[GRASS-SVN] r70477 - grass/trunk/imagery/i.zc
Thu Feb 2 08:59:40 PST 2017
Author: mlennert
Date: 2017-02-02 08:59:40 -0800 (Thu, 02 Feb 2017)
New Revision: 70477
   grass/trunk/imagery/i.zc/i.zc.html
   grass/trunk/imagery/i.zc/main.c
i.zc: threshold was not read correctly and had no effect
Modified: grass/trunk/imagery/i.zc/i.zc.html
--- grass/trunk/imagery/i.zc/i.zc.html	2017-02-02 15:41:19 UTC (rev 70476)
+++ grass/trunk/imagery/i.zc/i.zc.html	2017-02-02 16:59:40 UTC (rev 70477)
@@ -34,7 +34,7 @@
 <p>
 The <b>threshold=</b> parameter determines the "sensitivity" of the
-Gaussian filter.  The default value is <b>10</b>;  higher and
+Gaussian filter.  The default value is <b>0.01</b>;  higher and
 lower values can be tested by the user.  Increasing the
 threshold value will result in fewer edges being found.
Modified: grass/trunk/imagery/i.zc/main.c
--- grass/trunk/imagery/i.zc/main.c	2017-02-02 15:41:19 UTC (rev 70476)
+++ grass/trunk/imagery/i.zc/main.c	2017-02-02 16:59:40 UTC (rev 70477)
@@ -86,7 +86,7 @@
     threshold->required = NO;
     threshold->multiple = NO;
     threshold->description = _("Sensitivity of Gaussian filter");
-    threshold->answer = "10";
+    threshold->answer = "0.01";
     orientations = G_define_option();
     orientations->key = "orientations";
@@ -103,10 +103,9 @@
     /* open input cell map */
     inputfd = Rast_open_old(input_map->answer, "");
-    sscanf(threshold->answer, "%1lf", &Thresh);
+    Thresh = atof(threshold->answer);
     if (Thresh <= 0.0)
 	G_fatal_error(_("Threshold less than or equal to zero not allowed"));
-    Thresh /= 100.0;
     sscanf(width->answer, "%f", &Width);
