[GRASS-SVN] r70582 - grass/trunk/vector/v.select
Wed Feb 15 07:04:43 PST 2017
Author: hcho
Date: 2017-02-15 07:04:43 -0800 (Wed, 15 Feb 2017)
New Revision: 70582
   grass/trunk/vector/v.select/copy_tabs.c
   grass/trunk/vector/v.select/main.c
v.select: Avoid database warnings when no features are selected and copy an
empty table
Modified: grass/trunk/vector/v.select/copy_tabs.c
--- grass/trunk/vector/v.select/copy_tabs.c	2017-02-15 14:50:07 UTC (rev 70581)
+++ grass/trunk/vector/v.select/copy_tabs.c	2017-02-15 15:04:43 UTC (rev 70582)
@@ -55,12 +55,17 @@
 	OFi =
 	    Vect_default_field_info(Out, IFi->number, IFi->name, ttype);
-	ret =
-	    db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
-				  OFi->driver,
-				  Vect_subst_var(OFi->database, Out),
-				  OFi->table, IFi->key, cats[i],
-				  ncats[i]);
+	if (ncats[i] > 0)
+	    ret = db_copy_table_by_ints(IFi->driver, IFi->database, IFi->table,
+					OFi->driver,
+					Vect_subst_var(OFi->database, Out),
+					OFi->table, IFi->key, cats[i],
+					ncats[i]);
+	else
+	    ret = db_copy_table_where(IFi->driver, IFi->database, IFi->table,
+				      OFi->driver,
+				      OFi->table, "0 = 1");
 	if (ret == DB_FAILED) {
 	    G_warning(_("Unable to copy table for layer %d"), fields[i]);
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c	2017-02-15 14:50:07 UTC (rev 70581)
+++ grass/trunk/vector/v.select/main.c	2017-02-15 15:04:43 UTC (rev 70582)
@@ -7,7 +7,7 @@
  *               Markus Neteler <neteler itc.it>
  *               Martin Landa <landa.martin gmail.com> (GEOS support)
  * PURPOSE:      Select features from one map by features in another map.
- * COPYRIGHT:    (C) 2003-2014 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2003-2017 by the GRASS Development Team
  *               This program is free software under the GNU General
  *               Public License (>=v2). Read the file COPYING that
