[GRASS-SVN] r70532 - grass/trunk/raster/r.terraflow
Sat Feb 11 13:22:16 PST 2017
Author: martinl
Date: 2017-02-11 13:22:16 -0800 (Sat, 11 Feb 2017)
New Revision: 70532
   grass/trunk/raster/r.terraflow/flow.cpp
   grass/trunk/raster/r.terraflow/main.cpp
   grass/trunk/raster/r.terraflow/r.terraflow.html
   grass/trunk/raster/r.terraflow/weightWindow.cpp
r.terraflow: module description simplification
             module updates
             fix some warnings
Modified: grass/trunk/raster/r.terraflow/flow.cpp
--- grass/trunk/raster/r.terraflow/flow.cpp	2017-02-11 19:22:10 UTC (rev 70531)
+++ grass/trunk/raster/r.terraflow/flow.cpp	2017-02-11 21:22:16 UTC (rev 70532)
@@ -220,7 +220,7 @@
   G_debug(1, "sweep stream size: %.2fMB",
           (double)sweepstr->stream_len()*sizeof(sweepItem)/(1<<20));
-  G_debug(1, " (%d items, item size=%d B\n ",
+  G_debug(1, " (%d items, item size=%ld B\n ",
           (int)sweepstr->stream_len(), sizeof(sweepItem));;
   if (stats)
Modified: grass/trunk/raster/r.terraflow/main.cpp
--- grass/trunk/raster/r.terraflow/main.cpp	2017-02-11 19:22:10 UTC (rev 70531)
+++ grass/trunk/raster/r.terraflow/main.cpp	2017-02-11 21:22:16 UTC (rev 70532)
@@ -134,7 +134,7 @@
   mem->key         = "memory";
   mem->type        = TYPE_INTEGER;
   mem->required    = NO;
-  mem->answer      = "300";
+  mem->answer      = (char *) "300";
   mem->description = _("Maximum memory to be used (in MB)");
   /* temporary STREAM path */
@@ -153,7 +153,7 @@
   stats_opt->key        = "stats";
   stats_opt->type       = TYPE_STRING;
   stats_opt->required   = NO;
-  stats_opt->description= _("Name of file containing runtime statistics");
+  stats_opt->description= _("Name for output file containing runtime statistics");
   stats_opt->guisection = _("Outputs");
   G_option_requires(input_elev, output_elev, output_dir, output_watershed,
@@ -240,8 +240,8 @@
 #endif
 #ifdef ELEV_FLOAT
-	G_verbose_message( _("Elevation stored as FLOAT (%dB)"),
-			sizeof(elevation_type));
+	G_verbose_message(_("Elevation stored as FLOAT (%ldB)"),
+                          sizeof(elevation_type));
 	if (data_type == CELL_TYPE) {
 	  G_warning(_("Raster map <%s> is of type CELL_TYPE "
                       "-- you should use r.terraflow.short"), opt->elev_grid);
@@ -421,10 +421,10 @@
   G_debug(1, "total elements=%ld, nodata elements=%ld",
           (long)nrows * ncols, nodata_count);
   G_debug(1, "largest temporary files: ");
-  G_debug(1, "\t\t FILL: %s [%ld elements, %dB each]",
+  G_debug(1, "\t\t FILL: %s [%ld elements, %ldB each]",
           formatNumber(buf, fillmaxsize),
           (long)nrows * ncols, sizeof(waterWindowType));
-  G_debug(1, "\t\t FLOW: %s [%ld elements, %dB each]",
+  G_debug(1, "\t\t FLOW: %s [%ld elements, %ldB each]",
           formatNumber(buf, flowmaxsize),
           (long)nrows * ncols - nodata_count, sizeof(sweepItem));
   G_debug(1, "Will need at least %s space available in %s",
@@ -461,14 +461,7 @@
   module = G_define_module();
-#ifdef ELEV_SHORT
-  module->label = _("Performs flow computation for massive grids.");
-  module->description = _("Integer version.");
-#endif
-#ifdef ELEV_FLOAT
-  module->description = _("Float version.");
-#endif
+  module->description = _("Performs flow computation for massive grids.");
   G_add_keyword(_("raster"));
   G_add_keyword(_("hydrology"));
   G_add_keyword(_("flow"));
Modified: grass/trunk/raster/r.terraflow/r.terraflow.html
--- grass/trunk/raster/r.terraflow/r.terraflow.html	2017-02-11 19:22:10 UTC (rev 70531)
+++ grass/trunk/raster/r.terraflow/r.terraflow.html	2017-02-11 21:22:16 UTC (rev 70532)
@@ -72,11 +72,11 @@
 <b>d8cut</b> option, then
 the flow of this cell is routed to its neighbors using the SFD (D8)
 model. This option affects only the flow accumulation raster and is
-meaningful only for MFD flow (i.e. if the -s flag is not used); If
+meaningful only for MFD flow (i.e. if the <b>-s</b> flag is not used); If
 this option is used for SFD flow it is ignored. The default value of
 <b>d8cut</b> is <i>infinity</i>.
-<p><em>r.terraflow</em> also computes the tci raster (topographic convergence
+<p><em>r.terraflow</em> also computes the <b>tci</b> raster (topographic convergence
 index, defined as the logarithm of the ratio of flow accumulation and
 local slope).
@@ -96,7 +96,7 @@
 is the number of valid (not no-data) cells in the input elevation
 raster).
 <p>All these intermediate temporary files are stored in the path specified
-by the <b>STREAM_DIR</b> option. Note: <b>STREAM_DIR</b> must contain
+by the <b>directory</b> option. Note: <b>directory</b> must contain
 enough free disk space in order to store up to 2 x 80N bytes.
 <p>The <b>memory</b> option can be used to set the maximum amount of main
@@ -118,8 +118,7 @@
 created by the user if needed.
 <p>Hints concerning compilation with storage of elevations internally as
-shorts:
-<br>such a version uses less space (up to 60B per cell, up
+shorts: such a version uses less space (up to 60B per cell, up
 to 60N intermediate file) and therefore is more space and time
 efficient. <em>r.terraflow</em> is intended for use with floating
 point raster data (FCELL), and <em>r.terraflow (short)</em> with integer
@@ -147,12 +146,10 @@
 <h2>EXAMPLES</h2>
-Example for small area in North Carolina sample dataset:
+Example for small area in North Carolina sample dataset to calculate flow accumulation:
 <div class="code"><pre>
 g.region raster=elev_lid792_1m
-r.terraflow elevation=elev_lid792_1m filled=elev_lid792_1m_filled \
-    direction=elev_lid792_1m_direction swatershed=elev_lid792_1m_swatershed \
-    accumulation=elev_lid792_1m_accumulation tci=elev_lid792_1m_tci
+r.terraflow elevation=elev_lid792_1m accumulation=elev_lid792_1m_accumulation
 </pre></div>
 <div align="center" style="margin: 10px">
@@ -189,7 +186,35 @@
 </pre></div>
+<h2>REFERENCES</h2>
+<ol>
+  <li> The <a href="http://www.cs.duke.edu/geo*/terraflow/">TerraFlow</a> project at Duke University
+  <li><A NAME="arge:drainage"
+       HREF="http://www.cs.duke.edu/geo*/terraflow/papers/alenex00_drainage.ps.gz">
+       I/O-efficient algorithms for problems on grid-based
+       terrains</a>.  Lars Arge, Laura Toma, and Jeffrey S. Vitter. In
+       <em>Proc. Workshop on Algorithm Engineering and Experimentation</em>,
+       2000. To appear in <em>Journal of Experimental Algorithms</em>.
+  <li><A NAME="terraflow:acmgis01"
+       HREF="http://www.cs.duke.edu/geo*/terraflow/papers/acmgis01_terraflow.pdf">
+       Flow computation on massive grids</a>.
+       Lars Arge, Jeffrey S. Chase, Patrick N. Halpin, Laura Toma,
+       Jeffrey S. Vitter, Dean Urban and Rajiv Wickremesinghe. In
+       <em>Proc. ACM Symposium on Advances in Geographic Information
+       Systems</em>, 2001.
+  <li><A NAME="terraflow:geoinformatica"
+       HREF="http://www.cs.duke.edu/geo*/terraflow/papers/journal_terraflow.pdf">
+       Flow computation on massive grid terrains</a>.
+       In <em>GeoInformatica, International Journal on
+       Advances of Computer Science for Geographic Information
+       Systems</em>, 7(4):283-313, December 2003.
+</ol>
 <h2>SEE ALSO</h2>
 <em>
@@ -202,8 +227,6 @@
 <a href="r.watershed.html">r.watershed</a>
 </em>
 <h2>AUTHORS</h2>
 <dl>
@@ -226,34 +249,4 @@
 	<dt>Contact: <a href="mailto:ltoma at bowdoin.edu "> Laura Toma</a></dt>
 </dl>
-<h2>REFERENCES</h2>
-<ol>
-  <li> The <a href="http://www.cs.duke.edu/geo*/terraflow/">TerraFlow</a> project at Duke University
-  <li><A NAME="arge:drainage"
-       HREF="http://www.cs.duke.edu/geo*/terraflow/papers/alenex00_drainage.ps.gz">
-       I/O-efficient algorithms for problems on grid-based
-       terrains</a>.  Lars Arge, Laura Toma, and Jeffrey S. Vitter. In
-       <em>Proc. Workshop on Algorithm Engineering and Experimentation</em>,
-       2000. To appear in <em>Journal of Experimental Algorithms</em>.
-  <li><A NAME="terraflow:acmgis01"
-       HREF="http://www.cs.duke.edu/geo*/terraflow/papers/acmgis01_terraflow.pdf">
-       Flow computation on massive grids</a>.
-       Lars Arge, Jeffrey S. Chase, Patrick N. Halpin, Laura Toma,
-       Jeffrey S. Vitter, Dean Urban and Rajiv Wickremesinghe. In
-       <em>Proc. ACM Symposium on Advances in Geographic Information
-       Systems</em>, 2001.
-  <li><A NAME="terraflow:geoinformatica"
-       HREF="http://www.cs.duke.edu/geo*/terraflow/papers/journal_terraflow.pdf">
-       Flow computation on massive grid terrains</a>.
-       In <em>GeoInformatica, International Journal on
-       Advances of Computer Science for Geographic Information
-       Systems</em>, 7(4):283-313, December 2003.
-</ol>
 <p><i>Last changed: $Date$</i>
Modified: grass/trunk/raster/r.terraflow/weightWindow.cpp
--- grass/trunk/raster/r.terraflow/weightWindow.cpp	2017-02-11 19:22:10 UTC (rev 70531)
+++ grass/trunk/raster/r.terraflow/weightWindow.cpp	2017-02-11 21:22:16 UTC (rev 70532)
@@ -192,8 +192,7 @@
 		      const direction_type dir,
 		      const int trustdir) {
-  elevation_type elev_crt, elev_neighb, e_diff;
-  dimension_type i_neighb, j_neighb;
+  elevation_type elev_crt, elev_neighb;
   /* initialize all weights to 0 */
   init();
@@ -210,10 +209,7 @@
     for (short dj = -1; dj <= 1; dj++) {
       /* grid coordinates and elevation of neighbour */
-      i_neighb = i + di;
-      j_neighb = j + dj;
       elev_neighb = elevwin.get(di, dj);
-      e_diff = (elevation_type)(elev_crt - elev_neighb);
       skipit = ((di ==0) && (dj==0));
       skipit |= (elev_crt < elev_neighb);
