[GRASS-SVN] r70520 - grass/trunk/display/d.vect
svn_grass at osgeo.org
Fri Feb 10 01:09:00 PST 2017
Author: martinl
Date: 2017-02-10 01:09:00 -0800 (Fri, 10 Feb 2017)
New Revision: 70520
grass/trunk/display/d.vect/main.c
grass/trunk/display/d.vect/shape.c
d.vect: zcolor, rgb_column, and -c mutually exclusive
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2017-02-09 20:27:06 UTC (rev 70519)
+++ grass/trunk/display/d.vect/main.c 2017-02-10 09:09:00 UTC (rev 70520)
@@ -329,6 +329,8 @@
legend_flag->label = _("Do not show this layer in vector legend");
legend_flag->guisection = _("Legend");
+ G_option_exclusive(zcol_opt, rgbcol_opt, cats_acolors_flag, NULL);
/* Check command line */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
Modified: grass/trunk/display/d.vect/shape.c
--- grass/trunk/display/d.vect/shape.c 2017-02-09 20:27:06 UTC (rev 70519)
+++ grass/trunk/display/d.vect/shape.c 2017-02-10 09:09:00 UTC (rev 70520)
@@ -183,8 +183,7 @@
z_style = NULL;
else if (rgb_column) {
- G_warning(_("%s= and %s= are mutually exclusive. "
- "%s= will be ignored."), "zcolor", "rgb_column", "zcolor");
+ /* this should not happend, zcolor and rgb_columns are mutually exclusive */
z_style = NULL;
else {
