[GRASS-SVN] r70617 - in grass/branches/releasebranch_7_2: include lib/gis
svn_grass at osgeo.org
Sat Feb 18 06:55:19 PST 2017
Author: martinl
Date: 2017-02-18 06:55:19 -0800 (Sat, 18 Feb 2017)
New Revision: 70617
grass/branches/releasebranch_7_2/include/gis.h
grass/branches/releasebranch_7_2/lib/gis/parser.c
grass/branches/releasebranch_7_2/lib/gis/parser_local_proto.h
libgis: add suppress overwrite attribute (see #3270)
Modified: grass/branches/releasebranch_7_2/include/gis.h
--- grass/branches/releasebranch_7_2/include/gis.h 2017-02-18 14:39:37 UTC (rev 70616)
+++ grass/branches/releasebranch_7_2/include/gis.h 2017-02-18 14:55:19 UTC (rev 70617)
@@ -540,6 +540,7 @@
char key; /*!< Key char used on command line */
char answer; /*!< Stores flag state: 0/1 */
char suppress_required; /*!< Suppresses checking of required options */
+ char suppress_overwrite; /*!< Suppresses checking of existing output */
const char *label; /*!< Optional short label, used in GUI as item label */
const char *description; /*!< String describing flag meaning */
const char *guisection; /*!< GUI Layout guidance: ';' delimited hierarchical tree position */
Modified: grass/branches/releasebranch_7_2/lib/gis/parser.c
--- grass/branches/releasebranch_7_2/lib/gis/parser.c 2017-02-18 14:39:37 UTC (rev 70616)
+++ grass/branches/releasebranch_7_2/lib/gis/parser.c 2017-02-18 14:55:19 UTC (rev 70617)
@@ -624,8 +624,10 @@
return -1;
- if (check_overwrite())
- return -1;
+ if (!st->suppress_overwrite) {
+ if (check_overwrite())
+ return -1;
return 0;
@@ -972,6 +974,8 @@
flag->answer = 1;
if (flag->suppress_required)
st->suppress_required = 1;
+ if (flag->suppress_overwrite)
+ st->suppress_overwrite = 1;
return;
flag = flag->next_flag;
Modified: grass/branches/releasebranch_7_2/lib/gis/parser_local_proto.h
--- grass/branches/releasebranch_7_2/lib/gis/parser_local_proto.h 2017-02-18 14:39:37 UTC (rev 70616)
+++ grass/branches/releasebranch_7_2/lib/gis/parser_local_proto.h 2017-02-18 14:55:19 UTC (rev 70617)
@@ -21,6 +21,7 @@
int quiet;
int has_required;
int suppress_required;
+ int suppress_overwrite;
struct GModule module_info; /* general information on the corresponding module */
