[GRASS-SVN] r72002 - grass/branches/releasebranch_7_4/general/g.message
Sat Dec 30 02:57:34 PST 2017
Author: neteler
Date: 2017-12-30 02:57:34 -0800 (Sat, 30 Dec 2017)
New Revision: 72002
   grass/branches/releasebranch_7_4/general/g.message/g.message.html
g.message manual: example added (contributed by Jerry Huang and Google Code-in); further improvements according to https://trac.osgeo.org/grass/wiki/Submitting/Docs
Modified: grass/branches/releasebranch_7_4/general/g.message/g.message.html
--- grass/branches/releasebranch_7_4/general/g.message/g.message.html	2017-12-30 10:55:06 UTC (rev 72001)
+++ grass/branches/releasebranch_7_4/general/g.message/g.message.html	2017-12-30 10:57:34 UTC (rev 72002)
@@ -7,7 +7,7 @@
 <tt>GRASS_MESSAGE_FORMAT</tt> environment variables.
 <p>
-The program can be used for standard informative messages as well as warnings
+The program can be used for standard informative messages as well as warnings
 (<b>-w</b> flag) and fatal errors (<b>-e</b> flag). For debugging
 purposes, the <b>-d</b> flag will cause <em>g.message</em> to print a debugging
 message at the given level.
@@ -82,9 +82,9 @@
 Controlled by the "<tt>GRASS_VERBOSE</tt>" environment variable. Typically this
 is set using the <b>--quiet</b> or <b>--verbose</b> command line options.
 <ul>
-<li>0 - only errors and warnings are printed
-<li>1 - progress messages are printed
-<li>2 - all module messages are printed
+<li>0 - only errors and warnings are printed
+<li>1 - progress messages are printed
+<li>2 - all module messages are printed
 <li>3 - additional verbose messages are printed
 </ul>
@@ -96,9 +96,47 @@
 <ul>
 <li>1 - message is printed once or few times per module
 <li>3 - each row (raster) or line (vector)
-<li>5 - each cell (raster) or point (vector)
+<li>5 - each cell (raster) or point (vector)
 </ul>
+<h2>EXAMPLES</h2>
+This basic example prints the message "hello" in the console:
+<div class="code"><pre>
+g.message message="hello"
+</pre></div>
+<p>
+To print a message as an error message use the <b>-e</b> flag:
+g.message -e message="my error"
+</pre></div>
+<p>
+To print a message highlighted as a debug message ("D0/0: debug") in the
+console, use the <b>-d</b> flag. Optionally the debug level can be defined (see
+also <a href="g.gisenv.html">g.gisenv</a> for details):
+# Levels: (recommended levels)
+#   0 - silence
+#   1 - message is printed once or few times per module
+#   3 - each row (raster) or line (vector)
+#   5 - each cell (raster) or point (vector)
+g.message -d message="debug" debug=0
+</pre></div>
+<p>
+To print a message highlighted as a warning message ("WARNING: my warning")
+in the console, use the <b>-w</b> flag:
+g.message -w message="my warning"
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="variables.html">GRASS variables and environment variables</a><br>
