[GRASS-SVN] r70612 - grass/trunk/vector/v.distance
Sat Feb 18 00:43:49 PST 2017
Author: hcho
Date: 2017-02-18 00:43:49 -0800 (Sat, 18 Feb 2017)
New Revision: 70612
   grass/trunk/vector/v.distance/v.distance.html
v.distance: Update the manual; column= & -p are mutually exclusive
Modified: grass/trunk/vector/v.distance/v.distance.html
--- grass/trunk/vector/v.distance/v.distance.html	2017-02-18 08:33:54 UTC (rev 70611)
+++ grass/trunk/vector/v.distance/v.distance.html	2017-02-18 08:43:49 UTC (rev 70612)
@@ -97,7 +97,7 @@
 needed for network analysis:
 <div class="code"><pre>
-v.distance -p from=pnt to=ln out=connections upload=dist column=dist
+v.distance from=pnt to=ln out=connections upload=dist column=dist
 </pre></div>
 <h3>Query information</h3>
@@ -116,7 +116,7 @@
 Find nearest features:
-v.distance from=pnt to=map_to_query upload=cat col=somecol -p
+v.distance -p from=pnt to=map_to_query upload=cat
 </pre></div>
 <h3>Point-in-polygon</h3>
@@ -174,7 +174,7 @@
 echo "0|-58|1" | v.in.ascii output=pnt2 input=-
 # here, distances is in degree units
-v.distance from=pnt1 to=pnt2 upload=dist col=distance -p --q
+v.distance -p --q from=pnt1 to=pnt2 upload=dist
 from_cat|distance
 1|3
 </pre></div>
@@ -186,15 +186,14 @@
 <p>
 Spearfish sample data location:
-v.distance -pa from=archsites to=archsites upload=dist col=dist
+v.distance -pa from=archsites to=archsites upload=dist
 </pre></div>
 <p>
 North Carolina sample data location:
-v.distance -pa from=hospitals to=hospitals upload=dist \
-  col=dist separator=tab
+v.distance -pa from=hospitals to=hospitals upload=dist separator=tab
 from_cat to_cat       dist
               1          2          3          4          5 ...
 1             0    7489.10  339112.17   70900.39   70406.23 ...
