[GRASS-SVN] r70702 - grass-addons/grass7/raster/r.object.spatialautocor
svn_grass at osgeo.org
Tue Feb 28 12:13:17 PST 2017
Author: neteler
Date: 2017-02-28 12:13:17 -0800 (Tue, 28 Feb 2017)
New Revision: 70702
grass-addons/grass7/raster/r.object.spatialautocor/r.object.spatialautocor.html
r.object.spatialautocor manual: fix addons path; HTML cosmetics
Modified: grass-addons/grass7/raster/r.object.spatialautocor/r.object.spatialautocor.html
--- grass-addons/grass7/raster/r.object.spatialautocor/r.object.spatialautocor.html 2017-02-28 19:49:45 UTC (rev 70701)
+++ grass-addons/grass7/raster/r.object.spatialautocor/r.object.spatialautocor.html 2017-02-28 20:13:17 UTC (rev 70702)
@@ -1,6 +1,6 @@
<h2>DESCRIPTION</h2>
-<p><em>r.object.spatialautocor</em> calculates global spatial autocorrelation
+<em>r.object.spatialautocor</em> calculates global spatial autocorrelation
of the raster objects in the <em>object_map</em> based on the values in the
<em>variable_map</em>. The user can choose between Moran's I or Geary's G
indicator using the <em>method</em> parameter.
@@ -11,25 +11,26 @@
<h2>NOTES</h2>
-<p>
-The module depends on the addon <a href="https://grass.osgeo.org/grass70/manuals/addons/r.neighborhoodmatrix.html">r.neighborhoodmatrix</a> which needs to be installed.
+The module depends on the addon
+<a href="https://grass.osgeo.org/grass7/manuals/addons/r.neighborhoodmatrix.html">r.neighborhoodmatrix</a>
+which needs to be installed.
<h2>EXAMPLE</h2>
-<p>Calculate the spatial autocorrelation of altitude in the elevation map using
-individual patches in the landclass96 as objects:
+Calculate the spatial autocorrelation of altitude in the elevation map using
+individual patches in the landclass96 (North Carolina sample dataset) as objects:
<p>
<div class="code"><pre>
-g.region rast=elevation
-r.clump landclass96 out=objects
+g.region raster=elevation
+r.clump landclass96 output=objects
r.object.spatialautocor ob=objects var=elevation method=moran
r.object.spatialautocor ob=objects var=elevation method=geary
</pre></div>
<h2>REFERENCES</h2>
-Moran, P.A.P., 1950. Notes on Continuous Stochastic Phenomena. Biometrika 37, 17–23.
+Moran, P.A.P., 1950. Notes on Continuous Stochastic Phenomena. Biometrika 37, 17-23.
<a href="https://dx.doi.org/10.2307%2F2332142">https://dx.doi.org/10.2307%2F2332142</a>
<br><br>
Geary, R.C., 1954. The Contiguity Ratio and Statistical Mapping. The Incorporated Statistician 5, 115.
