[GRASS-SVN] r70644 - grass/trunk/lib/gis
svn_grass at osgeo.org
Mon Feb 20 06:16:20 PST 2017
Author: mmetz
Date: 2017-02-20 06:16:20 -0800 (Mon, 20 Feb 2017)
New Revision: 70644
grass/trunk/lib/gis/window_map.c
libgis: fix G_adjust_east_longitude() and G_adjust_easting()
Modified: grass/trunk/lib/gis/window_map.c
--- grass/trunk/lib/gis/window_map.c 2017-02-20 14:10:24 UTC (rev 70643)
+++ grass/trunk/lib/gis/window_map.c 2017-02-20 14:16:20 UTC (rev 70644)
@@ -18,8 +18,8 @@
\brief Adjust east longitude.
- This routine returns an equivalent <i>east</i> that is larger, but
- no more than 360 larger than the <i>west</i> coordinate.
+ This routine returns an equivalent <i>east</i> that is at least as
+ large as the <i>west</i> coordinate.
<b>Note:</b> This routine should be used only with
latitude-longitude coordinates.
@@ -31,22 +31,24 @@
double G_adjust_east_longitude(double east, double west)
- while (east > west + 360.0)
- east -= 360.0;
- while (east <= west)
- east += 360.0;
+ double shift;
- return east;
+ shift = 0;
+ while (east + shift < west)
+ shift += 360.0;
+ return east + shift;
- \brief Returns east larger than west.
+ \brief Returns east not smaller than west.
If the region projection is <tt>PROJECTION_LL</tt>, then this
- routine returns an equivalent <i>east</i> that is larger, but no
- more than 360 degrees larger, than the coordinate for the western
- edge of the region. Otherwise no adjustment is made and the original
- <i>east</i> is returned.
+ routine returns an equivalent <i>east</i> that is not smaller than
+ the coordinate for the western edge of the region and, if possible,
+ smaller than the coordinate for the eastern edge of the region.
+ Otherwise no adjustment is made and the original <i>east</i> is
+ returned.
\param east east coordinate
\param window pointer to Cell_head
@@ -55,13 +57,17 @@
double G_adjust_easting(double east, const struct Cell_head *window)
+ double shift;
+ shift = 0;
if (window->proj == PROJECTION_LL) {
- east = G_adjust_east_longitude(east, window->west);
- if (east > window->east && east == window->west + 360)
- east = window->west;
+ while (east + shift >= window->east)
+ shift -= 360.0;
+ while (east + shift < window->west)
+ shift += 360.0;
- return east;
