[GRASS-SVN] r70663 - grass/trunk/lib/gis
svn_grass at osgeo.org
Wed Feb 22 08:50:40 PST 2017
Author: mmetz
Date: 2017-02-22 08:50:39 -0800 (Wed, 22 Feb 2017)
New Revision: 70663
grass/trunk/lib/gis/rd_cellhd.c
libgis, G__read_Cell_head_array(): more informative error messages (fix r40698)
Modified: grass/trunk/lib/gis/rd_cellhd.c
--- grass/trunk/lib/gis/rd_cellhd.c 2017-02-22 16:49:15 UTC (rev 70662)
+++ grass/trunk/lib/gis/rd_cellhd.c 2017-02-22 16:50:39 UTC (rev 70663)
@@ -138,7 +138,8 @@
switch (scan_item(buf, label, value)) {
case -1:
- G_fatal_error(_("Syntax error in cell header"));
+ G_fatal_error(_("Syntax error in cell header, line %d: %s"),
+ line, buf);
case 0:
continue;
case 1:
@@ -149,7 +150,7 @@
G_fatal_error(_("Duplicate projection field"));
if (!scan_int(value, &cellhd->proj))
+ G_fatal_error(_("Invalid projection field: %s"), value);
SET(F_PROJ);
continue;
@@ -159,7 +160,7 @@
G_fatal_error(_("Duplicate zone field"));
if (!scan_int(value, &cellhd->zone))
+ G_fatal_error(_("Invalid zone field: %s"), value);
SET(F_ZONE);
continue;
@@ -176,7 +177,8 @@
G_debug(3, "region item: %s", buf);
case -1:
+ line, buf);
case 0:
continue;
case 1:
@@ -192,7 +194,7 @@
if (TEST(F_NORTH))
G_fatal_error(_("Duplicate north field"));
if (!G_scan_northing(value, &cellhd->north, cellhd->proj))
+ G_fatal_error(_("Invalid north field: %s"), value);
SET(F_NORTH);
continue;
@@ -200,7 +202,7 @@
if (TEST(F_SOUTH))
G_fatal_error(_("Duplicate south field"));
if (!G_scan_northing(value, &cellhd->south, cellhd->proj))
+ G_fatal_error(_("Invalid south field: %s"), value);
SET(F_SOUTH);
continue;
@@ -208,7 +210,7 @@
if (TEST(F_EAST))
G_fatal_error(_("Duplicate east field"));
if (!G_scan_easting(value, &cellhd->east, cellhd->proj))
+ G_fatal_error(_("Invalid east field: %s"), value);
SET(F_EAST);
continue;
@@ -216,7 +218,7 @@
if (TEST(F_WEST))
G_fatal_error(_("Duplicate west field"));
if (!G_scan_easting(value, &cellhd->west, cellhd->proj))
+ G_fatal_error(_("Invalid west field: %s"), value);
SET(F_WEST);
continue;
@@ -224,7 +226,7 @@
if (TEST(F_TOP))
G_fatal_error(_("Duplicate top field"));
if (!scan_double(value, &cellhd->top))
+ G_fatal_error(_("Invalid top field: %s"), value);
SET(F_TOP);
continue;
@@ -232,7 +234,7 @@
if (TEST(F_BOTTOM))
G_fatal_error(_("Duplicate bottom field"));
if (!scan_double(value, &cellhd->bottom))
+ G_fatal_error(_("Invalid bottom field: %s"), value);
SET(F_BOTTOM);
continue;
@@ -240,9 +242,9 @@
if (TEST(F_EWRES))
G_fatal_error(_("Duplicate e-w resolution field"));
if (!G_scan_resolution(value, &cellhd->ew_res, cellhd->proj))
+ G_fatal_error(_("Invalid e-w resolution field: %s"), value);
if (cellhd->ew_res <= 0.0)
SET(F_EWRES);
continue;
@@ -250,9 +252,9 @@
if (TEST(F_EWRES3))
G_fatal_error(_("Duplicate 3D e-w resolution field"));
if (!G_scan_resolution(value, &cellhd->ew_res3, cellhd->proj))
+ G_fatal_error(_("Invalid 3D e-w resolution field: %s"), value);
if (cellhd->ew_res3 <= 0.0)
SET(F_EWRES3);
continue;
@@ -260,9 +262,9 @@
if (TEST(F_NSRES))
G_fatal_error(_("Duplicate n-s resolution field"));
if (!G_scan_resolution(value, &cellhd->ns_res, cellhd->proj))
+ G_fatal_error(_("Invalid n-s resolution field: %s"), value);
if (cellhd->ns_res <= 0.0)
SET(F_NSRES);
continue;
@@ -270,9 +272,9 @@
if (TEST(F_NSRES3))
G_fatal_error(_("Duplicate 3D n-s resolution field"));
if (!G_scan_resolution(value, &cellhd->ns_res3, cellhd->proj))
+ G_fatal_error(_("Invalid 3D n-s resolution field: %s"), value);
if (cellhd->ns_res3 <= 0.0)
SET(F_NSRES3);
continue;
@@ -280,9 +282,9 @@
if (TEST(F_TBRES))
G_fatal_error(_("Duplicate t-b resolution field"));
if (!scan_double(value, &cellhd->tb_res))
+ G_fatal_error(_("Invalid t-b resolution field: %s"), value);
if (cellhd->tb_res <= 0.0)
SET(F_TBRES);
continue;
@@ -290,9 +292,9 @@
if (TEST(F_ROWS))
G_fatal_error(_("Duplicate rows field"));
if (!scan_int(value, &cellhd->rows))
+ G_fatal_error(_("Invalid rows field: %s"), value);
if (cellhd->rows <= 0)
SET(F_ROWS);
continue;
@@ -300,9 +302,9 @@
if (TEST(F_ROWS3))
G_fatal_error(_("Duplicate 3D rows field"));
if (!scan_int(value, &cellhd->rows3))
+ G_fatal_error(_("Invalid 3D rows field: %s"), value);
if (cellhd->rows3 <= 0)
SET(F_ROWS3);
continue;
@@ -310,9 +312,9 @@
if (TEST(F_COLS))
G_fatal_error(_("Duplicate cols field"));
if (!scan_int(value, &cellhd->cols))
+ G_fatal_error(_("Invalid cols field: %s"), value);
if (cellhd->cols <= 0)
SET(F_COLS);
continue;
@@ -320,9 +322,9 @@
if (TEST(F_COLS3))
G_fatal_error(_("Duplicate 3D cols field"));
if (!scan_int(value, &cellhd->cols3))
+ G_fatal_error(_("Invalid 3D cols field: %s"), value);
if (cellhd->cols3 <= 0)
SET(F_COLS3);
continue;
@@ -330,9 +332,9 @@
if (TEST(F_DEPTHS))
G_fatal_error(_("Duplicate depths field"));
if (!scan_int(value, &cellhd->depths))
+ G_fatal_error(_("Invalid depths field: %s"), value);
if (cellhd->depths <= 0)
SET(F_DEPTHS);
continue;
@@ -340,7 +342,7 @@
if (TEST(F_FORMAT))
G_fatal_error(_("Duplicate format field"));
if (!scan_int(value, &cellhd->format))
+ G_fatal_error(_("Invalid format field: %s"), value);
SET(F_FORMAT);
continue;
@@ -348,11 +350,12 @@
if (TEST(F_COMP))
G_fatal_error(_("Duplicate compressed field"));
if (!scan_int(value, &cellhd->compressed))
+ G_fatal_error(_("Invalid compressed field: %s"), value);
SET(F_COMP);
continue;
+ line, buf);
/* check some of the fields */
