[GRASS-SVN] r70599 - grass/trunk/vector/v.build.polylines
svn_grass at osgeo.org
Wed Feb 15 23:26:39 PST 2017
Author: hcho
Date: 2017-02-15 23:26:39 -0800 (Wed, 15 Feb 2017)
New Revision: 70599
grass/trunk/vector/v.build.polylines/main.c
grass/trunk/vector/v.build.polylines/walk.c
v.build.polylines: Activate the cats=same option; Remove compile warnings
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c 2017-02-16 07:08:51 UTC (rev 70598)
+++ grass/trunk/vector/v.build.polylines/main.c 2017-02-16 07:26:39 UTC (rev 70599)
@@ -97,7 +97,6 @@
int polyline;
int *lines_visited;
- int points_in_polyline;
int start_line;
int nlines;
int write_cats, copy_tables;
@@ -177,8 +176,10 @@
write_cats = NO_CATS;
else if (strcmp(cats->answer, "first") == 0)
write_cats = ONE_CAT;
- else
+ else if (strcmp(cats->answer, "multi") == 0)
write_cats = MULTI_CATS;
+ else
+ write_cats = SAME_CATS;
if (type_opt->answer)
type = Vect_option_to_types(type_opt);
@@ -218,9 +219,8 @@
G_debug(1, "Polyline %d: start line = %d", polyline, start_line);
/* Walk forward and pick up coordinates */
- points_in_polyline =
- walk_forward_and_pick_up_coords(&map, start_line, ltype, points,
- lines_visited, Cats, write_cats);
+ walk_forward_and_pick_up_coords(&map, start_line, ltype, points,
+ lines_visited, Cats, write_cats);
/* Write the line (type of the first line is used) */
Vect_write_line(&Out, ltype, points, Cats);
@@ -230,12 +230,10 @@
G_verbose_message(n_("%d line or boundaries found in input vector map",
"%d lines or boundaries found in input vector map",
- nlines),
- nlines, Vect_get_name(&map), Vect_get_mapset(&map));
+ nlines), nlines);
G_verbose_message(n_("%d polyline stored in output vector map",
"%d polylines stored in output vector map",
- polyline),
- polyline, Vect_get_name(&Out), Vect_get_mapset(&Out));
+ polyline), polyline);
/* Copy (all linked) tables if needed */
if (copy_tables) {
Modified: grass/trunk/vector/v.build.polylines/walk.c
--- grass/trunk/vector/v.build.polylines/walk.c 2017-02-16 07:08:51 UTC (rev 70598)
+++ grass/trunk/vector/v.build.polylines/walk.c 2017-02-16 07:26:39 UTC (rev 70599)
@@ -129,7 +129,7 @@
int cat_idx;
int line, next_line, n1, n2;
- int type, node, next_node;
+ int node, next_node;
struct line_pnts *pnts;
struct line_cats *cats_tmp;
@@ -149,9 +149,9 @@
/* Pick up first set of coordinates */
lines_visited[line] = 1;
if (cats_tmp)
- type = Vect_read_line(map, pnts, Cats, line);
+ Vect_read_line(map, pnts, Cats, line);
else
- type = Vect_read_line(map, pnts, NULL, line);
+ Vect_read_line(map, pnts, NULL, line);
Vect_get_line_nodes(map, line, &n1, &n2);
next_line = find_next_line(map, line, n1, ltype);
@@ -175,7 +175,7 @@
node = next_node;
while (line != 0 && line != start_line) {
G_debug(2, " line = %d", line);
- type = Vect_read_line(map, pnts, cats_tmp, line);
+ Vect_read_line(map, pnts, cats_tmp, line);
if (cats_tmp && write_cats == MULTI_CATS) {
for (cat_idx = 0; cat_idx < cats_tmp->n_cats; cat_idx++) {
Vect_cat_set(Cats, cats_tmp->field[cat_idx],
