[GRASS-SVN] r70631 - grass/trunk/scripts/v.report
svn_grass at osgeo.org
Sun Feb 19 15:40:29 PST 2017
Author: hcho
Date: 2017-02-19 15:40:29 -0800 (Sun, 19 Feb 2017)
New Revision: 70631
grass/trunk/scripts/v.report/v.report.py
v.report: Sort numerically (all options are numbers); Sort coor by (x, y, z); Fix non-first cat column
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py 2017-02-19 23:24:26 UTC (rev 70630)
+++ grass/trunk/scripts/v.report/v.report.py 2017-02-19 23:40:29 UTC (rev 70631)
@@ -4,9 +4,9 @@
# MODULE: v.report
# AUTHOR(S): Markus Neteler, converted to Python by Glynn Clements
-# Bug fixed by Huidae Cho <grass4u gmail.com>
+# Bug fixes, sort for coor by Huidae Cho <grass4u gmail.com>
# PURPOSE: Reports geometry statistics for vector maps
-# COPYRIGHT: (C) 2005, 2007-2009 by MN and the GRASS Development Team
+# COPYRIGHT: (C) 2005, 2007-2017 by MN and the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -77,10 +77,8 @@
colnames = ['cat']
if option == 'coor':
- columns = ['dummy1', 'dummy2', 'dummy3']
extracolnames = ['x', 'y', 'z']
else:
- columns = ['dummy1']
extracolnames = [option]
if units in ['p', 'percent']:
@@ -92,18 +90,28 @@
# NOTE: we suppress -1 cat and 0 cat
if isConnection:
- p = grass.pipe_command('v.db.select', quiet=True, flags='c', map=mapname, layer=layer)
+ p = grass.pipe_command('v.db.select', quiet=True, map=mapname, layer=layer)
records1 = []
+ catcol = -1
for line in p.stdout:
cols = line.rstrip('\r\n').split('|')
- if cols[0] == '0':
+ if catcol == -1:
+ for i in range(0, len(cols)):
+ if cols[i] == 'cat':
+ catcol = i
+ break
+ if catcol == -1:
+ # shouldn't happen, but let's do this
+ catcol = 0
continue
- records1.append([int(cols[0])] + cols[1:])
+ if cols[catcol] == '-1' or cols[catcol] == '0':
+ continue
+ records1.append(cols[:catcol] + [int(cols[catcol])] + cols[(catcol+1):])
p.wait()
if p.returncode != 0:
sys.exit(1)
- records1.sort()
+ records1.sort(key=lambda r: r[catcol])
if len(records1) == 0:
try:
@@ -115,16 +123,15 @@
pass
# fetch the requested attribute sorted by cat:
- p = grass.pipe_command('v.to.db', flags='p',
- quiet=True,
- map=mapname, option=option, columns=columns,
+ p = grass.pipe_command('v.to.db', flags='p', quiet=True,
+ map=mapname, option=option,
layer=layer, units=unitsp)
records2 = []
fields = line.rstrip('\r\n').split('|')
if fields[0] in ['cat', '-1', '0']:
continue
- records2.append([int(fields[0])] + fields[1:-1] + [float(fields[-1])])
+ records2.append([int(fields[0])] + fields[1:])
p.wait()
records2.sort()
@@ -133,7 +140,7 @@
# v.db.select can return attributes that are not linked to features.
records3 = []
for r2 in records2:
- records3.append(filter(lambda r1: r1[0] == r2[0], records1)[0] + r2[1:])
+ records3.append(filter(lambda r1: r1[catcol] == r2[0], records1)[0] + r2[1:])
else:
records1 = []
p = grass.pipe_command('v.category', inp=mapname, layer=layer, option='print')
@@ -146,9 +153,8 @@
records1 = uniq(records1)
# make pre-table
- quiet=True,
records3 = []
@@ -179,9 +185,15 @@
# sort results
if options['sort']:
if options['sort'] == 'asc':
- records3.sort(key=lambda r: r[-1])
+ if options['option'] == 'coor':
+ records3.sort(key=lambda r: (float(r[-3]), float(r[-2]), float(r[-1])))
+ else:
+ records3.sort(key=lambda r: float(r[-1]))
else:
- records3.sort(key=lambda r: r[-1], reverse=True)
+ records3.sort(key=lambda r: (float(r[-3]), float(r[-2]), float(r[-1])), reverse=True)
+ else:
+ records3.sort(key=lambda r: float(r[-1]), reverse=True)
for r in records3:
sys.stdout.write('|'.join(map(str, r)) + '\n')
