[GRASS-SVN] r70262 - in grass/trunk: include/vect lib/vector/Vlib lib/vector/diglib vector/v.external
svn_grass at osgeo.org
Thu Jan 5 03:30:58 PST 2017
Author: martinl
Date: 2017-01-05 03:30:58 -0800 (Thu, 05 Jan 2017)
New Revision: 70262
grass/trunk/include/vect/dig_structs.h
grass/trunk/lib/vector/Vlib/build_sfa.c
grass/trunk/lib/vector/Vlib/read_pg.c
grass/trunk/lib/vector/diglib/frmt.c
grass/trunk/vector/v.external/args.c
grass/trunk/vector/v.external/local_proto.h
grass/trunk/vector/v.external/main.c
grass/trunk/vector/v.external/v.external.html
v.external: implement where statement option (requires distclean)
Modified: grass/trunk/include/vect/dig_structs.h
--- grass/trunk/include/vect/dig_structs.h 2017-01-05 11:10:21 UTC (rev 70261)
+++ grass/trunk/include/vect/dig_structs.h 2017-01-05 11:30:58 UTC (rev 70262)
@@ -527,6 +527,10 @@
\brief OGR layer name
char *layer_name;
+ \brief SQL where statement (to filter features)
+ char *where;
#ifdef HAVE_OGR
\brief Pointer to OGRDriver
@@ -614,6 +618,10 @@
char *table_name;
+ \brief SQL where statement (fo filter features)
+ char *where;
\brief FID column
char *fid_column;
Modified: grass/trunk/lib/vector/Vlib/build_sfa.c
--- grass/trunk/lib/vector/Vlib/build_sfa.c 2017-01-05 11:10:21 UTC (rev 70261)
+++ grass/trunk/lib/vector/Vlib/build_sfa.c 2017-01-05 11:30:58 UTC (rev 70262)
@@ -625,6 +625,9 @@
/* Note: Do not use OGR_L_GetFeatureCount (it may scan all features) */
OGR_L_ResetReading(ogr_info->layer);
+ if (ogr_info->where)
+ /* set attribute filter if where sql statement defined */
+ OGR_L_SetAttributeFilter(ogr_info->layer, ogr_info->where);
npoints = iFeature = nskipped = 0;
G_message(_("Registering primitives..."));
while ((hFeature = OGR_L_GetNextFeature(ogr_info->layer)) != NULL) {
Modified: grass/trunk/lib/vector/Vlib/read_pg.c
--- grass/trunk/lib/vector/Vlib/read_pg.c 2017-01-05 11:10:21 UTC (rev 70261)
+++ grass/trunk/lib/vector/Vlib/read_pg.c 2017-01-05 11:30:58 UTC (rev 70262)
@@ -1245,10 +1245,17 @@
if (!pg_info->toposchema_name) {
/* simple feature access (geom, fid) */
/* TODO: start_fid */
- sprintf(stmt,
- "DECLARE %s CURSOR FOR SELECT %s,%s FROM \"%s\".\"%s\" ORDER BY %s",
- pg_info->cursor_name, pg_info->geom_column, pg_info->fid_column, pg_info->schema_name,
- pg_info->table_name, pg_info->fid_column);
+ if (pg_info->where)
+ sprintf(stmt,
+ "DECLARE %s CURSOR FOR SELECT %s,%s FROM \"%s\".\"%s\" WHERE %s ORDER BY %s",
+ pg_info->cursor_name, pg_info->geom_column, pg_info->fid_column, pg_info->schema_name,
+ pg_info->table_name, pg_info->where, pg_info->fid_column);
+ else
+ sprintf(stmt,
+ "DECLARE %s CURSOR FOR SELECT %s,%s FROM \"%s\".\"%s\" ORDER BY %s",
+ pg_info->table_name, pg_info->fid_column);
else {
/* topology access (geom,id,fid,type) */
@@ -1666,7 +1673,7 @@
Vect_append_point(line_p, list.box[found].E, list.box[found].N, 0.0);
if (line_c) {
- Vect_cat_set(line_c, 1, topo->area);
+ Vect_cat_set(line_c, 1, Line->offset);
return GV_CENTROID;
Modified: grass/trunk/lib/vector/diglib/frmt.c
--- grass/trunk/lib/vector/diglib/frmt.c 2017-01-05 11:10:21 UTC (rev 70261)
+++ grass/trunk/lib/vector/diglib/frmt.c 2017-01-05 11:30:58 UTC (rev 70262)
@@ -111,6 +111,8 @@
finfo->ogr.dsn = G_store(ptr);
if (G_strcasecmp(buf1, "LAYER") == 0)
finfo->ogr.layer_name = G_store(ptr);
+ if (G_strcasecmp(buf1, "WHERE") == 0)
+ finfo->ogr.where = G_store(ptr);
#endif
#ifdef HAVE_POSTGRES
@@ -123,6 +125,8 @@
finfo->pg.table_name = G_store(ptr);
if (G_strcasecmp(buf1, "FID") == 0)
finfo->pg.fid_column = G_store(ptr);
+ finfo->pg.where = G_store(ptr);
#endif
Modified: grass/trunk/vector/v.external/args.c
--- grass/trunk/vector/v.external/args.c 2017-01-05 11:10:21 UTC (rev 70261)
+++ grass/trunk/vector/v.external/args.c 2017-01-05 11:30:58 UTC (rev 70262)
@@ -32,7 +32,9 @@
options->layer->required = NO;
options->layer->key_desc = "name";
options->layer->gisprompt = "old,datasource_layer,datasource_layer";
+ options->where = G_define_standard_option(G_OPT_DB_WHERE);
options->output = G_define_standard_option(G_OPT_V_OUTPUT);
options->output->required = NO;
options->output->description = _("Name for output GRASS vector map (default: input layer)");
Modified: grass/trunk/vector/v.external/local_proto.h
--- grass/trunk/vector/v.external/local_proto.h 2017-01-05 11:10:21 UTC (rev 70261)
+++ grass/trunk/vector/v.external/local_proto.h 2017-01-05 11:30:58 UTC (rev 70262)
@@ -2,7 +2,7 @@
#define V_EXTERNAL_LOCAL_PROTO_H
struct _options {
- struct Option *dsn, *output, *layer;
+ struct Option *dsn, *output, *layer, *where;
struct _flags {
Modified: grass/trunk/vector/v.external/main.c
--- grass/trunk/vector/v.external/main.c 2017-01-05 11:10:21 UTC (rev 70261)
+++ grass/trunk/vector/v.external/main.c 2017-01-05 11:30:58 UTC (rev 70262)
@@ -8,7 +8,7 @@
* PURPOSE: Create a new vector as a link to OGR layer
- * COPYRIGHT: (C) 2003-2016 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2017 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -175,7 +175,7 @@
if (schema_name)
fprintf(fd, "schema: %s\n", schema_name);
fprintf(fd, "table: %s\n", table_name);
G_free(table_name);
G_free(schema_name);
@@ -184,6 +184,9 @@
fprintf(fd, "dsn: %s\n", dsn);
fprintf(fd, "layer: %s\n", layer);
+ if (options.where->answer)
+ fprintf(fd, "where: %s\n", options.where->answer);
fclose(fd);
if (!flags.topo->answer) {
Modified: grass/trunk/vector/v.external/v.external.html
--- grass/trunk/vector/v.external/v.external.html 2017-01-05 11:10:21 UTC (rev 70261)
+++ grass/trunk/vector/v.external/v.external.html 2017-01-05 11:30:58 UTC (rev 70262)
@@ -8,6 +8,20 @@
PostGIS feature table can be linked also using built-in <em>GRASS-PostGIS
data driver</em> (requires GRASS to be built with PostgreSQL support).
+<h2>NOTES</h2>
+<p>The simple feature data model used by OGR (or PostGIS) is very
+different from the topological format used by GRASS. Instead of true
+topology, so called 'pseudo topology' is created for data linked by
+<em>v.external</em>. User should learn the difference between those
+two formats, because <b>some modules</b> working correctly with GRASS native
+data, <b>can produce wrong results</b> with input vector maps created
+by <em>v.external</em>.
+<p>See <em><a href="v.db.connect.html">v.db.connect</a></em> for an
+example of maintaining attributes in external DBMS in also writable
+mode.
<h3>Supported OGR vector formats</h3>
To list supported OGR formats, type
@@ -17,7 +31,7 @@
</pre></div>
For details see
-<a href="http://www.gdal.org/ogr_formats.html">OGR web site</a>.
+<a href="http://www.gdal.org/ogr_formats.html">GDAL web site</a>.
<h2>EXAMPLES</h2>
@@ -30,8 +44,37 @@
v.external input=/home/user/shape_data layer=test_shape output=grass_map
</pre></div>
+<h3>PostGIS layers</h3>
+By default, PostGIS links are created by built-in PostGIS support,
+ie. using <em>GRASS-PostGIS data driver</em>. If the environment
+variable <tt>GRASS_VECTOR_OGR</tt> exists, or GRASS is compiled
+without PostgreSQL support then GRASS will use OGR-PostgreSQL driver
+for creating a link.
+<p>List of layers for given data source can be printed by <b>-l</b>
+flag.
+<div class="code"><pre>
+v.external input="PG:host=localhost user=postgres dbname=postgis" -l
+polymap
+</pre></div>
+v.external input="PG:host=localhost user=postgres dbname=postgis" layer=polymap
+</pre></div>
+Note: Authentication details (user password) can be preferably defined
+by <em><a href="db.login.html">db.login</a></em>.
<h3>MapInfo files</h3>
+Assuming that 'mapinfo_test' MapInfo file is located in the current
+directory (".").
v.external input=./ layer=mapinfo_test output=grass_map
</pre></div>
@@ -50,34 +93,23 @@
v.external input=input/2000/56015/ layer=CompleteChain,PIP output=t56015_all
</pre></div>
-<h3>PostGIS layers</h3>
+<h3>Linking subset of features</h3>
-PostGIS links are by default created by built-in PostGIS support,
-ie. using <em>GRASS-PostGIS data driver</em>. If the environment
-variable <tt>GRASS_VECTOR_OGR</tt> exists, or GRASS is compiled
-without PostgreSQL support then GRASS will use OGR-PostgreSQL driver
-for creating a link.
+By <b>where</b> option only subset of features can be linked. In the
+example below only one feature (in this case a vector tile) will be
+linked as a new GRASS vector map.
-v.external input="PG:host=localhost user=postgres dbname=postgis" layer=polymap
+v.external in="PG:dbname=tiles" layer=wrs2_descending where="pr=191026"
+Number of areas: 1
</pre></div>
-<h2>NOTES</h2>
-The simple feature data model used by OGR (or PostGIS) is very
-different from the topological format used by GRASS. Instead of true
-topology, so called 'pseudo topology' is created for data linked by
-<em>v.external</em>. User should learn the difference between those
-two formats, because some modules working correctly with GRASS native
-data, can produce wrong results with input vector maps created
-by <em>v.external</em>.
-<p>See <em><a href="v.db.connect.html">v.db.connect</a></em> for an example of
-maintaining attributes in external DBMS in also writable mode.
<h2>REFERENCES</h2>
-<a href="http://www.gdal.org/ogr__api_8h.html">OGR vector library C API</a> documentation
+<a href="http://www.gdal.org/ogr__api_8h.html">OGR vector library C
+API</a> documentation
<h2>SEE ALSO</h2>
@@ -92,7 +124,7 @@
</em>
<p>
-<a href="http://www.gdal.org/">OGR Library</a>
+<a href="http://www.gdal.org/">GDAL Library</a>
<br>
<a href="http://postgis.org/">PostGIS</a>
@@ -104,7 +136,8 @@
Radim Blazek, ITC-Irst, Trento, Italy
<br>
-PostGIS support by Martin Landa, Czech Technical University in Prague, Czech Republic
+PostGIS support by Martin Landa, GeoForAll (OSGeoREL) Lab, Czech
+Technical University in Prague, Czech Republic
<p>
<i>Last changed: $Date$</i>
