[GRASS-SVN] r70280 - grass/trunk/db/drivers/ogr
Fri Jan 6 09:41:22 PST 2017
Author: martinl
Date: 2017-01-06 09:41:21 -0800 (Fri, 06 Jan 2017)
New Revision: 70280
   grass/trunk/db/drivers/ogr/describe.c
fix r70259 for GDAL 1.x
Modified: grass/trunk/db/drivers/ogr/describe.c
--- grass/trunk/db/drivers/ogr/describe.c	2017-01-06 17:35:44 UTC (rev 70279)
+++ grass/trunk/db/drivers/ogr/describe.c	2017-01-06 17:41:21 UTC (rev 70280)
@@ -106,7 +106,11 @@
 	ogrType = OGR_Fld_GetType(hFieldDefn);
 	fieldName = OGR_Fld_GetNameRef(hFieldDefn);
-	if (ogrType != OFTInteger && ogrType != OFTInteger64 && ogrType != OFTReal &&
+	if (ogrType != OFTInteger &&
+#if GDAL_VERSION_NUM >= 2000000
+            ogrType != OFTInteger64 &&
+#endif
+            ogrType != OFTReal &&
 	    ogrType != OFTString  && ogrType != OFTDate &&
 	    ogrType != OFTTime    && ogrType != OFTDateTime ) {
 	    G_warning(_("OGR driver: column '%s', OGR type %d is not supported"),
@@ -171,13 +175,17 @@
 	switch (ogrType) {
 	case OFTInteger:
         case OFTInteger64:
+#endif
 	    sqlType = DB_SQL_TYPE_INTEGER;
 	    size = OGR_Fld_GetWidth(hFieldDefn);	/* OK ? */
 	    precision = 0;
             if (ogrType == OFTInteger64)
                 G_warning(_("Column '%s' : type int8 (bigint) is stored as integer (4 bytes) "
                             "some data may be damaged"), fieldName);
+#endif
 	    break;
 	case OFTReal:
