[GRASS-SVN] r70534 - grass/trunk/gui/wxpython/lmgr
Sat Feb 11 14:24:38 PST 2017
Author: wenzeslaus
Date: 2017-02-11 14:24:38 -0800 (Sat, 11 Feb 2017)
New Revision: 70534
   grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI/lmgr: center forms in Layers (layer props and v.colors) on parent, not screen
This reverts behavior from r42374, see also r32519.
Centering on lmgr is consistent with adding new layers.
It is not consistent with some other forms started from
layer context menu (e.g. r.colors).
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py	2017-02-11 21:23:15 UTC (rev 70533)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py	2017-02-11 22:24:38 UTC (rev 70534)
@@ -154,6 +154,8 @@
         # if cursor points at layer checkbox (to cancel selection changes)
         self.hitCheckbox = False
         self.forceCheck = False              # force check layer if CheckItem is called
+        # forms default to centering on screen, this will put on lmgr
+        self.centreFromsOnParent = True
         try:
             ctstyle |= CT.TR_ALIGN_WINDOWS
@@ -1014,8 +1016,8 @@
     def OnVectorColorTable(self, event):
         """Set color table for vector map"""
         name = self.GetLayerInfo(self.layer_selected, key='maplayer').GetName()
-        GUI(parent=self, centreOnParent=False).ParseCommand(['v.colors',
-                                                             'map=%s' % name])
+        GUI(parent=self, centreOnParent=self.centreFromsOnParent).ParseCommand(
+            ['v.colors', 'map=%s' % name])
     def OnCopyMap(self, event):
         """Copy selected map into current mapset"""
@@ -1530,7 +1532,8 @@
         cmd = None
         if self.GetLayerInfo(layer, key='cmd'):
-            module = GUI(parent=self, show=show, centreOnParent=False)
+            module = GUI(parent=self, show=show,
+                         centreOnParent=self.centreFromsOnParent)
             module.ParseCommand(self.GetLayerInfo(layer, key='cmd'),
                                 completed=(self.GetOptData, layer, params))
             self.SetLayerInfo(layer, key='cmd', value=module.GetCmd())
@@ -1544,7 +1547,7 @@
                 cmd += GetDisplayVectSettings()
         if cmd:
-            module = GUI(parent=self, centreOnParent=False)
+            module = GUI(parent=self, centreOnParent=self.centreFromsOnParent)
             module.ParseCommand(cmd,
