[GRASS-SVN] r70183 - in grass/branches/releasebranch_7_0: . doc general/g.version include lib/gis lib/init man
svn_grass at osgeo.org
Sun Jan 1 12:06:10 PST 2017
Author: neteler
Date: 2017-01-01 12:06:10 -0800 (Sun, 01 Jan 2017)
New Revision: 70183
grass/branches/releasebranch_7_0/INSTALL
grass/branches/releasebranch_7_0/REQUIREMENTS.html
grass/branches/releasebranch_7_0/doc/howto_release.txt
grass/branches/releasebranch_7_0/general/g.version/g.version.html
grass/branches/releasebranch_7_0/grasslib.dox
grass/branches/releasebranch_7_0/include/VERSION
grass/branches/releasebranch_7_0/lib/gis/gislib_cmdline_parsing.dox
grass/branches/releasebranch_7_0/lib/init/grass.py
grass/branches/releasebranch_7_0/man/build_rest.py
Happy New Year
Modified: grass/branches/releasebranch_7_0/INSTALL
--- grass/branches/releasebranch_7_0/INSTALL 2017-01-01 19:48:33 UTC (rev 70182)
+++ grass/branches/releasebranch_7_0/INSTALL 2017-01-01 20:06:10 UTC (rev 70183)
@@ -314,6 +314,6 @@
https://grass.osgeo.org/documentation/first-time-users/
-(C) 1999-2016 by The GRASS Development Team
+(C) 1999-2017 by The GRASS Development Team
Last changed: $Date$
Modified: grass/branches/releasebranch_7_0/REQUIREMENTS.html
--- grass/branches/releasebranch_7_0/REQUIREMENTS.html 2017-01-01 19:48:33 UTC (rev 70182)
+++ grass/branches/releasebranch_7_0/REQUIREMENTS.html 2017-01-01 20:06:10 UTC (rev 70183)
@@ -9,14 +9,14 @@
<h2>REQUIREMENTS to compile GRASS GIS 7</h2>
-A workstation running some flavor of UNIX like Solaris, IRIX,
-GNU/Linux, BSD, Mac OS X, Cygwin or MinGW (on Win32). Ideally, you
-should have at least 500 Mb. The source code package needs around 80
-MB compressed. The resulting binaries may need between 20 MB and 180
-MB depending on your platform. During a full compilation you may need
+A workstation running some flavor of UNIX including GNU/Linux, Solaris, IRIX, BSD,
+Mac OSX, Cygwin or MinGW (on Win32/Win64). Ideally, you should have at least 800 MB of
+free disk space. The source code package needs disk space of around 26 MB compressed
+and 440MB uncompressed. The resulting binaries may need between 20 MB and 180 MB
+depending on your platform and compiler flags. During a full compilation you may need
temporarily up to 550MB including the source code.
<p>
-To disable features please read the <a href="INSTALL">INSTALL</a> file.
+To enable and disable features please read the <a href="INSTALL">INSTALL</a> file.
<h3>General requirements:</h3>
@@ -64,7 +64,8 @@
<h3>Optional requirements:</h3>
-Note: also the respective xxx-dev or xxx-devel packages need to be installed.
+Note: also the respective development packages (commonly named xxx-dev or xxx-devel) need
+to be installed.
<ul>
@@ -91,8 +92,8 @@
<a href="http://www.unidata.ucar.edu/software/netcdf/">http://www.unidata.ucar.edu/software/netcdf/</a>
</li>
-<li>If hardware openGL support is missing in the X
-Server, <b>Mesa-3.x</b> (openGL clone) may be required for wxNVIZ<br>
+<li>If hardware openGL support is missing in the X Server, <b>Mesa-3.x</b> (openGL clone)
+may be required for wxNVIZ<br>
<a href="http://mesa3d.sourceforge.net">http://mesa3d.sourceforge.net</a>
</li>
@@ -157,7 +158,7 @@
<li><b>Python Imaging Library or PILLOW</b> (highly recommended for wxGUI and necessary for wxGUI Cartographic Composer)<br>
<a href="http://www.pythonware.com/products/pil">http://www.pythonware.com/products/pil</a>,
-a newer version is "python-pillow"
+newer versions are named "python-pillow"
</li>
<li><b>Python matplotlib > 1.2</b> ("python-matplotlib", needed for the several wxGUI tools)<br>
@@ -181,19 +182,26 @@
<a href="http://cairographics.org">http://cairographics.org</a>
</li>
+<!-- really needed? -->
<li><b>AVCE00 and E00Compr Libraries</b> (avcimport)<br>
<a href="http://avce00.maptools.org">http://avce00.maptools.org</a>
</li>
+<li><b>Subversion</b> (svn for g.extension)<br>
+<a href="https://subversion.apache.org/">https://subversion.apache.org/</a><br>
+</li>
</ul>
<h3>Note:</h3>
+<!-- since 2014 no longer supported: -->
SUN Solaris users may go here to download precompiled libraries etc.:
<br><a href="http://www.sunfreeware.com">http://www.sunfreeware.com</a>
<p>
+<!-- no longer supported: -->
SGI IRIX users may go here to download precompiled libraries etc.:
<br><a href="http://freeware.sgi.com">http://freeware.sgi.com</a>
@@ -204,7 +212,7 @@
<p>
<hr width="100%">
-<i>© GRASS Development Team 2001-2016</i>
+<i>© GRASS Development Team 1997-2017</i>
<p>Please report bugs here:
<br><a href="http://grass.osgeo.org/development/bug-tracking/">http://grass.osgeo.org/development/bug-tracking/</a>
Modified: grass/branches/releasebranch_7_0/doc/howto_release.txt
--- grass/branches/releasebranch_7_0/doc/howto_release.txt 2017-01-01 19:48:33 UTC (rev 70182)
+++ grass/branches/releasebranch_7_0/doc/howto_release.txt 2017-01-01 20:06:10 UTC (rev 70183)
@@ -60,7 +60,7 @@
7
0
6RC1
-2016
+2017
rm -f include/VERSION~
- Update OSGeo4W setup.hint file
@@ -121,7 +121,7 @@
7
0
6svn
-2016
+2017
svn ci -m"back to SVN" include/VERSION
Modified: grass/branches/releasebranch_7_0/general/g.version/g.version.html
--- grass/branches/releasebranch_7_0/general/g.version/g.version.html 2017-01-01 19:48:33 UTC (rev 70182)
+++ grass/branches/releasebranch_7_0/general/g.version/g.version.html 2017-01-01 20:06:10 UTC (rev 70183)
@@ -38,7 +38,7 @@
<div class="code"><pre>
g.version
-GRASS 7.0.0RC2 (2015)
+GRASS 7.0.6svn (2017)
</pre></div>
<h3>GIS Library info</h3>
@@ -46,26 +46,26 @@
g.version -r
-libgis Revision: 64007
-libgis Date: 2015-01-08 20:08:36 +0100 (Thu, 08 Jan 2015)
+libgis Revision: 67364
+libgis Date: 2015-12-24 16:07:44 +0100 (Thu, 24 Dec 2015)
</pre></div>
<h3>Full info in shell script style</h3>
g.version -rge
-version=7.0.0RC2
-date=2015
-revision=64517M
-build_date=2015-01-12
-build_platform=x86_64-unknown-linux-gnu
-libgis_revision=64007
-libgis_date="2015-01-08 20:08:36 +0100 (Thu, 08 Jan 2015) "
-proj4=4.8.0
-gdal=1.11.1
-geos=3.4.2
-sqlite=3.8.8
+version=7.0.6svn
+date=2016
+revision=70171
+build_date=2017-01-01
+build_platform=x86_64-pc-linux-gnu
+libgis_revision=67364
+libgis_date="2015-12-24 16:07:44 +0100 (Thu, 24 Dec 2015) "
+proj4=4.9.2
+gdal=2.1.2
+geos=3.5.0
+sqlite=3.13.0
</pre></div>
<h2>Citing GRASS GIS</h2>
Modified: grass/branches/releasebranch_7_0/grasslib.dox
--- grass/branches/releasebranch_7_0/grasslib.dox 2017-01-01 19:48:33 UTC (rev 70182)
+++ grass/branches/releasebranch_7_0/grasslib.dox 2017-01-01 20:06:10 UTC (rev 70183)
@@ -23,7 +23,7 @@
are cited within their module's source code and the contributed manual
pages.
-© 2000-2016 by the GRASS Development Team
+© 2000-2017 by the GRASS Development Team
This manual is published under <a
href="http://www.fsf.org/copyleft/fdl.html">GNU Free Documentation
Modified: grass/branches/releasebranch_7_0/include/VERSION
--- grass/branches/releasebranch_7_0/include/VERSION 2017-01-01 19:48:33 UTC (rev 70182)
+++ grass/branches/releasebranch_7_0/include/VERSION 2017-01-01 20:06:10 UTC (rev 70183)
@@ -1,4 +1,4 @@
7
0
6svn
-2016
+2017
Modified: grass/branches/releasebranch_7_0/lib/gis/gislib_cmdline_parsing.dox
--- grass/branches/releasebranch_7_0/lib/gis/gislib_cmdline_parsing.dox 2017-01-01 19:48:33 UTC (rev 70182)
+++ grass/branches/releasebranch_7_0/lib/gis/gislib_cmdline_parsing.dox 2017-01-01 20:06:10 UTC (rev 70183)
@@ -4,7 +4,7 @@
extracted form gislib.dox and improved by Vaclav Petras, 2013
-Copyright 2004-2013 by the GRASS Development Team
+Copyright 2004-2017 by the GRASS Development Team
Published under GNU Free Documentation License
Modified: grass/branches/releasebranch_7_0/lib/init/grass.py
--- grass/branches/releasebranch_7_0/lib/init/grass.py 2017-01-01 19:48:33 UTC (rev 70182)
+++ grass/branches/releasebranch_7_0/lib/init/grass.py 2017-01-01 20:06:10 UTC (rev 70183)
@@ -17,7 +17,7 @@
# command line options for setting the GISDBASE, LOCATION,
# and/or MAPSET. Finally it starts GRASS with the appropriate
# user interface and cleans up after it is finished.
-# COPYRIGHT: (C) 2000-2016 by the GRASS Development Team
+# COPYRIGHT: (C) 2000-2017 by the GRASS Development Team
# This program is free software under the GNU General
# Public License (>=v2). Read the file COPYING that
Modified: grass/branches/releasebranch_7_0/man/build_rest.py
--- grass/branches/releasebranch_7_0/man/build_rest.py 2017-01-01 19:48:33 UTC (rev 70182)
+++ grass/branches/releasebranch_7_0/man/build_rest.py 2017-01-01 20:06:10 UTC (rev 70183)
@@ -167,7 +167,7 @@
:doc:`Manual main page <index>` \| :doc:`Full Index <full_index>`
- 2003-2016 `GRASS Development Team <http://grass.osgeo.org>`_, GRASS GIS ${grass_version} Reference Manual
+ 2003-2017 `GRASS Development Team <http://grass.osgeo.org>`_, GRASS GIS ${grass_version} Reference Manual
cmd1_tmpl = string.Template(\
