[GRASS-SVN] r70615 - grass/trunk/vector/v.distance
svn_grass at osgeo.org
Sat Feb 18 06:16:18 PST 2017
Author: hcho
Date: 2017-02-18 06:16:17 -0800 (Sat, 18 Feb 2017)
New Revision: 70615
grass/trunk/vector/v.distance/main.c
v.distance: Don't require -p or column= just to create new features with no attributes; Don't output to stdout when -a is used with column= (stdout only with -p)
v.distance from= to= # new map
v.distance from= to= upload= -p # new map & stdout
v.distance from= to= upload= column= # new map with attributes
v.distance -a from= to= # new map
v.distance -a from= to= upload= -p # new map & stdout
v.distance -a from= to= upload= column= table= # new map with attributes
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2017-02-18 09:52:36 UTC (rev 70614)
+++ grass/trunk/vector/v.distance/main.c 2017-02-18 14:16:17 UTC (rev 70615)
@@ -38,6 +38,7 @@
int i, j;
int print_as_matrix; /* only for do_all=TRUE */
int do_all; /* calculate from each to each within the threshold */
+ int upload;
struct GModule *module;
struct {
struct Option *from, *to, *from_type, *to_type,
@@ -81,6 +82,7 @@
char *sep;
do_all = FALSE;
+ upload = FALSE;
print_as_matrix = FALSE;
column = NULL;
@@ -151,7 +153,7 @@
opt.upload = G_define_option();
opt.upload->key = "upload";
opt.upload->type = TYPE_STRING;
- opt.upload->required = YES;
+ opt.upload->required = NO;
opt.upload->multiple = YES;
opt.upload->guisection = _("From");
opt.upload->options = "cat,dist,to_x,to_y,to_along,to_angle,to_attr";
@@ -217,8 +219,9 @@
flag.all->label =
_("Calculate distances to all features within the threshold");
flag.all->description =
- _("Output is written to stdout but may be uploaded to a new table "
- "created by this module; multiple 'upload' options may be used.");
+ _("Output may be written to stdout using the 'print' flag, "
+ "or uploaded to a new table created by the 'table' option; "
+ "multiple 'upload' options may be used.");
/* GUI dependency */
opt.from->guidependency = G_store(opt.from_field->key);
@@ -227,7 +230,11 @@
opt.to_field->guidependency = G_store(opt.to_column->key);
G_option_exclusive(opt.column, flag.print, NULL);
- G_option_required(opt.column, flag.print, NULL);
+ G_option_exclusive(opt.table, flag.print, NULL);
+ G_option_requires(opt.upload, flag.print, opt.column, NULL);
+ G_option_requires(opt.column, opt.upload, NULL);
+ G_option_requires(flag.print, opt.upload, NULL);
+ G_option_requires_all(opt.table, flag.all, opt.upload, NULL);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -240,6 +247,8 @@
if (flag.all->answer)
do_all = TRUE;
+ if (opt.column->answer || flag.print->answer)
+ upload = TRUE;
geodesic = G_projection() == PROJECTION_LL;
if (geodesic)
@@ -250,7 +259,7 @@
/* Read upload and column options */
/* count */
i = 0;
- while (opt.upload->answers[i])
+ while (opt.upload->answer && opt.upload->answers[i])
i++;
if (strcmp(opt.from->answer, opt.to->answer) == 0 &&
do_all && !opt.table->answer && i == 1)
@@ -260,7 +269,7 @@
Upload = (UPLOAD *) G_calloc(i + 1, sizeof(UPLOAD));
/* read upload */
i = 0;
- while (opt.upload->answers[i]) {
+ while (opt.upload->answer && opt.upload->answers[i]) {
if (strcmp(opt.upload->answers[i], "cat") == 0)
Upload[i].upload = CAT;
else if (strcmp(opt.upload->answers[i], "from_x") == 0)
@@ -286,9 +295,8 @@
Upload[i].upload = TO_ATTR;
- /* store relation names if -p is given because column= and -p are
- * mutually exclusive */
- if (flag.print->answer)
+ /* store default column names if column= is not given */
+ if (!opt.column->answer)
Upload[i].column = G_store(opt.upload->answers[i]);
i++;
@@ -457,7 +465,7 @@
db_init_string(&dbstr);
driver = NULL;
Fi = NULL;
- if (!flag.print->answer && !do_all) {
+ if (upload && !flag.print->answer && !do_all) {
Fi = Vect_get_field(&From, from_field);
if (Fi == NULL)
@@ -525,7 +533,7 @@
/* Check column types */
char *fcname = NULL;
int fctype, tctype;
@@ -1295,13 +1303,13 @@
/* open from driver */
- if (!flag.print->answer) {
+ if (upload && !flag.print->answer) {
if (!do_all) {
driver = db_start_driver_open_database(Fi->driver, Fi->database);
if (driver == NULL)
G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
- Fi->database, Fi->driver);
+ Fi->database, Fi->driver);
else {
driver = db_start_driver_open_database(NULL, NULL);
@@ -1370,7 +1378,7 @@
opt.table->answer);
- else if (!do_all) { /* read existing cats from table */
+ else if (upload && !do_all) { /* read existing cats from table */
ncatexist =
db_select_int(driver, Fi->table, Fi->key, NULL, &catexist);
G_debug(1, "%d cats selected from the table", ncatexist);
@@ -1386,13 +1394,13 @@
if (driver)
db_begin_transaction(driver);
- if (!(flag.print->answer || (do_all && !opt.table->answer))) /* no printing */
+ if (!flag.print->answer) /* no printing */
G_message("Update vector attributes...");
for (i = 0; i < count; i++) {
dbCatVal *catval = 0;
G_percent(i, count, 1);
/* Write line connecting nearest points */
@@ -1423,7 +1431,7 @@
db_CatValArray_get_value(&cvarr, Near[i].to_cat, &catval);
- if (flag.print->answer || (do_all && !opt.table->answer)) { /* print only */
+ if (flag.print->answer) { /* print only */
input and output is the same &&
calculate distances &&
@@ -1455,7 +1463,7 @@
fprintf(stdout, "\n");
- else if (do_all) { /* insert new record */
+ else if (do_all && opt.table->answer) { /* insert new record */
if (!Outp)
sprintf(buf1, "insert into %s values ( %d ", opt.table->answer,
Near[i].from_cat);
@@ -1538,7 +1546,7 @@
update_err++;
- else { /* update table */
+ else if (upload) { /* update table */
/* check if exists in table */
cex =
(int *)bsearch((void *)&(Near[i].from_cat), catexist,
@@ -1652,7 +1660,7 @@
G_message(_("%d categories - no nearest feature found"),
update_notfound);
db_close_database_shutdown_driver(driver);
db_free_string(&stmt);
