[GRASS-SVN] r70501 - grass/trunk/vector/v.out.ogr
svn_grass at osgeo.org
Wed Feb 8 01:15:37 PST 2017
Author: martinl
Date: 2017-02-08 01:15:37 -0800 (Wed, 08 Feb 2017)
New Revision: 70501
grass/trunk/vector/v.out.ogr/args.c
grass/trunk/vector/v.out.ogr/main.c
v.out.ogr: fatal_error -> option rule
Modified: grass/trunk/vector/v.out.ogr/args.c
--- grass/trunk/vector/v.out.ogr/args.c 2017-02-08 09:05:21 UTC (rev 70500)
+++ grass/trunk/vector/v.out.ogr/args.c 2017-02-08 09:15:37 UTC (rev 70501)
@@ -126,6 +126,8 @@
_("Create a new empty layer in defined OGR datasource "
"and exit. Nothing is read from input.");
flags->new->guisection = _("Creation");
+ G_option_requires(flags->append, options->layer, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c 2017-02-08 09:05:21 UTC (rev 70500)
+++ grass/trunk/vector/v.out.ogr/main.c 2017-02-08 09:15:37 UTC (rev 70501)
@@ -193,10 +193,6 @@
if (!options.layer->answer) {
char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
- if (flags.append->answer)
- G_fatal_error(_("Appending to OGR layer requires option '%s'"),
- options.layer->key);
if (G_name_is_fully_qualified(options.input->answer, xname, xmapset))
options.layer->answer = G_store(xname);
else
