
#else
LZ4_stream_t ctx;
- void* ctxPtr = &ctx;
+ void* const ctxPtr = &ctx;
#endif
- int result = LZ4_compress_fast_extState(ctxPtr, source, dest, inputSize, maxOutputSize, acceleration);
+ int const result = LZ4_compress_fast_extState(ctxPtr, source, dest, inputSize, maxOutputSize, acceleration);
-#if (HEAPMODE)
+#if (LZ4_HEAPMODE)
FREEMEM(ctxPtr);
#endif
return result;
@@ -705,22 +723,21 @@
int LZ4_compress_fast_force(const char* source, char* dest, int inputSize, int maxOutputSize, int acceleration)
LZ4_stream_t ctx;
LZ4_resetStream(&ctx);
- return LZ4_compress_generic(&ctx, source, dest, inputSize, maxOutputSize, limitedOutput, byU16, noDict, noDictIssue, acceleration);
+ return LZ4_compress_generic(&ctx.internal_donotuse, source, dest, inputSize, maxOutputSize, limitedOutput, byU16, noDict, noDictIssue, acceleration);
else
- return LZ4_compress_generic(&ctx, source, dest, inputSize, maxOutputSize, limitedOutput, LZ4_64bits() ? byU32 : byPtr, noDict, noDictIssue, acceleration);
+ return LZ4_compress_generic(&ctx.internal_donotuse, source, dest, inputSize, maxOutputSize, limitedOutput, sizeof(void*)==8 ? byU32 : byPtr, noDict, noDictIssue, acceleration);
-* destSize variant
+* *_destSize() variant
static int LZ4_compress_destSize_generic(
- void* const ctx,
+ LZ4_stream_t_internal* const ctx,
const char* const src,
char* const dst,
int* const srcSizePtr,
@@ -752,32 +769,30 @@
/* First Byte */
*srcSizePtr = 0;
+ LZ4_putPosition(ip, ctx->hashTable, tableType, base);
/* Main Loop */
- for ( ; ; )
+ for ( ; ; ) {
const BYTE* match;
BYTE* token;
unsigned step = 1;
unsigned searchMatchNb = 1 << LZ4_skipTrigger;
do {
U32 h = forwardH;
ip = forwardIp;
forwardIp += step;
- if (unlikely(forwardIp > mflimit))
- goto _last_literals;
+ if (unlikely(forwardIp > mflimit)) goto _last_literals;
+ match = LZ4_getPositionOnHash(h, ctx->hashTable, tableType, base);
+ LZ4_putPositionOnHash(ip, h, ctx->hashTable, tableType, base);
} while ( ((tableType==byU16) ? 0 : (match + MAX_DISTANCE < ip))
|| (LZ4_read32(match) != LZ4_read32(ip)) );
@@ -786,18 +801,15 @@
/* Catch up */
while ((ip>anchor) && (match > lowLimit) && (unlikely(ip[-1]==match[-1]))) { ip--; match--; }
+ /* Encode Literal length */
+ { unsigned litLength = (unsigned)(ip - anchor);
token = op++;
- if (op + ((litLength+240)/255) + litLength > oMaxLit)
+ if (op + ((litLength+240)/255) + litLength > oMaxLit) {
/* Not enough space for a last match */
op--;
+ if (litLength>=RUN_MASK) {
unsigned len = litLength - RUN_MASK;
@@ -815,21 +827,15 @@
- size_t matchLength;
+ { size_t matchLength = LZ4_count(ip+MINMATCH, match+MINMATCH, matchlimit);
- if (op + ((matchLength+240)/255) > oMaxMatch)
+ if (op + ((matchLength+240)/255) > oMaxMatch) {
/* Match description too long : reduce it */
matchLength = (15-1) + (oMaxMatch-op) * 255;
- /* printf("offset %5i, matchLength%5i \n", (int)(ip-match), matchLength + MINMATCH); */
+ if (matchLength>=ML_MASK) {
*token += ML_MASK;
while (matchLength >= 255) { matchLength-=255; *op++ = 255; }
@@ -845,11 +851,11 @@
if (op > oMaxSeq) break;
/* Fill table */
+ LZ4_putPosition(ip-2, ctx->hashTable, tableType, base);
+ match = LZ4_getPosition(ip, ctx->hashTable, tableType, base);
if ( (match+MAX_DISTANCE>=ip)
&& (LZ4_read32(match)==LZ4_read32(ip)) )
{ token=op++; *token=0; goto _next_match; }
@@ -860,25 +866,20 @@
_last_literals:
- size_t lastRunSize = (size_t)(iend - anchor);
- if (op + 1 /* token */ + ((lastRunSize+240)/255) /* litLength */ + lastRunSize /* literals */ > oend)
+ { size_t lastRunSize = (size_t)(iend - anchor);
+ if (op + 1 /* token */ + ((lastRunSize+240)/255) /* litLength */ + lastRunSize /* literals */ > oend) {
/* adapt lastRunSize to fill 'dst' */
lastRunSize = (oend-op) - 1;
lastRunSize -= (lastRunSize+240)/255;
ip = anchor + lastRunSize;
- if (lastRunSize >= RUN_MASK)
+ if (lastRunSize >= RUN_MASK) {
size_t accumulator = lastRunSize - RUN_MASK;
- else
+ } else {
*op++ = (BYTE)(lastRunSize<<ML_BITS);
memcpy(op, anchor, lastRunSize);
@@ -891,36 +892,33 @@
-static int LZ4_compress_destSize_extState (void* state, const char* src, char* dst, int* srcSizePtr, int targetDstSize)
+static int LZ4_compress_destSize_extState (LZ4_stream_t* state, const char* src, char* dst, int* srcSizePtr, int targetDstSize)
- LZ4_resetStream((LZ4_stream_t*)state);
+ LZ4_resetStream(state);
- if (targetDstSize >= LZ4_compressBound(*srcSizePtr)) /* compression success is guaranteed */
+ if (targetDstSize >= LZ4_compressBound(*srcSizePtr)) { /* compression success is guaranteed */
return LZ4_compress_fast_extState(state, src, dst, *srcSizePtr, targetDstSize, 1);
- else
+ } else {
if (*srcSizePtr < LZ4_64Klimit)
- return LZ4_compress_destSize_generic(state, src, dst, srcSizePtr, targetDstSize, byU16);
+ return LZ4_compress_destSize_generic(&state->internal_donotuse, src, dst, srcSizePtr, targetDstSize, byU16);
else
- return LZ4_compress_destSize_generic(state, src, dst, srcSizePtr, targetDstSize, LZ4_64bits() ? byU32 : byPtr);
+ return LZ4_compress_destSize_generic(&state->internal_donotuse, src, dst, srcSizePtr, targetDstSize, sizeof(void*)==8 ? byU32 : byPtr);
int LZ4_compress_destSize(const char* src, char* dst, int* srcSizePtr, int targetDstSize)
-#if (HEAPMODE)
- void* ctx = ALLOCATOR(1, sizeof(LZ4_stream_t)); /* malloc-calloc always properly aligned */
+#if (LZ4_HEAPMODE)
+ LZ4_stream_t* ctx = (LZ4_stream_t*)ALLOCATOR(1, sizeof(LZ4_stream_t)); /* malloc-calloc always properly aligned */
#else
LZ4_stream_t ctxBody;
- void* ctx = &ctxBody;
+ LZ4_stream_t* ctx = &ctxBody;
#endif
int result = LZ4_compress_destSize_extState(ctx, src, dst, srcSizePtr, targetDstSize);
-#if (HEAPMODE)
+#if (LZ4_HEAPMODE)
FREEMEM(ctx);
#endif
return result;
@@ -928,7 +926,7 @@
* Streaming functions
@@ -947,15 +945,16 @@
int LZ4_freeStream (LZ4_stream_t* LZ4_stream)
+ if (!LZ4_stream) return 0; /* support free on NULL */
FREEMEM(LZ4_stream);
return (0);
-#define HASH_UNIT sizeof(size_t)
+#define HASH_UNIT sizeof(reg_t)
int LZ4_loadDict (LZ4_stream_t* LZ4_dict, const char* dictionary, int dictSize)
- LZ4_stream_t_internal* dict = (LZ4_stream_t_internal*) LZ4_dict;
+ LZ4_stream_t_internal* dict = &LZ4_dict->internal_donotuse;
const BYTE* p = (const BYTE*)dictionary;
const BYTE* const dictEnd = p + dictSize;
const BYTE* base;
@@ -963,8 +962,7 @@
if ((dict->initCheck) || (dict->currentOffset > 1 GB)) /* Uninitialized structure, or reuse overflow */
LZ4_resetStream(LZ4_dict);
- if (dictSize < (int)HASH_UNIT)
+ if (dictSize < (int)HASH_UNIT) {
dict->dictionary = NULL;
dict->dictSize = 0;
return 0;
@@ -977,8 +975,7 @@
dict->dictSize = (U32)(dictEnd - p);
dict->currentOffset += dict->dictSize;
- while (p <= dictEnd-HASH_UNIT)
+ while (p <= dictEnd-HASH_UNIT) {
LZ4_putPosition(p, dict->hashTable, byU32, base);
p+=3;
@@ -990,14 +987,12 @@
static void LZ4_renormDictT(LZ4_stream_t_internal* LZ4_dict, const BYTE* src)
if ((LZ4_dict->currentOffset > 0x80000000) ||
- ((size_t)LZ4_dict->currentOffset > (size_t)src)) /* address space overflow */
+ ((uptrval)LZ4_dict->currentOffset > (uptrval)src)) { /* address space overflow */
/* rescale hash table */
- U32 delta = LZ4_dict->currentOffset - 64 KB;
+ U32 const delta = LZ4_dict->currentOffset - 64 KB;
const BYTE* dictEnd = LZ4_dict->dictionary + LZ4_dict->dictSize;
int i;
- for (i=0; i<HASH_SIZE_U32; i++)
+ for (i=0; i<LZ4_HASH_SIZE_U32; i++) {
if (LZ4_dict->hashTable[i] < delta) LZ4_dict->hashTable[i]=0;
else LZ4_dict->hashTable[i] -= delta;
@@ -1010,7 +1005,7 @@
int LZ4_compress_fast_continue (LZ4_stream_t* LZ4_stream, const char* source, char* dest, int inputSize, int maxOutputSize, int acceleration)
- LZ4_stream_t_internal* streamPtr = (LZ4_stream_t_internal*)LZ4_stream;
+ LZ4_stream_t_internal* streamPtr = &LZ4_stream->internal_donotuse;
const BYTE* const dictEnd = streamPtr->dictionary + streamPtr->dictSize;
const BYTE* smallest = (const BYTE*) source;
@@ -1020,10 +1015,8 @@
/* Check overlapping input/dictionary space */
- const BYTE* sourceEnd = (const BYTE*) source + inputSize;
- if ((sourceEnd > streamPtr->dictionary) && (sourceEnd < dictEnd))
+ { const BYTE* sourceEnd = (const BYTE*) source + inputSize;
+ if ((sourceEnd > streamPtr->dictionary) && (sourceEnd < dictEnd)) {
streamPtr->dictSize = (U32)(dictEnd - sourceEnd);
if (streamPtr->dictSize > 64 KB) streamPtr->dictSize = 64 KB;
if (streamPtr->dictSize < 4) streamPtr->dictSize = 0;
@@ -1032,25 +1025,23 @@
/* prefix mode : source data follows dictionary */
- if (dictEnd == (const BYTE*)source)
+ if (dictEnd == (const BYTE*)source) {
int result;
if ((streamPtr->dictSize < 64 KB) && (streamPtr->dictSize < streamPtr->currentOffset))
- result = LZ4_compress_generic(LZ4_stream, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, withPrefix64k, dictSmall, acceleration);
+ result = LZ4_compress_generic(streamPtr, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, withPrefix64k, dictSmall, acceleration);
else
- result = LZ4_compress_generic(LZ4_stream, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, withPrefix64k, noDictIssue, acceleration);
+ result = LZ4_compress_generic(streamPtr, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, withPrefix64k, noDictIssue, acceleration);
streamPtr->dictSize += (U32)inputSize;
streamPtr->currentOffset += (U32)inputSize;
return result;
/* external dictionary mode */
- int result;
+ { int result;
- result = LZ4_compress_generic(LZ4_stream, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, usingExtDict, dictSmall, acceleration);
+ result = LZ4_compress_generic(streamPtr, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, usingExtDict, dictSmall, acceleration);
else
- result = LZ4_compress_generic(LZ4_stream, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, usingExtDict, noDictIssue, acceleration);
+ result = LZ4_compress_generic(streamPtr, source, dest, inputSize, maxOutputSize, limitedOutput, byU32, usingExtDict, noDictIssue, acceleration);
streamPtr->dictionary = (const BYTE*)source;
streamPtr->dictSize = (U32)inputSize;
@@ -1062,15 +1053,15 @@
/* Hidden debug function, to force external dictionary mode */
int LZ4_compress_forceExtDict (LZ4_stream_t* LZ4_dict, const char* source, char* dest, int inputSize)
- LZ4_stream_t_internal* streamPtr = (LZ4_stream_t_internal*)LZ4_dict;
+ LZ4_stream_t_internal* streamPtr = &LZ4_dict->internal_donotuse;
int result;
const BYTE* smallest = dictEnd;
if (smallest > (const BYTE*) source) smallest = (const BYTE*) source;
- LZ4_renormDictT((LZ4_stream_t_internal*)LZ4_dict, smallest);
+ LZ4_renormDictT(streamPtr, smallest);
- result = LZ4_compress_generic(LZ4_dict, source, dest, inputSize, 0, notLimited, byU32, usingExtDict, noDictIssue, 1);
+ result = LZ4_compress_generic(streamPtr, source, dest, inputSize, 0, notLimited, byU32, usingExtDict, noDictIssue, 1);
@@ -1080,10 +1071,17 @@
+/*! LZ4_saveDict() :
+ * If previously compressed data block is not guaranteed to remain available at its memory location,
+ * save it into a safer place (char* safeBuffer).
+ * Note : you don't need to call LZ4_loadDict() afterwards,
+ * dictionary is immediately usable, you can therefore call LZ4_compress_fast_continue().
+ * Return : saved dictionary size in bytes (necessarily <= dictSize), or 0 if error.
int LZ4_saveDict (LZ4_stream_t* LZ4_dict, char* safeBuffer, int dictSize)
- const BYTE* previousDictEnd = dict->dictionary + dict->dictSize;
+ LZ4_stream_t_internal* const dict = &LZ4_dict->internal_donotuse;
+ const BYTE* const previousDictEnd = dict->dictionary + dict->dictSize;
if ((U32)dictSize > 64 KB) dictSize = 64 KB; /* useless to define a dictionary > 64 KB */
if ((U32)dictSize > dict->dictSize) dictSize = dict->dictSize;
@@ -1098,14 +1096,14 @@
* Decompression functions
- * This generic decompression function cover all use cases.
- * It shall be instantiated several times, using different sets of directives
- * Note that it is essential this generic function is really inlined,
- * in order to remove useless branches during compilation optimization.
+/*! LZ4_decompress_generic() :
+ * This generic decompression function cover all use cases.
+ * It shall be instantiated several times, using different sets of directives
+ * Note that it is important this generic function is really inlined,
+ * in order to remove useless branches during compilation optimization.
FORCE_INLINE int LZ4_decompress_generic(
@@ -1117,7 +1115,7 @@
int partialDecoding, /* full, partial */
int targetOutputSize, /* only used if partialDecoding==partial */
int dict, /* noDict, withPrefix64k, usingExtDict */
- const BYTE* const lowPrefix, /* == dest if dict == noDict */
+ const BYTE* const lowPrefix, /* == dest when no prefix */
const BYTE* const dictStart, /* only if dict==usingExtDict */
const size_t dictSize /* note : = 0 if noDict */
@@ -1133,53 +1131,45 @@
const BYTE* const lowLimit = lowPrefix - dictSize;
const BYTE* const dictEnd = (const BYTE*)dictStart + dictSize;
- const size_t dec32table[] = {4, 1, 2, 1, 4, 4, 4, 4};
- const size_t dec64table[] = {0, 0, 0, (size_t)-1, 0, 1, 2, 3};
+ const unsigned dec32table[] = {0, 1, 2, 1, 4, 4, 4, 4};
+ const int dec64table[] = {0, 0, 0, -1, 0, 1, 2, 3};
const int safeDecode = (endOnInput==endOnInputSize);
const int checkOffset = ((safeDecode) && (dictSize < (int)(64 KB)));
/* Special cases */
- if ((partialDecoding) && (oexit> oend-MFLIMIT)) oexit = oend-MFLIMIT; /* targetOutputSize too high => decode everything */
+ if ((partialDecoding) && (oexit > oend-MFLIMIT)) oexit = oend-MFLIMIT; /* targetOutputSize too high => decode everything */
if ((endOnInput) && (unlikely(outputSize==0))) return ((inputSize==1) && (*ip==0)) ? 0 : -1; /* Empty output buffer */
if ((!endOnInput) && (unlikely(outputSize==0))) return (*ip==0?1:-1);
- /* Main Loop */
- while (1)
- unsigned token;
+ /* Main Loop : decode sequences */
+ while (1) {
size_t length;
const BYTE* match;
+ size_t offset;
/* get literal length */
- token = *ip++;
- if ((length=(token>>ML_BITS)) == RUN_MASK)
+ unsigned const token = *ip++;
+ if ((length=(token>>ML_BITS)) == RUN_MASK) {
unsigned s;
- do
+ do {
s = *ip++;
length += s;
- while (likely((endOnInput)?ip<iend-RUN_MASK:1) && (s==255));
- if ((safeDecode) && unlikely((size_t)(op+length)<(size_t)(op))) goto _output_error; /* overflow detection */
- if ((safeDecode) && unlikely((size_t)(ip+length)<(size_t)(ip))) goto _output_error; /* overflow detection */
+ } while ( likely(endOnInput ? ip<iend-RUN_MASK : 1) & (s==255) );
+ if ((safeDecode) && unlikely((uptrval)(op)+length<(uptrval)(op))) goto _output_error; /* overflow detection */
+ if ((safeDecode) && unlikely((uptrval)(ip)+length<(uptrval)(ip))) goto _output_error; /* overflow detection */
/* copy literals */
cpy = op+length;
- if (((endOnInput) && ((cpy>(partialDecoding?oexit:oend-MFLIMIT)) || (ip+length>iend-(2+1+LASTLITERALS))) )
- || ((!endOnInput) && (cpy>oend-COPYLENGTH)))
+ if ( ((endOnInput) && ((cpy>(partialDecoding?oexit:oend-MFLIMIT)) || (ip+length>iend-(2+1+LASTLITERALS))) )
+ || ((!endOnInput) && (cpy>oend-WILDCOPYLENGTH)) )
- if (partialDecoding)
+ if (partialDecoding) {
if (cpy > oend) goto _output_error; /* Error : write attempt beyond end of output buffer */
if ((endOnInput) && (ip+length > iend)) goto _output_error; /* Error : read attempt beyond end of input buffer */
- else
+ } else {
if ((!endOnInput) && (cpy != oend)) goto _output_error; /* Error : block decoding must stop exactly there */
if ((endOnInput) && ((ip+length != iend) || (cpy > oend))) goto _output_error; /* Error : input must be consumed */
@@ -1192,84 +1182,76 @@
ip += length; op = cpy;
/* get offset */
- match = cpy - LZ4_readLE16(ip); ip+=2;
- if ((checkOffset) && (unlikely(match < lowLimit))) goto _output_error; /* Error : offset outside destination buffer */
+ offset = LZ4_readLE16(ip); ip+=2;
+ match = op - offset;
+ if ((checkOffset) && (unlikely(match < lowLimit))) goto _output_error; /* Error : offset outside buffers */
+ LZ4_write32(op, (U32)offset); /* costs ~1%; silence an msan warning when offset==0 */
/* get matchlength */
length = token & ML_MASK;
- if (length == ML_MASK)
+ if (length == ML_MASK) {
unsigned s;
- do
- if ((endOnInput) && (ip > iend-LASTLITERALS)) goto _output_error;
+ do {
s = *ip++;
+ if ((endOnInput) && (ip > iend-LASTLITERALS)) goto _output_error;
length += s;
} while (s==255);
- if ((safeDecode) && unlikely((size_t)(op+length)<(size_t)op)) goto _output_error; /* overflow detection */
+ if ((safeDecode) && unlikely((uptrval)(op)+length<(uptrval)op)) goto _output_error; /* overflow detection */
length += MINMATCH;
/* check external dictionary */
- if ((dict==usingExtDict) && (match < lowPrefix))
+ if ((dict==usingExtDict) && (match < lowPrefix)) {
if (unlikely(op+length > oend-LASTLITERALS)) goto _output_error; /* doesn't respect parsing restriction */
- if (length <= (size_t)(lowPrefix-match))
+ if (length <= (size_t)(lowPrefix-match)) {
/* match can be copied as a single segment from external dictionary */
- match = dictEnd - (lowPrefix-match);
- memmove(op, match, length); op += length;
- else
- /* match encompass external dictionary and current segment */
- size_t copySize = (size_t)(lowPrefix-match);
+ memmove(op, dictEnd - (lowPrefix-match), length);
+ op += length;
+ } else {
+ /* match encompass external dictionary and current block */
+ size_t const copySize = (size_t)(lowPrefix-match);
+ size_t const restSize = length - copySize;
memcpy(op, dictEnd - copySize, copySize);
op += copySize;
- copySize = length - copySize;
- if (copySize > (size_t)(op-lowPrefix)) /* overlap within current segment */
- BYTE* const endOfMatch = op + copySize;
+ if (restSize > (size_t)(op-lowPrefix)) { /* overlap copy */
+ BYTE* const endOfMatch = op + restSize;
const BYTE* copyFrom = lowPrefix;
while (op < endOfMatch) *op++ = *copyFrom++;
- else
- memcpy(op, lowPrefix, copySize);
- op += copySize;
+ } else {
+ memcpy(op, lowPrefix, restSize);
+ op += restSize;
continue;
- /* copy repeated sequence */
+ /* copy match within block */
cpy = op + length;
- if (unlikely((op-match)<8))
- const size_t dec64 = dec64table[op-match];
+ if (unlikely(offset<8)) {
+ const int dec64 = dec64table[offset];
op[0] = match[0];
op[1] = match[1];
op[2] = match[2];
op[3] = match[3];
- match += dec32table[op-match];
- LZ4_copy4(op+4, match);
- op += 8; match -= dec64;
- } else { LZ4_copy8(op, match); op+=8; match+=8; }
+ match += dec32table[offset];
+ memcpy(op+4, match, 4);
+ match -= dec64;
+ } else { LZ4_copy8(op, match); match+=8; }
+ op += 8;
- if (unlikely(cpy>oend-12))
- if (cpy > oend-LASTLITERALS) goto _output_error; /* Error : last LASTLITERALS bytes must be literals */
- if (op < oend-8)
- LZ4_wildCopy(op, match, oend-8);
- match += (oend-8) - op;
- op = oend-8;
+ if (unlikely(cpy>oend-12)) {
+ BYTE* const oCopyLimit = oend-(WILDCOPYLENGTH-1);
+ if (cpy > oend-LASTLITERALS) goto _output_error; /* Error : last LASTLITERALS bytes must be literals (uncompressed) */
+ if (op < oCopyLimit) {
+ LZ4_wildCopy(op, match, oCopyLimit);
+ match += oCopyLimit - op;
+ op = oCopyLimit;
while (op<cpy) *op++ = *match++;
+ } else {
+ LZ4_copy8(op, match);
+ if (length>16) LZ4_wildCopy(op+8, match+8, cpy);
- else
- LZ4_wildCopy(op, match, cpy);
op=cpy; /* correction */
@@ -1301,21 +1283,8 @@
-/* streaming decompression functions */
+/*===== streaming decompression functions =====*/
-typedef struct
- const BYTE* externalDict;
- size_t extDictSize;
- const BYTE* prefixEnd;
- size_t prefixSize;
-} LZ4_streamDecode_t_internal;
- * If you prefer dynamic allocation methods,
- * LZ4_createStreamDecode()
- * provides a pointer (void*) towards an initialized LZ4_streamDecode_t structure.
LZ4_streamDecode_t* LZ4_createStreamDecode(void)
LZ4_streamDecode_t* lz4s = (LZ4_streamDecode_t*) ALLOCATOR(1, sizeof(LZ4_streamDecode_t));
@@ -1324,20 +1293,21 @@
int LZ4_freeStreamDecode (LZ4_streamDecode_t* LZ4_stream)
return 0;
- * LZ4_setStreamDecode
- * Use this function to instruct where to find the dictionary
+ * LZ4_setStreamDecode() :
+ * Use this function to instruct where to find the dictionary.
* This function is not necessary if previous data is still available where it was decoded.
* Loading a size of 0 is allowed (same effect as no dictionary).
* Return : 1 if OK, 0 if error
int LZ4_setStreamDecode (LZ4_streamDecode_t* LZ4_streamDecode, const char* dictionary, int dictSize)
- LZ4_streamDecode_t_internal* lz4sd = (LZ4_streamDecode_t_internal*) LZ4_streamDecode;
+ LZ4_streamDecode_t_internal* lz4sd = &LZ4_streamDecode->internal_donotuse;
lz4sd->prefixSize = (size_t) dictSize;
lz4sd->prefixEnd = (const BYTE*) dictionary + dictSize;
lz4sd->externalDict = NULL;
@@ -1354,20 +1324,17 @@
int LZ4_decompress_safe_continue (LZ4_streamDecode_t* LZ4_streamDecode, const char* source, char* dest, int compressedSize, int maxOutputSize)
int result;
- if (lz4sd->prefixEnd == (BYTE*)dest)
+ if (lz4sd->prefixEnd == (BYTE*)dest) {
result = LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize,
endOnInputSize, full, 0,
usingExtDict, lz4sd->prefixEnd - lz4sd->prefixSize, lz4sd->externalDict, lz4sd->extDictSize);
if (result <= 0) return result;
lz4sd->prefixSize += result;
lz4sd->prefixEnd += result;
- else
+ } else {
lz4sd->extDictSize = lz4sd->prefixSize;
lz4sd->externalDict = lz4sd->prefixEnd - lz4sd->extDictSize;
@@ -1383,22 +1350,19 @@
int LZ4_decompress_fast_continue (LZ4_streamDecode_t* LZ4_streamDecode, const char* source, char* dest, int originalSize)
int result;
result = LZ4_decompress_generic(source, dest, 0, originalSize,
endOnOutputSize, full, 0,
lz4sd->prefixSize += originalSize;
lz4sd->prefixEnd += originalSize;
- else
+ } else {
- lz4sd->externalDict = (BYTE*)dest - lz4sd->extDictSize;
+ lz4sd->externalDict = lz4sd->prefixEnd - lz4sd->extDictSize;
usingExtDict, (BYTE*)dest, lz4sd->externalDict, lz4sd->extDictSize);
@@ -1422,8 +1386,7 @@
if (dictSize==0)
return LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize, safe, full, 0, noDict, (BYTE*)dest, NULL, 0);
- if (dictStart+dictSize == dest)
+ if (dictStart+dictSize == dest) {
if (dictSize >= (int)(64 KB - 1))
return LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize, safe, full, 0, withPrefix64k, (BYTE*)dest-64 KB, NULL, 0);
return LZ4_decompress_generic(source, dest, compressedSize, maxOutputSize, safe, full, 0, noDict, (BYTE*)dest-dictSize, NULL, 0);
@@ -1448,7 +1411,7 @@
* Obsolete Functions
/* obsolete compression functions */
@@ -1473,29 +1436,29 @@
int LZ4_sizeofStreamState() { return LZ4_STREAMSIZE; }
-static void LZ4_init(LZ4_stream_t_internal* lz4ds, BYTE* base)
+static void LZ4_init(LZ4_stream_t* lz4ds, BYTE* base)
- MEM_INIT(lz4ds, 0, LZ4_STREAMSIZE);
- lz4ds->bufferStart = base;
+ MEM_INIT(lz4ds, 0, sizeof(LZ4_stream_t));
+ lz4ds->internal_donotuse.bufferStart = base;
int LZ4_resetStreamState(void* state, char* inputBuffer)
- if ((((size_t)state) & 3) != 0) return 1; /* Error : pointer is not aligned on 4-bytes boundary */
- LZ4_init((LZ4_stream_t_internal*)state, (BYTE*)inputBuffer);
+ if ((((uptrval)state) & 3) != 0) return 1; /* Error : pointer is not aligned on 4-bytes boundary */
+ LZ4_init((LZ4_stream_t*)state, (BYTE*)inputBuffer);
return 0;
void* LZ4_create (char* inputBuffer)
- void* lz4ds = ALLOCATOR(8, LZ4_STREAMSIZE_U64);
- LZ4_init ((LZ4_stream_t_internal*)lz4ds, (BYTE*)inputBuffer);
+ LZ4_stream_t* lz4ds = (LZ4_stream_t*)ALLOCATOR(8, sizeof(LZ4_stream_t));
+ LZ4_init (lz4ds, (BYTE*)inputBuffer);
return lz4ds;
char* LZ4_slideInputBuffer (void* LZ4_Data)
- LZ4_stream_t_internal* ctx = (LZ4_stream_t_internal*)LZ4_Data;
+ LZ4_stream_t_internal* ctx = &((LZ4_stream_t*)LZ4_Data)->internal_donotuse;
int dictSize = LZ4_saveDict((LZ4_stream_t*)LZ4_Data, (char*)ctx->bufferStart, 64 KB);
return (char*)(ctx->bufferStart + dictSize);
@@ -1513,4 +1476,3 @@
#endif /* LZ4_COMMONDEFS_ONLY */
Modified: grass/trunk/lib/gis/lz4.h
--- grass/trunk/lib/gis/lz4.h 2017-12-29 11:30:23 UTC (rev 71998)
+++ grass/trunk/lib/gis/lz4.h 2017-12-29 11:30:53 UTC (rev 71999)
@@ -1,7 +1,7 @@
- LZ4 - Fast LZ compression algorithm
- Header File
+ * LZ4 - Fast LZ compression algorithm
+ * Header File
+ * Copyright (C) 2011-2017, Yann Collet.
@@ -29,52 +29,97 @@
-#pragma once
#if defined (__cplusplus)
extern "C" {
#endif
+#ifndef LZ4_H_2983827168210
+#define LZ4_H_2983827168210
+/* --- Dependency --- */
+#include <stddef.h> /* size_t */
+ Introduction
+ LZ4 is lossless compression algorithm, providing compression speed at 400 MB/s per core,
+ scalable with multi-cores CPU. It features an extremely fast decoder, with speed in
+ multiple GB/s per core, typically reaching RAM speed limits on multi-core systems.
+ The LZ4 compression library provides in-memory compression and decompression functions.
+ Compression can be done in:
+ - a single step (described as Simple Functions)
+ - a single step, reusing a context (described in Advanced Functions)
+ - unbounded multiple steps (described as Streaming compression)
+ lz4.h provides block compression functions. It gives full buffer control to user.
+ Decompressing an lz4-compressed block also requires metadata (such as compressed size).
+ Each application is free to encode such metadata in whichever way it wants.
+ An additional format, called LZ4 frame specification (doc/lz4_Frame_format.md),
+ take care of encoding standard metadata alongside LZ4-compressed blocks.
+ If your application requires interoperability, it's recommended to use it.
+ A library is provided to take care of it, see lz4frame.h.
+* Export parameters
- * lz4.h provides block compression functions, and gives full buffer control to programmer.
- * If you need to generate inter-operable compressed data (respecting LZ4 frame specification),
- * and can let the library handle its own memory, please use lz4frame.h instead.
+* LZ4_DLL_EXPORT :
+* Enable exporting of functions when building a Windows DLL
+* LZ4LIB_API :
+* Control library symbols visibility.
+#if defined(LZ4_DLL_EXPORT) && (LZ4_DLL_EXPORT==1)
+# define LZ4LIB_API __declspec(dllexport)
+#elif defined(LZ4_DLL_IMPORT) && (LZ4_DLL_IMPORT==1)
+# define LZ4LIB_API __declspec(dllimport) /* It isn't required but allows to generate better code, saving a function pointer load from the IAT and an indirect jump.*/
+#elif defined(__GNUC__) && (__GNUC__ >= 4)
+# define LZ4LIB_API __attribute__ ((__visibility__ ("default")))
+#else
+#endif
-* Version
+/*------ Version ------*/
#define LZ4_VERSION_MAJOR 1 /* for breaking interface changes */
-#define LZ4_VERSION_MINOR 7 /* for new (non-breaking) interface capabilities */
-#define LZ4_VERSION_RELEASE 1 /* for tweaks, bug-fixes, or development */
+#define LZ4_VERSION_MINOR 8 /* for new (non-breaking) interface capabilities */
+#define LZ4_VERSION_RELEASE 0 /* for tweaks, bug-fixes, or development */
#define LZ4_VERSION_NUMBER (LZ4_VERSION_MAJOR *100*100 + LZ4_VERSION_MINOR *100 + LZ4_VERSION_RELEASE)
-int LZ4_versionNumber (void);
+#define LZ4_LIB_VERSION LZ4_VERSION_MAJOR.LZ4_VERSION_MINOR.LZ4_VERSION_RELEASE
+#define LZ4_QUOTE(str) #str
+#define LZ4_EXPAND_AND_QUOTE(str) LZ4_QUOTE(str)
+#define LZ4_VERSION_STRING LZ4_EXPAND_AND_QUOTE(LZ4_LIB_VERSION)
+LZ4LIB_API int LZ4_versionNumber (void); /**< library version number; to be used when checking dll version */
+LZ4LIB_API const char* LZ4_versionString (void); /**< library version string; to be used when checking dll version */
* Tuning parameter
* LZ4_MEMORY_USAGE :
* Memory usage formula : N->2^N Bytes (examples : 10 -> 1KB; 12 -> 4KB ; 16 -> 64KB; 20 -> 1MB; etc.)
* Increasing memory usage improves compression ratio
* Reduced memory usage can improve speed, due to cache effect
* Default value is 14, for 16KB, which nicely fits into Intel x86 L1 cache
-#define LZ4_MEMORY_USAGE 14
+#ifndef LZ4_MEMORY_USAGE
+# define LZ4_MEMORY_USAGE 14
+#endif
* Simple Functions
-int LZ4_compress_default(const char* source, char* dest, int sourceSize, int maxDestSize);
-int LZ4_decompress_safe (const char* source, char* dest, int compressedSize, int maxDecompressedSize);
-LZ4_compress_default() :
+/*! LZ4_compress_default() :
Compresses 'sourceSize' bytes from buffer 'source'
into already allocated 'dest' buffer of size 'maxDestSize'.
Compression is guaranteed to succeed if 'maxDestSize' >= LZ4_compressBound(sourceSize).
@@ -86,9 +131,10 @@
sourceSize : Max supported value is LZ4_MAX_INPUT_VALUE
maxDestSize : full or partial size of buffer 'dest' (which must be already allocated)
return : the number of bytes written into buffer 'dest' (necessarily <= maxOutputSize)
- or 0 if compression fails
+ or 0 if compression fails */
+LZ4LIB_API int LZ4_compress_default(const char* source, char* dest, int sourceSize, int maxDestSize);
-LZ4_decompress_safe() :
+/*! LZ4_decompress_safe() :
compressedSize : is the precise full size of the compressed block.
maxDecompressedSize : is the size of destination buffer, which must be already allocated.
return : the number of bytes decompressed into destination buffer (necessarily <= maxDecompressedSize)
@@ -97,15 +143,16 @@
This function is protected against buffer overflow exploits, including malicious data packets.
It never writes outside output buffer, nor reads outside input buffer.
+LZ4LIB_API int LZ4_decompress_safe (const char* source, char* dest, int compressedSize, int maxDecompressedSize);
* Advanced Functions
#define LZ4_MAX_INPUT_SIZE 0x7E000000 /* 2 113 929 216 bytes */
#define LZ4_COMPRESSBOUND(isize) ((unsigned)(isize) > (unsigned)LZ4_MAX_INPUT_SIZE ? 0 : (isize) + ((isize)/255) + 16)
LZ4_compressBound() :
Provides the maximum size that LZ4 compression may output in a "worst case" scenario (input data not compressible)
This function is primarily useful for memory allocation purposes (destination buffer size).
@@ -115,31 +162,31 @@
return : maximum output size in a "worst case" scenario
or 0, if input size is too large ( > LZ4_MAX_INPUT_SIZE)
-int LZ4_compressBound(int inputSize);
+LZ4LIB_API int LZ4_compressBound(int inputSize);
LZ4_compress_fast() :
- Same as LZ4_compress_default(), but allows selecting an "acceleration" factor.
+ Same as LZ4_compress_default(), but allows to select an "acceleration" factor.
The larger the acceleration value, the faster the algorithm, but also the lesser the compression.
It's a trade-off. It can be fine tuned, with each successive value providing roughly +~3% to speed.
An acceleration value of "1" is the same as regular LZ4_compress_default()
Values <= 0 will be replaced by ACCELERATION_DEFAULT (see lz4.c), which is 1.
-int LZ4_compress_fast (const char* source, char* dest, int sourceSize, int maxDestSize, int acceleration);
+LZ4LIB_API int LZ4_compress_fast (const char* source, char* dest, int sourceSize, int maxDestSize, int acceleration);
LZ4_compress_fast_extState() :
Same compression function, just using an externally allocated memory space to store compression state.
Use LZ4_sizeofState() to know how much memory must be allocated,
and allocate it on 8-bytes boundaries (using malloc() typically).
Then, provide it as 'void* state' to compression function.
-int LZ4_sizeofState(void);
-int LZ4_compress_fast_extState (void* state, const char* source, char* dest, int inputSize, int maxDestSize, int acceleration);
+LZ4LIB_API int LZ4_sizeofState(void);
+LZ4LIB_API int LZ4_compress_fast_extState (void* state, const char* source, char* dest, int inputSize, int maxDestSize, int acceleration);
LZ4_compress_destSize() :
Reverse the logic, by compressing as much data as possible from 'source' buffer
into already allocated buffer 'dest' of size 'targetDestSize'.
@@ -150,10 +197,10 @@
return : Nb bytes written into 'dest' (necessarily <= targetDestSize)
-int LZ4_compress_destSize (const char* source, char* dest, int* sourceSizePtr, int targetDestSize);
+LZ4LIB_API int LZ4_compress_destSize (const char* source, char* dest, int* sourceSizePtr, int targetDestSize);
LZ4_decompress_fast() :
originalSize : is the original and therefore uncompressed size
return : the number of bytes read from the source buffer (in other words, the compressed size)
@@ -164,9 +211,9 @@
However, it does not provide any protection against intentionally modified data stream (malicious input).
Use this function in trusted environment only (data to decode comes from a trusted source).
-int LZ4_decompress_fast (const char* source, char* dest, int originalSize);
+LZ4LIB_API int LZ4_decompress_fast (const char* source, char* dest, int originalSize);
LZ4_decompress_safe_partial() :
This function decompress a compressed block of size 'compressedSize' at position 'source'
into destination buffer 'dest' of size 'maxDecompressedSize'.
@@ -178,142 +225,203 @@
If the source stream is detected malformed, the function will stop decoding and return a negative result.
This function never writes outside of output buffer, and never reads outside of input buffer. It is therefore protected against malicious data packets
-int LZ4_decompress_safe_partial (const char* source, char* dest, int compressedSize, int targetOutputSize, int maxDecompressedSize);
+LZ4LIB_API int LZ4_decompress_safe_partial (const char* source, char* dest, int compressedSize, int targetOutputSize, int maxDecompressedSize);
* Streaming Compression Functions
-#define LZ4_STREAMSIZE_U64 ((1 << (LZ4_MEMORY_USAGE-3)) + 4)
-#define LZ4_STREAMSIZE (LZ4_STREAMSIZE_U64 * sizeof(long long))
- * LZ4_stream_t
- * information structure to track an LZ4 stream.
- * important : init this structure content before first use !
- * note : only allocated directly the structure if you are statically linking LZ4
- * If you are using liblz4 as a DLL, please use below construction methods instead.
-typedef struct { long long table[LZ4_STREAMSIZE_U64]; } LZ4_stream_t;
+typedef union LZ4_stream_u LZ4_stream_t; /* incomplete type (defined later) */
- * LZ4_resetStream
- * Use this function to init an allocated LZ4_stream_t structure
+/*! LZ4_createStream() and LZ4_freeStream() :
+ * LZ4_createStream() will allocate and initialize an `LZ4_stream_t` structure.
+ * LZ4_freeStream() releases its memory.
-void LZ4_resetStream (LZ4_stream_t* streamPtr);
+LZ4LIB_API LZ4_stream_t* LZ4_createStream(void);
+LZ4LIB_API int LZ4_freeStream (LZ4_stream_t* streamPtr);
- * LZ4_createStream will allocate and initialize an LZ4_stream_t structure
- * LZ4_freeStream releases its memory.
- * In the context of a DLL (liblz4), please use these methods rather than the static struct.
- * They are more future proof, in case of a change of LZ4_stream_t size.
+/*! LZ4_resetStream() :
+ * An LZ4_stream_t structure can be allocated once and re-used multiple times.
+ * Use this function to init an allocated `LZ4_stream_t` structure and start a new compression.
-LZ4_stream_t* LZ4_createStream(void);
-int LZ4_freeStream (LZ4_stream_t* streamPtr);
+LZ4LIB_API void LZ4_resetStream (LZ4_stream_t* streamPtr);
- * LZ4_loadDict
- * Use this function to load a static dictionary into LZ4_stream.
- * Any previous data will be forgotten, only 'dictionary' will remain in memory.
- * Loading a size of 0 is allowed.
- * Return : dictionary size, in bytes (necessarily <= 64 KB)
+/*! LZ4_loadDict() :
+ * Use this function to load a static dictionary into LZ4_stream.
+ * Any previous data will be forgotten, only 'dictionary' will remain in memory.
+ * Loading a size of 0 is allowed.
+ * Return : dictionary size, in bytes (necessarily <= 64 KB)
-int LZ4_loadDict (LZ4_stream_t* streamPtr, const char* dictionary, int dictSize);
+LZ4LIB_API int LZ4_loadDict (LZ4_stream_t* streamPtr, const char* dictionary, int dictSize);
- * LZ4_compress_fast_continue
- * Compress buffer content 'src', using data from previously compressed blocks as dictionary to improve compression ratio.
- * Important : Previous data blocks are assumed to still be present and unmodified !
- * 'dst' buffer must be already allocated.
- * If maxDstSize >= LZ4_compressBound(srcSize), compression is guaranteed to succeed, and runs faster.
- * If not, and if compressed data cannot fit into 'dst' buffer size, compression stops, and function returns a zero.
+/*! LZ4_compress_fast_continue() :
+ * Compress buffer content 'src', using data from previously compressed blocks as dictionary to improve compression ratio.
+ * Important : Previous data blocks are assumed to remain present and unmodified !
+ * 'dst' buffer must be already allocated.
+ * If dstCapacity >= LZ4_compressBound(srcSize), compression is guaranteed to succeed, and runs faster.
+ * If not, and if compressed data cannot fit into 'dst' buffer size, compression stops, and function @return==0.
+ * After an error, the stream status is invalid, it can only be reset or freed.
-int LZ4_compress_fast_continue (LZ4_stream_t* streamPtr, const char* src, char* dst, int srcSize, int maxDstSize, int acceleration);
+LZ4LIB_API int LZ4_compress_fast_continue (LZ4_stream_t* streamPtr, const char* src, char* dst, int srcSize, int dstCapacity, int acceleration);
- * LZ4_saveDict
- * If previously compressed data block is not guaranteed to remain available at its memory location
- * save it into a safer place (char* safeBuffer)
- * Note : you don't need to call LZ4_loadDict() afterwards,
- * dictionary is immediately usable, you can therefore call LZ4_compress_fast_continue()
- * Return : saved dictionary size in bytes (necessarily <= dictSize), or 0 if error
+ * If previously compressed data block is not guaranteed to remain available at its current memory location,
+ * Note : it's not necessary to call LZ4_loadDict() after LZ4_saveDict(), dictionary is immediately usable.
+ * @return : saved dictionary size in bytes (necessarily <= dictSize), or 0 if error.
-int LZ4_saveDict (LZ4_stream_t* streamPtr, char* safeBuffer, int dictSize);
+LZ4LIB_API int LZ4_saveDict (LZ4_stream_t* streamPtr, char* safeBuffer, int dictSize);
* Streaming Decompression Functions
+* Bufferless synchronous API
+typedef union LZ4_streamDecode_u LZ4_streamDecode_t; /* incomplete type (defined later) */
-#define LZ4_STREAMDECODESIZE_U64 4
-#define LZ4_STREAMDECODESIZE (LZ4_STREAMDECODESIZE_U64 * sizeof(unsigned long long))
-typedef struct { unsigned long long table[LZ4_STREAMDECODESIZE_U64]; } LZ4_streamDecode_t;
- * LZ4_streamDecode_t
- * init this structure content using LZ4_setStreamDecode or memset() before first use !
- * In the context of a DLL (liblz4) please prefer usage of construction methods below.
- * They are more future proof, in case of a change of LZ4_streamDecode_t size in the future.
- * LZ4_createStreamDecode will allocate and initialize an LZ4_streamDecode_t structure
- * LZ4_freeStreamDecode releases its memory.
-LZ4_streamDecode_t* LZ4_createStreamDecode(void);
-int LZ4_freeStreamDecode (LZ4_streamDecode_t* LZ4_stream);
+/*! LZ4_createStreamDecode() and LZ4_freeStreamDecode() :
+ * creation / destruction of streaming decompression tracking structure */
+LZ4LIB_API LZ4_streamDecode_t* LZ4_createStreamDecode(void);
+LZ4LIB_API int LZ4_freeStreamDecode (LZ4_streamDecode_t* LZ4_stream);
- * Use this function to instruct where to find the dictionary.
- * Setting a size of 0 is allowed (same effect as reset).
- * Return : 1 if OK, 0 if error
+/*! LZ4_setStreamDecode() :
+ * Setting a size of 0 is allowed (same effect as reset).
+ * @return : 1 if OK, 0 if error
-int LZ4_setStreamDecode (LZ4_streamDecode_t* LZ4_streamDecode, const char* dictionary, int dictSize);
+LZ4LIB_API int LZ4_setStreamDecode (LZ4_streamDecode_t* LZ4_streamDecode, const char* dictionary, int dictSize);
-*_continue() :
- These decoding functions allow decompression of multiple blocks in "streaming" mode.
- Previously decoded blocks *must* remain available at the memory position where they were decoded (up to 64 KB)
- In the case of a ring buffers, decoding buffer must be either :
- - Exactly same size as encoding buffer, with same update rule (block boundaries at same positions)
- In which case, the decoding & encoding ring buffer can have any size, including very small ones ( < 64 KB).
- - Larger than encoding buffer, by a minimum of maxBlockSize more bytes.
- maxBlockSize is implementation dependent. It's the maximum size you intend to compress into a single block.
- In which case, encoding and decoding buffers do not need to be synchronized,
- and encoding ring buffer can have any size, including small ones ( < 64 KB).
- - _At least_ 64 KB + 8 bytes + maxBlockSize.
- and encoding ring buffer can have any size, including larger than decoding buffer.
- Whenever these conditions are not possible, save the last 64KB of decoded data into a safe buffer,
- and indicate where it is saved using LZ4_setStreamDecode()
+/*! LZ4_decompress_*_continue() :
+ * These decoding functions allow decompression of multiple blocks in "streaming" mode.
+ * Previously decoded blocks *must* remain available at the memory position where they were decoded (up to 64 KB)
+ * In the case of a ring buffers, decoding buffer must be either :
+ * - Exactly same size as encoding buffer, with same update rule (block boundaries at same positions)
+ * In which case, the decoding & encoding ring buffer can have any size, including very small ones ( < 64 KB).
+ * - Larger than encoding buffer, by a minimum of maxBlockSize more bytes.
+ * maxBlockSize is implementation dependent. It's the maximum size you intend to compress into a single block.
+ * In which case, encoding and decoding buffers do not need to be synchronized,
+ * and encoding ring buffer can have any size, including small ones ( < 64 KB).
+ * - _At least_ 64 KB + 8 bytes + maxBlockSize.
+ * and encoding ring buffer can have any size, including larger than decoding buffer.
+ * Whenever these conditions are not possible, save the last 64KB of decoded data into a safe buffer,
+ * and indicate where it is saved using LZ4_setStreamDecode()
-int LZ4_decompress_safe_continue (LZ4_streamDecode_t* LZ4_streamDecode, const char* source, char* dest, int compressedSize, int maxDecompressedSize);
-int LZ4_decompress_fast_continue (LZ4_streamDecode_t* LZ4_streamDecode, const char* source, char* dest, int originalSize);
+LZ4LIB_API int LZ4_decompress_safe_continue (LZ4_streamDecode_t* LZ4_streamDecode, const char* source, char* dest, int compressedSize, int maxDecompressedSize);
+LZ4LIB_API int LZ4_decompress_fast_continue (LZ4_streamDecode_t* LZ4_streamDecode, const char* source, char* dest, int originalSize);
-Advanced decoding functions :
-*_usingDict() :
- These decoding functions work the same as
- a combination of LZ4_setStreamDecode() followed by LZ4_decompress_x_continue()
- They are stand-alone. They don't need nor update an LZ4_streamDecode_t structure.
-int LZ4_decompress_safe_usingDict (const char* source, char* dest, int compressedSize, int maxDecompressedSize, const char* dictStart, int dictSize);
-int LZ4_decompress_fast_usingDict (const char* source, char* dest, int originalSize, const char* dictStart, int dictSize);
+/*! LZ4_decompress_*_usingDict() :
+ * These decoding functions work the same as
+ * a combination of LZ4_setStreamDecode() followed by LZ4_decompress_*_continue()
+ * They are stand-alone, and don't need an LZ4_streamDecode_t structure.
+LZ4LIB_API int LZ4_decompress_safe_usingDict (const char* source, char* dest, int compressedSize, int maxDecompressedSize, const char* dictStart, int dictSize);
+LZ4LIB_API int LZ4_decompress_fast_usingDict (const char* source, char* dest, int originalSize, const char* dictStart, int dictSize);
+ * !!!!!! STATIC LINKING ONLY !!!!!!
+ * Private definitions
+ * Do not use these definitions.
+ * They are exposed to allow static allocation of `LZ4_stream_t` and `LZ4_streamDecode_t`.
+ * Using these definitions will expose code to API and/or ABI break in future versions of the library.
+#define LZ4_HASHLOG (LZ4_MEMORY_USAGE-2)
+#define LZ4_HASHTABLESIZE (1 << LZ4_MEMORY_USAGE)
+#define LZ4_HASH_SIZE_U32 (1 << LZ4_HASHLOG) /* required as macro for static allocation */
+#if defined(__cplusplus) || (defined (__STDC_VERSION__) && (__STDC_VERSION__ >= 199901L) /* C99 */)
+#include <stdint.h>
+typedef struct {
+ uint32_t hashTable[LZ4_HASH_SIZE_U32];
+ uint32_t currentOffset;
+ uint32_t initCheck;
+ const uint8_t* dictionary;
+ uint8_t* bufferStart; /* obsolete, used for slideInputBuffer */
+ uint32_t dictSize;
+} LZ4_stream_t_internal;
+typedef struct {
+ const uint8_t* externalDict;
+ size_t extDictSize;
+ const uint8_t* prefixEnd;
+ size_t prefixSize;
+} LZ4_streamDecode_t_internal;
+#else
+typedef struct {
+ unsigned int hashTable[LZ4_HASH_SIZE_U32];
+ unsigned int currentOffset;
+ unsigned int initCheck;
+ const unsigned char* dictionary;
+ unsigned char* bufferStart; /* obsolete, used for slideInputBuffer */
+ unsigned int dictSize;
+typedef struct {
+ const unsigned char* externalDict;
+ const unsigned char* prefixEnd;
+#endif
+ * LZ4_stream_t :
+ * information structure to track an LZ4 stream.
+ * init this structure before first use.
+ * note : only use in association with static linking !
+ * this definition is not API/ABI safe,
+ * it may change in a future version !
+#define LZ4_STREAMSIZE_U64 ((1 << (LZ4_MEMORY_USAGE-3)) + 4)
+#define LZ4_STREAMSIZE (LZ4_STREAMSIZE_U64 * sizeof(unsigned long long))
+union LZ4_stream_u {
+ unsigned long long table[LZ4_STREAMSIZE_U64];
+ LZ4_stream_t_internal internal_donotuse;
+} ; /* previously typedef'd to LZ4_stream_t */
+ * LZ4_streamDecode_t :
+ * information structure to track an LZ4 stream during decompression.
+ * init this structure using LZ4_setStreamDecode (or memset()) before first use
+ * and may change in a future version !
+#define LZ4_STREAMDECODESIZE_U64 4
+#define LZ4_STREAMDECODESIZE (LZ4_STREAMDECODESIZE_U64 * sizeof(unsigned long long))
+union LZ4_streamDecode_u {
+ unsigned long long table[LZ4_STREAMDECODESIZE_U64];
+ LZ4_streamDecode_t_internal internal_donotuse;
+} ; /* previously typedef'd to LZ4_streamDecode_t */
-/* Deprecate Warnings */
-/* Should these warnings messages be a problem,
+/*! Deprecation warnings
+ Should deprecation warnings be a problem,
it is generally possible to disable them,
- with -Wno-deprecated-declarations for gcc
- or _CRT_SECURE_NO_WARNINGS in Visual for example.
- You can also define LZ4_DEPRECATE_WARNING_DEFBLOCK. */
-#ifndef LZ4_DEPRECATE_WARNING_DEFBLOCK
-# define LZ4_DEPRECATE_WARNING_DEFBLOCK
+ typically with -Wno-deprecated-declarations for gcc
+ or _CRT_SECURE_NO_WARNINGS in Visual.
+ Otherwise, it's also possible to define LZ4_DISABLE_DEPRECATE_WARNINGS */
+#ifdef LZ4_DISABLE_DEPRECATE_WARNINGS
+# define LZ4_DEPRECATED(message) /* disable deprecation warnings */
+#else
# define LZ4_GCC_VERSION (__GNUC__ * 100 + __GNUC_MINOR__)
-# if (LZ4_GCC_VERSION >= 405) || defined(__clang__)
+# if defined (__cplusplus) && (__cplusplus >= 201402) /* C++14 or greater */
+# define LZ4_DEPRECATED(message) [[deprecated(message)]]
+# elif (LZ4_GCC_VERSION >= 405) || defined(__clang__)
# define LZ4_DEPRECATED(message) __attribute__((deprecated(message)))
# elif (LZ4_GCC_VERSION >= 301)
# define LZ4_DEPRECATED(message) __attribute__((deprecated))
@@ -323,38 +431,33 @@
# pragma message("WARNING: You need to implement LZ4_DEPRECATED for this compiler")
# endif
-#endif /* LZ4_DEPRECATE_WARNING_DEFBLOCK */
+#endif /* LZ4_DISABLE_DEPRECATE_WARNINGS */
/* Obsolete compression functions */
-/* These functions are planned to start generate warnings by r131 approximately */
-int LZ4_compress (const char* source, char* dest, int sourceSize);
-int LZ4_compress_limitedOutput (const char* source, char* dest, int sourceSize, int maxOutputSize);
-int LZ4_compress_withState (void* state, const char* source, char* dest, int inputSize);
-int LZ4_compress_limitedOutput_withState (void* state, const char* source, char* dest, int inputSize, int maxOutputSize);
-int LZ4_compress_continue (LZ4_stream_t* LZ4_streamPtr, const char* source, char* dest, int inputSize);
-int LZ4_compress_limitedOutput_continue (LZ4_stream_t* LZ4_streamPtr, const char* source, char* dest, int inputSize, int maxOutputSize);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_compress_default() instead") int LZ4_compress (const char* source, char* dest, int sourceSize);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_compress_default() instead") int LZ4_compress_limitedOutput (const char* source, char* dest, int sourceSize, int maxOutputSize);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_compress_fast_extState() instead") int LZ4_compress_withState (void* state, const char* source, char* dest, int inputSize);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_compress_fast_extState() instead") int LZ4_compress_limitedOutput_withState (void* state, const char* source, char* dest, int inputSize, int maxOutputSize);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_compress_fast_continue() instead") int LZ4_compress_continue (LZ4_stream_t* LZ4_streamPtr, const char* source, char* dest, int inputSize);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_compress_fast_continue() instead") int LZ4_compress_limitedOutput_continue (LZ4_stream_t* LZ4_streamPtr, const char* source, char* dest, int inputSize, int maxOutputSize);
/* Obsolete decompression functions */
-/* These function names are completely deprecated and must no longer be used.
- They are only provided here for compatibility with older programs.
- - LZ4_uncompress is the same as LZ4_decompress_fast
- - LZ4_uncompress_unknownOutputSize is the same as LZ4_decompress_safe
- These function prototypes are now disabled; uncomment them only if you really need them.
- It is highly recommended to stop using these prototypes and migrate to maintained ones */
-/* int LZ4_uncompress (const char* source, char* dest, int outputSize); */
-/* int LZ4_uncompress_unknownOutputSize (const char* source, char* dest, int isize, int maxOutputSize); */
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_decompress_fast() instead") int LZ4_uncompress (const char* source, char* dest, int outputSize);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_decompress_safe() instead") int LZ4_uncompress_unknownOutputSize (const char* source, char* dest, int isize, int maxOutputSize);
/* Obsolete streaming functions; use new streaming interface whenever possible */
-LZ4_DEPRECATED("use LZ4_createStream() instead") void* LZ4_create (char* inputBuffer);
-LZ4_DEPRECATED("use LZ4_createStream() instead") int LZ4_sizeofStreamState(void);
-LZ4_DEPRECATED("use LZ4_resetStream() instead") int LZ4_resetStreamState(void* state, char* inputBuffer);
-LZ4_DEPRECATED("use LZ4_saveDict() instead") char* LZ4_slideInputBuffer (void* state);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_createStream() instead") void* LZ4_create (char* inputBuffer);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_createStream() instead") int LZ4_sizeofStreamState(void);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_resetStream() instead") int LZ4_resetStreamState(void* state, char* inputBuffer);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_saveDict() instead") char* LZ4_slideInputBuffer (void* state);
/* Obsolete streaming decoding functions */
-LZ4_DEPRECATED("use LZ4_decompress_safe_usingDict() instead") int LZ4_decompress_safe_withPrefix64k (const char* src, char* dst, int compressedSize, int maxDstSize);
-LZ4_DEPRECATED("use LZ4_decompress_fast_usingDict() instead") int LZ4_decompress_fast_withPrefix64k (const char* src, char* dst, int originalSize);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_decompress_safe_usingDict() instead") int LZ4_decompress_safe_withPrefix64k (const char* src, char* dst, int compressedSize, int maxDstSize);
+LZ4LIB_API LZ4_DEPRECATED("use LZ4_decompress_fast_usingDict() instead") int LZ4_decompress_fast_withPrefix64k (const char* src, char* dst, int originalSize);
+#endif /* LZ4_H_2983827168210 */
#endif
