[GRASS-SVN] r70585 - in grass-addons/grass7/temporal: . t.rast.kappa
svn_grass at osgeo.org
Wed Feb 15 08:31:20 PST 2017
Author: lucadelu
Date: 2017-02-15 08:31:20 -0800 (Wed, 15 Feb 2017)
New Revision: 70585
Added:
grass-addons/grass7/temporal/t.rast.kappa/
grass-addons/grass7/temporal/t.rast.kappa/Makefile
grass-addons/grass7/temporal/t.rast.kappa/t.rast.kappa.html
grass-addons/grass7/temporal/t.rast.kappa/t.rast.kappa.py
added new addons t.rast.kappa
Added: grass-addons/grass7/temporal/t.rast.kappa/Makefile
--- grass-addons/grass7/temporal/t.rast.kappa/Makefile (rev 0)
+++ grass-addons/grass7/temporal/t.rast.kappa/Makefile 2017-02-15 16:31:20 UTC (rev 70585)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = t.rast.kappa
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/temporal/t.rast.kappa/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass7/temporal/t.rast.kappa/t.rast.kappa.html
--- grass-addons/grass7/temporal/t.rast.kappa/t.rast.kappa.html (rev 0)
+++ grass-addons/grass7/temporal/t.rast.kappa/t.rast.kappa.html 2017-02-15 16:31:20 UTC (rev 70585)
@@ -0,0 +1,50 @@
+<h2>DESCRIPTION</h2>
+The t.rast.kappa calculate kappa parameter in a space time raster dataset.
+It can calculate kappa values using two different algorithm, the one provided
+by <a href="r.kappa.html">r.kappa</a> and the one provided by
+<a href="http://scikit-learn.org/stable/modules/generated/sklearn.metrics.cohen_kappa_score.html" target="_blank">SciKit-Learn metrics</a> library
+<h2>EXAMPLE</h2>
+<h3>Using r.kappa as backend</h3>
+In this example t.rast.kappa is using <a href="r.kappa.html">r.kappa</a> as backend,
+it return the results inside the <em>/tmp</em>em> directory into files with <em>mystrds</em> as prefix.
+<em>weight</em> option is not considered using <a href="r.kappa.html">r.kappa</a> as backend.
+<div class="code">
+ <pre>
+ t.rast.kappa -k strds=mystrds output=/tmp/mystrds
+ </pre>
+</div>
+<h3>Using SciKit-Learn as backend, text as output</h3>
+library as backend, without <em>output</em> option, the module print the results to standard output
+<div class="code">
+ <pre>
+ t.rast.kappa strds=mystrds where="start_time >= '1999-12-01' weight='linear'
+ </pre>
+</div>
+<h3>Using SciKit-Learn as backend, map as output</h3>
+library as backend, the output is a map with the kappa values calculated for each pixel.
+The <em>splittingday</em> option is required to split the space time raster dataset in two groups and analyze them;
+the two groups must have the same number of maps, otherwise and error will be reported.
+<div class="code">
+ <pre>
+ t.rast.kappa -p strds=mystrds output=mykappa splittingday='2005-01-01'
+ </pre>
+</div>
+<h2>SEE ALSO</h2>
+<a href="r.kappa.html">r.kappa</a>
+<h2>AUTHOR</h2>
+Luca Delucchi, <i>Fondazione Edmund Mach</i>
Property changes on: grass-addons/grass7/temporal/t.rast.kappa/t.rast.kappa.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass7/temporal/t.rast.kappa/t.rast.kappa.py
--- grass-addons/grass7/temporal/t.rast.kappa/t.rast.kappa.py (rev 0)
+++ grass-addons/grass7/temporal/t.rast.kappa/t.rast.kappa.py 2017-02-15 16:31:20 UTC (rev 70585)
@@ -0,0 +1,260 @@
+#!/usr/bin/env python
+# -*- coding: utf-8 -*-
+# MODULE: t.rast.kappa
+# AUTHOR(S): Luca Delucchi
+# PURPOSE: t.rast.kappa calculate kappa parameter for accuracy
+# assessment in a space time raster dataset
+# COPYRIGHT: (C) 2017 by Luca Delucchi
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+#%module
+#% description: Calculate kappa parameter in a space time raster dataset
+#% keyword: temporal
+#% keyword: raster
+#% keyword: statistics
+#%end
+#%flag
+#% key: k
+#% description: Use r.kappa module instead SciKit-Learn Laboratory metrics.kappa
+#%end
+#%flag
+#% key: l
+#% label: Use memory swap
+#% guisection: Optional
+#%end
+#%flag
+#% key: p
+#% label: Pixel by pixel analysis along different years
+#%end
+#%option G_OPT_STRDS_INPUT
+#% key: strds
+#%end
+#%option G_OPT_F_OUTPUT
+#% required: no
+#% description: Name for the output file or "-" in case stdout should be used
+#% answer: -
+#%end
+#%option
+#% key: weight
+#% type: string
+#% label: Specifies the weight matrix for the calculation
+#% multiple: no
+#% required: no
+#% options: linear, quadratic
+#%end
+#%option G_OPT_T_WHERE
+#%end
+#%option
+#% key: splittingday
+#% type: string
+#% label: Specifies the day to split the space time raster dataset in two groups, isotime format
+#% multiple: no
+#% required: no
+#%end
+#%option G_OPT_F_SEP
+#%end
+import sys
+import grass.script as gscript
+import grass.temporal as tgis
+from grass.pygrass.raster import RasterRow
+from grass.pygrass.gis.region import Region
+from grass.script.utils import separator
+try:
+ from collections import OrderedDic
+except:
+ from types import DictType as OrderedDic
+import numpy as np
+def _load_skll():
+ try:
+ from sklearn.metrics import cohen_kappa_score
+ return False
+ except ImportError:
+ gscript.warning(_(""))
+ return True
+def _split_maps(maps, splitting):
+ from datetime import datetime
+ before = OrderedDic()
+ after = OrderedDic()
+ split = None
+ if splitting.count('T') == 0:
+ try:
+ split = datetime.strptime(splitting, "%Y-%m-%d")
+ except ValueError:
+ pass
+ else:
+ try:
+ split = datetime.strptime(splitting, "%Y-%m-%dT%H:%M:%S")
+ pass
+ if not split:
+ gscript.fatal(_("It is not possible to parse splittingday value. "
+ "Please you one of the two supported format: "
+ "'%Y-%m-%d' or '%Y-%m-%dT%H:%M:%S'"))
+ for mapp in maps:
+ tempext = mapp.get_temporal_extent()
+ raster = RasterRow(mapp.get_name())
+ raster.open('r')
+ array = np.array(raster)
+ if tempext.start_time <= split:
+ before[mapp.get_name()] = array
+ else:
+ after[mapp.get_name()] = array
+ return before, after
+def _kappa_pixel(maps1, maps2, out, method, over):
+ from grass.pygrass.raster.buffer import Buffer
+ import sklearn
+ rasterout = RasterRow(out, overwrite=over)
+ rasterout.open('w','DCELL')
+ array1 = maps1.values()[0]
+ for row in range(len(array1)):
+ newrow = Buffer((len(array1[row]),), mtype='DCELL')
+ for col in range(len(array1[row])):
+ vals1 = np.ndarray(len(maps1.values()))
+ vals2 = np.ndarray(len(maps2.values()))
+ x = 0
+ for value in maps1.values():
+ vals1[x] = value[row][col]
+ x += 1
+ x = 0
+ for value in maps2.values():
+ vals2[x] = value[row][col]
+ x += 1
+ if sklearn.__version__ >= '0.18':
+ outval = sklearn.metrics.cohen_kappa_score(vals1, vals2,
+ weights=method)
+ else:
+ outval = sklearn.metrics.cohen_kappa_score(vals1, vals2)
+ newrow[col] = outval
+ rasterout.put_row(newrow)
+ rasterout.close()
+ return
+def _kappa_skll(map1, map2, lowmem, method):
+ import sklearn
+ raster1 = RasterRow(map1)
+ raster2 = RasterRow(map2)
+ raster1.open('r')
+ raster2.open('r')
+ if lowmem is False:
+ array1 = np.array(raster1).reshape(-1)
+ array2 = np.array(raster2).reshape(-1)
+ else:
+ import tempfile
+ current = Region()
+ array1 = np.memmap(tempfile.NamedTemporaryFile(),
+ dtype='float32', mode='w+',
+ shape=(current.rows, current.cols))
+ array1[:] = np.array(raster1).reshape(-1)
+ array2 = np.memmap(tempfile.NamedTemporaryFile(),
+ array2[:] = np.array(raster2).reshape(-1)
+ raster1.close()
+ raster2.close()
+ return sklearn.metrics.cohen_kappa_score(array1, array2,
+ weights=method)
+ else:
+ return sklearn.metrics.cohen_kappa_score(array1, array2)
+def _kappa_grass(map1, map2):
+ return(gscript.read_command('r.kappa', classification=map1,
+ reference=map2, quiet=True))
+def main():
+ strds = options["strds"]
+ out_name = options["output"]
+ if options["weight"] == '':
+ method = None
+ else:
+ method = options["weight"]
+ where = options["where"]
+ sep = separator(options["separator"])
+ if flags['p'] and not options["splittingday"]:
+ gscript.fatal(_("'p' flag required to set also 'splittingday' option"))
+ elif flags['p'] and options["splittingday"] and out_name == '-':
+ gscript.fatal(_("'output' option is required with 'p' flag"))
+ if flags['k'] and flags['p']:
+ gscript.fatal(_("It is not possible to use 'k' and 'p' flag together"))
+ elif flags['k'] and not method:
+ rkappa = True
+ elif flags['k'] and method:
+ gscript.message(_("If method is different from 'no' it is not possible"
+ " to use r.kappa"))
+ rkappa = _load_skll()
+ else:
+ tgis.init()
+ # We need a database interface
+ dbif = tgis.SQLDatabaseInterfaceConnection()
+ dbif.connect()
+ sp = tgis.open_old_stds(strds, "strds", dbif)
+ maps = sp.get_registered_maps_as_objects(where, "start_time", None)
+ if maps is None:
+ gscript.fatal(_("Space time raster dataset {st} seems to be "
+ "empty".format(st=strds)))
+ return 1
+ if flags['p']:
+ before, after = _split_maps(maps, options["splittingday"])
+ _kappa_pixel(before, after, out_name, method, gscript.overwrite())
+ return
+ mapnames = [mapp.get_name() for mapp in maps]
+ if not rkappa:
+ if out_name != '-':
+ fi = open(out_name, 'w')
+ else:
+ fi = sys.stdout
+ for i1 in range(len(mapnames)):
+ for i2 in range(i1 + 1, len(mapnames)):
+ map1 = mapnames[i1]
+ map2 = mapnames[i2]
+ if map1 != map2:
+ if not rkappa:
+ fi.write("{}-{}{}{}\n".format(map1, map2, sep,
+ _kappa_skll(map1, map2,
+ flags['l'],
+ method)))
+ else:
+ fi = open("{}_{}_{}".format(out_name, map1, map2), 'w')
+ else:
+ fi = sys.stdout
+ fi.write("{}".format(_kappa_grass(map1, map2)))
+ fi.close()
+ if not rkappa:
+ fi.close()
+ gscript.message(_("All data have analyzed"))
+if __name__ == "__main__":
+ options, flags = gscript.parser()
+ sys.exit(main())
Property changes on: grass-addons/grass7/temporal/t.rast.kappa/t.rast.kappa.py
+ text/x-python
+ native
