[GRASS-SVN] r70680 - grass/trunk/vector/v.net.path
svn_grass at osgeo.org
Sun Feb 26 05:27:01 PST 2017
Author: mmetz
Date: 2017-02-26 05:27:01 -0800 (Sun, 26 Feb 2017)
New Revision: 70680
grass/trunk/vector/v.net.path/path.c
v.net.path: fix segfault, skip identical from - to
Modified: grass/trunk/vector/v.net.path/path.c
--- grass/trunk/vector/v.net.path/path.c 2017-02-26 13:25:38 UTC (rev 70679)
+++ grass/trunk/vector/v.net.path/path.c 2017-02-26 13:27:01 UTC (rev 70680)
@@ -122,6 +122,7 @@
cat = 0;
formaterr = nopoint = unreachable = 0;
while (1) {
+ double fdist, tdist;
if (!filename) {
if (fgets(buf, sizeof(buf), stdin) == NULL)
@@ -132,16 +133,19 @@
break;
+ G_chop(buf);
- double fdist, tdist;
+ sp = SP_OK;
- G_chop(buf);
ret =
sscanf(buf, "%d %lf %lf %lf %lf %s", &id, &fx, &fy, &tx, &ty,
dummy);
if (ret == 5) {
input_mode = INPUT_MODE_COOR;
+ if (fx == tx && fy == ty) {
+ G_warning(_("From and to are identical (id %d)"), id);
+ continue;
else {
ret = sscanf(buf, "%d %d %d %s", &id, &fcat, &tcat, dummy);
@@ -151,15 +155,7 @@
continue;
input_mode = INPUT_MODE_NODE;
- G_debug(3, "mode = %d", input_mode);
- cat++; /* Output category */
- sp = SP_OK;
- cost = fdist = tdist = 0;
- if (input_mode == INPUT_MODE_NODE) {
/* From */
Citem =
(CIDX *) bsearch((void *)&fcat, Cidx, npoints, sizeof(CIDX),
@@ -177,6 +173,8 @@
fnode =
Vect_find_node(In, Points->x[0], Points->y[0],
Points->z[0], 0, 0);
+ if (fnode == 0)
+ sp = SP_NOPOINT;
/* Vect_get_line_nodes(In, fline, &fnode, NULL); */
G_debug(3, "from: cat = %5d point(line) = %5d node = %5d", fcat,
@@ -199,65 +197,82 @@
tnode =
+ if (tnode == 0)
+ sp = SP_NOPOINT;
/* Vect_get_line_nodes(In, tline, &tnode, NULL); */
G_debug(3, "to : cat = %5d point(line) = %5d node = %5d", tcat,
tline, tnode);
- if (sp != SP_NOPOINT) {
- if (use_ttb)
- ret =
- Vect_net_ttb_shortest_path(In, fnode, 0, tnode, 0,
- tucfield, AList, &cost);
- else
- ret =
- Vect_net_shortest_path(In, fnode, tnode, AList,
- &cost);
+ if (sp == SP_NOPOINT)
+ continue;
- if (ret == -1) {
- sp = SP_UNREACHABLE;
- unreachable++;
- G_warning(_("Point with category [%d] is not reachable "
- "from point with category [%d]"), tcat, fcat);
- else {
- /* Write new line connecting 'from' and 'to' */
- G_debug(3, "Number of arcs = %d, total costs = %f",
- AList->n_values, cost);
+ if (fnode == tnode) {
+ continue;
- Vect_reset_cats(Cats);
- Vect_cat_set(Cats, 1, cat);
+ G_debug(3, "mode = %d", input_mode);
- if (segments) {
- for (i = 0; i < AList->n_values; i++) {
- line = AList->value[i];
- Vect_read_line(In, Points, NULL, abs(line));
+ cat++; /* Output category */
+ cost = fdist = tdist = 0;
- if (line > 0) {
- Vect_write_line(Out, GV_LINE, Points, Cats);
- else {
- Vect_reset_line(OPoints);
- Vect_append_points(OPoints, Points,
- GV_BACKWARD);
- Vect_write_line(Out, GV_LINE, OPoints, Cats);
+ if (input_mode == INPUT_MODE_NODE) {
+ if (use_ttb)
+ ret =
+ Vect_net_ttb_shortest_path(In, fnode, 0, tnode, 0,
+ tucfield, AList, &cost);
+ else
+ ret =
+ Vect_net_shortest_path(In, fnode, tnode, AList,
+ &cost);
+ if (ret == -1) {
+ sp = SP_UNREACHABLE;
+ unreachable++;
+ G_warning(_("Point with category [%d] is not reachable "
+ "from point with category [%d]"), tcat, fcat);
+ else {
+ /* Write new line connecting 'from' and 'to' */
+ G_debug(3, "Number of arcs = %d, total costs = %f",
+ AList->n_values, cost);
+ Vect_reset_cats(Cats);
+ Vect_cat_set(Cats, 1, cat);
+ if (segments) {
+ for (i = 0; i < AList->n_values; i++) {
+ line = AList->value[i];
+ Vect_read_line(In, Points, NULL, abs(line));
+ if (line > 0) {
+ Vect_write_line(Out, GV_LINE, Points, Cats);
+ else {
+ Vect_reset_line(OPoints);
+ Vect_append_points(OPoints, Points,
+ GV_BACKWARD);
+ Vect_write_line(Out, GV_LINE, OPoints, Cats);
- else {
+ else {
- if (line > 0)
- GV_FORWARD);
- else
- GV_BACKWARD);
- OPoints->n_points--;
+ if (line > 0)
+ GV_FORWARD);
+ else
+ GV_BACKWARD);
+ OPoints->n_points--;
+ if (AList->n_values > 0 && OPoints->n_points > 0) {
OPoints->n_points++;
@@ -319,7 +334,8 @@
else {
+ if (OPoints->n_points > 0)
