[GRASS-SVN] r70633 - grass/trunk/vector/v.to.db
svn_grass at osgeo.org
Sun Feb 19 17:15:14 PST 2017
Author: hcho
Date: 2017-02-19 17:15:14 -0800 (Sun, 19 Feb 2017)
New Revision: 70633
grass/trunk/vector/v.to.db/main.c
v.to.db: Don't throw a fatal error when there are no features
Modified: grass/trunk/vector/v.to.db/main.c
--- grass/trunk/vector/v.to.db/main.c 2017-02-20 00:15:14 UTC (rev 70632)
+++ grass/trunk/vector/v.to.db/main.c 2017-02-20 01:15:14 UTC (rev 70633)
@@ -71,7 +71,7 @@
/* (+ 1 is for cat -1 (no category) reported at the end ) */
findex = Vect_cidx_get_field_index(&Map, options.field);
if (findex > -1) {
- n = Vect_cidx_get_num_unique_cats_by_index(&Map, findex);
+ n = Vect_cidx_get_num_cats_by_index(&Map, findex);
else {
n = 0;
@@ -80,7 +80,6 @@
Values = (struct value *) G_calloc(n + 1, sizeof(struct value));
/* prepopulate Values */
- n = Vect_cidx_get_num_cats_by_index(&Map, findex);
i = 0;
Values[i].cat = -1; /* features without category */
Values[i].used = 0;
