[GRASS-SVN] r70527 - grass/trunk/vector/v.info
svn_grass at osgeo.org
Fri Feb 10 03:14:18 PST 2017
Author: martinl
Date: 2017-02-10 03:14:18 -0800 (Fri, 10 Feb 2017)
New Revision: 70527
grass/trunk/vector/v.info/level1.c
v.info: level1 cosmetics - remove outdated commets, destroy structs
Modified: grass/trunk/vector/v.info/level1.c
--- grass/trunk/vector/v.info/level1.c 2017-02-10 10:48:11 UTC (rev 70526)
+++ grass/trunk/vector/v.info/level1.c 2017-02-10 11:14:18 UTC (rev 70527)
@@ -28,11 +28,12 @@
Vect_rewind(Map);
G_message(_("Topology not available for vector map <%s>. "
"Registering primitives..."), Vect_get_full_name(Map));
- while (1) {
+ while (TRUE) {
/* register line */
type = Vect_read_next_line(Map, Points, Cats);
- /* Note: check for dead lines is not needed, because they are skipped by V1_read_next_line_nat() */
+ /* Note: check for dead lines is not needed, because they are
+ skipped by V1_read_next_line_nat() */
if (type == -1) {
G_warning(_("Unable to read vector map"));
return 0;
@@ -61,27 +62,17 @@
G_debug(3, "Register line: offset = %lu", (unsigned long)offset);
dig_line_box(Points, &box);
- if (first == 1) {
+ if (first == TRUE) {
Vect_box_copy(&(plus->box), &box);
- first = 0;
+ first = FALSE;
else
Vect_box_extend(&(plus->box), &box);
- /* can't print progress, unfortunately */
- /* what about using G_clicker() then. or, check file
- size with stat.st_size and make a rough guess? */
- if (G_verbose() > G_verbose_min() && i % 1000 == 0) {
- if (format == G_INFO_FORMAT_PLAIN)
- fprintf(stderr, "%d..", i);
- else
- fprintf(stderr, "%11d\b\b\b\b\b\b\b\b\b\b\b", i);
- i++;
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats);
/* save result in plus */
plus->n_lines = n_primitives;
plus->n_plines = n_points;
