[GRASS-SVN] r70678 - grass/branches/releasebranch_7_2/lib/vector/Vlib
svn_grass at osgeo.org
Sun Feb 26 05:24:48 PST 2017
Author: mmetz
Date: 2017-02-26 05:24:48 -0800 (Sun, 26 Feb 2017)
New Revision: 70678
grass/branches/releasebranch_7_2/lib/vector/Vlib/net_analyze.c
vectorlib, network analysis: initialize output, fix shortcut, prune path (backport from trunk r70677)
Modified: grass/branches/releasebranch_7_2/lib/vector/Vlib/net_analyze.c
--- grass/branches/releasebranch_7_2/lib/vector/Vlib/net_analyze.c 2017-02-26 13:24:05 UTC (rev 70677)
+++ grass/branches/releasebranch_7_2/lib/vector/Vlib/net_analyze.c 2017-02-26 13:24:48 UTC (rev 70678)
@@ -150,6 +150,9 @@
/* Note : if from == to dgl goes to nearest node and returns back (dgl feature) =>
* check here for from == to */
+ if (List != NULL)
+ Vect_reset_list(List);
/* Check if from and to are identical, otherwise dglib returns path to neares node and back! */
if (from == to) {
if (cost != NULL)
@@ -822,6 +825,11 @@
Vect_reset_line(SPoints);
if (flen == tlen) {
cur_cst = 0;
+ Vect_append_point(SPoints, fx, fy, fz);
+ Vect_append_point(SPoints, fcx, fcy, fcz);
+ Vect_append_point(SPoints, tx, ty, tz);
reachable = shortcut = 1;
else if (flen < tlen) {
@@ -948,6 +956,7 @@
Vect_append_points(Points, APoints, GV_FORWARD);
else
Vect_append_points(Points, APoints, GV_BACKWARD);
+ Points->n_points--;
if (NodesList) {
int node, node1, node2;
@@ -966,8 +975,11 @@
Vect_list_append(List, line);
- if (Points)
+ if (Points) {
+ if (LList->n_values)
+ Points->n_points++;
Vect_append_points(Points, tPoints[tn], GV_FORWARD);
if (TPoints)
Vect_append_points(TPoints, tPoints[tn], GV_FORWARD);
@@ -981,6 +993,8 @@
if (costs)
*costs = cur_cst;
+ if (Points)
+ Vect_line_prune(Points);
return reachable;
