[GRASS-SVN] r70199 - grass/branches/releasebranch_7_0/vector/v.in.db
Mon Jan 2 03:34:13 PST 2017
Author: neteler
Date: 2017-01-02 03:34:13 -0800 (Mon, 02 Jan 2017)
New Revision: 70199
   grass/branches/releasebranch_7_0/vector/v.in.db/v.in.db.html
v.in.db manual: fix typos in examples
Modified: grass/branches/releasebranch_7_0/vector/v.in.db/v.in.db.html
--- grass/branches/releasebranch_7_0/vector/v.in.db/v.in.db.html	2017-01-02 11:33:51 UTC (rev 70198)
+++ grass/branches/releasebranch_7_0/vector/v.in.db/v.in.db.html	2017-01-02 11:34:13 UTC (rev 70199)
@@ -58,23 +58,23 @@
 column:
 <div class="code"><pre>
-# preview table structure with OGR tool:
-ogrinfo -so meteodata.ods mysheet
+# preview table structure with OGR tool (table name is "Layer name" here):
+ogrinfo -al -so meteodata.ods
-# import from ODS into map
+# import sheet from ODS into map
 v.in.db key=ID table=mysheet x=long y=lat z=height output=meteodata \
-         driver=ogr datatabase=meteodata.ods
+         driver=ogr database=meteodata.ods
 </pre></div>
 <h3>Creating a map from MS Excel file</h3>
 A new vector point map is created from given sheet in MS Excel file. The
 <b>database</b> option points to the file in MS Excel
-format. Option <b>table</b> is name of the selected spreadsheet list:
+format. Option <b>table</b> is name of the selected spreadsheet "List1":
 v.in.db table=List1 x=long y=lat z=height output=meteodata \
-         driver=ogr datatabase=meteodata.xls
+         driver=ogr database=meteodata.xls
 </pre></div>
 Note that in this example the <b>key</b> option is omitted. In this case
@@ -135,6 +135,7 @@
 <a href="db.execute.html">db.execute</a>,
 <a href="db.in.ogr.html">db.in.ogr</a>,
 <a href="v.info.html">v.info</a>,
+<a href="v.in.geonames.html">v.in.geonames</a>,
 <a href="v.in.ogr.html">v.in.ogr</a>,
 <a href="v.to.db.html">v.to.db</a>
 </em>
