[GRASS-SVN] r70554 - grass/trunk/lib/vector/vedit
svn_grass at osgeo.org
Mon Feb 13 22:55:56 PST 2017
Author: hcho
Date: 2017-02-13 22:55:56 -0800 (Mon, 13 Feb 2017)
New Revision: 70554
grass/trunk/lib/vector/vedit/break.c
vedit: Vedit_connect_lines handles two more cases properly by extending both
lines.
Since dist was not always the normal distance from line_from to line_to (cases
2 & 3), dist_p sometimes overestimated the distance of extension and resulted
in unexpected connections (e.g., case 2).
Modified: grass/trunk/lib/vector/vedit/break.c
--- grass/trunk/lib/vector/vedit/break.c 2017-02-13 21:11:32 UTC (rev 70553)
+++ grass/trunk/lib/vector/vedit/break.c 2017-02-14 06:55:56 UTC (rev 70554)
@@ -16,6 +16,8 @@
static int connect_lines(struct Map_info *, int, int, int,
double, struct ilist *);
+static int find_extended_intersection(double, double, double, double, double,
+ double, double *, double *);
\brief Split selected lines on given position
@@ -137,21 +139,39 @@
\brief Connect lines in given threshold
\code
- id1 \ -> \
- id2 --------- -----+---
- \endcode
+ 1. Extend first line only
+ id1 \ -> \
+ id2 ---------- -----+----
- If two lines are selected and <i>thresh</i> is -1, no limit is
- applied.
- \param Map pointer to Map_info
- \param List list of selected lines
- \param thresh threshold value
+ 2. Extend both lines
+ id1 \ -> \
+ id2 --- +----
- \return number of modified lines
- \return -1 on error
+ 3. Extend first line when both are on the same line
+ id1 --- --- id2 -> -----+----
+ 4. Don't connect two lines that don't intersect
+ id1 ------ ------
+ id2 ------ ------
+ \endcode
+ If two lines are selected and <i>thresh</i> is -1, no limit is
+ applied.
+ \param Map pointer to Map_info
+ \param List list of selected lines
+ \param thresh threshold value
+ \return number of modified lines
+ \return -1 on error
int Vedit_connect_lines(struct Map_info *Map, struct ilist *List,
double thresh)
@@ -194,6 +214,9 @@
do {
/* find first nearest line */
+ /* thresh=-1 for Vect_find_line_list doesn't mean no limit
+ * search => inconsistent behavior! Either this is a bug or the
+ * function description is incorrect. */
found = Vect_find_line_list(Map, x, y, z,
GV_LINES, thresh, WITHOUT_Z,
List_exclude, List_found);
@@ -227,8 +250,8 @@
int type_from, type_to;
int n_points, seg, is;
double x, y, px, py, x1, y1;
- double dist, spdist, lpdist, length, dist_p;
- double angle_t, angle_f, angle;
+ double dist, spdist, lpdist, length;
+ double angle_t, angle_f;
struct line_pnts *Points_from, *Points_to, *Points_final;
struct line_cats *Cats_from, *Cats_to;
@@ -247,12 +270,13 @@
line_new = -1;
if (line_new > -1) {
+ n_points = Points_from->n_points - 1;
if (first) {
x = Points_from->x[0];
y = Points_from->y[0];
else {
- n_points = Points_from->n_points - 1;
x = Points_from->x[n_points];
y = Points_from->y[n_points];
@@ -271,22 +295,9 @@
if (Vect_point_on_line(Points_to, lpdist,
NULL, NULL, NULL, &angle_t,
NULL) > 0) {
- angle = angle_t - angle_f;
- dist_p = fabs(dist / sin(angle));
- if (first) {
- if (angle_f < 0)
- angle_f -= M_PI;
- else
- angle_f += M_PI;
- x1 = x + dist_p * cos(angle_f);
- y1 = y + dist_p * sin(angle_f);
- length = Vect_line_length(Points_to);
- Vect_line_insert_point(Points_to, seg, x1, y1, 0.);
- if (fabs(Vect_line_length(Points_to) - length) < length * 1e-3) {
+ /* extend both line_from & line_to and find intersection */
+ if (find_extended_intersection(x, y, angle_f,
+ px, py, angle_t, &x1, &y1)) {
/* lines connected -> split line_to */
/* update line_from */
if (first) {
@@ -302,31 +313,37 @@
Points_from, Cats_from);
/* Vect_list_append(List, line_new); */
- /* update line_to -- first part */
- Vect_reset_line(Points_final);
- for (is = 0; is < seg; is++) {
- Vect_append_point(Points_final, Points_to->x[is],
- Points_to->y[is],
- Points_to->z[is]);
- Vect_append_point(Points_final, x1, y1, 0.0);
- line_new = Vect_rewrite_line(Map, line_to, type_to,
- Points_final, Cats_to);
- /* Vect_list_append(List, line_new); */
+ length = Vect_line_length(Points_to);
+ /* avoid adding duplicate nodes */
+ if (lpdist > 0 && lpdist < length) {
+ /* update line_to -- first part */
+ Vect_reset_line(Points_final);
+ for (is = 0; is < seg; is++) {
+ Vect_append_point(Points_final,
+ Points_to->x[is],
+ Points_to->y[is],
+ Points_to->z[is]);
+ Vect_append_point(Points_final, x1, y1, 0.0);
+ line_new = Vect_rewrite_line(Map, line_to, type_to,
+ Points_final, Cats_to);
+ /* Vect_list_append(List, line_new); */
- /* write second part */
- for (is = seg; is < Points_to->n_points; is++) {
- Points_to->y[is],
+ /* write second part */
+ for (is = seg; is < Points_to->n_points; is++) {
+ Points_to->x[is],
+ Points_to->y[is],
+ /* rewrite first part */
+ line_new = Vect_write_line(Map, type_to,
- /* rewrite first part */
- line_new = Vect_write_line(Map, type_to,
@@ -341,3 +358,42 @@
return line_new > 0 ? 1 : 0;
+static int find_extended_intersection(double x1, double y1, double angle1,
+ double x2, double y2, double angle2,
+ double *x, double *y)
+ double c1, s1, c2, s2, d, a;
+ if (fabs(sin(angle1 - angle2)) <= 1e-10) {
+ /* two lines are parallel */
+ double angle;
+ angle = atan2(y2 - y1, x2 - x1);
+ if (angle == angle1) {
+ /* they are on the same line */
+ *x = x2;
+ *y = y2;
+ return 1;
+ /* two lines don't intersect */
+ return 0;
+ c1 = cos(angle1);
+ s1 = sin(angle1);
+ c2 = cos(angle2);
+ s2 = sin(angle2);
+ d = -c1 * s2 + c2 * s1;
+ if (d == 0.0)
+ /* shouldn't happen again */
+ return 0;
+ a = (-s2 * (x2 - x1) + c2 * (y2 - y1)) / d;
+ *x = x1 + a * c1;
+ *y = y1 + a * s1;
+ return 1;
