[GRASS-SVN] r70676 - in grass/branches/releasebranch_7_2: lib/calc raster/r.mapcalc/testsuite
svn_grass at osgeo.org
Sun Feb 26 02:14:27 PST 2017
Author: marisn
Date: 2017-02-26 02:14:27 -0800 (Sun, 26 Feb 2017)
New Revision: 70676
Added:
grass/branches/releasebranch_7_2/raster/r.mapcalc/testsuite/test_nmedian_bug_3296.py
grass/branches/releasebranch_7_2/lib/calc/xnmedian.c
Do not calculate median if only one variable is provided.
Fixes #3296 (backport of r70674)
Modified: grass/branches/releasebranch_7_2/lib/calc/xnmedian.c
--- grass/branches/releasebranch_7_2/lib/calc/xnmedian.c 2017-02-26 10:01:10 UTC (rev 70675)
+++ grass/branches/releasebranch_7_2/lib/calc/xnmedian.c 2017-02-26 10:14:27 UTC (rev 70676)
@@ -82,6 +82,8 @@
if (!n)
SET_NULL_C(&res[i]);
+ else if (n == 1)
+ res[i] = *a1;
else {
qsort(a, n, sizeof(CELL), icmp);
res[i] = (*a1 + *a2) / 2;
@@ -109,6 +111,8 @@
if (!n)
SET_NULL_F(&res[i]);
+ else if (n == 1)
+ res[i] = *a1;
else {
qsort(a, n, sizeof(FCELL), fcmp);
@@ -136,6 +140,8 @@
if (!n)
SET_NULL_D(&res[i]);
+ else if (n == 1)
+ res[i] = *a1;
else {
qsort(a, n, sizeof(DCELL), dcmp);
Copied: grass/branches/releasebranch_7_2/raster/r.mapcalc/testsuite/test_nmedian_bug_3296.py (from rev 70674, grass/trunk/raster/r.mapcalc/testsuite/test_nmedian_bug_3296.py)
--- grass/branches/releasebranch_7_2/raster/r.mapcalc/testsuite/test_nmedian_bug_3296.py (rev 0)
+++ grass/branches/releasebranch_7_2/raster/r.mapcalc/testsuite/test_nmedian_bug_3296.py 2017-02-26 10:14:27 UTC (rev 70676)
@@ -0,0 +1,104 @@
+#!/usr/bin/env python
+# MODULE: test_nmedian_bug.py
+# AUTHOR: Maris Nartiss, based on Vaclav Petras test_row_above_below_bug.py
+# PURPOSE: Show bug reported in #3296
+# COPYRIGHT: (C) 2017 by Maris Nartiss and the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# #3296
+# r.mapcalc calculates wrong median value if one of two input maps has a null value
+# Also depends on correct functioning of row() and col() mapcalc variables
+# https://trac.osgeo.org/grass/ticket/3296
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+OUTPUT = """\
+north: 3
+south: 0
+west: 0
+east: 3
+rows: 3
+cols: 3
+null: *
+1.0 1.0 1.0
+4.0 4.0 4.0
+9.0 9.0 9.0
+OUTPUT_CELL = """\
+north: 3
+south: 0
+west: 0
+east: 3
+rows: 3
+cols: 3
+null: *
+1 1 1
+4 4 4
+9 9 9
+class TestNmedianBug(TestCase):
+ to_remove = []
+ input = 'r_mapcalc_test_pattern'
+ output = 'r_mapcalc_test_output'
+ output_ref = 'r_mapcalc_test_output_ref'
+ output_cell = 'r_mapcalc_test_output_cell'
+ def setUp(self):
+ expression = "{o}=row()*col()".format(o=self.input)
+ self.use_temp_region()
+ self.runModule('g.region', n=3, s=0, e=3, w=0, res=1)
+ self.runModule('r.mapcalc', expression=expression, overwrite=True)
+ self.to_remove.append(self.input)
+ self.runModule('r.in.ascii', input='-', stdin_=OUTPUT,
+ output=self.output_ref, overwrite=True)
+ self.to_remove.append(self.output_ref)
+ self.runModule('r.in.ascii', input='-', stdin_=OUTPUT_CELL,
+ output=self.output_cell, overwrite=True)
+ self.to_remove.append(self.output_cell)
+ def tearDown(self):
+ self.del_temp_region()
+ if 0 and self.to_remove:
+ self.runModule('g.remove', flags='f', type='raster',
+ name=','.join(self.to_remove), verbose=True)
+ def test_cell(self):
+ expression = "{o}=nmedian(({i}[0,-1] - {i})^2,({i}[0,1] - {i})^2)".format(o=self.output, i=self.input)
+ self.assertModule('r.mapcalc', expression=expression, overwrite=True)
+ self.assertRasterExists(self.output)
+ self.to_remove.append(self.output)
+ self.assertRastersNoDifference(actual=self.output,
+ reference=self.output_cell, precision=0)
+ def test_fcell(self):
+ expression = "{o}=nmedian(float(({i}[0,-1] - {i})^2), float(({i}[0,1] - {i})^2))".format(o=self.output, i=self.input)
+ reference=self.output_ref, precision=0)
+ def test_dcell(self):
+ expression = "{o}=nmedian(double(({i}[0,-1] - {i})^2), double(({i}[0,1] - {i})^2))".format(o=self.output, i=self.input)
+if __name__ == '__main__':
+ test()
