[GRASS-SVN] r70626 - grass/trunk/vector/v.distance
svn_grass at osgeo.org
Sun Feb 19 13:28:50 PST 2017
Author: hcho
Date: 2017-02-19 13:28:50 -0800 (Sun, 19 Feb 2017)
New Revision: 70626
grass/trunk/vector/v.distance/main.c
v.distance: remove trailing whitespaces; fit comments to 80 columns
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2017-02-19 21:19:28 UTC (rev 70625)
+++ grass/trunk/vector/v.distance/main.c 2017-02-19 21:28:50 UTC (rev 70626)
@@ -2,7 +2,7 @@
* MODULE: v.distance
* AUTHOR(S): - J.Soimasuo 15.9.1994, University of Joensuu,
* Faculty of Forestry, Finland
* - some additions by Markus Neteler (2002)
@@ -11,14 +11,14 @@
* - speed-up for dmax != 0 by Markus Metz (2010)
* - support all features by Markus Metz (2012)
* - create a new table for non -a runs by Huidae Cho (2017)
* PURPOSE: Calculates distance from a point to nearest feature in vector
* layer.
* COPYRIGHT: (C) 2002-2017 by the GRASS Development Team
- * This program is free software under the
- * GNU General Public License (>=v2).
+ * This program is free software under the
+ * GNU General Public License (>=v2).
* Read the file COPYING that comes with GRASS
* for details.
@@ -207,12 +207,13 @@
"measured CCW from the +x axis, in radians, between -Pi and Pi "
"inclusive"),
_("attribute of nearest feature given by to_column option"));
- /* "from_x - x coordinate of the nearest point on 'from' feature;" */
- /* "from_y - y coordinate of the nearest point on 'from' feature;" */
- /* "from_along - distance to the nearest point on 'from' feature along linear feature;" */
- /* "from_angle - angle between the linear feature in 'to' map and the +x "
- "axis, at the location of point/centroid in 'from' map, CCW, in "
- "radians, between -Pi and Pi inclusive;" */
+ /* "from_x - x coordinate of the nearest point on 'from' feature;"
+ * "from_y - y coordinate of the nearest point on 'from' feature;"
+ * "from_along - distance to the nearest point on 'from' feature along linear feature;"
+ * "from_angle - angle between the linear feature in 'to' map and the +x "
+ * "axis, at the location of point/centroid in 'from' map, CCW, in "
+ * "radians, between -Pi and Pi inclusive;"
opt.upload->descriptions = desc;
opt.column = G_define_standard_option(G_OPT_DB_COLUMN);
@@ -227,7 +228,7 @@
opt.to_column->description =
_("Column name of nearest feature (used with upload=to_attr)");
opt.to_column->guisection = _("To");
opt.table = G_define_standard_option(G_OPT_DB_TABLE);
opt.table->gisprompt = "new_dbtable,dbtable,dbtable";
opt.table->description = _("Name of table created");
@@ -256,7 +257,7 @@
sprintf(buf1, "%s,%s", opt.to_field->key, opt.to_column->key);
opt.to->guidependency = G_store(buf1);
opt.to_field->guidependency = G_store(opt.to_column->key);
G_option_required(opt.upload, opt.out, NULL);
G_option_exclusive(opt.column, flag.print, NULL);
G_option_exclusive(opt.table, flag.print, NULL);
@@ -378,7 +379,7 @@
Vect_close(&From);
G_fatal_error(_("No features of selected type found in <%s>"), name);
/* Open 'to' vector */
Vect_set_open_level(2);
if (Vect_open_old2(&To, opt.to->answer, "", opt.to_field->answer) < 0)
@@ -445,10 +446,11 @@
max = max_map;
- /* how to determine a reasonable number of steps to increase the search box? */
- /* with max > 0 but max <<< tmp_max, 2 steps are sufficient, first 0 then max
- * a reasonable number of steps also depends on the number of features in To
- * e.g. only one area in To, no need to step */
+ /* how to determine a reasonable number of steps to increase the search
+ * box? */
+ /* with max > 0 but max <<< tmp_max, 2 steps are sufficient, first 0
+ * then max a reasonable number of steps also depends on the number of
+ * features in To e.g. only one area in To, no need to step */
if (geodesic)
n_max_steps = sqrt(nto);
@@ -556,13 +558,13 @@
/* check if to_column exists and get its SQL type */
db_get_column(to_driver, toFi->table, opt.to_column->answer, &column);
if (column) {
- sqltype = db_get_column_sqltype(column);
- switch(sqltype) {
- case DB_SQL_TYPE_CHARACTER:
- sprintf(to_attr_sqltype, "VARCHAR(%d)", db_get_column_length(column));
- break;
- default:
- sprintf(to_attr_sqltype, "%s", db_sqltype_name(sqltype));
+ sqltype = db_get_column_sqltype(column);
+ switch(sqltype) {
+ case DB_SQL_TYPE_CHARACTER:
+ sprintf(to_attr_sqltype, "VARCHAR(%d)", db_get_column_length(column));
+ break;
+ default:
+ sprintf(to_attr_sqltype, "%s", db_sqltype_name(sqltype));
db_free_column(column);
@@ -631,7 +633,8 @@
lList = Vect_new_boxlist(1); /* line list */
aList = Vect_new_boxlist(1); /* area list */
- /* Allocate space ( may be more than needed (duplicate cats and elements without cats) ) */
+ /* Allocate space ( may be more than needed (duplicate cats and elements
+ * without cats) ) */
/* Be careful with do_all, it can easily run out of memory */
anear = nfrom;
Near = (NEAR *) G_calloc(nfrom, sizeof(NEAR));
@@ -643,7 +646,8 @@
for (i = 1; i <= nlines; i++) {
ftype = Vect_read_line(&From, NULL, FCats, i);
- /* This keeps also categories of areas for future (if area s in from_type) */
+ /* This keeps also categories of areas for future (if area s in
+ * from_type) */
if (!(ftype & from_type) &&
(ftype != GV_CENTROID || !(from_type & GV_AREA)))
continue;
@@ -658,7 +662,7 @@
G_debug(1, "%d cats loaded from vector (including duplicates)",
nfcats);
if (nfcats == 0)
G_fatal_error(_("No categories for 'from' for slected type and layer"));
@@ -679,7 +683,8 @@
/* Go through all lines in 'from' and find nearest in 'to' for each */
- /* Note: as from_type is restricted to GV_POINTS (for now) everything is simple */
+ /* Note: as from_type is restricted to GV_POINTS (for now) everything is
+ * simple */
/* suppress compiler warnings */
tx = ty = tz = fx = fy = fz = 0;
@@ -688,7 +693,7 @@
/* Find nearest features for 'from' lines */
if (nfromlines) {
G_message(_("Finding nearest features..."));
near = NULL;
nlines = Vect_get_num_lines(&From);
@@ -741,7 +746,7 @@
if (box_edge < tmp_min)
continue;
box.E = fbox.E + box_edge;
box.W = fbox.W - box_edge;
box.N = fbox.N + box_edge;
@@ -923,7 +928,7 @@
if (!do_all && curr_step < n_max_steps) {
double dist_map = dist;
if (geodesic && tfeature > 0) {
double dx = fx - tx;
double dy = fy - ty;
@@ -934,11 +939,13 @@
/* enlarging the search box is possible */
if (tfeature > 0 && dist_map > box_edge) {
/* line found but distance > search edge:
- * line bbox overlaps with search box, line itself is outside search box */
+ * line bbox overlaps with search box, line itself is
+ * outside search box */
done = FALSE;
else if (tfeature == 0) {
- /* no line within max dist, but search box can still be enlarged */
+ /* no line within max dist, but search box can still be
+ * enlarged */
done = FALSE;
@@ -970,7 +977,7 @@
/* Find nearest features for 'from' areas */
/* the code is pretty much identical to the one for lines */
if (nfromareas) {
near = NULL;
G_message(_("Finding nearest features for areas..."));
@@ -1023,7 +1030,7 @@
continue;
@@ -1141,7 +1148,7 @@
continue;
Vect_get_area_points(&To, tarea, TPoints);
ttype = GV_BOUNDARY;
/* Find the distance of the outer ring of 'to' area
@@ -1274,7 +1281,7 @@
@@ -1285,11 +1292,13 @@
/* area found but distance > search edge:
- * area bbox overlaps with search box, area itself is outside search box */
+ * area bbox overlaps with search box, area itself is
done = FALSE;
- /* no area within max dist, but search box can still be enlarged */
+ /* no area within max dist, but search box can still be
+ * enlarged */
done = FALSE;
@@ -1396,8 +1405,8 @@
case TO_ALONG:
case TO_ANGLE:
sprintf(buf2, "%s double precision", Upload[j].column);
- break;
- case TO_ATTR:
+ break;
+ case TO_ATTR:
sprintf(buf2, "%s %s", Upload[j].column, to_attr_sqltype);
db_append_string(&stmt, buf2);
@@ -1587,7 +1596,7 @@
update_err++;
- else if (update_table) { /* update table */
+ else if (update_table) { /* update table */
/* check if exists in table */
cex =
(int *)bsearch((void *)&(Near[i].from_cat), catexist,
@@ -1741,7 +1750,7 @@
db_set_default_connection();
db_get_connection(&connection);
- Vect_map_add_dblink(Outp, 1, NULL, opt.table->answer, "cat",
+ Vect_map_add_dblink(Outp, 1, NULL, opt.table->answer, "cat",
connection.databaseName,
connection.driverName);
