[GRASS-SVN] r70509 - grass/trunk/raster/r.to.vect
svn_grass at osgeo.org
Wed Feb 8 17:58:57 PST 2017
Author: hcho
Date: 2017-02-08 17:58:57 -0800 (Wed, 08 Feb 2017)
New Revision: 70509
grass/trunk/raster/r.to.vect/areas_io.c
grass/trunk/raster/r.to.vect/global.h
r.to.vect: Fix a couple of compile errors/warnings
Modified: grass/trunk/raster/r.to.vect/areas_io.c
--- grass/trunk/raster/r.to.vect/areas_io.c 2017-02-08 19:53:53 UTC (rev 70508)
+++ grass/trunk/raster/r.to.vect/areas_io.c 2017-02-09 01:58:57 UTC (rev 70509)
@@ -34,7 +34,7 @@
int write_boundary(struct COOR *seed)
struct COOR *point, *line_begin, *line_end, *last;
- int dir, line_type, n, n1, i;
+ int dir, line_type, n, n1;
point = seed;
if ((dir = at_end(point))) { /* already have one end of line */
Modified: grass/trunk/raster/r.to.vect/global.h
--- grass/trunk/raster/r.to.vect/global.h 2017-02-08 19:53:53 UTC (rev 70508)
+++ grass/trunk/raster/r.to.vect/global.h 2017-02-09 01:58:57 UTC (rev 70509)
@@ -104,7 +104,7 @@
int extract_lines(void);
/* lines_io.c */
-int write_line(struct COOR *seed);
+int write_line(struct COOR *);
/* areas.c */
int alloc_areas_bufs(int);
@@ -112,7 +112,7 @@
int more_equivs(void);
/* areas_io.c */
-int write_boundary(struct COOR *seed);
+int write_boundary(struct COOR *);
int write_area(struct area_table *, struct equiv_table *, int, int);
/* points.c */
@@ -124,4 +124,7 @@
int at_end(struct COOR *);
int read_row(void *);
void insert_value(int, int, double);
-int free_ptr(struct COOR *ptr);
+int free_ptr(struct COOR *);
+/* set_error_handler.c */
+void set_error_handler(struct Map_info *, dbDriver **);
