[GRASS-SVN] r70542 - in grass/branches/releasebranch_7_2: display/d.mon gui/wxpython gui/wxpython/core gui/wxpython/datacatalog gui/wxpython/gmodeler gui/wxpython/gui_core gui/wxpython/iscatt gui/wxpython/lmgr gui/wxpython/location_wizard gui/wxpython/mapdisp gui/wxpython/timeline gui/wxpython/tplot lib/init lib/python/gunittest lib/python/pygrass/tests lib/python/script man scripts/g.extension scripts/g.search.modules scripts/r.in.wms scripts/v.rast.stats tools
svn_grass at osgeo.org
Sun Feb 12 12:22:30 PST 2017
Author: neteler
Date: 2017-02-12 12:22:30 -0800 (Sun, 12 Feb 2017)
New Revision: 70542
grass/branches/releasebranch_7_2/display/d.mon/render_cmd.py
grass/branches/releasebranch_7_2/gui/wxpython/core/debug.py
grass/branches/releasebranch_7_2/gui/wxpython/core/render.py
grass/branches/releasebranch_7_2/gui/wxpython/core/utils.py
grass/branches/releasebranch_7_2/gui/wxpython/core/ws.py
grass/branches/releasebranch_7_2/gui/wxpython/datacatalog/tree.py
grass/branches/releasebranch_7_2/gui/wxpython/gis_set.py
grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/dialogs.py
grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/model.py
grass/branches/releasebranch_7_2/gui/wxpython/gui_core/ghelp.py
grass/branches/releasebranch_7_2/gui/wxpython/gui_core/preferences.py
grass/branches/releasebranch_7_2/gui/wxpython/gui_core/pyedit.py
grass/branches/releasebranch_7_2/gui/wxpython/iscatt/plots.py
grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py
grass/branches/releasebranch_7_2/gui/wxpython/location_wizard/wizard.py
grass/branches/releasebranch_7_2/gui/wxpython/mapdisp/main.py
grass/branches/releasebranch_7_2/gui/wxpython/timeline/frame.py
grass/branches/releasebranch_7_2/gui/wxpython/tplot/frame.py
grass/branches/releasebranch_7_2/lib/init/grass.py
grass/branches/releasebranch_7_2/lib/python/gunittest/case.py
grass/branches/releasebranch_7_2/lib/python/gunittest/reporters.py
grass/branches/releasebranch_7_2/lib/python/pygrass/tests/benchmark.py
grass/branches/releasebranch_7_2/lib/python/script/core.py
grass/branches/releasebranch_7_2/man/build_class_graphical.py
grass/branches/releasebranch_7_2/man/build_graphical_index.py
grass/branches/releasebranch_7_2/man/build_manual_gallery.py
grass/branches/releasebranch_7_2/man/parser_standard_options.py
grass/branches/releasebranch_7_2/scripts/g.extension/g.extension.py
grass/branches/releasebranch_7_2/scripts/g.search.modules/g.search.modules.py
grass/branches/releasebranch_7_2/scripts/r.in.wms/wms_base.py
grass/branches/releasebranch_7_2/scripts/v.rast.stats/v.rast.stats.py
grass/branches/releasebranch_7_2/tools/mkhtml.py
Python 2.6 does not support ommitting of positional argument specifiers: Fixes ValueError zero length field name in format (trunk, r70476)
Modified: grass/branches/releasebranch_7_2/display/d.mon/render_cmd.py
--- grass/branches/releasebranch_7_2/display/d.mon/render_cmd.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/display/d.mon/render_cmd.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -11,7 +11,7 @@
width = height = legfile = None
fd = open(env_file, 'r')
if fd is None:
- grass.fatal("Unable to open file '{}'".format(env_file))
+ grass.fatal("Unable to open file '{0}'".format(env_file))
lines = fd.readlines()
for l in lines:
if l.startswith('#'):
@@ -40,7 +40,7 @@
try:
grass.run_command(cmd[0], env=env, **cmd[1])
except Exception as e:
- grass.debug(1, "Unable to render: {}".format(e))
+ grass.debug(1, "Unable to render: {0}".format(e))
# update cmd file
def update_cmd_file(cmd_file, cmd, mapfile):
@@ -54,13 +54,13 @@
# update cmd file
fd = open(cmd_file, mode)
if fd is None:
- grass.fatal("Unable to open file '{}'".format(cmd_file))
+ grass.fatal("Unable to open file '{0}'".format(cmd_file))
if mode == 'a':
frame = os.getenv('GRASS_RENDER_FRAME', None)
if frame:
- fd.write('# GRASS_RENDER_FRAME={}\n'.format(frame))
+ fd.write('# GRASS_RENDER_FRAME={0}\n'.format(frame))
if mapfile:
- fd.write('# GRASS_RENDER_FILE={}\n'.format(mapfile))
+ fd.write('# GRASS_RENDER_FILE={0}\n'.format(mapfile))
fd.write(' '.join(gtask.cmdtuple_to_list(cmd)))
fd.write('\n')
else:
Modified: grass/branches/releasebranch_7_2/gui/wxpython/core/debug.py
--- grass/branches/releasebranch_7_2/gui/wxpython/core/debug.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/core/debug.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -45,12 +45,12 @@
self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
if self.debuglevel < 0 or self.debuglevel > 5:
raise ValueError(
- _("Wx debug level {}.").format(
+ _("Wx debug level {0}.").format(
self.debuglevel))
except ValueError as e:
self.debuglevel = 0
sys.stderr.write(
- _("WARNING: Ignoring unsupported wx debug level (must be >=0 and <=5). {}\n").format(e))
+ _("WARNING: Ignoring unsupported wx debug level (must be >=0 and <=5). {0}\n").format(e))
def msg(self, level, message, *args):
"""Print debug message
Modified: grass/branches/releasebranch_7_2/gui/wxpython/core/render.py
--- grass/branches/releasebranch_7_2/gui/wxpython/core/render.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/core/render.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -411,7 +411,7 @@
def Abort(self):
"""Abort rendering process"""
- Debug.msg(1, "RenderLayerMgr({}).Abort()".format(self.layer))
+ Debug.msg(1, "RenderLayerMgr({0}).Abort()".format(self.layer))
self.thread.Terminate()
# force rendering layer next time
@@ -1272,7 +1272,7 @@
renderMgr = layer.GetRenderMgr()
Debug.msg(
- 1, "Map.AddLayer(): ltype={}, command={}".format(
+ 1, "Map.AddLayer(): ltype={0}, command={1}".format(
ltype, layer.GetCmd(
string=True)))
if renderMgr:
@@ -1333,7 +1333,7 @@
def SetLayers(self, layers):
self.layers = layers
- Debug.msg(5, "Map.SetLayers(): layers={}".format([EncodeString(layer.GetCmd(string=True)) for layer in layers]))
+ Debug.msg(5, "Map.SetLayers(): layers={0}".format([EncodeString(layer.GetCmd(string=True)) for layer in layers]))
def ChangeLayer(self, layer, render=False, **kargs):
"""Change map layer properties
@@ -1483,7 +1483,7 @@
renderMgr = overlay.GetRenderMgr()
Debug.msg(
- 1, "Map.AddOverlay(): cmd={}".format(EncodeString(
+ 1, "Map.AddOverlay(): cmd={0}".format(EncodeString(
overlay.GetCmd(
string=True))))
if renderMgr:
Modified: grass/branches/releasebranch_7_2/gui/wxpython/core/utils.py
--- grass/branches/releasebranch_7_2/gui/wxpython/core/utils.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/core/utils.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -532,7 +532,7 @@
try:
f = open(path, "r")
except IOError:
- raise OpenError(_("failed to open '{}'").format(path))
+ raise OpenError(_("failed to open '{0}'").format(path))
code = None
for line in f.readlines():
@@ -547,7 +547,7 @@
try:
code = int(code.replace('<', '').replace('>', ''))
- raise OpenError('{}'.format(e))
+ raise OpenError('{0}'.format(e))
if code is not None:
epsgCodeDict[code] = (descr, params)
@@ -555,7 +555,7 @@
f.close()
return epsgCodeDict
@@ -1204,7 +1204,7 @@
if 'GUI_PID' in env:
guiPid = env['GUI_PID'].split(',')
guiPid.append(str(pid))
- grass.run_command('g.gisenv', set='GUI_PID={}'.format(','.join(guiPid)))
+ grass.run_command('g.gisenv', set='GUI_PID={0}'.format(','.join(guiPid)))
def unregisterPid(pid):
@@ -1222,7 +1222,7 @@
guiPid.remove(pid)
grass.run_command(
'g.gisenv',
- set='GUI_PID={}'.format(
+ set='GUI_PID={0}'.format(
','.join(guiPid)))
if __name__ == '__main__':
Modified: grass/branches/releasebranch_7_2/gui/wxpython/core/ws.py
--- grass/branches/releasebranch_7_2/gui/wxpython/core/ws.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/core/ws.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -245,7 +245,7 @@
def Abort(self):
- Debug.msg(1, "RenderWMSMgr({}).Abort()".format(self.layer))
+ Debug.msg(1, "RenderWMSMgr({0}).Abort()".format(self.layer))
Modified: grass/branches/releasebranch_7_2/gui/wxpython/datacatalog/tree.py
--- grass/branches/releasebranch_7_2/gui/wxpython/datacatalog/tree.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/datacatalog/tree.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -138,7 +138,7 @@
else:
listOfMapsets = mapsets.split(',')
Debug.msg(
- 4, "Location <{}>: {} mapsets found".format(
+ 4, "Location <{0}>: {1} mapsets found".format(
location, len(listOfMapsets)))
for each in listOfMapsets:
maps_dict[each] = {}
@@ -160,7 +160,7 @@
# fill dictionary
listOfMaps = maplist.splitlines()
Debug.msg(
- 4, "Location <{}>: {} maps found".format(
+ 4, "Location <{0}>: {1} maps found".format(
location, len(listOfMaps)))
for each in listOfMaps:
ltype, wholename = each.split('/')
@@ -311,7 +311,7 @@
location_nodes = []
nlocations = len(locations)
grassdata_node = self._model.AppendNode(
- parent=self._model.root, label=_('GRASS locations in {}').format(
+ parent=self._model.root, label=_('GRASS locations in {0}').format(
genv['GISDBASE']), data=dict(
type='grassdata'))
for location in locations:
@@ -323,7 +323,7 @@
loc_count += 1
Debug.msg(
- 3, "Scanning location <{}> ({}/{})".format(location, loc_count, nlocations))
+ 3, "Scanning location <{0}> ({1}/{2})".format(location, loc_count, nlocations))
q = Queue()
p = Process(target=getLocationTree,
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gis_set.py
--- grass/branches/releasebranch_7_2/gui/wxpython/gis_set.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gis_set.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -775,7 +775,7 @@
except (UnicodeEncodeError, UnicodeDecodeError) as e:
GError(parent=self,
message=_("Unicode error detected. "
- "Check your locale settings. Details: {}").format(e),
+ "Check your locale settings. Details: {0}").format(e),
showTraceback=False)
self.lblocations.Clear()
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/dialogs.py
--- grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/dialogs.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/dialogs.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -922,7 +922,7 @@
options = action.GetParameterizedParams()
params = []
for f in options['flags']:
- params.append('-{}'.format(f['name']))
+ params.append('-{0}'.format(f['name']))
for p in options['params']:
params.append(p['name'])
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/model.py
--- grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/model.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gmodeler/model.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -1862,7 +1862,7 @@
else:
tabName = _("empty")
raise GException(
- _("Details: unsupported tag name '{}'.").format(tagName))
+ _("Details: unsupported tag name '{0}'.").format(tagName))
# list of actions, data
self.properties = dict()
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gui_core/ghelp.py
--- grass/branches/releasebranch_7_2/gui/wxpython/gui_core/ghelp.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gui_core/ghelp.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -295,7 +295,7 @@
except CalledModuleError as error:
text = _("Unable to provide citation suggestion,"
" see GRASS GIS website instead."
- " The error was: {}").format(error)
+ " The error was: {0}").format(error)
# put text into a scrolling panel
window = ScrolledPanel(self.aboutNotebook)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gui_core/preferences.py
--- grass/branches/releasebranch_7_2/gui/wxpython/gui_core/preferences.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gui_core/preferences.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -1882,7 +1882,7 @@
epsgCombo.SetItems([])
GError(
parent=self,
- message=_("Unable to read EPGS codes: {}").format(e),
+ message=_("Unable to read EPGS codes: {0}").format(e),
return
Modified: grass/branches/releasebranch_7_2/gui/wxpython/gui_core/pyedit.py
--- grass/branches/releasebranch_7_2/gui/wxpython/gui_core/pyedit.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/gui_core/pyedit.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -235,7 +235,7 @@
try:
stats = gscript.parse_command('r.univar', map=input_raster, flags='g')
except CalledModuleError as e:
- gscript.fatal('{}'.format(e))
+ gscript.fatal('{0}'.format(e))
raster_mean = float(stats['mean'])
raster_stddev = float(stats['stddev'])
raster_high = raster_mean + raster_stddev
Modified: grass/branches/releasebranch_7_2/gui/wxpython/iscatt/plots.py
--- grass/branches/releasebranch_7_2/gui/wxpython/iscatt/plots.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/iscatt/plots.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -40,7 +40,7 @@
import matplotlib.cbook as cbook
except ImportError as e:
raise ImportError(_('The Scatterplot Tool needs the "matplotlib" '
- '(python-matplotlib) package to be installed. {}').format(e))
+ '(python-matplotlib) package to be installed. {0}').format(e))
import grass.script as grass
from grass.pydispatch.signal import Signal
Modified: grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py
--- grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/lmgr/frame.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -2495,7 +2495,7 @@
grass.warning(_("Unable to exit GRASS shell: unknown PID"))
return
- Debug.msg(1, "Exiting shell with pid={}".format(shellPid))
+ Debug.msg(1, "Exiting shell with pid={0}".format(shellPid))
import signal
os.kill(shellPid, signal.SIGTERM)
Modified: grass/branches/releasebranch_7_2/gui/wxpython/location_wizard/wizard.py
--- grass/branches/releasebranch_7_2/gui/wxpython/location_wizard/wizard.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/location_wizard/wizard.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -1643,7 +1643,7 @@
except OpenError as e:
GError(
parent=self,
self.epsglist.Populate(list(), update=True)
return
@@ -1890,7 +1890,7 @@
GError(
parent=self,
- message=_("Unable to read IAU codes: {}").format(e),
+ message=_("Unable to read IAU codes: {0}").format(e),
return
Modified: grass/branches/releasebranch_7_2/gui/wxpython/mapdisp/main.py
--- grass/branches/releasebranch_7_2/gui/wxpython/mapdisp/main.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/mapdisp/main.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -480,9 +480,9 @@
width, height = self.MapWindow.GetClientSize()
for line in fileinput.input(monFile['env'], inplace=True):
if 'GRASS_RENDER_WIDTH' in line:
- print 'GRASS_RENDER_WIDTH={}'.format(width)
+ print 'GRASS_RENDER_WIDTH={0}'.format(width)
elif 'GRASS_RENDER_HEIGHT' in line:
- print 'GRASS_RENDER_HEIGHT={}'.format(height)
+ print 'GRASS_RENDER_HEIGHT={0}'.format(height)
else:
print line.rstrip('\n')
Modified: grass/branches/releasebranch_7_2/gui/wxpython/timeline/frame.py
--- grass/branches/releasebranch_7_2/gui/wxpython/timeline/frame.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/timeline/frame.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -37,7 +37,7 @@
from matplotlib import cbook
raise ImportError(_('The Timeline Tool needs the "matplotlib" '
from core.utils import _
Modified: grass/branches/releasebranch_7_2/gui/wxpython/tplot/frame.py
--- grass/branches/releasebranch_7_2/gui/wxpython/tplot/frame.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/gui/wxpython/tplot/frame.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -41,7 +41,7 @@
raise ImportError(_('The Temporal Plot Tool needs the "matplotlib" '
Modified: grass/branches/releasebranch_7_2/lib/init/grass.py
--- grass/branches/releasebranch_7_2/lib/init/grass.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/lib/init/grass.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -1055,7 +1055,7 @@
except:
continue
- debug("Environmental variable set {}={}".format(k, v))
+ debug("Environmental variable set {0}={1}".format(k, v))
os.environ[k] = v
# Allow for mixed ISIS-GRASS Environment
@@ -1383,11 +1383,11 @@
return
import signal
for pid in env['GUI_PID'].split(','):
- debug("Exiting GUI with pid={}".format(pid))
+ debug("Exiting GUI with pid={0}".format(pid))
try:
os.kill(int(pid), signal.SIGTERM)
except OSError as e:
- message(_("Unable to close GUI. {}").format(e))
+ message(_("Unable to close GUI. {0}").format(e))
def clear_screen():
"""Clear terminal"""
@@ -1875,7 +1875,7 @@
# User selects LOCATION and MAPSET if not set
if not set_mapset_interactive(grass_gui):
# No GUI available, update gisrc file
- fatal(_("<{}> requested, but not available. Run GRASS in text "
+ fatal(_("<{0}> requested, but not available. Run GRASS in text "
"mode (-text) or install missing package (usually "
"'grass-gui').").format(grass_gui))
else:
Modified: grass/branches/releasebranch_7_2/lib/python/gunittest/case.py
--- grass/branches/releasebranch_7_2/lib/python/gunittest/case.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/lib/python/gunittest/case.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -1140,7 +1140,7 @@
module = _module_from_parameters(module, **kwargs)
_check_module_run_parameters(module)
if not shutil_which(module.name):
- stdmsg = "Cannot find the module '{}'".format(module.name)
+ stdmsg = "Cannot find the module '{0}'".format(module.name)
self.fail(self._formatMessage(msg, stdmsg))
try:
module.run()
Modified: grass/branches/releasebranch_7_2/lib/python/gunittest/reporters.py
--- grass/branches/releasebranch_7_2/lib/python/gunittest/reporters.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/lib/python/gunittest/reporters.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -721,7 +721,7 @@
if type(modules) is not list:
modules = [modules]
file_index.write(
- '<tr><td>Tested modules</td><td>{}</td></tr>'.format(
+ '<tr><td>Tested modules</td><td>{0}</td></tr>'.format(
', '.join(sorted(set(modules)))))
file_index.write('</tbody></table>')
Modified: grass/branches/releasebranch_7_2/lib/python/pygrass/tests/benchmark.py
--- grass/branches/releasebranch_7_2/lib/python/pygrass/tests/benchmark.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/lib/python/pygrass/tests/benchmark.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -282,7 +282,7 @@
for oper, operdict in operation.items():
operdict['time'], operdict['times'] = mytimer(operdict['func'],runs)
if profile:
- filename = '{}_{}_{}'.format(execmode, oper, profile)
+ filename = '{0}_{1}_{2}'.format(execmode, oper, profile)
cProfile.runctx(operdict['func'].__name__ + '()',
globals(), locals(), filename = filename)
print((' {0}: {1: 40.6f}s'.format(oper, operdict['time'])))
Modified: grass/branches/releasebranch_7_2/lib/python/script/core.py
--- grass/branches/releasebranch_7_2/lib/python/script/core.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/lib/python/script/core.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -64,7 +64,7 @@
and kwargs.get('executable') is None):
cmd = shutil_which(args[0])
if cmd is None:
- raise OSError(_("Cannot find the executable {}")
+ raise OSError(_("Cannot find the executable {0}")
.format(args[0]))
args = [cmd] + args[1:]
name, ext = os.path.splitext(cmd)
@@ -1535,10 +1535,10 @@
try:
_debug_level = int(gisenv().get('DEBUG', 0))
if _debug_level < 0 or _debug_level > 5:
- raise ValueError(_("Debug level {}").format(_debug_level))
+ raise ValueError(_("Debug level {0}").format(_debug_level))
_debug_level = 0
- sys.stderr.write(_("WARNING: Ignoring unsupported debug level (must be >=0 and <=5). {}\n").format(e))
+ sys.stderr.write(_("WARNING: Ignoring unsupported debug level (must be >=0 and <=5). {0}\n").format(e))
return _debug_level
Modified: grass/branches/releasebranch_7_2/man/build_class_graphical.py
--- grass/branches/releasebranch_7_2/man/build_class_graphical.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/man/build_class_graphical.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -148,7 +148,7 @@
elif module_family == 'guimodules':
output.write("<h3>g.gui.* modules:</h3>")
else:
- output.write("<h3>{} modules:</h3>".format(to_title(module_family)))
+ output.write("<h3>{0} modules:</h3>".format(to_title(module_family)))
output.write('<ul class="img-list">')
#for all modules:
Modified: grass/branches/releasebranch_7_2/man/build_graphical_index.py
--- grass/branches/releasebranch_7_2/man/build_graphical_index.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/man/build_graphical_index.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -86,7 +86,7 @@
def std_img_name(name):
- return "gi_{}.jpg".format(name)
+ return "gi_{0}.jpg".format(name)
index_items = [
Modified: grass/branches/releasebranch_7_2/man/build_manual_gallery.py
--- grass/branches/releasebranch_7_2/man/build_manual_gallery.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/man/build_manual_gallery.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -32,7 +32,7 @@
img_blacklist = ['grass_logo.png', 'grass_icon.png']
# circles with numbers from helptext.html (unfortunate we have to list it here)
-img_blacklist.extend(['circle_{}.png'.format(num) for num in range(1, 6)])
+img_blacklist.extend(['circle_{0}.png'.format(num) for num in range(1, 6)])
year = os.getenv("VERSION_DATE")
@@ -97,7 +97,7 @@
def img_in_html(filename, imagename):
# for some reason, calling search just once is much faster
# than calling it on every line (time is spent in _compile)
- pattern = re.compile('<img .*src=.{}.*>'.format(imagename))
+ pattern = re.compile('<img .*src=.{0}.*>'.format(imagename))
with open(filename) as file:
if re.search(pattern, file.read()):
return True
Modified: grass/branches/releasebranch_7_2/man/parser_standard_options.py
--- grass/branches/releasebranch_7_2/man/parser_standard_options.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/man/parser_standard_options.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -107,7 +107,7 @@
def html(self, endline='\n', indent=' ', toptions='border=1'):
"""Return a HTML table with the options"""
- html = ['<table{}>'.format(' ' + toptions if toptions else '')]
+ html = ['<table{0}>'.format(' ' + toptions if toptions else '')]
# write headers
html.append(indent + "<thead>")
html.append(indent + "<tr>")
Modified: grass/branches/releasebranch_7_2/scripts/g.extension/g.extension.py
--- grass/branches/releasebranch_7_2/scripts/g.extension/g.extension.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/scripts/g.extension/g.extension.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -307,10 +307,10 @@
for tnode in tree.findall('task'):
if flags['g']:
desc, keyw = get_optional_params(tnode)
- ret.append('name={}'.format(tnode.get('name').strip()))
- ret.append('description={}'.format(desc))
- ret.append('keywords={}'.format(keyw))
- ret.append('executables={}'.format(','.join(
+ ret.append('name={0}'.format(tnode.get('name').strip()))
+ ret.append('description={0}'.format(desc))
+ ret.append('keywords={0}'.format(keyw))
+ ret.append('executables={0}'.format(','.join(
get_module_executables(tnode))
else:
@@ -326,7 +326,7 @@
For toolboxes it lists also all modules.
- gscript.debug("list_available_extensions(url={})".format(url))
+ gscript.debug("list_available_extensions(url={0})".format(url))
if flags['t']:
grass.message(_("List of available extensions (toolboxes):"))
tlist = get_available_toolboxes(url)
@@ -808,10 +808,10 @@
tree = etree_fromurl(url, proxies=PROXIES)
except (HTTPError, URLError, IOError, OSError) as error:
grass.error(_("Unable to read addons metadata file"
- " from the remote server: {}").format(error))
+ " from the remote server: {0}").format(error))
return data, bin_list
except ETREE_EXCEPTIONS as error:
- grass.warning(_("Unable to parse '%s': {}").format(error) % url)
+ grass.warning(_("Unable to parse '%s': {0}").format(error) % url)
for mnode in tree.findall('task'):
name = mnode.get('name')
@@ -938,7 +938,7 @@
'patch': version[2]}
# resolve ZIP URL
- source, url = resolve_source_code(url='{}/{}.zip'.format(base_url, name))
+ source, url = resolve_source_code(url='{0}/{1}.zip'.format(base_url, name))
# to hide non-error messages from subprocesses
if grass.verbosity() <= 2:
@@ -995,7 +995,7 @@
a different directory in the way that if there was one directory extracted,
the contained files are moved.
- gscript.debug("move_extracted_files({})".format(locals()))
+ gscript.debug("move_extracted_files({0})".format(locals()))
if len(files) == 1:
shutil.copytree(os.path.join(extract_dir, files[0]), target_dir)
else:
@@ -1056,7 +1056,7 @@
move_extracted_files(extract_dir=extract_dir,
target_dir=directory, files=files)
except zipfile.BadZipfile as error:
- gscript.fatal(_("ZIP file is unreadable: {}").format(error))
+ gscript.fatal(_("ZIP file is unreadable: {0}").format(error))
# TODO: solve the other related formats
@@ -1075,7 +1075,7 @@
except tarfile.TarError as error:
- gscript.fatal(_("Archive file is unreadable: {}").format(error))
+ gscript.fatal(_("Archive file is unreadable: {0}").format(error))
extract_tar.supported_formats = ['tar.gz', 'gz', 'bz2', 'tar', 'gzip', 'targz']
@@ -1116,7 +1116,7 @@
fix_newlines(directory)
else:
# probably programmer error
- grass.fatal(_("Unknown extension (addon) source type '{}'."
+ grass.fatal(_("Unknown extension (addon) source type '{0}'."
" Please report this to the grass-user mailing list.")
.format(source))
assert os.path.isdir(directory)
@@ -1459,8 +1459,8 @@
path = os.environ['GRASS_ADDON_BASE']
if os.path.exists(path) and \
not os.access(path, os.W_OK):
- grass.fatal(_("You don't have permission to install extension to <{}>."
- " Try to run {} with administrator rights"
+ grass.fatal(_("You don't have permission to install extension to <{0}>."
+ " Try to run {1} with administrator rights"
" (su or sudo).")
.format(path, 'g.extension'))
# ensure dir sep at the end for cases where path is used as URL and pasted
@@ -1481,7 +1481,7 @@
>>> resolve_xmlurl_prefix('http://grass.osgeo.org/addons/')
- gscript.debug("resolve_xmlurl_prefix(url={}, source={})".format(url, source))
+ gscript.debug("resolve_xmlurl_prefix(url={0}, source={1})".format(url, source))
if source == 'official':
# use pregenerated modules XML file
url = 'http://grass.osgeo.org/addons/grass%s/' % version[0]
@@ -1541,7 +1541,7 @@
if url.startswith(start + value['domain']):
match = value
actual_start = start
- gscript.verbose(_("Identified {} as known hosting service")
+ gscript.verbose(_("Identified {0} as known hosting service")
.format(key))
for suffix in value['ignored_suffixes']:
if url.endswith(suffix):
@@ -1558,7 +1558,7 @@
url = '{prefix}{base}{suffix}'.format(prefix=actual_start,
base=url.rstrip('/'),
suffix=match['url_end'])
- gscript.verbose(_("Will use the following URL for download: {}")
+ gscript.verbose(_("Will use the following URL for download: {0}")
.format(url))
return 'remote_zip', url
else:
Modified: grass/branches/releasebranch_7_2/scripts/g.search.modules/g.search.modules.py
--- grass/branches/releasebranch_7_2/scripts/g.search.modules/g.search.modules.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/scripts/g.search.modules/g.search.modules.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -146,9 +146,9 @@
import textwrap
for item in data:
- print('\n{}'.format(colorize(item['name'], attrs=['bold'])))
+ print('\n{0}'.format(colorize(item['name'], attrs=['bold'])))
for attr in item['attributes']:
- out = '{}: {}'.format(attr, item['attributes'][attr])
+ out = '{0}: {1}'.format(attr, item['attributes'][attr])
out = textwrap.wrap(out, width=79, initial_indent=4 * ' ',
subsequent_indent=4 * ' ' + len(attr) * ' ' + ' ')
for line in out:
Modified: grass/branches/releasebranch_7_2/scripts/r.in.wms/wms_base.py
--- grass/branches/releasebranch_7_2/scripts/r.in.wms/wms_base.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/scripts/r.in.wms/wms_base.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -246,13 +246,13 @@
_("Authorization failed to <%s> when fetching capabilities") %
options['url'])
else:
- msg = _("Unable to fetch capabilities from <{}>. Reason: ").format(
+ msg = _("Unable to fetch capabilities from <{0}>. Reason: ").format(
options['url'])
if hasattr(e, 'reason'):
- msg += '{}'.format(e.reason)
+ msg += '{0}'.format(e.reason)
else:
- msg += '{}'.format(e)
+ msg += '{0}'.format(e)
grass.fatal(msg)
Modified: grass/branches/releasebranch_7_2/scripts/v.rast.stats/v.rast.stats.py
--- grass/branches/releasebranch_7_2/scripts/v.rast.stats/v.rast.stats.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/scripts/v.rast.stats/v.rast.stats.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -240,7 +240,7 @@
first_line = 1
- f.write("{}\n".format(grass.db_begin_transaction(fi['driver'])))
+ f.write("{0}\n".format(grass.db_begin_transaction(fi['driver'])))
for line in p.stdout:
if first_line:
first_line = 0
@@ -267,7 +267,7 @@
f.write(" %s=%s" % (colname, value))
f.write(" WHERE %s=%s;\n" % (fi['key'], vars[0]))
- f.write("{}\n".format(grass.db_commit_transaction(fi['driver'])))
+ f.write("{0}\n".format(grass.db_commit_transaction(fi['driver'])))
p.wait()
f.close()
Modified: grass/branches/releasebranch_7_2/tools/mkhtml.py
--- grass/branches/releasebranch_7_2/tools/mkhtml.py 2017-02-12 20:07:52 UTC (rev 70541)
+++ grass/branches/releasebranch_7_2/tools/mkhtml.py 2017-02-12 20:22:30 UTC (rev 70542)
@@ -309,7 +309,7 @@
# addons
pgmname = os.path.basename(pgmdir)
classname = index_names[pgmname[:pgmname.find('.')]]
- url_source = urlparse.urljoin('{}{}/'.format(os.environ['SOURCE_URL'], classname),
+ url_source = urlparse.urljoin('{0}{1}/'.format(os.environ['SOURCE_URL'], classname),
pgmname)
else:
url_source = urlparse.urljoin(source_url, pgmdir)
